2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: [Bug 1783475] Re: const link support can't handle escaped charactors
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sun, 04 Jul 2021 03:11:09 -0000
** Changed in: epics-base/7.0
       Status: Triaged => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1783475
Title:
Status in EPICS Base:
  Fix Released
Status in EPICS Base 3.16 series:
  Won't Fix
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  I think the following should work, but it doesn't.  The culprit seems
  to be the call to dbTranslateEscape() in dbRecordField() and
  dbRecordInfo().  The escaped newline is handled correctly by dbLex,
  but the later dbJLinkParse() errors on the now unescaped newline.
  > record(stringin, "test") {
  >      field(INP, {const:"multi\nline"})
  > dbJLinkInit: lexical error: invalid character inside string.
  >                          {"const":"multi line"}
  >                      (right here) ------^
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1783475/+subscriptions
Prev: Jenkins build is back to normal : epics-base-7.0-win64 #261 APS Jenkins via Core-talk
Next: [Bug 1932118] Re: Bug in vxWorks epicsAtomicCmpAndSwapIntT Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: [Bug 1783475] Re: const link support can't handle escaped charactors Andrew Johnson via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-177 AppVeyor via Core-talk
ANJ, 03 Jul 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
