2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-7 #362
From: Jenkins EPICS PSI via Core-talk <core-talk at aps.anl.gov>
To: <dirk.zimoch at psi.ch>, <core-talk at aps.anl.gov>
Date: Thu, 1 Jul 2021 20:29:31 +0200
See <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/362/display/redirect?page=changes>
Changes:
[anj] Dump the Darwin README file, very dated
[anj] Reworked the README.md file
[anj] Added missing entries to Release Notes
[anj] Releasing R3.15.9
[anj] Update versions after tagging
[anj] Fix typos in Release Notes
[anj] Fix typos in internal build variable names
[anj] Check module set EPICS_BASE in a RELEASE file
[mdavidsaver] update PVD/PVA modules
[mdavidsaver] osiSockTest: ignore large messages on WIN32
[mdavidsaver] re-sync initHookName() with initHookState enum
[mdavidsaver] add initHookTest
Started by an SCM change
Building in workspace <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base
 > git init <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > git --version # timeout=10
 > git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
 > git config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
 > git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse origin/7.0^{commit} # timeout=10
Checking out Revision 710c50b5ed957f2fcfdc80bd8426dac58565710e (origin/7.0)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 710c50b5ed957f2fcfdc80bd8426dac58565710e
Commit message: "add initHookTest"
 > git rev-list --no-walk c7e2acb1a69b4c8f26355ff32c3c6c8c97251ea2 # timeout=10
 > git remote # timeout=10
 > git submodule init # timeout=10
 > git submodule sync # timeout=10
 > git config --get remote.origin.url # timeout=10
 > git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
 > git config --get submodule.modules/pvData.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvData
 > git config --get submodule.modules/pvAccess.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvAccess
 > git config --get submodule.modules/normativeTypes.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
 > git submodule update --init --recursive --remote modules/normativeTypes
 > git config --get submodule.modules/pvaClient.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvaClient
 > git config --get submodule.modules/pvDatabase.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvDatabase
 > git config --get submodule.modules/pva2pva.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > git submodule update --init --recursive --remote modules/pva2pva
 > git config --get submodule..ci.url # timeout=10
 > git config -f .gitmodules --get submodule..ci.path # timeout=10
 > git submodule update --init --recursive --remote .ci
[EPICS-7] $ /bin/sh -xe /tmp/jenkins5982695120924980190.sh
+ tar xfz /net/sls-hafs/export/exchange/home/zimoch/epics/PSIconfig.tgz
+ patch -p1
patching file configure/os/CONFIG_SITE.Common.vxWorksCommon
patching file configure/os/CONFIG_SITE.linux-x86.Common
Hunk #1 FAILED at 7.
1 out of 1 hunk FAILED -- saving rejects to file configure/os/CONFIG_SITE.linux-x86.Common.rej
patching file configure/os/CONFIG_SITE.linux-x86_64.Common
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Build failed in Jenkins: EPICS-7 #363 Jenkins EPICS PSI via Core-talk
Build failed in Jenkins: EPICS-7 #361 Jenkins EPICS PSI via Core-talk
Prev: Re: osiSockTest fail on WIN32 Michael Davidsaver via Core-talk
Next: Build completed: pva2pva 1.0.33 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: EPICS-7 #361 Jenkins EPICS PSI via Core-talk
Next: Build failed in Jenkins: EPICS-7 #363 Jenkins EPICS PSI via Core-talk
ANJ, 04 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
