2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 17 Jun 2021 17:47:08 -0000
I'm having difficulty downloading your patch, Launchpad's librarian web-
server seems to be misbehaving and neither of my browsers nor curl can
fetch it. Is your fix to just delete that routine and its associated
#define from the libCom osi/os/vxWorks/epicsAtomicOSD.h file, thus
falling back to the gcc-specific version?
We really should have a test that can actually detect this bug, could
you look at what needs doing to add that to epicsAtomicTest.cpp please?
We should fix this on the 3.15 branch and merge it up rather than just
fixing it on 7.0. Note that we'll be releasing EPICS 7.0.6 next week so
I'd like to get it included ASAP.
** Changed in: epics-base
       Status: New => In Progress
   Importance: Undecided => Critical
     Assignee: (unassigned) => Dirk Zimoch (dirk.zimoch)
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1932118
Title:
Status in EPICS Base:
  In Progress
Bug description:
  The usage of epicsAtomicCmpAndSwapIntT() in callback.c suggests that
  the function should return the previous value. But the VxWorks
  implementation uses vxCas() which is documented as returning "TRUE if
  the write actually occurs, FALSE otherwise."
  vxAtomicLib.html:
  vxCas( )
  NAME
      vxCas( ) - atomically compare-and-swap the contents of a memory location
  SYNOPSIS
      BOOL vxCas
          atomic_t *  target,
          atomicVal_t oldValue,
          atomicVal_t newValue
  DESCRIPTION
      This routine performs an atomic compare-and-swap; testing that *target contains oldValue, and if it does, setting the value of *target to newValue.
  RETURNS
      TRUE if the swap is actually executed, FALSE otherwise.
  Comparing this with the gcc documentation:
  bool __sync_bool_compare_and_swap (type *ptr, type oldval type newval, ...)
  type __sync_val_compare_and_swap (type *ptr, type oldval type newval, ...)
  These builtins perform an atomic compare and swap.  That is, if the
  current value of *ptr is oldval, then write newval into *ptr.
  The “bool” version returns true if the comparison is successful and newval was written.
  The “val” version returns the contents of *ptr before the operation.
  That means epicsAtomicCmpAndSwapIntT() behaves behaves like __sync_bool_compare_and_swap(). Simply casting the return value from BOOL to the type of oldVal does not change that.
  But the usage implies an expected bahavior like
  __sync_val_compare_and_swap (), wich is used in the gcc implementation
  of epicsAtomicCmpAndSwapIntT().
  This bugs prevents the callback threads from being started in vxWorks 6.7, maybe more or all vxWorks 6 versions.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1932118/+subscriptions
[Bug 1932118] [NEW] Bug in vxWorks epicsAtomicCmpAndSwapIntT Dirk Zimoch via Core-talk
Prev: Build failed in Jenkins: EPICS-3.14 #1067 Jenkins EPICS PSI via Core-talk
Next: [Bug 1932120] Re: callbackRequest potentially accesses uninitialized memory Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: [Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT Dirk Zimoch via Core-talk
Next: [Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT Andrew Johnson via Core-talk
ANJ, 17 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
