See <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/357/display/redirect?page=changes>
Changes:
[anj] Fix vxWorks version of epicsAtomicCmpAndSwapIntT()
[anj] Protect callbackRequest() from failed callbackInit()
[anj] Squish various compiler warnings
[anj] Adjust RTEMS-mvme2100 and -mvme2700 build config's
Started by an SCM change
Building in workspace <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base
> git init <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
> git --version # timeout=10
> git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
> git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse origin/7.0^{commit} # timeout=10
Checking out Revision ce876d6f114fa1e293c1b278bc11f05bba4cb886 (origin/7.0)
> git config core.sparsecheckout # timeout=10
> git checkout -f ce876d6f114fa1e293c1b278bc11f05bba4cb886
Commit message: "Adjust RTEMS-mvme2100 and -mvme2700 build config's"
> git rev-list --no-walk 983f77e1196f81c527cf9b7114e1260157981b1e # timeout=10
> git remote # timeout=10
> git submodule init # timeout=10
> git submodule sync # timeout=10
> git config --get remote.origin.url # timeout=10
> git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
> git config --get submodule.modules/pvData.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
> git submodule update --init --recursive --remote modules/pvData
> git config --get submodule.modules/pvAccess.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
> git submodule update --init --recursive --remote modules/pvAccess
> git config --get submodule.modules/normativeTypes.url # timeout=10
> git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
> git submodule update --init --recursive --remote modules/normativeTypes
> git config --get submodule.modules/pvaClient.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
> git submodule update --init --recursive --remote modules/pvaClient
> git config --get submodule.modules/pvDatabase.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
> git submodule update --init --recursive --remote modules/pvDatabase
> git config --get submodule.modules/pva2pva.url # timeout=10
> git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
> git submodule update --init --recursive --remote modules/pva2pva
> git config --get submodule..ci.url # timeout=10
> git config -f .gitmodules --get submodule..ci.path # timeout=10
> git submodule update --init --recursive --remote .ci
[EPICS-7] $ /bin/sh -xe /tmp/jenkins2765234960822152204.sh
+ tar xfz /net/sls-hafs/export/exchange/home/zimoch/epics/PSIconfig.tgz
+ patch -p1
patching file configure/os/CONFIG_SITE.Common.vxWorksCommon
patching file configure/os/CONFIG_SITE.linux-x86.Common
Hunk #1 FAILED at 7.
1 out of 1 hunk FAILED -- saving rejects to file configure/os/CONFIG_SITE.linux-x86.Common.rej
patching file configure/os/CONFIG_SITE.linux-x86_64.Common
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
- Build failed in Jenkins: EPICS-7 #358 Jenkins EPICS PSI via Core-talk
- Build failed in Jenkins: EPICS-7 #356 Jenkins EPICS PSI via Core-talk
[Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT Andrew Johnson via Core-talk
[Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT Dirk Zimoch via Core-talk
<2021>
2025
2026
<2021>
2025
2026
