2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 13 Aug 2021 07:47:10 -0000
A bit of background why people are not simply using longout instead:
They want to use the MASK and SHFT features provided by some drivers, in
particular read-modify-write when updating some bits in a longer
hardware register.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1939568
Title:
Status in EPICS Base:
  New
Bug description:
  In EPICS 3.14, it was possible to write to mbboDirect.VAL. This does not work any longer with EPICS 3.15 or higher.
  However, writing to .VAL was always buggy anyway (did not update the.Bx fields).
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1939568/+subscriptions
[Bug 1939568] [NEW] Writing to mbboDirect.VAL does not work any more in EPICS 7 Dirk Zimoch via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-373 AppVeyor via Core-talk
Next: [Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: [Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15 Dirk Zimoch via Core-talk
ANJ, 13 Aug 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
