2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15 #530
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 26 Jun 2021 03:07:48 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15/530/display/redirect>
Changes:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building on master in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/>
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --resolve-git-dir <https://jenkins.aps.anl.gov/job/epics-base-3.15/ws/.git> # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > git --version # timeout=10
 > git --version # 'git version 1.8.3.1'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/3.15:refs/remotes/origin/3.15 # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1000)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1241)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1301)
	at hudson.scm.SCM.checkout(SCM.java:505)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1215)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:640)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:512)
	at hudson.model.Run.execute(Run.java:1912)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:100)
	at hudson.model.Executor.run(Executor.java:432)
Caused by: hudson.plugins.git.GitException: Command "git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/3.15:refs/remotes/origin/3.15" returned status code 128:
stdout:
stderr: fatal: Couldn't find remote ref refs/heads/3.15
Unexpected end of command stream
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2639)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2079)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:84)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:601)
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:998)
	... 11 more
Archiving artifacts
Jenkins build is back to normal : epics-base-3.15 #531 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-base-7.0-win64 #248 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-mac #365 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-base-7.0-win64 #249 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-base-3.15 #531 APS Jenkins via Core-talk
ANJ, 26 Jun 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
