2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1905159] Re: Fix warnings from recent compiler versions
From: Jerzy Tarasiuk via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 16 Jun 2021 16:56:33 -0000
modules/ca/src/client/caRepeater.cpp  line 93
- a chdir("/"); alone causes a warning;
  an old construction (void)chdir("/"); caused a warning, too;
  to avoid the warning, need use:  if(chdir("/")) {}  ;)
modules/database/src/ioc/dbtemplate/msi.cpp  line 306
- signed/unsigned comparision: maybe declare 'i' as unsigned?
  as an array index unsigned is OK, maybe need use typecast:
  cmdind = i;  =>  cmdint = (int)i;  (the cmdint must be int)
an alternative can be a code like:
  for (cmdint = NELEMENTS(cmdNames); cmdint >=0; cmdint--) {
    if (strstr(command, cmdNames[cmdint])) break;
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1905159
Title:
Status in EPICS Base:
  Triaged
Bug description:
  Builds of EPICS Base using recent versions of gcc, clang and MSVC
  generate compiler warnings, which we try to minimize if possible. Some
  of these warnings can be prevented with suitable code modifications,
  although the code must still build on the older compilers and other
  architectures that we support.
  Both the 3.15 and 7.0 branches can be examined for warnings; fixes
  made on the 3.15 branch get propagated to the 7.0 branch during
  periodic up-merges, so there is no need to make the same changes to
  both branches. Some code only exists on one branch; for example the
  gdd module was unbundled after 3.15, and there are many new modules in
  7.0.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1905159/+subscriptions
Prev: [Bug 1905159] Re: Fix warnings from recent compiler versions Jerzy Tarasiuk via Core-talk
Next: [Bug 1932033] Re: base EPICS compilation misses convertRelease.pl Jerzy Tarasiuk via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: [Bug 1905159] Re: Fix warnings from recent compiler versions Jerzy Tarasiuk via Core-talk
ANJ, 16 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
