** Changed in: epics-base/3.15
Milestone: None => 3.15.9
Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1776141
Title:
Buffer overrun in dbpr with long INP field
Status in EPICS Base:
Fix Released
Status in EPICS Base 3.15 series:
Fix Released
Status in EPICS Base 3.16 series:
Fix Released
Status in EPICS Base 7.0 series:
Fix Released
Bug description:
softIoc crashes with a buffer overflow in dbTest.c:1152 when running
"dbpr A 4" on the attached database file (test.db).
Root cause: pmsg points to msgBuff->message which has a fixed size of
128 but the output of sprintf can be longer.
I can see two potential solutions here:
1. Use snprintf() to prevent the buffer overflow.
2. Convert the file to C++ and use strings.
Note: dbTest.c contains a total of 23 sprintf() calls so there might
be potential for more issues...
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1776141/+subscriptions
[Bug 1682185] Re: Windows build failure in dbUnitTest.c Andrew Johnson via Core-talk
[Bug 1899697] Re: PHAS is not always respected when SCAN=Event Andrew Johnson via Core-talk
<2021>
2025
2026
Build failed in Jenkins: epics-base-3.15 #538 APS Jenkins via Core-talk
<2021>
2025
2026
