2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: epics-7.0 » linux64 - Build # 359 - Still Failing!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 3 Sep 2021 14:34:40 -0500 (CDT)
Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux64/359/
This job failed to build.
Started by upstream project "epics-7.0" build number 359
originally caused by:
 Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building on the built-in node in workspace /var/lib/jenkins/jobs/epics-7.0/workspace/OS/linux64
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --resolve-git-dir /var/lib/jenkins/jobs/epics-7.0/workspace/OS/linux64/.git # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > git --version # timeout=10
 > git --version # 'git version 1.8.3.1'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --progress https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/* # timeout=10
Checking out Revision 8e2f78caf529dfe60faa12308603c9ea9cd501ad (refs/remotes/origin/7.0)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 8e2f78caf529dfe60faa12308603c9ea9cd501ad # timeout=10
Commit message: "dbStatic: Better error reports for bad JSON string chars"
 > git rev-list --no-walk 7ce69155a9736ab02ea1265901c55d9044a19350 # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
 > git submodule foreach --recursive git reset --hard # timeout=10
 > git submodule foreach git clean -fdx # timeout=10
 > git remote # timeout=10
 > git submodule init # timeout=10
 > git submodule sync # timeout=10
 > git config --get remote.origin.url # timeout=10
 > git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
 > git config --get submodule.modules/pvData.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
 > git config --get submodule.modules/pvAccess.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
 > git config --get submodule.modules/normativeTypes.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
 > git config --get submodule.modules/pvaClient.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
 > git config --get submodule.modules/pvDatabase.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > git config --get submodule.modules/pva2pva.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > git config --get submodule..ci.url # timeout=10
 > git config -f .gitmodules --get submodule..ci.path # timeout=10
 > git submodule update modules/pvData # timeout=10
 > git submodule update modules/pvAccess # timeout=10
 > git submodule update modules/normativeTypes # timeout=10
 > git submodule update modules/pvaClient # timeout=10
 > git submodule update modules/pvDatabase # timeout=10
 > git submodule update modules/pva2pva # timeout=10
 > git submodule update .ci # timeout=10
No emails were triggered.
[linux64] $ /bin/sh -xe /tmp/jenkins6977542744938467412.sh
+ git submodule foreach 'git checkout master && git pull'
Entering '.ci'
Already on 'master'
Your branch is up-to-date with 'origin/master'.
Already up-to-date.
Entering 'modules/normativeTypes'
Already on 'master'
Already up-to-date.
Entering 'modules/pvAccess'
Already on 'master'
Already up-to-date.
Entering 'modules/pvData'
Already on 'master'
Already up-to-date.
Entering 'modules/pvDatabase'
Already on 'master'
Already up-to-date.
Entering 'modules/pva2pva'
Already on 'master'
Already up-to-date.
Entering 'modules/pvaClient'
Already on 'master'
Already up-to-date.
+ csac=configure/os/CONFIG_SITE.linux-x86_64.Common
+ echo 'CROSS_COMPILER_TARGET_ARCHS :='
+ case $EPICS_HOST_ARCH in
+ echo 'CROSS_COMPILER_TARGET_ARCHS += vxWorks-ppc32'
+ echo 'CROSS_COMPILER_TARGET_ARCHS += vxWorks-ppc32sf'
+ echo 'CROSS_COMPILER_TARGET_ARCHS += RTEMS-uC5282'
+ echo 'RTEMS_VERSION = 4.10.2'
+ echo 'RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)'
+ EXTRA='-j4 -Orecurse'
+ echo ------------------------------------------------------------------
+ /Jenkins/jenkins/bin/make -j4 -Orecurse host
/Jenkins/jenkins/bin/make -C ./configure install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure'
perl -CSD ../src/tools/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD ../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD ../src/tools/makeMakefile.pl O.vxWorks-ppc32sf ../..
perl -CSD ../src/tools/makeMakefile.pl O.RTEMS-uC5282 ../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.linux-x86_64'
/usr/bin/gcc -x c -E  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include         ../toolchain.c > TOOLCHAIN.linux-x86_64.linux-x86_64
Installing CFG file ../../cfg/TOOLCHAIN.linux-x86_64.linux-x86_64
mkdir ../../cfg
Installing CFG file ../../cfg/CONFIG_LIBCOM_VERSION
Installing CFG file ../../cfg/CONFIG_LIBCOM_MODULE
Installing CFG file ../../cfg/CONFIG_CA_MODULE
Installing CFG file ../../cfg/CONFIG_CA_VERSION
Installing CFG file ../../cfg/CONFIG_DATABASE_MODULE
Installing CFG file ../../cfg/CONFIG_DATABASE_VERSION
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.linux-x86_64'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure'
/Jenkins/jenkins/bin/make -C ./src install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src'
/Jenkins/jenkins/bin/make -C ./tools install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools'
perl -CSD ../../src/tools/makeMakefile.pl O.vxWorks-ppc32 ../../..
perl -CSD ../../src/tools/makeMakefile.pl O.linux-x86_64 ../../..
perl -CSD ../../src/tools/makeMakefile.pl O.vxWorks-ppc32sf ../../..
perl -CSD ../../src/tools/makeMakefile.pl O.RTEMS-uC5282 ../../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.linux-x86_64'
Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm
mkdir ../../../lib
Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/PodXHtml.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/PodHtml.pm
Installing PERL_MODULES file ../../../lib/perl/EpicsHostArch.pl
Installing html ../../../html/./style.css
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Path.html ../EPICS/Path.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o Readfile.html ../EPICS/Readfile.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o fullPathName.html ../fullPathName.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o makeAPIheader.html ../makeAPIheader.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o munch.html ../munch.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o podToHtml.html ../podToHtml.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o podRemove.html ../podRemove.pl
Installing script ../../../bin/linux-x86_64/assembleSnippets.pl
mkdir ../../../bin
mkdir ../../../bin/linux-x86_64
Installing script ../../../bin/linux-x86_64/cvsclean.pl
Installing script ../../../bin/linux-x86_64/convertRelease.pl
Installing script ../../../bin/linux-x86_64/depclean.pl
Installing script ../../../bin/linux-x86_64/dos2unix.pl
Installing script ../../../bin/linux-x86_64/epicsProve.pl
Installing script ../../../bin/linux-x86_64/expandVars.pl
Installing script ../../../bin/linux-x86_64/fullPathName.pl
Installing script ../../../bin/linux-x86_64/makeAPIheader.pl
Installing script ../../../bin/linux-x86_64/installEpics.pl
Installing script ../../../bin/linux-x86_64/makeMakefile.pl
Installing script ../../../bin/linux-x86_64/makeTestfile.pl
Installing script ../../../bin/linux-x86_64/mkmf.pl
Installing script ../../../bin/linux-x86_64/munch.pl
Installing script ../../../bin/linux-x86_64/podToHtml.pl
Installing script ../../../bin/linux-x86_64/podRemove.pl
Installing script ../../../bin/linux-x86_64/replaceVAR.pl
Installing script ../../../bin/linux-x86_64/tap-to-junit-xml.pl
Installing script ../../../bin/linux-x86_64/useManifestTool.pl
Installing script ../../../bin/linux-x86_64/testFailures.pl
Installing script ../../../bin/linux-x86_64/genVersionHeader.pl
Installing script ../../../bin/linux-x86_64/makeRPath.py
Installing generated html ../../../html/./fullPathName.html
Installing generated html ../../../html/./EPICS/Path.html
mkdir ../../../html/./EPICS
Installing generated html ../../../html/./EPICS/Getopts.html
Installing generated html ../../../html/./EPICS/Readfile.html
Installing generated html ../../../html/./makeAPIheader.html
Installing generated html ../../../html/./munch.html
Installing generated html ../../../html/./podRemove.html
Installing generated html ../../../html/./podToHtml.html
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools'
/Jenkins/jenkins/bin/make -C template/base install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../../../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.linux-x86_64'
Installing script ../../../../bin/linux-x86_64/makeBaseApp.pl
Installing ../../../../templates/makeBaseApp/top/Makefile
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG
mkdir ../../../../templates/makeBaseApp/top/configure
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseApp/top/configure/Makefile
Installing ../../../../templates/makeBaseApp/top/configure/RELEASE
Installing ../../../../templates/makeBaseApp/top/configure/RULES
Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc
Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base'
/Jenkins/jenkins/bin/make -C template/ext install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext'
mkdir -p O.Common
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.linux-x86_64'
Installing script ../../../../bin/linux-x86_64/makeBaseExt.pl
Installing ../../../../templates/makeBaseExt/top/Makefile
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
Installing ../../../../templates/makeBaseExt/top/README
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG
mkdir ../../../../templates/makeBaseExt/top/configure
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseExt/top/configure/Makefile
Installing ../../../../templates/makeBaseExt/top/configure/RELEASE
Installing ../../../../templates/makeBaseExt/top/configure/RULES
Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP
Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON
Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc
mkdir ../../../../templates/makeBaseExt/top/configure/os
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
Installing ../../../../templates/makeBaseExt/top/src/Makefile
mkdir ../../../../templates/makeBaseExt/top/src
Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/exampleExt
Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM
Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c
Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src'
/Jenkins/jenkins/bin/make -C ./test install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test'
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools'
mkdir -p O.Common
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.linux-x86_64'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../.. -a linux-x86_64 ../Snippets.plt Snippets.t
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.linux-x86_64'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test'
/Jenkins/jenkins/bin/make -C ./modules install.linux-x86_64
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules'
Creating RELEASE.linux-x86_64.local with
    EPICS_BASE = /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
/Jenkins/jenkins/bin/make -C ./libcom install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.linux-x86_64'
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
perl -CSD ../misc/makeEpicsVersion.pl -o epicsVersion.h   ../../../../configure/CONFIG_BASE_VERSION
Building epicsVersion.h from ../../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 7.0.6.1-DEV
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeAPIheader.pl -o ../O.Common/libComAPI.h libCom
perl -CSD ../error/makeStatTbl.pl  ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
Installing created executable ../../../../bin/linux-x86_64/bldEnvData.pl
perl -CSD ../../../../bin/linux-x86_64/bldEnvData.pl  -t linux-x86_64 \
	-c gcc -s Linux ../../../../configure
Generating envData.c
Installing generated generic include file ../../../../include/libComAPI.h
mkdir ../../../../include
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_encode.d  ../yajl/yajl_encode.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_lex.d  ../yajl/yajl_lex.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_gen.d  ../yajl/yajl_gen.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_alloc.d  ../yajl/yajl_alloc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_parser.d  ../yajl/yajl_parser.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_buf.d  ../yajl/yajl_buf.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl.d  ../yajl/yajl.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueueActive.d  ../timer/timerQueueActive.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueueActiveMgr.d  ../timer/timerQueueActiveMgr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueuePassive.d  ../timer/timerQueuePassive.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timerQueue.d  ../timer/timerQueue.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsRingBytes.d  ../ring/epicsRingBytes.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF taskwd.d  ../taskwd/taskwd.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsRingPointer.d  ../ring/epicsRingPointer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF timer.d  ../timer/timer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTimer.d  ../timer/epicsTimer.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF threadPool.d  ../pool/threadPool.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF poolJob.d  ../pool/poolJob.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdBackTrace.d  ../osi/os/Linux/osdBackTrace.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF devLibVMEOSD.d  ../osi/os/default/devLibVMEOSD.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdFindAddr.d  ../osi/os/Linux/osdFindAddr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStackTrace.d  ../osi/epicsStackTrace.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF devLibVME.d  ../osi/devLibVME.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdgetexec.d  ../osi/os/Linux/osdgetexec.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdMessageQueue.d  ../osi/os/default/osdMessageQueue.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdProcess.d  ../osi/os/posix/osdProcess.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdNetIntf.d  ../osi/os/Linux/osdNetIntf.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdMonotonic.d  ../osi/os/posix/osdMonotonic.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdEvent.d  ../osi/os/posix/osdEvent.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSpin.d  ../osi/os/posix/osdSpin.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdMutex.d  ../osi/os/posix/osdMutex.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdThreadHooks.d  ../osi/os/default/osdThreadHooks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdThreadExtra.d  ../osi/os/Linux/osdThreadExtra.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdTime.d  ../osi/os/posix/osdTime.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdStdio.d  ../osi/os/posix/osdStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTempFile.d  ../osi/os/posix/epicsTempFile.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdThread.d  ../osi/os/posix/osdThread.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStdio.d  ../osi/epicsStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE   -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsReadline.d  ../osi/epicsReadline.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdPoolStatus.d  ../osi/os/default/osdPoolStatus.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdEnv.d  ../osi/os/default/osdEnv.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSignal.d  ../osi/os/posix/osdSignal.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdFindSymbol.d  ../osi/os/posix/osdFindSymbol.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdInterrupt.d  ../osi/os/default/osdInterrupt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdAssert.d  ../osi/os/default/osdAssert.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsSocketConvertErrnoToString.d  ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF systemCallIntMech.d  ../osi/os/posix/systemCallIntMech.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osiSock.d  ../osi/osiSock.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSockUnsentCount.d  ../osi/os/Linux/osdSockUnsentCount.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSockAddrReuse.d  ../osi/os/default/osdSockAddrReuse.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osiClockTime.d  ../osi/osiClockTime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osdSock.d  ../osi/os/posix/osdSock.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsAtomicOSD.d  ../osi/os/posix/epicsAtomicOSD.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMath.d  ../osi/epicsMath.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsGeneralTime.d  ../osi/epicsGeneralTime.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMessageQueue.d  ../osi/epicsMessageQueue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEvent.d  ../osi/epicsEvent.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsUnitTest.d  ../misc/epicsUnitTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMutex.d  ../osi/epicsMutex.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTime.d  ../osi/epicsTime.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF truncateFile.d  ../misc/truncateFile.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThread.d  ../osi/epicsThread.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStdlib.d  ../misc/epicsStdlib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsString.d  ../misc/epicsString.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsExit.d  ../misc/epicsExit.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ipAddrToAsciiAsynchronous.d  ../misc/ipAddrToAsciiAsynchronous.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsConvert.d  ../misc/epicsConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF cantProceed.d  ../misc/cantProceed.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF adjustment.d  ../misc/adjustment.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF alarmString.d  ../misc/alarmString.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macUtil.d  ../macLib/macUtil.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF aToIPAddr.d  ../misc/aToIPAddr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macEnv.d  ../macLib/macEnv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macCore.d  ../macLib/macCore.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF registry.d  ../iocsh/registry.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocLog.d  ../log/iocLog.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF logClient.d  ../log/logClient.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF libComRegister.d  ../iocsh/libComRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF initHooks.d  ../iocsh/initHooks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF gpHashLib.d  ../gpHash/gpHashLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF freeListLib.d  ../freeList/freeListLib.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocsh.d  ../iocsh/iocsh.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF errSymTbl.d  errSymTbl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF errSymLib.d  ../error/errSymLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF envData.d  envData.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF errlog.d  ../error/errlog.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF fdManager.d  ../fdmgr/fdManager.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF fdmgr.d  ../fdmgr/fdmgr.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ellSort.d  ../ellLib/ellSort.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ellLib.d  ../ellLib/ellLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF envSubr.d  ../env/envSubr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF dbmf.d  ../dbmf/dbmf.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF cvtFast.d  ../cvtFast/cvtFast.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsSingletonMutex.d  ../cxxTemplates/epicsSingletonMutex.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF resourceLib.d  ../cxxTemplates/resourceLib.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF calcPerform.d  ../calc/calcPerform.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF postfix.d  ../calc/postfix.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF bucketLib.d  ../bucketLib/bucketLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF asTrapWrite.d  ../as/asTrapWrite.c
Installing generic include file ../../../../include/valgrind/valgrind.h
mkdir ../../../../include/valgrind
Installing generated generic include file ../../../../include/libComVersion.h
Installing generic include file ../../../../include/asLib.h
Installing generic include file ../../../../include/asTrapWrite.h
Installing generic include file ../../../../include/bucketLib.h
Installing generic include file ../../../../include/postfix.h
Installing generic include file ../../../../include/cvtFast.h
Installing generic include file ../../../../include/epicsAlgorithm.h
Installing generic include file ../../../../include/resourceLib.h
Installing generic include file ../../../../include/tsDLList.h
Installing generic include file ../../../../include/tsSLList.h
Installing generic include file ../../../../include/tsMinMax.h
Installing generic include file ../../../../include/tsFreeList.h
Installing generic include file ../../../../include/epicsSingleton.h
Installing generic include file ../../../../include/epicsGuard.h
Installing generic include file ../../../../include/dbmf.h
Installing generic include file ../../../../include/ellLib.h
Installing generic include file ../../../../include/envDefs.h
Installing generic include file ../../../../include/epicsPrint.h
Installing generic include file ../../../../include/errMdef.h
Installing generic include file ../../../../include/errSymTbl.h
Installing generic include file ../../../../include/errlog.h
Installing generic include file ../../../../include/fdManager.h
Installing generic include file ../../../../include/fdmgr.h
Installing generic include file ../../../../include/flex.skel.static
Installing generic include file ../../../../include/freeList.h
Installing generic include file ../../../../include/gpHash.h
Installing generic include file ../../../../include/iocsh.h
Installing generic include file ../../../../include/initHooks.h
Installing generic include file ../../../../include/registry.h
Installing generic include file ../../../../include/libComRegister.h
Installing generic include file ../../../../include/iocLog.h
Installing generic include file ../../../../include/logClient.h
Installing generic include file ../../../../include/macLib.h
Installing generic include file ../../../../include/alarm.h
Installing generic include file ../../../../include/alarmString.h
Installing generic include file ../../../../include/adjustment.h
Installing generic include file ../../../../include/cantProceed.h
Installing generic include file ../../../../include/dbDefs.h
Installing generic include file ../../../../include/epicsConvert.h
Installing generic include file ../../../../include/epicsExit.h
Installing generic include file ../../../../include/epicsStdlib.h
Installing generic include file ../../../../include/epicsString.h
Installing generic include file ../../../../include/epicsTypes.h
Installing generic include file ../../../../include/shareLib.h
Installing generic include file ../../../../include/epicsExport.h
Installing generic include file ../../../../include/locationException.h
Installing generic include file ../../../../include/ipAddrToAsciiAsynchronous.h
Installing generic include file ../../../../include/compilerDependencies.h
Installing generic include file ../../../../include/epicsUnitTest.h
Installing generic include file ../../../../include/testMain.h
Installing generated generic include file ../../../../include/epicsVersion.h
Installing compiler dependent include file ../../../../include/compiler/gcc/compilerSpecific.h
mkdir ../../../../include/compiler
mkdir ../../../../include/compiler/gcc
Installing generic include file ../../../../include/osiFileName.h
Installing generic include file ../../../../include/osiSock.h
Installing OS dependent include file ../../../../include/os/Linux/osdSock.h
mkdir ../../../../include/os
mkdir ../../../../include/os/Linux
Installing generic include file ../../../../include/epicsInterrupt.h
Installing OS dependent include file ../../../../include/os/Linux/osdInterrupt.h
Installing OS dependent include file ../../../../include/os/Linux/osdMutex.h
Installing OS dependent include file ../../../../include/os/Linux/osdEvent.h
Installing generic include file ../../../../include/epicsMutex.h
Installing generic include file ../../../../include/epicsSpin.h
Installing generic include file ../../../../include/epicsEvent.h
Installing OS dependent include file ../../../../include/os/Linux/epicsMath.h
Installing OS dependent include file ../../../../include/os/Linux/osdMessageQueue.h
Installing OS dependent include file ../../../../include/os/Linux/osdStrtod.h
Installing generic include file ../../../../include/epicsAssert.h
Installing generic include file ../../../../include/epicsFindSymbol.h
Installing generic include file ../../../../include/osiPoolStatus.h
Installing OS dependent include file ../../../../include/os/Linux/osdPoolStatus.h
Installing OS dependent include file ../../../../include/os/Linux/osdThread.h
Installing generic include file ../../../../include/epicsThread.h
Installing generic include file ../../../../include/epicsTime.h
Installing generic include file ../../../../include/epicsGeneralTime.h
Installing OS dependent include file ../../../../include/os/Linux/osdTime.h
Installing generic include file ../../../../include/generalTimeSup.h
Installing generic include file ../../../../include/osiClockTime.h
Installing generic include file ../../../../include/epicsSignal.h
Installing generic include file ../../../../include/osiProcess.h
Installing OS dependent include file ../../../../include/os/Linux/osiUnistd.h
Installing generic include file ../../../../include/osiWireFormat.h
Installing OS dependent include file ../../../../include/os/Linux/osdWireFormat.h
Installing OS dependent include file ../../../../include/os/Linux/osdWireConfig.h
Installing generic include file ../../../../include/epicsAtomic.h
Installing generic include file ../../../../include/epicsAtomicDefault.h
Installing OS dependent include file ../../../../include/os/Linux/epicsAtomicOSD.h
Installing generic include file ../../../../include/epicsEndian.h
Installing generic include file ../../../../include/epicsReadline.h
Installing generic include file ../../../../include/epicsMessageQueue.h
Installing compiler dependent include file ../../../../include/compiler/gcc/epicsAtomicCD.h
Installing generic include file ../../../../include/epicsStdio.h
Installing generic include file ../../../../include/epicsStdioRedirect.h
Installing generic include file ../../../../include/epicsTempFile.h
Installing OS dependent include file ../../../../include/os/Linux/epicsGetopt.h
Installing generic include file ../../../../include/epicsStackTrace.h
Installing generic include file ../../../../include/devLib.h
Installing generic include file ../../../../include/devLibVME.h
Installing generic include file ../../../../include/devLibVMEImpl.h
Installing OS dependent include file ../../../../include/os/Linux/osdVME.h
Installing OS dependent include file ../../../../include/os/Linux/epicsMMIO.h
Installing OS dependent include file ../../../../include/os/Linux/epicsMMIODef.h
Installing generic include file ../../../../include/epicsAtomicGCC.h
Installing generic include file ../../../../include/epicsThreadPool.h
Installing generic include file ../../../../include/epicsRingPointer.h
Installing generic include file ../../../../include/epicsRingBytes.h
Installing generic include file ../../../../include/taskwd.h
Installing generic include file ../../../../include/epicsTimer.h
Installing generic include file ../../../../include/yajl_alloc.h
Installing generic include file ../../../../include/yajl_common.h
Installing generic include file ../../../../include/yajl_gen.h
Installing generic include file ../../../../include/yajl_parse.h
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF verbose.d  ../yacc/verbose.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF skeleton.d  ../yacc/skeleton.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF warshall.d  ../yacc/warshall.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF symtab.d  ../yacc/symtab.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF reader.d  ../yacc/reader.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF mkpar.d  ../yacc/mkpar.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF output.d  ../yacc/output.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF antelope.d  ../yacc/antelope.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF error.d  ../yacc/error.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF lalr.d  ../yacc/lalr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF lr0.d  ../yacc/lr0.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF closure.d  ../yacc/closure.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF tblcmp.d  ../flex/tblcmp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF sym.d  ../flex/sym.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF nfa.d  ../flex/nfa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF misc.d  ../flex/misc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF gen.d  ../flex/gen.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ecs.d  ../flex/ecs.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocLogServer.d  ../log/iocLogServer.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF dfa.d  ../flex/dfa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ccl.d  ../flex/ccl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/ccl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/ecs.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/gen.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/misc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/nfa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/dfa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/sym.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/closure.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/error.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../flex/tblcmp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/antelope.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/lr0.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/lalr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/mkpar.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/skeleton.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/symtab.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/warshall.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/verbose.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/output.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yacc/reader.c
/usr/bin/g++ -o antelope  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         closure.o error.o lalr.o lr0.o antelope.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o
Installing created executable ../../../../bin/linux-x86_64/antelope
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -bparse -l -d ../flex/parse.y
mv parse.tab.c parse.c
mv parse.tab.h parse.h
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static    -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF parse.d  parse.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE       -DDEFAULT_SKELETON_FILE=flex.skel.static    -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c parse.c
/usr/bin/g++ -o e_flex  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o
Installing created executable ../../../../bin/linux-x86_64/e_flex
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/e_flex -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ../as/asLib_lex.l
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -basLib  ../as/asLib.y
mv asLib.tab.c asLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF asLib.d  asLib.c
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
Installing PERL_MODULES file ../../../../lib/perl/EPICS/macLib.pm
Expanding ../log/S99logServer@ to S99logServer
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -a linux-x86_64 -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../log/S99logServer@ S99logServer
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../as/asTrapWrite.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../calc/postfix.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../bucketLib/bucketLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../calc/calcPerform.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../cxxTemplates/resourceLib.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../cxxTemplates/epicsSingletonMutex.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../dbmf/dbmf.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ellLib/ellSort.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../cvtFast/cvtFast.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ellLib/ellLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c envData.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../env/envSubr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c errSymTbl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../error/errSymLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c asLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../error/errlog.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../freeList/freeListLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../gpHash/gpHashLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../iocsh/initHooks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../iocsh/registry.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../iocsh/iocsh.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../iocsh/libComRegister.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../fdmgr/fdmgr.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../log/iocLog.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../fdmgr/fdManager.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../macLib/macEnv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/alarmString.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../log/logClient.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/adjustment.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../macLib/macUtil.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../macLib/macCore.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/aToIPAddr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/cantProceed.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/epicsConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/epicsExit.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/truncateFile.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/epicsStdlib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/epicsUnitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/epicsString.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsEvent.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsMutex.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../misc/ipAddrToAsciiAsynchronous.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsThread.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsMessageQueue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsMath.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/epicsAtomicOSD.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/osiClockTime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdSock.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdSockAddrReuse.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsTime.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsGeneralTime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdSockUnsentCount.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/systemCallIntMech.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/osiSock.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdFindSymbol.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdAssert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdInterrupt.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdSignal.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdEnv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/epicsTempFile.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdPoolStatus.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE   -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsReadline.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdThreadExtra.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdThreadHooks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdMutex.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdSpin.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdEvent.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdMonotonic.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdThread.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdProcess.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdgetexec.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdNetIntf.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/posix/osdTime.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/devLibVMEOSD.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/epicsStackTrace.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdBackTrace.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/default/osdMessageQueue.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/devLibVME.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../pool/poolJob.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osi/os/Linux/osdFindAddr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../pool/threadPool.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ring/epicsRingPointer.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ring/epicsRingBytes.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../taskwd/taskwd.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/epicsTimer.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_alloc.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueueActive.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_buf.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueuePassive.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../timer/timerQueueActiveMgr.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_encode.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_parser.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_gen.c
Installing created executable ../../../../bin/linux-x86_64/S99logServer
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../log/iocLogServer.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/Linux -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl/yajl_lex.c
/usr/bin/ar -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
/usr/bin/ranlib libCom.a
/usr/bin/g++ -o libCom.so.3.20.1 -shared -fPIC -Wl,-hlibCom.so.3.20.1 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o       -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../../lib/linux-x86_64/libCom.so.3.20.1
ln -s libCom.so.3.20.1 ../../../../lib/linux-x86_64/libCom.so
Installing library ../../../../lib/linux-x86_64/libCom.a
/usr/bin/g++ -o iocLogServer  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         iocLogServer.o    -lCom
Installing created executable ../../../../bin/linux-x86_64/iocLogServer
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src'
/Jenkins/jenkins/bin/make -C ./vxWorks install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/vxWorks'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../../..
mkdir -p O.Common
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../../../..
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/vxWorks/O.linux-x86_64'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/vxWorks/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/vxWorks'
/Jenkins/jenkins/bin/make -C ./RTEMS install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/RTEMS'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/RTEMS/O.linux-x86_64'
Installing generic include file ../../../../include/epicsMemFs.h
Installing generic include file ../../../../include/epicsNtp.h
Installing generic include file ../../../../include/epicsRtemsInitHooks.h
Installing script ../../../../bin/linux-x86_64/epicsMakeMemFs.pl
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/RTEMS/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/RTEMS'
/Jenkins/jenkins/bin/make -C ./test install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/test'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/test/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF buckTest.d  ../buckTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF nonEpicsThreadPriorityTest.d  ../nonEpicsThreadPriorityTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMaxThreads.d  ../epicsMaxThreads.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsAtomicPerform.d  ../epicsAtomicPerform.cpp
INSTALL_LOCATION=../../../..
perl -CSD ../../../../modules/database/src/std/softIoc/makeInstallDir.pl "../../../.." > epicsInstallDir.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF cvtFastPerform.d  ../cvtFastPerform.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF testexecname.d  ../testexecname.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF yajl_test.d  ../yajl_test.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadPerform.d  ../epicsThreadPerform.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF iocshTest.d  ../iocshTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStackTraceTest.d  ../epicsStackTraceTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF osiSockTest.d  ../osiSockTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ipAddrToAsciiTest.d  ../ipAddrToAsciiTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMessageQueueTest.d  ../epicsMessageQueueTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF taskwdTest.d  ../taskwdTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macLibTest.d  ../macLibTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF aslibtest.d  ../aslibtest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF blockingSockTest.d  ../blockingSockTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF cvtFastTest.d  ../cvtFastTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF macDefExpandTest.d  ../macDefExpandTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsSpinTest.d  ../epicsSpinTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsAtomicTest.d  ../epicsAtomicTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMutexTest.d  ../epicsMutexTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ringBytesTest.d  ../ringBytesTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEventTest.d  ../epicsEventTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF ringPointerTest.d  ../ringPointerTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsExitTest.d  ../epicsExitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF initHookTest.d  ../initHookTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTimerTest.d  ../epicsTimerTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadPoolTest.d  ../epicsThreadPoolTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadHooksTest.d  ../epicsThreadHooksTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadPrivateTest.d  ../epicsThreadPrivateTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadPriorityTest.d  ../epicsThreadPriorityTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadOnceTest.d  ../epicsThreadOnceTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadClassTest.d  ../epicsThreadClassTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTimeZoneTest.d  ../epicsTimeZoneTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStringTest.d  ../epicsStringTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsSockResolveTest.d  ../epicsSockResolveTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsThreadTest.d  ../epicsThreadTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTimeTest.d  ../epicsTimeTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStdlibTest.d  ../epicsStdlibTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsStdioTest.d  ../epicsStdioTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEnvUnsetTest.d  ../epicsEnvUnsetTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEllTest.d  ../epicsEllTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsEnvTest.d  ../epicsEnvTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsErrlogTest.d  ../epicsErrlogTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMathTest.d  ../epicsMathTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsAlgorithmTest.d  ../epicsAlgorithmTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsInlineTest4.d  ../epicsInlineTest4.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsMMIOTest.d  ../epicsMMIOTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsInlineTest3.d  ../epicsInlineTest3.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsInlineTest2.d  ../epicsInlineTest2.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsCalcTest.d  ../epicsCalcTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsInlineTest1.d  ../epicsInlineTest1.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsTypesTest.d  ../epicsTypesTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsUnitTestTest.d  ../epicsUnitTestTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DBUILDING_SHARED_LIBRARIES    -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -MM -MF epicsLoadTest.d  ../epicsLoadTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsInlineTest2.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsUnitTestTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsInlineTest1.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsTypesTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsInlineTest3.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsInlineTest4.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsAlgorithmTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsMathTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsMMIOTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsEnvTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsEnvUnsetTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsEllTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsStdioTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsSockResolveTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsErrlogTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsStdlibTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsCalcTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsStringTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsTimeZoneTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadOnceTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadClassTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsTimeTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadPriorityTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../initHookTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadPrivateTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadHooksTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsExitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadPoolTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ringBytesTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ringPointerTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsSpinTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsEventTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsTimerTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../macDefExpandTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../macLibTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../aslibtest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsAtomicTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../taskwdTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsMutexTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../blockingSockTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsStackTraceTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsMessageQueueTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../testexecname.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../ipAddrToAsciiTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../osiSockTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../yajl_test.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../cvtFastTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DBUILDING_SHARED_LIBRARIES    -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsLoadTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsMaxThreads.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../buckTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../iocshTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsThreadPerform.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../nonEpicsThreadPriorityTest.cpp
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -a linux-x86_64 ../epicsUnitTestTest.plt epicsUnitTestTest.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -a linux-x86_64 ../macLib.plt macLib.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -a linux-x86_64 ../yajlTest.plt yajlTest.t
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../cvtFastPerform.cpp
/usr/bin/g++ -o epicsUnitTestTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsUnitTestTest.o    -lCom
/usr/bin/g++ -o epicsTypesTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsTypesTest.o    -lCom
/usr/bin/g++ -o epicsInlineTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsInlineTest1.o epicsInlineTest2.o epicsInlineTest3.o epicsInlineTest4.o    -lCom
/usr/bin/g++ -o epicsCalcTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsCalcTest.o    -lCom
/usr/bin/g++ -o epicsAlgorithmTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsAlgorithmTest.o    -lCom
/usr/bin/g++ -o epicsMathTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsMathTest.o    -lCom
/usr/bin/g++ -o epicsMMIOTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsMMIOTest.o    -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/gcc -I../../../../include/os/Linux -I../../../../include         -c ../epicsAtomicPerform.cpp
/usr/bin/g++ -o epicsEllTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsEllTest.o    -lCom
/usr/bin/g++ -o epicsEnvTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsEnvTest.o    -lCom
/usr/bin/g++ -o epicsEnvUnsetTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsEnvUnsetTest.o    -lCom
/usr/bin/g++ -o epicsErrlogTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsErrlogTest.o    -lCom
/usr/bin/g++ -o epicsStdioTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsStdioTest.o    -lCom
/usr/bin/g++ -o epicsStdlibTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsStdlibTest.o    -lCom
/usr/bin/g++ -o epicsSockResolveTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsSockResolveTest.o    -lCom
/usr/bin/g++ -o epicsStringTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsStringTest.o    -lCom
/usr/bin/g++ -o epicsTimeTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsTimeTest.o    -lCom
/usr/bin/g++ -o epicsTimeZoneTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsTimeZoneTest.o    -lCom
/usr/bin/g++ -o epicsThreadTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadTest.o    -lCom
/usr/bin/g++ -o epicsThreadClassTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadClassTest.o    -lCom
/usr/bin/g++ -o epicsThreadOnceTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadOnceTest.o    -lCom
/usr/bin/g++ -o epicsThreadPriorityTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadPriorityTest.o    -lCom
/usr/bin/g++ -o epicsThreadPrivateTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadPrivateTest.o    -lCom
/usr/bin/g++ -o epicsThreadHooksTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadHooksTest.o    -lCom
/usr/bin/g++ -o epicsThreadPoolTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadPoolTest.o    -lCom
/usr/bin/g++ -o initHookTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         initHookTest.o    -lCom
/usr/bin/g++ -o epicsExitTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsExitTest.o    -lCom
/usr/bin/g++ -o epicsTimerTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsTimerTest.o    -lCom
/usr/bin/g++ -o ringPointerTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ringPointerTest.o    -lCom
/usr/bin/g++ -o ringBytesTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ringBytesTest.o    -lCom
/usr/bin/g++ -o epicsEventTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsEventTest.o    -lCom
/usr/bin/g++ -o epicsMutexTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsMutexTest.o    -lCom
/usr/bin/g++ -o epicsSpinTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsSpinTest.o    -lCom
/usr/bin/g++ -o epicsAtomicTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsAtomicTest.o    -lCom
/usr/bin/g++ -o macDefExpandTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         macDefExpandTest.o    -lCom
/usr/bin/g++ -o cvtFastTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         cvtFastTest.o    -lCom
/usr/bin/g++ -o macLibTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         macLibTest.o    -lCom
/usr/bin/g++ -o aslibtest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         aslibtest.o    -lCom
/usr/bin/g++ -o taskwdTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         taskwdTest.o    -lCom
/usr/bin/g++ -o blockingSockTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         blockingSockTest.o    -lCom
/usr/bin/g++ -o epicsMessageQueueTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsMessageQueueTest.o    -lCom
/usr/bin/g++ -o epicsStackTraceTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsStackTraceTest.o    -lCom
/usr/bin/g++ -o ipAddrToAsciiTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ipAddrToAsciiTest.o    -lCom
/usr/bin/g++ -o osiSockTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         osiSockTest.o    -lCom
/usr/bin/g++ -o testexecname  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testexecname.o    -lCom
/usr/bin/g++ -o yajl_test  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         yajl_test.o    -lCom
/usr/bin/g++ -o iocshTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         iocshTest.o    -lCom
/usr/bin/g++ -o epicsLoadTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsLoadTest.o    -lCom
/usr/bin/g++ -o epicsThreadPerform  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsThreadPerform.o    -lCom
/usr/bin/g++ -o epicsMaxThreads  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsMaxThreads.o    -lCom
/usr/bin/g++ -o buckTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         buckTest.o    -lCom
/usr/bin/g++ -o epicsAtomicPerform  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicsAtomicPerform.o    -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsTypesTest.t epicsTypesTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsInlineTest.t epicsInlineTest
/usr/bin/g++ -o cvtFastPerform  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         cvtFastPerform.o    -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsCalcTest.t epicsCalcTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsAlgorithmTest.t epicsAlgorithmTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsMathTest.t epicsMathTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsMMIOTest.t epicsMMIOTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsEllTest.t epicsEllTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsEnvTest.t epicsEnvTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsEnvUnsetTest.t epicsEnvUnsetTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsErrlogTest.t epicsErrlogTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsStdioTest.t epicsStdioTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsStdlibTest.t epicsStdlibTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsSockResolveTest.t epicsSockResolveTest
/usr/bin/g++ -o nonEpicsThreadPriorityTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         nonEpicsThreadPriorityTest.o    -lCom  -lpthread
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsStringTest.t epicsStringTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsTimeTest.t epicsTimeTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsTimeZoneTest.t epicsTimeZoneTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadTest.t epicsThreadTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadClassTest.t epicsThreadClassTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadOnceTest.t epicsThreadOnceTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadPriorityTest.t epicsThreadPriorityTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadPrivateTest.t epicsThreadPrivateTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadHooksTest.t epicsThreadHooksTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsThreadPoolTest.t epicsThreadPoolTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 initHookTest.t initHookTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsExitTest.t epicsExitTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsTimerTest.t epicsTimerTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ringPointerTest.t ringPointerTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ringBytesTest.t ringBytesTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsMutexTest.t epicsMutexTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsEventTest.t epicsEventTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsSpinTest.t epicsSpinTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsAtomicTest.t epicsAtomicTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 cvtFastTest.t cvtFastTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 macDefExpandTest.t macDefExpandTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 macLibTest.t macLibTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 aslibtest.t aslibtest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 taskwdTest.t taskwdTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 blockingSockTest.t blockingSockTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsStackTraceTest.t epicsStackTraceTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsMessageQueueTest.t epicsMessageQueueTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ipAddrToAsciiTest.t ipAddrToAsciiTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 osiSockTest.t osiSockTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testexecname.t testexecname
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 iocshTest.t iocshTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 epicsLoadTest.t epicsLoadTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 nonEpicsThreadPriorityTest.t nonEpicsThreadPriorityTest
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/test/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/test'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom'
/Jenkins/jenkins/bin/make -C ./ca install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca'
/Jenkins/jenkins/bin/make -C ./src install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src'
/Jenkins/jenkins/bin/make -C ./template install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/template'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../../../..
mkdir -p O.Common
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../../../../..
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../../.. \
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/template/O.linux-x86_64'
Installing ../../../../../templates/makeBaseApp/top/caClientApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/caClientApp
Installing ../../../../../templates/makeBaseApp/top/caClientApp/caExample.c
Installing ../../../../../templates/makeBaseApp/top/caClientApp/caMonitor.c
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/caPerlApp
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/cainfo.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/caget.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/caput.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/camonitor.pl
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/template/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/template'
/Jenkins/jenkins/bin/make -C ./client install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/client'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/client/O.linux-x86_64'
Expanding ../caVersion.h@ to ../O.Common/caVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_CA_MAJOR_VERSION="4"  -DEPICS_CA_MINOR_VERSION="14"  -DEPICS_CA_MAINTENANCE_VERSION="1"  -DEPICS_CA_DEVELOPMENT_FLAG="1"  ../caVersion.h@ caVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeAPIheader.pl -o ../O.Common/libCaAPI.h libCa
Installing generated generic include file ../../../../../include/libCaAPI.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caEventRateMain.d  ../caEventRateMain.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caConnTest.d  ../caConnTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caEventRate.d  ../caEventRate.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF casw.d  ../casw.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caConnTestMain.d  ../caConnTestMain.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF acctst.d  ../acctst.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF acctstMain.d  ../acctstMain.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF catimeMain.d  ../catimeMain.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF catime.d  ../catime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF ca_test.d  ../test/ca_test.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF ca_test_main.d  ../test/ca_test_main.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caRepeater.d  ../caRepeater.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF hostNameCache.d  ../hostNameCache.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF comBuf.d  ../comBuf.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF msgForMultiplyDefinedPV.d  ../msgForMultiplyDefinedPV.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF comQueSend.d  ../comQueSend.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF localHostName.d  ../localHostName.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF comQueRecv.d  ../comQueRecv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF syncGroupWriteNotify.d  ../syncGroupWriteNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF syncGroupReadNotify.d  ../syncGroupReadNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF syncGroupNotify.d  ../syncGroupNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF syncgrp.d  ../syncgrp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF CASG.d  ../CASG.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF putCallback.d  ../putCallback.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF getCopy.d  ../getCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF getCallback.d  ../getCallback.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF oldSubscription.d  ../oldSubscription.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF oldChannelNotify.d  ../oldChannelNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF ca_client_context.d  ../ca_client_context.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF bhe.d  ../bhe.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF tcpRecvWatchdog.d  ../tcpRecvWatchdog.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF tcpSendWatchdog.d  ../tcpSendWatchdog.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF netSubscription.d  ../netSubscription.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF netWriteNotifyIO.d  ../netWriteNotifyIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF netReadNotifyIO.d  ../netReadNotifyIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF noopiiu.d  ../noopiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF tcpiiu.d  ../tcpiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF udpiiu.d  ../udpiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF netiiu.d  ../netiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF baseNMIU.d  ../baseNMIU.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF nciu.d  ../nciu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF repeaterSubscribeTimer.d  ../repeaterSubscribeTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF disconnectGovernorTimer.d  ../disconnectGovernorTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF searchTimer.d  ../searchTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF test_event.d  ../test_event.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF repeater.d  ../repeater.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF convert.d  ../convert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF iocinf.d  ../iocinf.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacStateNotify.d  ../cacStateNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacWriteNotify.d  ../cacWriteNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacReadNotify.d  ../cacReadNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacContextNotify.d  ../cacContextNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF access.d  ../access.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacChannelNotify.d  ../cacChannelNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cacChannel.d  ../cacChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cac.d  ../cac.cpp
Installing generic include file ../../../../../include/cadef.h
Installing generic include file ../../../../../include/caerr.h
Installing generic include file ../../../../../include/caeventmask.h
Installing generic include file ../../../../../include/caProto.h
Installing generic include file ../../../../../include/db_access.h
Installing generic include file ../../../../../include/addrList.h
Installing generic include file ../../../../../include/cacIO.h
Installing generic include file ../../../../../include/caDiagnostics.h
Installing generic include file ../../../../../include/net_convert.h
Installing html ../../../../../html/./CAref.html
Expanding ../caRepeater.service@ to caRepeater.service
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -a linux-x86_64 -t ../../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_CA_MAJOR_VERSION="4"  -DEPICS_CA_MINOR_VERSION="14"  -DEPICS_CA_MAINTENANCE_VERSION="1"  -DEPICS_CA_DEVELOPMENT_FLAG="1"  ../caRepeater.service@ caRepeater.service
Expanding ../S99caRepeater@ to S99caRepeater
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -a linux-x86_64 -t ../../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_CA_MAJOR_VERSION="4"  -DEPICS_CA_MINOR_VERSION="14"  -DEPICS_CA_MAINTENANCE_VERSION="1"  -DEPICS_CA_DEVELOPMENT_FLAG="1"  ../S99caRepeater@ S99caRepeater
Installing created executable ../../../../../bin/linux-x86_64/caRepeater.service
Installing created executable ../../../../../bin/linux-x86_64/S99caRepeater
Installing generated generic include file ../../../../../include/caVersion.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacChannelNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacContextNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacReadNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacWriteNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cacStateNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../iocinf.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../access.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../test_event.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cac.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../repeater.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../searchTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../disconnectGovernorTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../baseNMIU.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../convert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../repeaterSubscribeTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../netiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../nciu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../noopiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../udpiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../netReadNotifyIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../netWriteNotifyIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../netSubscription.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../tcpSendWatchdog.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../tcpiiu.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../tcpRecvWatchdog.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../bhe.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../oldChannelNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../ca_client_context.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../oldSubscription.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../getCallback.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../putCallback.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../getCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../syncgrp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../syncGroupNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../CASG.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../syncGroupReadNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../localHostName.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../syncGroupWriteNotify.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../comQueRecv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../comBuf.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../comQueSend.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../hostNameCache.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../test/ca_test_main.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../test/ca_test.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_libCa_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../msgForMultiplyDefinedPV.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../catimeMain.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caRepeater.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../acctstMain.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../catime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../acctst.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caConnTestMain.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caConnTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../casw.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caEventRateMain.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caEventRate.cpp
/usr/bin/ar -rc    libca.a     cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o
/usr/bin/ranlib libca.a
/usr/bin/g++ -o libca.so.4.14.1 -shared -fPIC -Wl,-hlibca.so.4.14.1 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64          cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o   -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../../../lib/linux-x86_64/libca.so.4.14.1
ln -s libca.so.4.14.1 ../../../../../lib/linux-x86_64/libca.so
Installing library ../../../../../lib/linux-x86_64/libca.a
/usr/bin/g++ -o ca_test  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ca_test_main.o ca_test.o    -lca -lCom -lca -lCom
/usr/bin/g++ -o caRepeater  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caRepeater.o    -lca -lCom
/usr/bin/g++ -o catime  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         catimeMain.o catime.o    -lca -lCom
/usr/bin/g++ -o acctst  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         acctstMain.o acctst.o    -lca -lCom
/usr/bin/g++ -o caConnTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caConnTestMain.o caConnTest.o    -lca -lCom
/usr/bin/g++ -o casw  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         casw.o    -lca -lCom
/usr/bin/g++ -o caEventRate  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caEventRateMain.o caEventRate.o    -lca -lCom
Installing created executable ../../../../../bin/linux-x86_64/ca_test
Installing created executable ../../../../../bin/linux-x86_64/catime
Installing created executable ../../../../../bin/linux-x86_64/acctst
Installing created executable ../../../../../bin/linux-x86_64/caConnTest
Installing created executable ../../../../../bin/linux-x86_64/casw
Installing created executable ../../../../../bin/linux-x86_64/caEventRate
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/client/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/client'
/Jenkins/jenkins/bin/make -C ./tools install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/tools'
mkdir -p O.Common
    T_A=linux-x86_64 install
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/tools/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caput.d  ../caput.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cainfo.d  ../cainfo.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF camonitor.d  ../camonitor.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caget.d  ../caget.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF tool_lib.d  ../tool_lib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caget.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../tool_lib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../camonitor.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../cainfo.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../caput.c
/usr/bin/g++ -o caget  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caget.o tool_lib.o   -lca -lCom
/usr/bin/g++ -o camonitor  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         camonitor.o tool_lib.o   -lca -lCom
/usr/bin/g++ -o cainfo  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         cainfo.o tool_lib.o   -lca -lCom
/usr/bin/g++ -o caput  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caput.o tool_lib.o   -lca -lCom
Installing created executable ../../../../../bin/linux-x86_64/caget
Installing created executable ../../../../../bin/linux-x86_64/camonitor
Installing created executable ../../../../../bin/linux-x86_64/cainfo
Installing created executable ../../../../../bin/linux-x86_64/caput
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/tools/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/tools'
/Jenkins/jenkins/bin/make -C ./perl install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/perl'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/perl/O.linux-x86_64'
rm -f Cap5.c Cap5.c_new
perl -CSD /usr/bin/xsubpp -typemap /usr/share/perl5/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration   -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64   -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include    -I/usr/lib64/perl5/CORE     -MM -MF Cap5.d  Cap5.c
Installing PERL_MODULES file ../../../../../lib/perl/CA.pm
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration   -D_REENTRANT -D_GNU_SOURCE -fno-strict-aliasing -pipe -fstack-protector -I/usr/local/include -D_LARGEFILE_SOURCE -D_FILE_OFFSET_BITS=64   -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include    -I/usr/lib64/perl5/CORE     -c Cap5.c
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podToHtml.pl -s -o CA.html ../CA.pm
Installing script ../../../../../bin/linux-x86_64/capr.pl
/usr/bin/g++ -o libCap5.so -shared -fPIC -Wl,-hlibCap5.so -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         Cap5.o    -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing generated html ../../../../../html/./CA.html
Installing loadable shared library ../../../../../lib/linux-x86_64/libCap5.so
Installing loadable shared library ../../../../../lib/perl/5.16.3/x86_64-linux-thread-multi/libCap5.so
mkdir ../../../../../lib/perl/5.16.3
mkdir ../../../../../lib/perl/5.16.3/x86_64-linux-thread-multi
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/perl/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src/perl'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca/src'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/ca'
/Jenkins/jenkins/bin/make -C ./pvData install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData'
/Jenkins/jenkins/bin/make -C ./configure install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/configure'
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/configure/O.linux-x86_64'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/convertRelease.pl checkRelease
Installing CFG file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/cfg/CONFIG_PVDATA_VERSION
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/configure/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/configure'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/src'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/src/O.linux-x86_64'
mkdir -p ../O.Common/pv
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -DEPICS_PVD_MAJOR_VERSION="8" -DEPICS_PVD_MINOR_VERSION="0" -DEPICS_PVD_MAINTENANCE_VERSION="5" -DEPICS_PVD_DEVELOPMENT_FLAG="1" -t /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64    ../pv/pvdVersionNum.h@ ../O.Common/pv/pvdVersionNum.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF print.d  ../../src/json/print.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF parseinto.d  ../../src/json/parseinto.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF parseany.d  ../../src/json/parseany.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF parsehelper.d  ../../src/json/parsehelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF bitSetUtil.d  ../../src/pvMisc/bitSetUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF requestmapper.d  ../../src/copy/requestmapper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF createRequest.d  ../../src/copy/createRequest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF timeStamp.d  ../../src/property/timeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvTimeStamp.d  ../../src/property/pvTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvEnumerated.d  ../../src/property/pvEnumerated.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvDisplay.d  ../../src/property/pvDisplay.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvControl.d  ../../src/property/pvControl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF alarm.d  ../../src/property/alarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvAlarm.d  ../../src/property/pvAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF StandardPVField.d  ../../src/factory/StandardPVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF printer.d  ../../src/factory/printer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF StandardField.d  ../../src/factory/StandardField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF Compare.d  ../../src/factory/Compare.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvSubArrayCopy.d  ../../src/factory/pvSubArrayCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF Convert.d  ../../src/factory/Convert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVDataCreateFactory.d  ../../src/factory/PVDataCreateFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVUnionArray.d  ../../src/factory/PVUnionArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVUnion.d  ../../src/factory/PVUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVStructureArray.d  ../../src/factory/PVStructureArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVStructure.d  ../../src/factory/PVStructure.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVScalarArray.d  ../../src/factory/PVScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVArray.d  ../../src/factory/PVArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVScalar.d  ../../src/factory/PVScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVField.d  ../../src/factory/PVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF TypeFunc.d  ../../src/factory/TypeFunc.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF FieldCreateFactory.d  ../../src/factory/FieldCreateFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvdVersion.d  ../../src/pv/pvdVersion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF valueBuilder.d  ../../src/pv/valueBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF debugPtr.d  ../../src/misc/debugPtr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF reftrack.d  ../../src/misc/reftrack.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF anyscalar.d  ../../src/misc/anyscalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvUnitTest.d  ../../src/misc/pvUnitTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF thread.d  ../../src/misc/thread.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF parseToPOD.d  ../../src/misc/parseToPOD.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF typeCast.d  ../../src/misc/typeCast.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF status.d  ../../src/misc/status.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF timer.d  ../../src/misc/timer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF event.d  ../../src/misc/event.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF epicsException.d  ../../src/misc/epicsException.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF serializeHelper.d  ../../src/misc/serializeHelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF byteBuffer.d  ../../src/misc/byteBuffer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF bitSet.d  ../../src/misc/bitSet.cpp
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/lock.h
mkdir /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/serialize.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/noDefaultMethods.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/bitSet.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/byteBuffer.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/epicsException.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/serializeHelper.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/event.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/thread.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/timer.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/status.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/sharedPtr.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/debugPtr.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/typeCast.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/sharedVector.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/templateMeta.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/current_function.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvUnitTest.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/reftrack.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/anyscalar.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvType.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvIntrospect.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/valueBuilder.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvData.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/convert.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/standardField.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvSubArrayCopy.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/standardPVField.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/typemap.h
Installing generated generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvdVersionNum.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvdVersion.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/factory.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/alarm.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvAlarm.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/control.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvControl.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/display.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvDisplay.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvEnumerated.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/timeStamp.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvTimeStamp.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/createRequest.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/bitSetUtil.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/json.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/byteBuffer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/epicsException.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/bitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/serializeHelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/event.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/timer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/status.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/thread.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/parseToPOD.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/typeCast.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/debugPtr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/pvUnitTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/reftrack.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pv/pvdVersion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/misc/anyscalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/TypeFunc.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pv/valueBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVStructure.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/FieldCreateFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVStructureArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVUnionArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/Convert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/pvSubArrayCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/Compare.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/StandardPVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/StandardField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/alarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/pvAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/PVDataCreateFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/printer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/pvControl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/timeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/pvDisplay.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/pvEnumerated.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/property/pvTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pvMisc/bitSetUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/json/parsehelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/copy/requestmapper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/json/parseany.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/copy/createRequest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/json/print.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/json/parseinto.cpp
/usr/bin/ar -rc    libpvData.a     byteBuffer.o bitSet.o epicsException.o serializeHelper.o event.o timer.o status.o typeCast.o thread.o parseToPOD.o pvUnitTest.o debugPtr.o reftrack.o anyscalar.o pvdVersion.o valueBuilder.o TypeFunc.o FieldCreateFactory.o PVField.o PVScalar.o PVArray.o PVScalarArray.o PVStructure.o PVStructureArray.o PVUnion.o PVUnionArray.o PVDataCreateFactory.o Convert.o pvSubArrayCopy.o Compare.o StandardField.o StandardPVField.o printer.o alarm.o pvAlarm.o pvControl.o pvDisplay.o pvEnumerated.o timeStamp.o pvTimeStamp.o createRequest.o requestmapper.o bitSetUtil.o parsehelper.o parseany.o parseinto.o print.o
/usr/bin/ranlib libpvData.a
/usr/bin/g++ -o libpvData.so.8.0.5 -shared -fPIC -Wl,-hlibpvData.so.8.0.5 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64          byteBuffer.o bitSet.o epicsException.o serializeHelper.o event.o timer.o status.o typeCast.o thread.o parseToPOD.o pvUnitTest.o debugPtr.o reftrack.o anyscalar.o pvdVersion.o valueBuilder.o TypeFunc.o FieldCreateFactory.o PVField.o PVScalar.o PVArray.o PVScalarArray.o PVStructure.o PVStructureArray.o PVUnion.o PVUnionArray.o PVDataCreateFactory.o Convert.o pvSubArrayCopy.o Compare.o StandardField.o StandardPVField.o printer.o alarm.o pvAlarm.o pvControl.o pvDisplay.o pvEnumerated.o timeStamp.o pvTimeStamp.o createRequest.o requestmapper.o bitSetUtil.o parsehelper.o parseany.o parseinto.o print.o   -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvData.so.8.0.5
ln -s libpvData.so.8.0.5 /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvData.so
Installing library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvData.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/src/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/src'
/Jenkins/jenkins/bin/make -C ./examples install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/examples'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/examples/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF unittest.d  ../unittest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../unittest.cpp
/usr/bin/g++ -o unittest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         unittest.o    -lpvData -lCom
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/examples/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/examples'
/Jenkins/jenkins/bin/make -C ./testApp install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/testApp'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/testApp/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testCreateRequest.d  ../../testApp/copy/testCreateRequest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testProperty.d  ../../testApp/property/testProperty.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testValueBuilder.d  ../../testApp/pv/testValueBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testFieldBuilder.d  ../../testApp/pv/testFieldBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testOperators.d  ../../testApp/pv/testOperators.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVStructureArray.d  ../../testApp/pv/testPVStructureArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVScalarArray.d  ../../testApp/pv/testPVScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testConvert.d  ../../testApp/pv/testConvert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVUnion.d  ../../testApp/pv/testPVUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVData.d  ../../testApp/pv/testPVData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testStandardPVField.d  ../../testApp/pv/testStandardPVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVType.d  ../../testApp/pv/testPVType.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testStandardField.d  ../../testApp/pv/testStandardField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testIntrospect.d  ../../testApp/pv/testIntrospect.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testBitSetUtil.d  ../../testApp/pv/testBitSetUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testanyscalar.d  ../../testApp/misc/testanyscalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testprinter.d  ../../testApp/misc/testprinter.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF test_reftrack.d  ../../testApp/misc/test_reftrack.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testjson.d  ../../testApp/misc/testjson.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testUnitTest.d  ../../testApp/misc/testUnitTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testTypeCast.d  ../../testApp/misc/testTypeCast.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testTimeStamp.d  ../../testApp/misc/testTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testSerialization.d  ../../testApp/misc/testSerialization.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testDebugPtr.d  ../../testApp/misc/testDebugPtr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testSharedVector.d  ../../testApp/misc/testSharedVector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testBaseException.d  ../../testApp/misc/testBaseException.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testByteBuffer.d  ../../testApp/misc/testByteBuffer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testByteOrder.d  ../../testApp/misc/testByteOrder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testOverrunBitSet.d  ../../testApp/misc/testOverrunBitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testBitSet.d  ../../testApp/misc/testBitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testTimer.d  ../../testApp/misc/testTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testEvent.d  ../../testApp/misc/testEvent.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testThread.d  ../../testApp/misc/testThread.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF performstruct.d  ../../testApp/pv/performstruct.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testThread.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/performstruct.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testEvent.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testBitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testTimer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testByteOrder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testOverrunBitSet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testBaseException.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testDebugPtr.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testByteBuffer.cpp
In file included from /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvUnitTest.h:11:0,
                 from ../../testApp/misc/testByteBuffer.cpp:19:
../../testApp/misc/testByteBuffer.cpp: In function ‘void testBasicOperations()’:
../../testApp/misc/testByteBuffer.cpp:164:36: warning: ‘const char* epics::pvData::ByteBuffer::getArray() const’ is deprecated (declared at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/byteBuffer.h:682) [-Wdeprecated-declarations]
     testOk1(strncmp(buff->getArray(),&src[2],6)==0);
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/epicsUnitTest.h:183:30: note: in definition of macro ‘testOk1’
 #define testOk1(cond) testOk(cond, "%s", #cond)
../../testApp/misc/testByteBuffer.cpp: In function ‘void testInverseEndianness(int, const char*)’:
../../testApp/misc/testByteBuffer.cpp:191:35: warning: ‘const char* epics::pvData::ByteBuffer::getArray() const’ is deprecated (declared at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/byteBuffer.h:682) [-Wdeprecated-declarations]
     testOk1(strncmp(buf->getArray(),expect,6)==0);
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testSharedVector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testUnitTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testjson.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/test_reftrack.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testTypeCast.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testSerialization.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testanyscalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testBitSetUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testPVType.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/misc/testprinter.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testStandardField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testIntrospect.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testStandardPVField.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testConvert.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testPVUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testPVStructureArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testPVData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testOperators.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testPVScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testValueBuilder.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/property/testProperty.cpp
/usr/bin/g++ -o performstruct  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         performstruct.o    -lpvData -lCom  -lrt
/usr/bin/g++ -o testThread  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testThread.o    -lpvData -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/pv/testFieldBuilder.cpp
/usr/bin/g++ -o testEvent  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testEvent.o    -lpvData -lCom
/usr/bin/g++ -o testTimer  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testTimer.o    -lpvData -lCom
/usr/bin/g++ -o testBitSet  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testBitSet.o    -lpvData -lCom
/usr/bin/g++ -o testOverrunBitSet  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testOverrunBitSet.o    -lpvData -lCom
/usr/bin/g++ -o testByteOrder  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testByteOrder.o    -lpvData -lCom
/usr/bin/g++ -o testByteBuffer  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testByteBuffer.o    -lpvData -lCom
/usr/bin/g++ -o testBaseException  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testBaseException.o    -lpvData -lCom
/usr/bin/g++ -o testSharedVector  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testSharedVector.o    -lpvData -lCom
/usr/bin/g++ -o testDebugPtr  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testDebugPtr.o    -lpvData -lCom
/usr/bin/g++ -o testSerialization  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testSerialization.o    -lpvData -lCom
/usr/bin/g++ -o testTimeStamp  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testTimeStamp.o    -lpvData -lCom
/usr/bin/g++ -o testTypeCast  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testTypeCast.o    -lpvData -lCom
/usr/bin/g++ -o testUnitTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testUnitTest.o    -lpvData -lCom
/usr/bin/g++ -o testjson  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testjson.o    -lpvData -lCom
/usr/bin/g++ -o test_reftrack  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         test_reftrack.o    -lpvData -lCom
/usr/bin/g++ -o testanyscalar  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testanyscalar.o    -lpvData -lCom
/usr/bin/g++ -o testprinter  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testprinter.o    -lpvData -lCom
/usr/bin/g++ -o testBitSetUtil  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testBitSetUtil.o    -lpvData -lCom
/usr/bin/g++ -o testIntrospect  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testIntrospect.o    -lpvData -lCom
/usr/bin/g++ -o testPVType  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVType.o    -lpvData -lCom
/usr/bin/g++ -o testStandardField  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testStandardField.o    -lpvData -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DPVD_INTERNAL   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/copy/testCreateRequest.cpp
/usr/bin/g++ -o testStandardPVField  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testStandardPVField.o    -lpvData -lCom
/usr/bin/g++ -o testPVData  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVData.o    -lpvData -lCom
/usr/bin/g++ -o testPVUnion  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVUnion.o    -lpvData -lCom
/usr/bin/g++ -o testConvert  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testConvert.o    -lpvData -lCom
/usr/bin/g++ -o testPVScalarArray  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVScalarArray.o    -lpvData -lCom
/usr/bin/g++ -o testPVStructureArray  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVStructureArray.o    -lpvData -lCom
/usr/bin/g++ -o testOperators  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testOperators.o    -lpvData -lCom
/usr/bin/g++ -o testFieldBuilder  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testFieldBuilder.o    -lpvData -lCom
/usr/bin/g++ -o testValueBuilder  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testValueBuilder.o    -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testThread.t testThread
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testEvent.t testEvent
/usr/bin/g++ -o testProperty  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testProperty.o    -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testTimer.t testTimer
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testBitSet.t testBitSet
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testOverrunBitSet.t testOverrunBitSet
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testByteBuffer.t testByteBuffer
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testBaseException.t testBaseException
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testSharedVector.t testSharedVector
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testDebugPtr.t testDebugPtr
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testSerialization.t testSerialization
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testTimeStamp.t testTimeStamp
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testTypeCast.t testTypeCast
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testUnitTest.t testUnitTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testjson.t testjson
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 test_reftrack.t test_reftrack
/usr/bin/g++ -o testCreateRequest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testCreateRequest.o    -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testanyscalar.t testanyscalar
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testprinter.t testprinter
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testBitSetUtil.t testBitSetUtil
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testIntrospect.t testIntrospect
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVType.t testPVType
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testStandardField.t testStandardField
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testStandardPVField.t testStandardPVField
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVData.t testPVData
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVUnion.t testPVUnion
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testConvert.t testConvert
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVScalarArray.t testPVScalarArray
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVStructureArray.t testPVStructureArray
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testFieldBuilder.t testFieldBuilder
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testOperators.t testOperators
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testValueBuilder.t testValueBuilder
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testProperty.t testProperty
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testCreateRequest.t testCreateRequest
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/testApp/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData/testApp'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvData'
/Jenkins/jenkins/bin/make -C ./database install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database'
/Jenkins/jenkins/bin/make -C ./src install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src'
/Jenkins/jenkins/bin/make -C ./tools install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/tools'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../../../../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../../.. \
    T_A=linux-x86_64 install
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/tools/O.linux-x86_64'
Installing PERL_MODULES file ../../../../../lib/perl/DBD.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Base.pm
mkdir ../../../../../lib/perl/DBD
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Breaktable.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Device.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Driver.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Link.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Function.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Menu.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Output.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Parser.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Recfield.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Recordtype.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Record.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Registrar.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Variable.pm
Installing PERL_MODULES file ../../../../../lib/perl/EPICS/IOC.pm
Expanding ../epics-base.pc@ to epics-base.pc
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -a linux-x86_64 -DFINAL_LOCATION="/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64" -DOS_CLASS="Linux" -DCMPLR_CLASS="gcc" -DC_CFLAGS="-D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -mtune=generic -m64" -DLDFLAGS="-rdynamic -m64" -DLDLIBS="-lpthread -lreadline -lm -lrt -ldl -lgcc" -DEPICS_VERSION="7" -DEPICS_REVISION="0" -DEPICS_MODIFICATION="6" -DEPICS_PATCH_LEVEL="1" -DCC="/usr/bin/gcc" -DCCC="/usr/bin/g++" -DCPP="/usr/bin/gcc -x c -E" -DAR="/usr/bin/ar -rc" -DLD="/usr/bin/ld -r" -DEPICS_BASE_HOST_LIBS="ca Com" -DEPICS_BASE_IOC_LIBS="dbRecStd dbCore ca Com" -t ../../../../..    ../epics-base.pc@ epics-base.pc
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podToHtml.pl -s -o IOC.html ../EPICS/IOC.pm
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podToHtml.pl -s -o dbdToHtml.html ../dbdToHtml.pl
Installing script ../../../../../bin/linux-x86_64/makeIncludeDbd.pl
Installing script ../../../../../bin/linux-x86_64/dbdToMenuH.pl
Installing script ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl
Installing script ../../../../../bin/linux-x86_64/dbdExpand.pl
Installing script ../../../../../bin/linux-x86_64/dbExpand.pl
Installing script ../../../../../bin/linux-x86_64/dbdToHtml.pl
Installing script ../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl
Expanding epics-base-linux-x86_64.pc@ to epics-base-linux-x86_64.pc
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -a linux-x86_64 -DFINAL_LOCATION="/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64" -DOS_CLASS="Linux" -DCMPLR_CLASS="gcc" -DC_CFLAGS="-D_GNU_SOURCE -D_DEFAULT_SOURCE -D_X86_64_ -DUNIX -Dlinux -mtune=generic -m64" -DLDFLAGS="-rdynamic -m64" -DLDLIBS="-lpthread -lreadline -lm -lrt -ldl -lgcc" -DEPICS_VERSION="7" -DEPICS_REVISION="0" -DEPICS_MODIFICATION="6" -DEPICS_PATCH_LEVEL="1" -DCC="/usr/bin/gcc" -DCCC="/usr/bin/g++" -DCPP="/usr/bin/gcc -x c -E" -DAR="/usr/bin/ar -rc" -DLD="/usr/bin/ld -r" -DEPICS_BASE_HOST_LIBS="ca Com" -DEPICS_BASE_IOC_LIBS="dbRecStd dbCore ca Com" -t ../../../../..    epics-base-linux-x86_64.pc@ epics-base-linux-x86_64.pc
Installing PKGCONFIG file ../../../../../lib/pkgconfig/epics-base.pc
mkdir ../../../../../lib/pkgconfig
Installing generated html ../../../../../html/./EPICS/IOC.html
Installing generated html ../../../../../html/./dbdToHtml.html
Installing PKGCONFIG file ../../../../../lib/pkgconfig/epics-base-linux-x86_64.pc
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/tools/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/tools'
/Jenkins/jenkins/bin/make -C ./template install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/template'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/template/O.linux-x86_64'
Installing ../../../../../templates/makeBaseApp/top/iocApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp
Installing ../../../../../templates/makeBaseApp/top/iocApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp/Db
Installing ../../../../../templates/makeBaseApp/top/iocApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp/src
Installing ../../../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp
Installing ../../../../../templates/makeBaseApp/top/supportApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp
Installing ../../../../../templates/makeBaseApp/top/supportApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp/Db
Installing ../../../../../templates/makeBaseApp/top/supportApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp/src
Installing ../../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp/Db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/circle.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/_APPNAME_Version.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp/src
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dev_APPNAME_Version.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dev_APPNAME_Version.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleBoot
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common
mkdir ../../../../../templates/makeBaseApp/top/exampleBoot/ioc
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@windows
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@cygwin
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocBoot
Installing ../../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common
mkdir ../../../../../templates/makeBaseApp/top/iocBoot/ioc
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@windows
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@cygwin
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/template/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/template'
/Jenkins/jenkins/bin/make -C ./ioc install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/ioc'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/ioc/O.linux-x86_64'
Expanding ../databaseVersion.h@ to ../O.Common/databaseVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../..   -DEPICS_DATABASE_MAJOR_VERSION="3"  -DEPICS_DATABASE_MINOR_VERSION="20"  -DEPICS_DATABASE_MAINTENANCE_VERSION="1"  -DEPICS_DATABASE_DEVELOPMENT_FLAG="1"  ../databaseVersion.h@ databaseVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuConvert.dbd ../bpt/menuConvert.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuAlarmSevr.dbd ../db/menuAlarmSevr.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuAlarmStat.dbd ../db/menuAlarmStat.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuFtype.dbd ../db/menuFtype.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuIvoa.dbd ../db/menuIvoa.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuOmsl.dbd ../db/menuOmsl.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuPini.dbd ../db/menuPini.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuPost.dbd ../db/menuPost.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuPriority.dbd ../db/menuPriority.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuYesNo.dbd ../db/menuYesNo.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuSimm.dbd ../db/menuSimm.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o menuScan.dbd ../db/menuScan.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o dbCommonRecord.dbd ../db/dbCommonRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeAPIheader.pl -o ../O.Common/dbCoreAPI.h dbCore
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/genVersionHeader.pl   -t ../../../../.. -N EPICS_VCS_VERSION -V "" ../O.Common/epicsVCS.h
Creating VCS header ../O.Common/epicsVCS.h
    EPICS_VCS_VERSION = "R7.0.6-31-g8e2f78caf529dfe60faa-dirty"
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/e_flex -S../../../../../include/flex.skel.static -8 -I -odbLoadTemplate_lex.c ../dbtemplate/dbLoadTemplate_lex.l
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/e_flex -S../../../../../include/flex.skel.static -8 -I -odbLex.c ../dbStatic/dbLex.l
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuConvert.h ../O.Common/menuConvert.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmSevr.h ../O.Common/menuAlarmSevr.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmStat.h ../O.Common/menuAlarmStat.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuFtype.h ../O.Common/menuFtype.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuIvoa.h ../O.Common/menuIvoa.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuOmsl.h ../O.Common/menuOmsl.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPini.h ../O.Common/menuPini.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPost.h ../O.Common/menuPost.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPriority.h ../O.Common/menuPriority.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuYesNo.h ../O.Common/menuYesNo.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuSimm.h ../O.Common/menuSimm.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuScan.h ../O.Common/menuScan.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl -I ../db  -I ../O.Common -o dbCommon.h ../O.Common/dbCommonRecord.dbd
Installing generated generic include file ../../../../../include/dbCoreAPI.h
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -bdbLoadTemplate  ../dbtemplate/dbLoadTemplate.y
mv dbLoadTemplate.tab.c dbLoadTemplate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbStaticIocRegister.d  ../dbStatic/dbStaticIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbStaticRun.d  ../dbStatic/dbStaticRun.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbPvdLib.d  ../dbStatic/dbPvdLib.c
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -bdbYacc  ../dbStatic/dbYacc.y
mv dbYacc.tab.c dbYacc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbStaticLib.d  ../dbStatic/dbStaticLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbServer.d  ../db/dbServer.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbUnitTest.d  ../db/dbUnitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbState.d  ../db/dbState.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF chfPlugin.d  ../db/chfPlugin.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbIocRegister.d  ../db/dbIocRegister.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbContextReadNotifyCache.d  ../db/dbContextReadNotifyCache.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbPutNotifyBlocker.d  ../db/dbPutNotifyBlocker.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbSubscriptionIO.d  ../db/dbSubscriptionIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbChannelIO.d  ../db/dbChannelIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbContext.d  ../db/dbContext.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cvtBpt.d  ../db/cvtBpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbCaTest.d  ../db/dbCaTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbCa.d  ../db/dbCa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF callback.d  ../db/callback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF recGbl.d  ../db/recGbl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF db_test.d  ../db/db_test.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF db_access.d  ../db/db_access.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbTest.d  ../db/dbTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbEvent.d  ../db/dbEvent.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbScan.d  ../db/dbScan.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbNotify.d  ../db/dbNotify.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbLink.d  ../db/dbLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbExtractArray.d  ../db/dbExtractArray.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbJLink.d  ../db/dbJLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbFastLinkConv.d  ../db/dbFastLinkConv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbDbLink.d  ../db/dbDbLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbConvertJSON.d  ../db/dbConvertJSON.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbConvert.d  ../db/dbConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbConstLink.d  ../db/dbConstLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbChannel.d  ../db/dbChannel.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbBkpt.d  ../db/dbBkpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF asIocRegister.d  ../as/asIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbLock.d  ../db/dbLock.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbAccess.d  ../db/dbAccess.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF asCa.d  ../as/asCa.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF msi.d  ../dbtemplate/msi.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF asDbLib.d  ../as/asDbLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF makeBpt.d  ../bpt/makeBpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF ascheck.d  ../as/ascheck.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF rsrvIocRegister.d  ../rsrv/rsrvIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF cast_server.d  ../rsrv/cast_server.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF online_notify.d  ../rsrv/online_notify.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF camsgtask.d  ../rsrv/camsgtask.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include    -I/ca/client     -MM -MF camessage.d  ../rsrv/camessage.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF caservertask.d  ../rsrv/caservertask.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF registryIocRegister.d  ../registry/registryIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF registryFunction.d  ../registry/registryFunction.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF registryCommon.d  ../registry/registryCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include    -I/ca/client     -MM -MF caserverio.d  ../rsrv/caserverio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF registryDriverSupport.d  ../registry/registryDriverSupport.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF registryDeviceSupport.d  ../registry/registryDeviceSupport.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF registryJLinks.d  ../registry/registryJLinks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF registryRecordType.d  ../registry/registryRecordType.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dlload.d  ../misc/dlload.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF miscIocRegister.d  ../misc/miscIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF iocshRegisterCommon.d  ../misc/iocshRegisterCommon.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF registerAllRecordDeviceDrivers.d  ../misc/registerAllRecordDeviceDrivers.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF epicsRelease.d  ../misc/epicsRelease.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbtoolsIocRegister.d  ../dbtemplate/dbtoolsIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF iocInit.d  ../misc/iocInit.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbLoadTemplate.d  dbLoadTemplate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbYacc.d  dbYacc.c
Keeping VCS header ../O.Common/epicsVCS.h
Installing generic include file ../../../../../include/asCa.h
Installing generic include file ../../../../../include/asDbLib.h
Installing generic include file ../../../../../include/asIocRegister.h
Installing generic include file ../../../../../include/callback.h
Installing generic include file ../../../../../include/cvtTable.h
Installing generic include file ../../../../../include/dbAccess.h
Installing generic include file ../../../../../include/dbAccessDefs.h
Installing generic include file ../../../../../include/dbAddr.h
Installing generic include file ../../../../../include/dbBkpt.h
Installing generic include file ../../../../../include/dbCa.h
Installing generic include file ../../../../../include/dbChannel.h
Installing generic include file ../../../../../include/dbConstLink.h
Installing generic include file ../../../../../include/dbConvert.h
Installing generic include file ../../../../../include/dbConvertFast.h
Installing generic include file ../../../../../include/dbConvertJSON.h
Installing generic include file ../../../../../include/dbDbLink.h
Installing generic include file ../../../../../include/dbExtractArray.h
Installing generic include file ../../../../../include/dbEvent.h
Installing generic include file ../../../../../include/dbJLink.h
Installing generic include file ../../../../../include/dbLink.h
Installing generic include file ../../../../../include/dbLock.h
Installing generic include file ../../../../../include/dbNotify.h
Installing generic include file ../../../../../include/dbScan.h
Installing generic include file ../../../../../include/dbServer.h
Installing generic include file ../../../../../include/dbTest.h
Installing generic include file ../../../../../include/dbCaTest.h
Installing generic include file ../../../../../include/db_test.h
Installing generic include file ../../../../../include/db_field_log.h
Installing generic include file ../../../../../include/recGbl.h
Installing generic include file ../../../../../include/dbIocRegister.h
Installing generic include file ../../../../../include/chfPlugin.h
Installing generic include file ../../../../../include/dbState.h
Installing generic include file ../../../../../include/db_access_routines.h
Installing generic include file ../../../../../include/db_convert.h
Installing generic include file ../../../../../include/dbUnitTest.h
Installing generic include file ../../../../../include/dbBase.h
Installing generic include file ../../../../../include/dbFldTypes.h
Installing generic include file ../../../../../include/dbStaticLib.h
Installing generic include file ../../../../../include/dbStaticPvt.h
Installing generic include file ../../../../../include/link.h
Installing generic include file ../../../../../include/special.h
Installing generic include file ../../../../../include/guigroup.h
Installing generic include file ../../../../../include/devSup.h
Installing generic include file ../../../../../include/drvSup.h
Installing generic include file ../../../../../include/recSup.h
Installing generic include file ../../../../../include/dbStaticIocRegister.h
Installing generic include file ../../../../../include/dbLoadTemplate.h
Installing generic include file ../../../../../include/dbtoolsIocRegister.h
Installing generic include file ../../../../../include/epicsRelease.h
Installing generic include file ../../../../../include/iocInit.h
Installing generic include file ../../../../../include/miscIocRegister.h
Installing generic include file ../../../../../include/iocshRegisterCommon.h
Installing generic include file ../../../../../include/registryRecordType.h
Installing generic include file ../../../../../include/registryDeviceSupport.h
Installing generic include file ../../../../../include/registryDriverSupport.h
Installing generic include file ../../../../../include/registryJLinks.h
Installing generic include file ../../../../../include/registryFunction.h
Installing generic include file ../../../../../include/registryCommon.h
Installing generic include file ../../../../../include/registryIocRegister.h
Installing generic include file ../../../../../include/rsrv.h
Installing generated generic include file ../../../../../include/menuConvert.h
Installing generated generic include file ../../../../../include/menuAlarmSevr.h
Installing generated generic include file ../../../../../include/menuAlarmStat.h
Installing generated generic include file ../../../../../include/menuFtype.h
Installing generated generic include file ../../../../../include/menuIvoa.h
Installing generated generic include file ../../../../../include/menuOmsl.h
Installing generated generic include file ../../../../../include/menuPini.h
Installing generated generic include file ../../../../../include/menuPost.h
Installing generated generic include file ../../../../../include/menuPriority.h
Installing generated generic include file ../../../../../include/menuYesNo.h
Installing generated generic include file ../../../../../include/menuSimm.h
Installing generated generic include file ../../../../../include/menuScan.h
Installing generated generic include file ../../../../../include/dbCommon.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o dbCommon.dbd ../db/dbCommon.dbd.pod
Creating dbd file menuGlobal.dbd
perl -CSD ../../../../../bin/linux-x86_64/makeIncludeDbd.pl menuAlarmSevr.dbd menuAlarmStat.dbd menuFtype.dbd menuIvoa.dbd menuOmsl.dbd menuPini.dbd menuPost.dbd menuPriority.dbd menuYesNo.dbd menuSimm.dbd menuGlobal.dbd
Installing dbd file ../../../../../dbd/system.dbd
mkdir ../../../../../dbd
Installing dbd file ../../../../../dbd/dlload.dbd
Installing dbd file ../../../../../dbd/rsrv.dbd
Installing dbd file ../../../../../dbd/dbCore.dbd
Installing created dbd file ../../../../../dbd/menuConvert.dbd
Installing created dbd file ../../../../../dbd/menuAlarmSevr.dbd
Installing created dbd file ../../../../../dbd/menuAlarmStat.dbd
Installing created dbd file ../../../../../dbd/menuFtype.dbd
Installing created dbd file ../../../../../dbd/menuIvoa.dbd
Installing created dbd file ../../../../../dbd/menuOmsl.dbd
Installing created dbd file ../../../../../dbd/menuPini.dbd
Installing created dbd file ../../../../../dbd/menuPost.dbd
Installing created dbd file ../../../../../dbd/menuPriority.dbd
Installing created dbd file ../../../../../dbd/menuYesNo.dbd
Installing created dbd file ../../../../../dbd/menuSimm.dbd
Installing created dbd file ../../../../../dbd/menuScan.dbd
Installing created dbd file ../../../../../dbd/dbCommon.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuConvert.html ../bpt/menuConvert.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuFtype.html ../db/menuFtype.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuScan.html ../db/menuScan.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPost.html ../db/menuPost.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuOmsl.html ../db/menuOmsl.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmSevr.html ../db/menuAlarmSevr.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuYesNo.html ../db/menuYesNo.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPini.html ../db/menuPini.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPriority.html ../db/menuPriority.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmStat.html ../db/menuAlarmStat.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuSimm.html ../db/menuSimm.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuIvoa.html ../db/menuIvoa.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o dbCommonRecord.html ../db/dbCommonRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podToHtml.pl -s -s -o dbCommonInput.html ../db/dbCommonInput.pod
Installing html ../../../../../html/./msi.html
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podToHtml.pl -s -s -o dbCommonOutput.html ../db/dbCommonOutput.pod
Installing created dbd file ../../../../../dbd/menuGlobal.dbd
Installing generated html ../../../../../html/./menuConvert.html
Installing generated html ../../../../../html/./menuFtype.html
Installing generated html ../../../../../html/./menuScan.html
Installing generated html ../../../../../html/./menuPost.html
Installing generated html ../../../../../html/./menuOmsl.html
Installing generated html ../../../../../html/./menuAlarmSevr.html
Installing generated html ../../../../../html/./menuYesNo.html
Installing generated html ../../../../../html/./menuPini.html
Installing generated html ../../../../../html/./menuPriority.html
Installing generated html ../../../../../html/./menuAlarmStat.html
Installing generated html ../../../../../html/./menuIvoa.html
Installing generated html ../../../../../html/./menuSimm.html
Installing generated html ../../../../../html/./dbCommonRecord.html
Installing generated html ../../../../../html/./dbCommonInput.html
Installing generated generic include file ../../../../../include/databaseVersion.h
Installing generated html ../../../../../html/./dbCommonOutput.html
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../bpt/makeBpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../as/asDbLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../as/asCa.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../as/asIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbLock.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbAccess.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbBkpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbConstLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbChannel.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbConvertJSON.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbDbLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbExtractArray.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbFastLinkConv.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbJLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbNotify.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbScan.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbEvent.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/db_access.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/db_test.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/recGbl.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/callback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbCaTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/cvtBpt.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbCa.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbChannelIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbContext.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbSubscriptionIO.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbPutNotifyBlocker.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbContextReadNotifyCache.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbState.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbServer.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/chfPlugin.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../db/dbUnitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dbStatic/dbPvdLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dbStatic/dbStaticRun.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dbStatic/dbStaticIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c dbYacc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dbStatic/dbStaticLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dbtemplate/dbtoolsIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../misc/epicsRelease.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c dbLoadTemplate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../misc/miscIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../misc/dlload.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../misc/iocInit.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../misc/iocshRegisterCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../registry/registryRecordType.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../registry/registryDeviceSupport.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../registry/registryDriverSupport.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../registry/registryJLinks.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../registry/registryFunction.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../registry/registryCommon.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../registry/registryIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include    -I/ca/client     -c ../rsrv/caserverio.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../misc/registerAllRecordDeviceDrivers.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rsrv/camsgtask.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rsrv/caservertask.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rsrv/cast_server.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include    -I/ca/client     -c ../rsrv/camessage.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rsrv/online_notify.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rsrv/rsrvIocRegister.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../as/ascheck.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dbtemplate/msi.cpp
/usr/bin/ar -rc    libdbCore.a    asDbLib.o asCa.o asIocRegister.o dbLock.o dbAccess.o dbBkpt.o dbChannel.o dbConstLink.o dbConvert.o dbConvertJSON.o dbDbLink.o dbFastLinkConv.o dbExtractArray.o dbJLink.o dbLink.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o dbIocRegister.o chfPlugin.o dbState.o dbUnitTest.o dbServer.o dbStaticLib.o dbYacc.o dbPvdLib.o dbStaticRun.o dbStaticIocRegister.o dbLoadTemplate.o dbtoolsIocRegister.o epicsRelease.o iocInit.o miscIocRegister.o dlload.o iocshRegisterCommon.o registerAllRecordDeviceDrivers.o registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryJLinks.o registryFunction.o registryCommon.o registryIocRegister.o caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o rsrvIocRegister.o
/usr/bin/ranlib libdbCore.a
/usr/bin/g++ -o libdbCore.so.3.20.1 -shared -fPIC -Wl,-hlibdbCore.so.3.20.1 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         asDbLib.o asCa.o asIocRegister.o dbLock.o dbAccess.o dbBkpt.o dbChannel.o dbConstLink.o dbConvert.o dbConvertJSON.o dbDbLink.o dbFastLinkConv.o dbExtractArray.o dbJLink.o dbLink.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o dbIocRegister.o chfPlugin.o dbState.o dbUnitTest.o dbServer.o dbStaticLib.o dbYacc.o dbPvdLib.o dbStaticRun.o dbStaticIocRegister.o dbLoadTemplate.o dbtoolsIocRegister.o epicsRelease.o iocInit.o miscIocRegister.o dlload.o iocshRegisterCommon.o registerAllRecordDeviceDrivers.o registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryJLinks.o registryFunction.o registryCommon.o registryIocRegister.o caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o rsrvIocRegister.o    -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../../../lib/linux-x86_64/libdbCore.so.3.20.1
ln -s libdbCore.so.3.20.1 ../../../../../lib/linux-x86_64/libdbCore.so
Installing library ../../../../../lib/linux-x86_64/libdbCore.a
/usr/bin/g++ -o makeBpt  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         makeBpt.o    -lCom
/usr/bin/g++ -o ascheck  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ascheck.o    -ldbCore -lca -lCom -lCom
/usr/bin/g++ -o msi  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         msi.o    -lCom -lCom
Installing created executable ../../../../../bin/linux-x86_64/ascheck
Installing created executable ../../../../../bin/linux-x86_64/msi
Installing created executable ../../../../../bin/linux-x86_64/makeBpt
../../../../../bin/linux-x86_64/makeBpt ../bpt/bptTypeJdegC.data bptTypeJdegC.dbd
../../../../../bin/linux-x86_64/makeBpt ../bpt/bptTypeJdegF.data bptTypeJdegF.dbd
../../../../../bin/linux-x86_64/makeBpt ../bpt/bptTypeKdegC.data bptTypeKdegC.dbd
../../../../../bin/linux-x86_64/makeBpt ../bpt/bptTypeKdegF.data bptTypeKdegF.dbd
Installing created dbd file ../../../../../dbd/bptTypeJdegC.dbd
Installing created dbd file ../../../../../dbd/bptTypeJdegF.dbd
Installing created dbd file ../../../../../dbd/bptTypeKdegC.dbd
Installing created dbd file ../../../../../dbd/bptTypeKdegF.dbd
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/ioc/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/ioc'
/Jenkins/jenkins/bin/make -C ./std install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/std'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../../../../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../../.. \
    T_A=linux-x86_64 install
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/std/O.linux-x86_64'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o aaiRecord.dbd ../rec/aaiRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o aaoRecord.dbd ../rec/aaoRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o aiRecord.dbd ../rec/aiRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o aoRecord.dbd ../rec/aoRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o aSubRecord.dbd ../rec/aSubRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o biRecord.dbd ../rec/biRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o boRecord.dbd ../rec/boRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o calcRecord.dbd ../rec/calcRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o calcoutRecord.dbd ../rec/calcoutRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o compressRecord.dbd ../rec/compressRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o dfanoutRecord.dbd ../rec/dfanoutRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o eventRecord.dbd ../rec/eventRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o fanoutRecord.dbd ../rec/fanoutRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o histogramRecord.dbd ../rec/histogramRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o int64inRecord.dbd ../rec/int64inRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o int64outRecord.dbd ../rec/int64outRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o longinRecord.dbd ../rec/longinRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o longoutRecord.dbd ../rec/longoutRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o lsiRecord.dbd ../rec/lsiRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o lsoRecord.dbd ../rec/lsoRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o mbbiRecord.dbd ../rec/mbbiRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o mbbiDirectRecord.dbd ../rec/mbbiDirectRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o mbboRecord.dbd ../rec/mbboRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o mbboDirectRecord.dbd ../rec/mbboDirectRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o permissiveRecord.dbd ../rec/permissiveRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o printfRecord.dbd ../rec/printfRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o selRecord.dbd ../rec/selRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o seqRecord.dbd ../rec/seqRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o stateRecord.dbd ../rec/stateRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o stringinRecord.dbd ../rec/stringinRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o stringoutRecord.dbd ../rec/stringoutRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o subRecord.dbd ../rec/subRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o subArrayRecord.dbd ../rec/subArrayRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o waveformRecord.dbd ../rec/waveformRecord.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeAPIheader.pl -o ../O.Common/dbRecStdAPI.h dbRecStd
FINAL_LOCATION=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
perl -CSD ../softIoc/makeInstallDir.pl "/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64" > epicsInstallDir.h
Creating dbd file stdRecords.dbd
perl -CSD ../../../../../bin/linux-x86_64/makeIncludeDbd.pl aaiRecord.dbd aaoRecord.dbd aiRecord.dbd aoRecord.dbd aSubRecord.dbd biRecord.dbd boRecord.dbd calcRecord.dbd calcoutRecord.dbd compressRecord.dbd dfanoutRecord.dbd eventRecord.dbd fanoutRecord.dbd histogramRecord.dbd int64inRecord.dbd int64outRecord.dbd longinRecord.dbd longoutRecord.dbd lsiRecord.dbd lsoRecord.dbd mbbiRecord.dbd mbbiDirectRecord.dbd mbboRecord.dbd mbboDirectRecord.dbd permissiveRecord.dbd printfRecord.dbd selRecord.dbd seqRecord.dbd stateRecord.dbd stringinRecord.dbd stringoutRecord.dbd subRecord.dbd subArrayRecord.dbd waveformRecord.dbd stdRecords.dbd
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o filters.dbd ../filters/filters.dbd.pod
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/podRemove.pl -o links.dbd ../link/links.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aaiRecord.h ../O.Common/aaiRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aaoRecord.h ../O.Common/aaoRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aiRecord.h ../O.Common/aiRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aoRecord.h ../O.Common/aoRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aSubRecord.h ../O.Common/aSubRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o biRecord.h ../O.Common/biRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o boRecord.h ../O.Common/boRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o calcRecord.h ../O.Common/calcRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o calcoutRecord.h ../O.Common/calcoutRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o compressRecord.h ../O.Common/compressRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o dfanoutRecord.h ../O.Common/dfanoutRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o eventRecord.h ../O.Common/eventRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o fanoutRecord.h ../O.Common/fanoutRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o histogramRecord.h ../O.Common/histogramRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o int64inRecord.h ../O.Common/int64inRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o int64outRecord.h ../O.Common/int64outRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o longinRecord.h ../O.Common/longinRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o longoutRecord.h ../O.Common/longoutRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o lsiRecord.h ../O.Common/lsiRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o lsoRecord.h ../O.Common/lsoRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbbiRecord.h ../O.Common/mbbiRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbbiDirectRecord.h ../O.Common/mbbiDirectRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbboRecord.h ../O.Common/mbboRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbboDirectRecord.h ../O.Common/mbboDirectRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o permissiveRecord.h ../O.Common/permissiveRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o printfRecord.h ../O.Common/printfRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o selRecord.h ../O.Common/selRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o seqRecord.h ../O.Common/seqRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stateRecord.h ../O.Common/stateRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stringinRecord.h ../O.Common/stringinRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stringoutRecord.h ../O.Common/stringoutRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o subRecord.h ../O.Common/subRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o subArrayRecord.h ../O.Common/subArrayRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o waveformRecord.h ../O.Common/waveformRecord.dbd
Installing generated generic include file ../../../../../include/dbRecStdAPI.h
Creating dbd file softIoc.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o softIoc.dbd base.dbd dlload.dbd system.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF lnkDebug.d  ../link/lnkDebug.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF lnkState.d  ../link/lnkState.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF lnkCalc.d  ../link/lnkCalc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF lnkConst.d  ../link/lnkConst.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF utag.d  ../filters/utag.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF decimate.d  ../filters/decimate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF sync.d  ../filters/sync.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dbnd.d  ../filters/dbnd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF arr.d  ../filters/arr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF ts.d  ../filters/ts.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF asSubRecordFunctions.d  ../dev/asSubRecordFunctions.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devEnviron.d  ../dev/devEnviron.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devStdio.d  ../dev/devStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devTimestamp.d  ../dev/devTimestamp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devGeneralTime.d  ../dev/devGeneralTime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devSoSoftCallback.d  ../dev/devSoSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devPrintfSoftCallback.d  ../dev/devPrintfSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbboDirectSoftCallback.d  ../dev/devMbboDirectSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbboSoftCallback.d  ../dev/devMbboSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devLsoSoftCallback.d  ../dev/devLsoSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devLoSoftCallback.d  ../dev/devLoSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devI64outSoftCallback.d  ../dev/devI64outSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devCalcoutSoftCallback.d  ../dev/devCalcoutSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devBoSoftCallback.d  ../dev/devBoSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devAoSoftCallback.d  ../dev/devAoSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbbiSoftCallback.d  ../dev/devMbbiSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devSiSoftCallback.d  ../dev/devSiSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbbiDirectSoftCallback.d  ../dev/devMbbiDirectSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devLiSoftCallback.d  ../dev/devLiSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devI64inSoftCallback.d  ../dev/devI64inSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devBiSoftCallback.d  ../dev/devBiSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devAiSoftCallback.d  ../dev/devAiSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devWfSoft.d  ../dev/devWfSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devSoSoft.d  ../dev/devSoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devSiSoft.d  ../dev/devSiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devSASoft.d  ../dev/devSASoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devPrintfSoft.d  ../dev/devPrintfSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbboSoftRaw.d  ../dev/devMbboSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbboSoft.d  ../dev/devMbboSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbboDirectSoftRaw.d  ../dev/devMbboDirectSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbboDirectSoft.d  ../dev/devMbboDirectSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbbiSoftRaw.d  ../dev/devMbbiSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbbiSoft.d  ../dev/devMbbiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbbiDirectSoftRaw.d  ../dev/devMbbiDirectSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devMbbiDirectSoft.d  ../dev/devMbbiDirectSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devLsoSoft.d  ../dev/devLsoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devLsiSoft.d  ../dev/devLsiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devLoSoft.d  ../dev/devLoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devLiSoft.d  ../dev/devLiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devI64outSoft.d  ../dev/devI64outSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devI64inSoft.d  ../dev/devI64inSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devHistogramSoft.d  ../dev/devHistogramSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devEventSoft.d  ../dev/devEventSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devBoDbState.d  ../dev/devBoDbState.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devCalcoutSoft.d  ../dev/devCalcoutSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devBoSoftRaw.d  ../dev/devBoSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devBoSoft.d  ../dev/devBoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devBiDbState.d  ../dev/devBiDbState.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devBiSoftRaw.d  ../dev/devBiSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devBiSoft.d  ../dev/devBiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devAoSoftRaw.d  ../dev/devAoSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devAoSoft.d  ../dev/devAoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devAiSoftRaw.d  ../dev/devAiSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devAiSoft.d  ../dev/devAiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devAaoSoft.d  ../dev/devAaoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF devAaiSoft.d  ../dev/devAaiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF waveformRecord.d  ../rec/waveformRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF subArrayRecord.d  ../rec/subArrayRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF subRecord.d  ../rec/subRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF stringoutRecord.d  ../rec/stringoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF stringinRecord.d  ../rec/stringinRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF stateRecord.d  ../rec/stateRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF seqRecord.d  ../rec/seqRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF selRecord.d  ../rec/selRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF printfRecord.d  ../rec/printfRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF permissiveRecord.d  ../rec/permissiveRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF mbboDirectRecord.d  ../rec/mbboDirectRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF mbboRecord.d  ../rec/mbboRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF mbbiDirectRecord.d  ../rec/mbbiDirectRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF mbbiRecord.d  ../rec/mbbiRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF lsoRecord.d  ../rec/lsoRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF lsiRecord.d  ../rec/lsiRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF longoutRecord.d  ../rec/longoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF longinRecord.d  ../rec/longinRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF int64outRecord.d  ../rec/int64outRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF int64inRecord.d  ../rec/int64inRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF fanoutRecord.d  ../rec/fanoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF histogramRecord.d  ../rec/histogramRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF eventRecord.d  ../rec/eventRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF compressRecord.d  ../rec/compressRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF dfanoutRecord.d  ../rec/dfanoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF calcoutRecord.d  ../rec/calcoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF calcRecord.d  ../rec/calcRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF boRecord.d  ../rec/boRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF biRecord.d  ../rec/biRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF aSubRecord.d  ../rec/aSubRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF aoRecord.d  ../rec/aoRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF aiRecord.d  ../rec/aiRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF aaoRecord.d  ../rec/aaoRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF aaiRecord.d  ../rec/aaiRecord.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF softMain.d  ../softIoc/softMain.cpp
perl -CSD ../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd    -o softIoc_registerRecordDeviceDriver.cpp ../O.Common/softIoc.dbd softIoc_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -MM -MF softIoc_registerRecordDeviceDriver.d  softIoc_registerRecordDeviceDriver.cpp
Installing generated generic include file ../../../../../include/aaiRecord.h
Installing generated generic include file ../../../../../include/aaoRecord.h
Installing ../../../../../db/softIocExit.db
mkdir ../../../../../db
Installing generated generic include file ../../../../../include/aoRecord.h
Installing generated generic include file ../../../../../include/aiRecord.h
Installing generated generic include file ../../../../../include/aSubRecord.h
Installing generated generic include file ../../../../../include/boRecord.h
Installing generated generic include file ../../../../../include/biRecord.h
Installing generated generic include file ../../../../../include/calcRecord.h
Installing generated generic include file ../../../../../include/calcoutRecord.h
Installing generated generic include file ../../../../../include/compressRecord.h
Installing generated generic include file ../../../../../include/dfanoutRecord.h
Installing generated generic include file ../../../../../include/fanoutRecord.h
Installing generated generic include file ../../../../../include/eventRecord.h
Installing generated generic include file ../../../../../include/histogramRecord.h
Installing generated generic include file ../../../../../include/int64inRecord.h
Installing generated generic include file ../../../../../include/int64outRecord.h
Installing generated generic include file ../../../../../include/longinRecord.h
Installing generated generic include file ../../../../../include/longoutRecord.h
Installing generated generic include file ../../../../../include/lsiRecord.h
Installing generated generic include file ../../../../../include/lsoRecord.h
Installing generated generic include file ../../../../../include/mbbiRecord.h
Installing generated generic include file ../../../../../include/mbbiDirectRecord.h
Installing generated generic include file ../../../../../include/mbboRecord.h
Installing generated generic include file ../../../../../include/mbboDirectRecord.h
Installing generated generic include file ../../../../../include/permissiveRecord.h
Installing generated generic include file ../../../../../include/printfRecord.h
Installing generated generic include file ../../../../../include/selRecord.h
Installing generated generic include file ../../../../../include/seqRecord.h
Installing generated generic include file ../../../../../include/stateRecord.h
Installing generated generic include file ../../../../../include/stringinRecord.h
Installing generated generic include file ../../../../../include/stringoutRecord.h
Installing generated generic include file ../../../../../include/subRecord.h
Installing generated generic include file ../../../../../include/subArrayRecord.h
Installing generated generic include file ../../../../../include/waveformRecord.h
Installing created dbd file ../../../../../dbd/stdRecords.dbd
Installing created dbd file ../../../../../dbd/filters.dbd
Installing dbd file ../../../../../dbd/devSoft.dbd
Installing created dbd file ../../../../../dbd/links.dbd
Installing dbd file ../../../../../dbd/base.dbd
Installing dbd file ../../../../../dbd/asSub.dbd
Installing created dbd file ../../../../../dbd/softIoc.dbd
Installing created dbd file ../../../../../dbd/aaoRecord.dbd
Installing created dbd file ../../../../../dbd/aaiRecord.dbd
Installing created dbd file ../../../../../dbd/aiRecord.dbd
Installing created dbd file ../../../../../dbd/aoRecord.dbd
Installing created dbd file ../../../../../dbd/aSubRecord.dbd
Installing created dbd file ../../../../../dbd/biRecord.dbd
Installing created dbd file ../../../../../dbd/boRecord.dbd
Installing created dbd file ../../../../../dbd/calcRecord.dbd
Installing created dbd file ../../../../../dbd/calcoutRecord.dbd
Installing created dbd file ../../../../../dbd/compressRecord.dbd
Installing created dbd file ../../../../../dbd/dfanoutRecord.dbd
Installing created dbd file ../../../../../dbd/fanoutRecord.dbd
Installing created dbd file ../../../../../dbd/histogramRecord.dbd
Installing created dbd file ../../../../../dbd/eventRecord.dbd
Installing created dbd file ../../../../../dbd/int64inRecord.dbd
Installing created dbd file ../../../../../dbd/int64outRecord.dbd
Installing created dbd file ../../../../../dbd/longinRecord.dbd
Installing created dbd file ../../../../../dbd/longoutRecord.dbd
Installing created dbd file ../../../../../dbd/lsiRecord.dbd
Installing created dbd file ../../../../../dbd/lsoRecord.dbd
Installing created dbd file ../../../../../dbd/mbbiRecord.dbd
Installing created dbd file ../../../../../dbd/mbbiDirectRecord.dbd
Installing created dbd file ../../../../../dbd/mbboDirectRecord.dbd
Installing created dbd file ../../../../../dbd/mbboRecord.dbd
Installing created dbd file ../../../../../dbd/permissiveRecord.dbd
Installing created dbd file ../../../../../dbd/printfRecord.dbd
Installing created dbd file ../../../../../dbd/selRecord.dbd
Installing created dbd file ../../../../../dbd/seqRecord.dbd
Installing created dbd file ../../../../../dbd/stateRecord.dbd
Installing created dbd file ../../../../../dbd/stringinRecord.dbd
Installing created dbd file ../../../../../dbd/stringoutRecord.dbd
Installing created dbd file ../../../../../dbd/subRecord.dbd
Installing created dbd file ../../../../../dbd/subArrayRecord.dbd
Installing created dbd file ../../../../../dbd/waveformRecord.dbd
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o calcoutRecord.html ../rec/calcoutRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aiRecord.html ../rec/aiRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o waveformRecord.html ../rec/waveformRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o lsoRecord.html ../rec/lsoRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o subRecord.html ../rec/subRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbboDirectRecord.html ../rec/mbboDirectRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o selRecord.html ../rec/selRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o subArrayRecord.html ../rec/subArrayRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o lsiRecord.html ../rec/lsiRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o longoutRecord.html ../rec/longoutRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stringinRecord.html ../rec/stringinRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aaoRecord.html ../rec/aaoRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o compressRecord.html ../rec/compressRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o int64inRecord.html ../rec/int64inRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stringoutRecord.html ../rec/stringoutRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stateRecord.html ../rec/stateRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o printfRecord.html ../rec/printfRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o seqRecord.html ../rec/seqRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aaiRecord.html ../rec/aaiRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o biRecord.html ../rec/biRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbbiRecord.html ../rec/mbbiRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o boRecord.html ../rec/boRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbbiDirectRecord.html ../rec/mbbiDirectRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o dfanoutRecord.html ../rec/dfanoutRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbboRecord.html ../rec/mbboRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o permissiveRecord.html ../rec/permissiveRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aSubRecord.html ../rec/aSubRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o int64outRecord.html ../rec/int64outRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aoRecord.html ../rec/aoRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o calcRecord.html ../rec/calcRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o longinRecord.html ../rec/longinRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o eventRecord.html ../rec/eventRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o fanoutRecord.html ../rec/fanoutRecord.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o histogramRecord.html ../rec/histogramRecord.dbd.pod
Installing html ../../../../../html/./image/compress-1.png
mkdir ../../../../../html/./image
Installing html ../../../../../html/./image/compress-2.png
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o filters.html ../filters/filters.dbd.pod
perl -CSD ../../../../../bin/linux-x86_64/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o links.html ../link/links.dbd.pod
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/aaiRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/aaoRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/aiRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/biRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/aoRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/boRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/calcRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/aSubRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/calcoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/compressRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/dfanoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/eventRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/fanoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/histogramRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/int64inRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/int64outRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/longinRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/longoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/lsiRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/lsoRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/mbbiRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/mbbiDirectRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/mbboRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/permissiveRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/mbboDirectRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/printfRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/stateRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/selRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/seqRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/stringinRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/stringoutRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/subArrayRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/subRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devAaiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../rec/waveformRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devAaoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devAiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devAiSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devAoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devAoSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devBiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devBiSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devBiDbState.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devBoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devBoSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devBoDbState.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devCalcoutSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devEventSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devHistogramSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devI64inSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devI64outSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devLiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devLoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devLsiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devLsoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbbiDirectSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbbiDirectSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbbiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbbiSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbboDirectSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbboDirectSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbboSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbboSoftRaw.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devPrintfSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devSASoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devSiSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devSoSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devWfSoft.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devAiSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devBiSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devI64inSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devLiSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbbiDirectSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbbiSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devSiSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devAoSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devBoSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devCalcoutSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devI64outSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devLoSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devLsoSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbboSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devMbboDirectSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devPrintfSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devSoSoftCallback.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devGeneralTime.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devTimestamp.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devStdio.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/devEnviron.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../dev/asSubRecordFunctions.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../filters/ts.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../filters/dbnd.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../filters/arr.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../filters/sync.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../filters/decimate.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../filters/utag.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../link/lnkConst.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../link/lnkCalc.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../link/lnkState.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../link/lnkDebug.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c softIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/gcc -I../../../../../include/os/Linux -I../../../../../include         -c ../softIoc/softMain.cpp
Installing generated html ../../../../../html/./calcoutRecord.html
Installing generated html ../../../../../html/./aiRecord.html
Installing generated html ../../../../../html/./waveformRecord.html
Installing generated html ../../../../../html/./lsoRecord.html
Installing generated html ../../../../../html/./subRecord.html
Installing generated html ../../../../../html/./mbboDirectRecord.html
Installing generated html ../../../../../html/./selRecord.html
Installing generated html ../../../../../html/./subArrayRecord.html
Installing generated html ../../../../../html/./lsiRecord.html
Installing generated html ../../../../../html/./longoutRecord.html
Installing generated html ../../../../../html/./aaoRecord.html
Installing generated html ../../../../../html/./stringinRecord.html
Installing generated html ../../../../../html/./compressRecord.html
Installing generated html ../../../../../html/./int64inRecord.html
Installing generated html ../../../../../html/./stringoutRecord.html
Installing generated html ../../../../../html/./stateRecord.html
Installing generated html ../../../../../html/./seqRecord.html
Installing generated html ../../../../../html/./printfRecord.html
Installing generated html ../../../../../html/./aaiRecord.html
Installing generated html ../../../../../html/./biRecord.html
Installing generated html ../../../../../html/./mbbiRecord.html
Installing generated html ../../../../../html/./boRecord.html
Installing generated html ../../../../../html/./mbbiDirectRecord.html
Installing generated html ../../../../../html/./dfanoutRecord.html
Installing generated html ../../../../../html/./mbboRecord.html
Installing generated html ../../../../../html/./permissiveRecord.html
Installing generated html ../../../../../html/./aSubRecord.html
Installing generated html ../../../../../html/./int64outRecord.html
Installing generated html ../../../../../html/./aoRecord.html
Installing generated html ../../../../../html/./longinRecord.html
Installing generated html ../../../../../html/./calcRecord.html
Installing generated html ../../../../../html/./eventRecord.html
Installing generated html ../../../../../html/./fanoutRecord.html
Installing generated html ../../../../../html/./histogramRecord.html
Installing generated html ../../../../../html/./filters.html
Installing generated html ../../../../../html/./links.html
/usr/bin/ar -rc    libdbRecStd.a    aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o aSubRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o int64inRecord.o int64outRecord.o longinRecord.o longoutRecord.o lsiRecord.o lsoRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o printfRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o devAaiSoft.o devAaoSoft.o devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBiDbState.o devBoSoft.o devBoSoftRaw.o devBoDbState.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devI64inSoft.o devI64outSoft.o devLiSoft.o devLoSoft.o devLsiSoft.o devLsoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devPrintfSoft.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devAiSoftCallback.o devBiSoftCallback.o devI64inSoftCallback.o devLiSoftCallback.o devMbbiDirectSoftCallback.o devMbbiSoftCallback.o devSiSoftCallback.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devI64outSoftCallback.o devLoSoftCallback.o devLsoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devPrintfSoftCallback.o devSoSoftCallback.o devGeneralTime.o devTimestamp.o devStdio.o devEnviron.o asSubRecordFunctions.o ts.o dbnd.o arr.o sync.o decimate.o utag.o lnkConst.o lnkCalc.o lnkState.o lnkDebug.o
/usr/bin/ranlib libdbRecStd.a
/usr/bin/g++ -o libdbRecStd.so.3.20.1 -shared -fPIC -Wl,-hlibdbRecStd.so.3.20.1 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o aSubRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o int64inRecord.o int64outRecord.o longinRecord.o longoutRecord.o lsiRecord.o lsoRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o printfRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o devAaiSoft.o devAaoSoft.o devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBiDbState.o devBoSoft.o devBoSoftRaw.o devBoDbState.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devI64inSoft.o devI64outSoft.o devLiSoft.o devLoSoft.o devLsiSoft.o devLsoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devPrintfSoft.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devAiSoftCallback.o devBiSoftCallback.o devI64inSoftCallback.o devLiSoftCallback.o devMbbiDirectSoftCallback.o devMbbiSoftCallback.o devSiSoftCallback.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devI64outSoftCallback.o devLoSoftCallback.o devLsoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devPrintfSoftCallback.o devSoSoftCallback.o devGeneralTime.o devTimestamp.o devStdio.o devEnviron.o asSubRecordFunctions.o ts.o dbnd.o arr.o sync.o decimate.o utag.o lnkConst.o lnkCalc.o lnkState.o lnkDebug.o    -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library ../../../../../lib/linux-x86_64/libdbRecStd.so.3.20.1
ln -s libdbRecStd.so.3.20.1 ../../../../../lib/linux-x86_64/libdbRecStd.so
Installing library ../../../../../lib/linux-x86_64/libdbRecStd.a
/usr/bin/g++ -o softIoc  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         softIoc_registerRecordDeviceDriver.o softMain.o    -ldbRecStd -ldbCore -lca -lCom
Installing created executable ../../../../../bin/linux-x86_64/softIoc
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/std/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src/std'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/src'
/Jenkins/jenkins/bin/make -C ./test install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test'
/Jenkins/jenkins/bin/make -C ioc/dbtemplate install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/dbtemplate'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../../../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../../../../../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../../../.. \
    T_A=linux-x86_64 install
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/dbtemplate/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbltExpand.d  ../dbltExpand.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbltExpand.c
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../../.. -a linux-x86_64 ../msi.plt msi.t
/usr/bin/g++ -o dbltExpand  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         dbltExpand.o    -ldbCore -lca -lCom
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/dbtemplate/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/dbtemplate'
/Jenkins/jenkins/bin/make -C std/link install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/link'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/link/O.linux-x86_64'
perl -CSD ../../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o ioRecord.h ../ioRecord.dbd
Creating dbd file linkTest.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o linkTest.dbd menuGlobal.dbd menuConvert.dbd menuScan.dbd links.dbd ioRecord.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF lnkCalcTest.d  ../lnkCalcTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF lnkStateTest.d  ../lnkStateTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF ioRecord.d  ../ioRecord.c
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o linkTest_registerRecordDeviceDriver.cpp ../O.Common/linkTest.dbd linkTest_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF linkTest_registerRecordDeviceDriver.d  linkTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../ioRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../lnkStateTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c linkTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../lnkCalcTest.c
/usr/bin/ar -rc    libRecs.a    ioRecord.o
/usr/bin/ranlib libRecs.a
/usr/bin/g++ -o libRecs.so.7.0.6 -shared -fPIC -Wl,-hlibRecs.so.7.0.6 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ioRecord.o    -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/g++ -o lnkStateTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/link/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/link/O.linux-x86_64           -rdynamic -m64         lnkStateTest.o linkTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o lnkCalcTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/link/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/link/O.linux-x86_64           -rdynamic -m64         lnkCalcTest.o linkTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 lnkStateTest.t lnkStateTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 lnkCalcTest.t lnkCalcTest
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/link/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/link'
/Jenkins/jenkins/bin/make -C std/filters install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64'
perl -CSD ../../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o arrRecord.h ../arrRecord.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o xRecord.h ../xRecord.dbd
Creating dbd file filterTest.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o filterTest.dbd menuGlobal.dbd menuConvert.dbd menuScan.dbd filters.dbd xRecord.dbd arrRecord.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF decTest.d  ../decTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF syncTest.d  ../syncTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF arrTest.d  ../arrTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbndTest.d  ../dbndTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF tsTest.d  ../tsTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF arrRecord.d  ../arrRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF xRecord.d  ../xRecord.c
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o filterTest_registerRecordDeviceDriver.cpp ../O.Common/filterTest.dbd filterTest_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF filterTest_registerRecordDeviceDriver.d  filterTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../xRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../arrRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../tsTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c filterTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbndTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../arrTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../syncTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../decTest.c
/usr/bin/ar -rc    libRecs.a    xRecord.o arrRecord.o
/usr/bin/g++ -o libRecs.so.7.0.6 -shared -fPIC -Wl,-hlibRecs.so.7.0.6 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         xRecord.o arrRecord.o    -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/g++ -o tsTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64           -rdynamic -m64         tsTest.o filterTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o dbndTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64           -rdynamic -m64         dbndTest.o filterTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o arrTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64           -rdynamic -m64         arrTest.o filterTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o syncTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64           -rdynamic -m64         syncTest.o filterTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o decTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64           -rdynamic -m64         decTest.o filterTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 tsTest.t tsTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbndTest.t dbndTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 arrTest.t arrTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 syncTest.t syncTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 decTest.t decTest
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/filters'
/Jenkins/jenkins/bin/make -C ./tools install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/tools'
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../../.. \
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/tools/O.linux-x86_64'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../Base.plt Base.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../Breaktable.plt Breaktable.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../DBD.plt DBD.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../Device.plt Device.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../Driver.plt Driver.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../Function.plt Function.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../Menu.plt Menu.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../Recfield.plt Recfield.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../Recordtype.plt Recordtype.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../Registrar.plt Registrar.t
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../../.. -a linux-x86_64 ../Variable.plt Variable.t
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/tools/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/tools'
/Jenkins/jenkins/bin/make -C ioc/db install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF jlinkz.d  ../jlinkz.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF xLink.d  ../xLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbLinkdset.d  ../dbLinkdset.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF xRecord.d  ../xRecord.c
Creating dbd file dbTestIoc.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o dbTestIoc.dbd menuGlobal.dbd menuConvert.dbd menuScan.dbd xRecord.dbd arrRecord.dbd xLink.dbd devx.dbd jlinkz.dbd dbLinkdset.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbStaticTest.d  ../dbStaticTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbPutGetTest.d  ../dbPutGetTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF recGblCheckDeadbandTest.d  ../recGblCheckDeadbandTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF benchdbConvert.d  ../benchdbConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF arrShorthandTest.d  ../arrShorthandTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF chfPluginTest.d  ../chfPluginTest.c
Creating dbd file dbChArrTest.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o dbChArrTest.dbd arrRecord.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbChArrTest.d  ../dbChArrTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbChannelTest.d  ../dbChannelTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF scanIoTest.d  ../scanIoTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbDbLinkTest.d  ../dbDbLinkTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbCACTest.d  ../dbCACTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbCaLinkTest.d  ../dbCaLinkTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbCaStatsTest.d  ../dbCaStatsTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbServerTest.d  ../dbServerTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbStateTest.d  ../dbStateTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF callbackParallelTest.d  ../callbackParallelTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF callbackTest.d  ../callbackTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF testdbConvert.d  ../testdbConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbStressLock.d  ../dbStressLock.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbLockTest.d  ../dbLockTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbPutLinkTest.d  ../dbPutLinkTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbShutdownTest.d  ../dbShutdownTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbScanTest.d  ../dbScanTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF devx.d  ../devx.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF arrRecord.d  ../arrRecord.c
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o dbTestIoc_registerRecordDeviceDriver.cpp ../O.Common/dbTestIoc.dbd dbTestIoc_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o dbChArrTest_registerRecordDeviceDriver.cpp ../O.Common/dbChArrTest.dbd dbChArrTest_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbTestIoc_registerRecordDeviceDriver.d  dbTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbChArrTest_registerRecordDeviceDriver.d  dbChArrTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../arrRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../xRecord.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbLinkdset.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../xLink.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../devx.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../jlinkz.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbScanTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c dbTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbShutdownTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbLockTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbPutLinkTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbStressLock.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../testdbConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../callbackTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../callbackParallelTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbStateTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbServerTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbCaStatsTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbCaLinkTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbCACTest.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbDbLinkTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../scanIoTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbChannelTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbChArrTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c dbChArrTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../chfPluginTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../arrShorthandTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../benchdbConvert.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../recGblCheckDeadbandTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbPutGetTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I ../../../../src/ioc/db -DUSE_TYPED_RSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbStaticTest.c
/usr/bin/ar -rc    libdbTestIoc.a    arrRecord.o xRecord.o dbLinkdset.o xLink.o devx.o jlinkz.o
/usr/bin/ranlib libdbTestIoc.a
/usr/bin/g++ -o libdbTestIoc.so.7.0.6 -shared -fPIC -Wl,-hlibdbTestIoc.so.7.0.6 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         arrRecord.o xRecord.o dbLinkdset.o xLink.o devx.o jlinkz.o    -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/g++ -o dbScanTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbScanTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbShutdownTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbShutdownTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbPutLinkTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbPutLinkTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbLockTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbLockTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbStressTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbStressLock.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom  -lrt
/usr/bin/g++ -o testdbConvert  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         testdbConvert.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o callbackTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         callbackTest.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o callbackParallelTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         callbackParallelTest.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbStateTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbStateTest.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbServerTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbServerTest.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbCaStatsTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbCaStatsTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbCaLinkTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbCaLinkTest.o dbCACTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbDbLinkTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbDbLinkTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o scanIoTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         scanIoTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbChannelTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbChannelTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbChArrTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbChArrTest.o dbChArrTest_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o chfPluginTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         chfPluginTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o arrShorthandTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         arrShorthandTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o benchdbConvert  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         benchdbConvert.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o recGblCheckDeadbandTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         recGblCheckDeadbandTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o testPutGetTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbPutGetTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
/usr/bin/g++ -o dbStaticTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64           -rdynamic -m64         dbStaticTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbScanTest.t dbScanTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbShutdownTest.t dbShutdownTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbPutLinkTest.t dbPutLinkTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbLockTest.t dbLockTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbStressTest.t dbStressTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testdbConvert.t testdbConvert
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 callbackTest.t callbackTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 callbackParallelTest.t callbackParallelTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbStateTest.t dbStateTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbServerTest.t dbServerTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbCaStatsTest.t dbCaStatsTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbCaLinkTest.t dbCaLinkTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbDbLinkTest.t dbDbLinkTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 scanIoTest.t scanIoTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbChannelTest.t dbChannelTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbChArrTest.t dbChArrTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 chfPluginTest.t chfPluginTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 arrShorthandTest.t arrShorthandTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 recGblCheckDeadbandTest.t recGblCheckDeadbandTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPutGetTest.t testPutGetTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 dbStaticTest.t dbStaticTest
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/ioc/db'
/Jenkins/jenkins/bin/make -C std/rec install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec'
mkdir -p O.Common
make[5]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64'
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF asTestLib.d  ../asTestLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF linkFilterTest.d  ../linkFilterTest.c
Creating dbd file recTestIoc.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o recTestIoc.dbd base.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF asyncproctest.d  ../asyncproctest.c
Creating dbd file asyncproctest.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o asyncproctest.dbd base.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF mbbioDirectTest.d  ../mbbioDirectTest.c
Creating dbd file simmTest.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o simmTest.dbd base.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF simmTest.d  ../simmTest.c
Creating dbd file regressTest.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o regressTest.dbd base.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF regressTest.d  ../regressTest.c
Creating dbd file scanEventTest.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o scanEventTest.dbd base.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF scanEventTest.d  ../scanEventTest.c
Creating dbd file analogMonitorTest.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o analogMonitorTest.dbd base.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF analogMonitorTest.d  ../analogMonitorTest.c
Creating dbd file asTestIoc.dbd
perl -CSD ../../../../../../bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o asTestIoc.dbd base.dbd asTest.dbd
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF asTest.d  ../asTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF seqTest.d  ../seqTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF softTest.d  ../softTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF asyncSoftTest.d  ../asyncSoftTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF compressTest.d  ../compressTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF linkInitTest.d  ../linkInitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF linkRetargetLinkTest.d  ../linkRetargetLinkTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration   -DLINK_DYNAMIC   -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF recMiscTest.d  ../recMiscTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF arrayOpTest.d  ../arrayOpTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbHeaderTestxx.d  ../dbHeaderTestxx.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF dbHeaderTest.d  ../dbHeaderTest.c
../../../../../../bin/linux-x86_64/msi -D    -I. -I.. -I../O.Common -I../../../../../../db -o ../O.Common/simmTest.db -S../simmTest.substitutions  > simmTest.db.d
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o recTestIoc_registerRecordDeviceDriver.cpp ../O.Common/recTestIoc.dbd recTestIoc_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o asyncproctest_registerRecordDeviceDriver.cpp ../O.Common/asyncproctest.dbd asyncproctest_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o simmTest_registerRecordDeviceDriver.cpp ../O.Common/simmTest.dbd simmTest_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o scanEventTest_registerRecordDeviceDriver.cpp ../O.Common/scanEventTest.dbd scanEventTest_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o regressTest_registerRecordDeviceDriver.cpp ../O.Common/regressTest.dbd regressTest_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o analogMonitorTest_registerRecordDeviceDriver.cpp ../O.Common/analogMonitorTest.dbd analogMonitorTest_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
perl -CSD ../../../../../../bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o asTestIoc_registerRecordDeviceDriver.cpp ../O.Common/asTestIoc.dbd asTestIoc_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF recTestIoc_registerRecordDeviceDriver.d  recTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF asyncproctest_registerRecordDeviceDriver.d  asyncproctest_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF simmTest_registerRecordDeviceDriver.d  simmTest_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF regressTest_registerRecordDeviceDriver.d  regressTest_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF scanEventTest_registerRecordDeviceDriver.d  scanEventTest_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF analogMonitorTest_registerRecordDeviceDriver.d  analogMonitorTest_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -MM -MF asTestIoc_registerRecordDeviceDriver.d  asTestIoc_registerRecordDeviceDriver.cpp
Inflating database from ../simmTest.substitutions
../../../../../../bin/linux-x86_64/msi    -I. -I.. -I../O.Common -I../../../../../../db -o simmTest.db -S../simmTest.substitutions
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../asTestLib.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbHeaderTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../dbHeaderTestxx.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../arrayOpTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c recTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration   -DLINK_DYNAMIC   -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../recMiscTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../linkRetargetLinkTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../linkInitTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../compressTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../asyncSoftTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../softTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../seqTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../asTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c asTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../analogMonitorTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c analogMonitorTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../scanEventTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c scanEventTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../regressTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c regressTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../simmTest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c simmTest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../mbbioDirectTest.c
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../asyncproctest.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c asyncproctest_registerRecordDeviceDriver.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DUSE_TYPED_DSET   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/gcc -I../../../../../../include/os/Linux -I../../../../../../include         -c ../linkFilterTest.c
/usr/bin/ar -rc    libdbRecStdTest.a    asTestLib.o
/usr/bin/ranlib libdbRecStdTest.a
/usr/bin/g++ -o libdbRecStdTest.so.7.0.6 -shared -fPIC -Wl,-hlibdbRecStdTest.so.7.0.6 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         asTestLib.o    -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
/usr/bin/g++ -o dbHeaderTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         dbHeaderTest.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o dbHeaderTestxx  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         dbHeaderTestxx.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o arrayOpTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         arrayOpTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o recMiscTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         recMiscTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o linkRetargetLinkTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         linkRetargetLinkTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o linkInitTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         linkInitTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o compressTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         compressTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o asyncSoftTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         asyncSoftTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o softTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         softTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o seqTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         seqTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o asTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         asTest.o asTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o analogMonitorTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         analogMonitorTest.o analogMonitorTest_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o scanEventTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         scanEventTest.o scanEventTest_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o regressTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         regressTest.o regressTest_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o simmTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         simmTest.o simmTest_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o mbbioDirectTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         mbbioDirectTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o asyncproctest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         asyncproctest.o asyncproctest_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o linkFilterTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64           -rdynamic -m64         linkFilterTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 arrayOpTest.t arrayOpTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 recMiscTest.t recMiscTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 linkRetargetLinkTest.t linkRetargetLinkTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 linkInitTest.t linkInitTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 compressTest.t compressTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 asyncSoftTest.t asyncSoftTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 softTest.t softTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 seqTest.t seqTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 asTest.t asTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 analogMonitorTest.t analogMonitorTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 scanEventTest.t scanEventTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 regressTest.t regressTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 simmTest.t simmTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 mbbioDirectTest.t mbbioDirectTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 asyncproctest.t asyncproctest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 linkFilterTest.t linkFilterTest
make[5]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec/O.linux-x86_64'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test/std/rec'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database/test'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/database'
/Jenkins/jenkins/bin/make -C ./normativeTypes install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes'
/Jenkins/jenkins/bin/make -C ./configure install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/configure'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../..
mkdir -p O.Common
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../..
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/configure/O.linux-x86_64'
Installing CFG file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/cfg/CONFIG_NTYPES_VERSION
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/convertRelease.pl checkRelease
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/configure/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/configure'
/Jenkins/jenkins/bin/make -C ./src install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/src'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntndarrayAttribute.d  ../ntndarrayAttribute.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF nturi.d  ../nturi.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF nthistogram.d  ../nthistogram.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntcontinuum.d  ../ntcontinuum.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntattribute.d  ../ntattribute.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntaggregate.d  ../ntaggregate.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntunion.d  ../ntunion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntenum.d  ../ntenum.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntmatrix.d  ../ntmatrix.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntndarray.d  ../ntndarray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntscalarMultiChannel.d  ../ntscalarMultiChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntmultiChannel.d  ../ntmultiChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF nttable.d  ../nttable.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntnameValue.d  ../ntnameValue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntscalarArray.d  ../ntscalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntscalar.d  ../ntscalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntid.d  ../ntid.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntfield.d  ../ntfield.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntutils.d  ../ntutils.cpp
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/nt.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntutils.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntid.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntfield.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntscalar.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntscalarArray.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntnameValue.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/nttable.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntmultiChannel.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntscalarMultiChannel.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntndarray.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntmatrix.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntenum.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntunion.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntaggregate.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntattribute.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntcontinuum.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/nthistogram.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/nturi.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/ntndarrayAttribute.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntutils.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntid.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntfield.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntscalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntscalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntnameValue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../nttable.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntmultiChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntscalarMultiChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntndarray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntenum.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntmatrix.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntunion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntaggregate.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntattribute.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntcontinuum.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../nthistogram.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../nturi.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntndarrayAttribute.cpp
/usr/bin/ar -rc    libnt.a     ntutils.o ntid.o ntfield.o ntscalar.o ntscalarArray.o ntnameValue.o nttable.o ntmultiChannel.o ntscalarMultiChannel.o ntndarray.o ntmatrix.o ntenum.o ntunion.o ntaggregate.o ntattribute.o ntcontinuum.o nthistogram.o nturi.o ntndarrayAttribute.o
/usr/bin/ranlib libnt.a
/usr/bin/g++ -o libnt.so.6.0.2 -shared -fPIC -Wl,-hlibnt.so.6.0.2 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64          ntutils.o ntid.o ntfield.o ntscalar.o ntscalarArray.o ntnameValue.o nttable.o ntmultiChannel.o ntscalarMultiChannel.o ntndarray.o ntmatrix.o ntenum.o ntunion.o ntaggregate.o ntattribute.o ntcontinuum.o nthistogram.o nturi.o ntndarrayAttribute.o   -lpvData -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libnt.so.6.0.2
ln -s libnt.so.6.0.2 /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libnt.so
Installing library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libnt.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/src/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/src'
/Jenkins/jenkins/bin/make -C ./test install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/test'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/test/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF validatorTest.d  ../validatorTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntutilsTest.d  ../ntutilsTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF nthistogramTest.d  ../nthistogramTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntndarrayAttributeTest.d  ../ntndarrayAttributeTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntattributeTest.d  ../ntattributeTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntaggregateTest.d  ../ntaggregateTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntunionTest.d  ../ntunionTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntenumTest.d  ../ntenumTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntmatrixTest.d  ../ntmatrixTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntndarrayTest.d  ../ntndarrayTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF nttableTest.d  ../nttableTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntscalarMultiChannelTest.d  ../ntscalarMultiChannelTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntmultiChannelTest.d  ../ntmultiChannelTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntnameValueTest.d  ../ntnameValueTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntscalarArrayTest.d  ../ntscalarArrayTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntscalarTest.d  ../ntscalarTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ntfieldTest.d  ../ntfieldTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntfieldTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntscalarTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntscalarArrayTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntnameValueTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntmultiChannelTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntscalarMultiChannelTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../nttableTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntndarrayTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntmatrixTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntunionTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntenumTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntaggregateTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntattributeTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntndarrayAttributeTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntutilsTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../ntcontinuumTest.cpp
/usr/bin/g++ -o ntfieldTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntfieldTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntscalarTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntscalarTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntscalarArrayTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntscalarArrayTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntnameValueTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntnameValueTest.o    -lnt -lpvData -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../nthistogramTest.cpp
/usr/bin/g++ -o ntmultiChannelTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntmultiChannelTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntscalarMultiChannelTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntscalarMultiChannelTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o nttableTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         nttableTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntndarrayTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntndarrayTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntmatrixTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntmatrixTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntenumTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntenumTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntunionTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntunionTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntaggregateTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntaggregateTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntattributeTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntattributeTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntndarrayAttributeTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntndarrayAttributeTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o ntcontinuumTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntcontinuumTest.o    -lnt -lpvData -lCom
/usr/bin/g++ -o nthistogramTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         nthistogramTest.o    -lnt -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntfieldTest.t ntfieldTest
/usr/bin/g++ -o ntutilsTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         ntutilsTest.o    -lnt -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntscalarTest.t ntscalarTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntscalarArrayTest.t ntscalarArrayTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntnameValueTest.t ntnameValueTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntmultiChannelTest.t ntmultiChannelTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntscalarMultiChannelTest.t ntscalarMultiChannelTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 nttableTest.t nttableTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntndarrayTest.t ntndarrayTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntmatrixTest.t ntmatrixTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntenumTest.t ntenumTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntunionTest.t ntunionTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntaggregateTest.t ntaggregateTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntattributeTest.t ntattributeTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntndarrayAttributeTest.t ntndarrayAttributeTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntcontinuumTest.t ntcontinuumTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 nthistogramTest.t nthistogramTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 ntutilsTest.t ntutilsTest
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../validatorTest.cpp
/usr/bin/g++ -o validatorTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         validatorTest.o    -lnt -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 validatorTest.t validatorTest
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/test/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes/test'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/normativeTypes'
/Jenkins/jenkins/bin/make -C ./pvAccess install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/configure'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/configure/O.linux-x86_64'
Installing CFG file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/cfg/CONFIG_PVACCESS_VERSION
Installing CFG file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/cfg/CONFIG_PVACCESS_MODULE
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/configure/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/configure'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src/O.linux-x86_64'
mkdir -p ../O.Common/pv
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -DEPICS_PVA_MAJOR_VERSION="7" -DEPICS_PVA_MINOR_VERSION="1" -DEPICS_PVA_MAINTENANCE_VERSION="5" -DEPICS_PVA_DEVELOPMENT_FLAG="1" -t /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64    ../pva/pvaVersionNum.h@ ../O.Common/pv/pvaVersionNum.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pipelineService.d  ../../src/pipelineService/pipelineService.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pipelineServer.d  ../../src/pipelineService/pipelineServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF rpcClient.d  ../../src/rpcClient/rpcClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF rpcService.d  ../../src/rpcService/rpcService.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF rpcServer.d  ../../src/rpcService/rpcServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF sharedstate_put.d  ../../src/server/sharedstate_put.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF sharedstate_rpc.d  ../../src/server/sharedstate_rpc.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF sharedstate_channel.d  ../../src/server/sharedstate_channel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF sharedstate_pv.d  ../../src/server/sharedstate_pv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF server.d  ../../src/server/server.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF beaconServerStatusProvider.d  ../../src/server/beaconServerStatusProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF beaconEmitter.d  ../../src/server/beaconEmitter.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF baseChannelRequester.d  ../../src/server/baseChannelRequester.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF serverChannelImpl.d  ../../src/server/serverChannelImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF serverContext.d  ../../src/server/serverContext.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF security.d  ../../src/remote/security.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF responseHandlers.d  ../../src/server/responseHandlers.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF clientContextImpl.d  ../../src/remoteClient/clientContextImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF serializationHelper.d  ../../src/remote/serializationHelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF codec.d  ../../src/remote/codec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF transportRegistry.d  ../../src/remote/transportRegistry.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF blockingTCPAcceptor.d  ../../src/remote/blockingTCPAcceptor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF abstractResponseHandler.d  ../../src/remote/abstractResponseHandler.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF channelSearchManager.d  ../../src/remote/channelSearchManager.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF blockingTCPConnector.d  ../../src/remote/blockingTCPConnector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF beaconHandler.d  ../../src/remote/beaconHandler.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF blockingUDPConnector.d  ../../src/remote/blockingUDPConnector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF blockingUDPTransport.d  ../../src/remote/blockingUDPTransport.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF clientInfo.d  ../../src/client/clientInfo.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF ChannelAccessFactory.d  ../../src/factory/ChannelAccessFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF clientMonitor.d  ../../src/client/clientMonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF clientRPC.d  ../../src/client/clientRPC.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF clientPut.d  ../../src/client/clientPut.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF clientGet.d  ../../src/client/clientGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF clientSync.d  ../../src/client/clientSync.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF wildcard.d  ../../src/utils/wildcard.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF monitor.d  ../../src/client/monitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF client.d  ../../src/client/client.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF requester.d  ../../src/utils/requester.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF referenceCountingLock.d  ../../src/utils/referenceCountingLock.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvAccess.d  ../../src/client/pvAccess.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF logger.d  ../../src/utils/logger.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF configuration.d  ../../src/utils/configuration.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF introspectionRegistry.d  ../../src/utils/introspectionRegistry.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF inetAddressUtil.d  ../../src/utils/inetAddressUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF hexDump.d  ../../src/utils/hexDump.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF clientFactory.d  ../../src/pva/clientFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaVersion.d  ../../src/pva/pvaVersion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF getgroups.d  ../../src/utils/getgroups.cpp
Installing generated generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvaVersionNum.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvaDefs.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvaConstants.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvaVersion.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/clientFactory.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/hexDump.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/logger.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/introspectionRegistry.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/referenceCountingLock.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/configuration.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/likely.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/wildcard.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/fairQueue.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/requester.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/destroyable.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/monitor.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvAccess.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pva/client.h
mkdir /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pva
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/security.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/serializationHelper.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/serverContext.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/beaconServerStatusProvider.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pva/server.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pva/sharedstate.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/rpcService.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/rpcServer.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/rpcClient.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pipelineService.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pipelineServer.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvAccessMB.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pva/clientFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/utils/hexDump.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pva/pvaVersion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/utils/logger.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/utils/inetAddressUtil.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/utils/referenceCountingLock.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/utils/getgroups.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/utils/wildcard.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/utils/requester.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/utils/introspectionRegistry.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/utils/configuration.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/client/pvAccess.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/client/monitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/client/client.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/client/clientSync.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/client/clientGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/client/clientPut.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/client/clientRPC.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/client/clientMonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/client/clientInfo.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/blockingUDPConnector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/beaconHandler.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/factory/ChannelAccessFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/blockingUDPTransport.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/abstractResponseHandler.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/blockingTCPConnector.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/blockingTCPAcceptor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/channelSearchManager.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/serializationHelper.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/transportRegistry.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/security.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remote/codec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/serverChannelImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/serverContext.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/beaconEmitter.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/baseChannelRequester.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/beaconServerStatusProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/responseHandlers.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/server.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/sharedstate_channel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/sharedstate_rpc.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/remoteClient/clientContextImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/rpcService/rpcService.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/sharedstate_pv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/server/sharedstate_put.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pipelineService/pipelineService.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/rpcClient/rpcClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/rpcService/rpcServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pipelineService/pipelineServer.cpp
/usr/bin/ar -rc    libpvAccess.a    pvaVersion.o clientFactory.o getgroups.o hexDump.o inetAddressUtil.o logger.o introspectionRegistry.o configuration.o referenceCountingLock.o requester.o wildcard.o pvAccess.o monitor.o client.o clientSync.o clientGet.o clientPut.o clientRPC.o clientMonitor.o clientInfo.o ChannelAccessFactory.o blockingUDPTransport.o blockingUDPConnector.o beaconHandler.o blockingTCPConnector.o channelSearchManager.o abstractResponseHandler.o blockingTCPAcceptor.o transportRegistry.o serializationHelper.o codec.o security.o clientContextImpl.o responseHandlers.o serverContext.o serverChannelImpl.o baseChannelRequester.o beaconEmitter.o beaconServerStatusProvider.o server.o sharedstate_pv.o sharedstate_channel.o sharedstate_rpc.o sharedstate_put.o rpcService.o rpcServer.o rpcClient.o pipelineService.o pipelineServer.o
/usr/bin/ranlib libpvAccess.a
/usr/bin/g++ -o libpvAccess.so.7.1.5 -shared -fPIC -Wl,-hlibpvAccess.so.7.1.5 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         pvaVersion.o clientFactory.o getgroups.o hexDump.o inetAddressUtil.o logger.o introspectionRegistry.o configuration.o referenceCountingLock.o requester.o wildcard.o pvAccess.o monitor.o client.o clientSync.o clientGet.o clientPut.o clientRPC.o clientMonitor.o clientInfo.o ChannelAccessFactory.o blockingUDPTransport.o blockingUDPConnector.o beaconHandler.o blockingTCPConnector.o channelSearchManager.o abstractResponseHandler.o blockingTCPAcceptor.o transportRegistry.o serializationHelper.o codec.o security.o clientContextImpl.o responseHandlers.o serverContext.o serverChannelImpl.o baseChannelRequester.o beaconEmitter.o beaconServerStatusProvider.o server.o sharedstate_pv.o sharedstate_channel.o sharedstate_rpc.o sharedstate_put.o rpcService.o rpcServer.o rpcClient.o pipelineService.o pipelineServer.o    -lpvData -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvAccess.so.7.1.5
ln -s libpvAccess.so.7.1.5 /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvAccess.so
Installing library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvAccess.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src'
/Jenkins/jenkins/bin/make -C src/ioc install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src/ioc'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src/ioc/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF reftrackioc.d  ../reftrackioc.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVAClientRegister.d  ../PVAClientRegister.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF PVAServerRegister.d  ../PVAServerRegister.cpp
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/syncChannelFind.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/iocshelper.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/iocreftrack.h
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/PVACommonRegister.dbd
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/PVAServerRegister.dbd
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/PVAClientRegister.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../PVAClientRegister.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../PVAServerRegister.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../reftrackioc.cpp
/usr/bin/ar -rc    libpvAccessIOC.a    PVAServerRegister.o PVAClientRegister.o reftrackioc.o
/usr/bin/ranlib libpvAccessIOC.a
/usr/bin/g++ -o libpvAccessIOC.so.7.1.5 -shared -fPIC -Wl,-hlibpvAccessIOC.so.7.1.5 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         PVAServerRegister.o PVAClientRegister.o reftrackioc.o    -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvAccessIOC.so.7.1.5
ln -s libpvAccessIOC.so.7.1.5 /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvAccessIOC.so
Installing library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvAccessIOC.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src/ioc/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src/ioc'
/Jenkins/jenkins/bin/make -C src/ca install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src/ca'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src/ca/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF notifierConveyor.d  ../notifierConveyor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF dbdToPv.d  ../dbdToPv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF caChannel.d  ../caChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF caContext.d  ../caContext.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF caProvider.d  ../caProvider.cpp
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/caProvider.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../caContext.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../caProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../caChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../dbdToPv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../notifierConveyor.cpp
/usr/bin/ar -rc    libpvAccessCA.a    caProvider.o caContext.o caChannel.o dbdToPv.o notifierConveyor.o
/usr/bin/ranlib libpvAccessCA.a
/usr/bin/g++ -o libpvAccessCA.so.7.1.5 -shared -fPIC -Wl,-hlibpvAccessCA.so.7.1.5 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         caProvider.o caContext.o caChannel.o dbdToPv.o notifierConveyor.o    -lpvAccess -lpvData -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvAccessCA.so.7.1.5
ln -s libpvAccessCA.so.7.1.5 /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvAccessCA.so
Installing library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvAccessCA.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src/ca/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/src/ca'
/Jenkins/jenkins/bin/make -C ./testCa install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/testCa'
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/testCa/O.linux-x86_64'
rm -f ../O.Common/testIoc.dbd
cp /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/softIoc.dbd ../O.Common/testIoc.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/ca   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testCaProvider.d  ../testCaProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/ca   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testConveyor.d  ../testConveyor.cpp
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd    -o testIoc_registerRecordDeviceDriver.cpp ../O.Common/testIoc.dbd testIoc_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/ca   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testIoc_registerRecordDeviceDriver.d  testIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/ca   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../testConveyor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/ca   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../testCaProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/ca   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c testIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++ -o testConveyor  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testConveyor.o    -lpvAccess -lpvAccessCA -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o testCaProvider  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testCaProvider.o testIoc_registerRecordDeviceDriver.o    -lpvAccess -lpvAccessCA -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testConveyor.t testConveyor
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testCaProvider.t testCaProvider
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/testCa/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/testCa'
/Jenkins/jenkins/bin/make -C ./pvtoolsSrc install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/pvtoolsSrc'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/pvtoolsSrc/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvlist.d  ../pvlist.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvutils.d  ../pvutils.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvinfo.d  ../pvinfo.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvcall.d  ../pvcall.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvput.d  ../pvput.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvmonitor.d  ../pvmonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvget.d  ../pvget.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvget.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvutils.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvmonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvput.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvcall.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvinfo.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/remote   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvlist.cpp
/usr/bin/g++ -o pvget  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         pvget.o pvutils.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
/usr/bin/g++ -o pvmonitor  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         pvmonitor.o pvutils.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
/usr/bin/g++ -o pvput  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         pvput.o pvutils.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
/usr/bin/g++ -o pvcall  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         pvcall.o pvutils.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
/usr/bin/g++ -o pvinfo  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         pvinfo.o pvutils.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
/usr/bin/g++ -o pvlist  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         pvlist.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
Installing created executable /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/pvget
Installing created executable /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/pvmonitor
Installing created executable /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/pvput
Installing created executable /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/pvcall
Installing created executable /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/pvinfo
Installing created executable /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/pvlist
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/pvtoolsSrc/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/pvtoolsSrc'
/Jenkins/jenkins/bin/make -C ./examples install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/examples'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/examples/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF minimonitor.d  ../minimonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF miniput.d  ../miniput.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF miniget.d  ../miniget.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF lazycounter.d  ../lazycounter.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF epicschat.d  ../epicschat.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF mailbox.d  ../mailbox.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF spamme.d  ../spamme.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF monitorme.d  ../monitorme.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF putme.d  ../putme.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF getme.d  ../getme.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../getme.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../putme.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../monitorme.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../spamme.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../mailbox.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../lazycounter.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../epicschat.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../miniget.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../miniput.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../minimonitor.cpp
/usr/bin/g++ -o getme  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         getme.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
/usr/bin/g++ -o putme  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         putme.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
/usr/bin/g++ -o monitorme  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         monitorme.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
/usr/bin/g++ -o spamme  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         spamme.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
/usr/bin/g++ -o mailbox  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         mailbox.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
/usr/bin/g++ -o epicschat  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         epicschat.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
/usr/bin/g++ -o lazycounter  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         lazycounter.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
/usr/bin/g++ -o miniget  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         miniget.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
/usr/bin/g++ -o miniput  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         miniput.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
/usr/bin/g++ -o minimonitor  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         minimonitor.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/examples/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/examples'
/Jenkins/jenkins/bin/make -C ./testApp install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/testApp'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/testApp/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testRAII.d  ../../testApp/remote/testRAII.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testClientFactory.d  ../../testApp/remote/testClientFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF rpcClientExample.d  ../../testApp/remote/rpcClientExample.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF rpcWildServiceExample.d  ../../testApp/remote/rpcWildServiceExample.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF rpcServiceAsyncExample.d  ../../testApp/remote/rpcServiceAsyncExample.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF rpcServiceExample.d  ../../testApp/remote/rpcServiceExample.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testMonitorPerformance.d  ../../testApp/remote/testMonitorPerformance.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testGetPerformance.d  ../../testApp/remote/testGetPerformance.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testsharedstate.d  ../../testApp/remote/testsharedstate.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testServer.d  ../../testApp/remote/testServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testmonitorfifo.d  ../../testApp/remote/testmonitorfifo.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testServerContext.d  ../../testApp/remote/testServerContext.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testChannelConnect.d  ../../testApp/remote/testChannelConnect.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testRemoteClientImpl.d  ../../testApp/remote/testRemoteClientImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testRPC.d  ../../testApp/remote/testRPC.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testCodec.d  ../../testApp/remote/testCodec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF channelAccessIFTest.d  ../../testApp/remote/channelAccessIFTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF showauth.d  ../../testApp/utils/showauth.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testWildcard.d  ../../testApp/utils/testWildcard.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testFairQueue.d  ../../testApp/utils/testFairQueue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF configurationTest.d  ../../testApp/utils/configurationTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testInetAddressUtils.d  ../../testApp/utils/testInetAddressUtils.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testHexDump.d  ../../testApp/utils/testHexDump.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testAtomicBoolean.d  ../../testApp/utils/testAtomicBoolean.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/utils/testAtomicBoolean.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/utils/testHexDump.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/utils/testInetAddressUtils.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/utils/configurationTest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/utils/testWildcard.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/utils/testFairQueue.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/utils/showauth.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testCodec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testRPC.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testRemoteClientImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testChannelConnect.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testServerContext.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testmonitorfifo.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/channelAccessIFTest.cpp
In file included from ../../testApp/remote/channelAccessIFTest.cpp:29:0:
../../testApp/remote/testServer.cpp: In constructor ‘MockChannel::MockChannel(epics::pvAccess::ChannelProvider::shared_pointer, epics::pvAccess::ChannelRequester::shared_pointer, std::string, std::string)’:
../../testApp/remote/testServer.cpp:2261:48: warning: ‘epics::pvData::FieldBuilderPtr epics::pvData::FieldBuilder::addBoundedString(const string&, std::size_t)’ is deprecated (declared at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvIntrospect.h:1095): See https://github.com/epics-base/pvDataCPP/issues/52 [-Wdeprecated-declarations]
                     addBoundedString("value", 8)->
../../testApp/remote/testServer.cpp:2270:57: warning: ‘epics::pvData::FieldBuilderPtr epics::pvData::FieldBuilder::addBoundedArray(const string&, epics::pvData::ScalarType, std::size_t)’ is deprecated (declared at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvIntrospect.h:1129): See https://github.com/epics-base/pvDataCPP/issues/52 [-Wdeprecated-declarations]
                     addBoundedArray("value", pvDouble, 8)->
../../testApp/remote/testServer.cpp:2279:55: warning: ‘epics::pvData::FieldBuilderPtr epics::pvData::FieldBuilder::addFixedArray(const string&, epics::pvData::ScalarType, std::size_t)’ is deprecated (declared at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvIntrospect.h:1120): See https://github.com/epics-base/pvDataCPP/issues/52 [-Wdeprecated-declarations]
                     addFixedArray("value", pvDouble, 8)->
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testsharedstate.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/rpcServiceExample.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testGetPerformance.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testMonitorPerformance.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/rpcWildServiceExample.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/rpcServiceAsyncExample.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/rpcClientExample.cpp
/usr/bin/g++ -o testAtomicBoolean  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testAtomicBoolean.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testHexDump  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testHexDump.o    -lpvAccess -lpvData -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testClientFactory.cpp
/usr/bin/g++ -o testInetAddressUtils  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testInetAddressUtils.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o configurationTest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         configurationTest.o    -lpvAccess -lpvData -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testRAII.cpp
/usr/bin/g++ -o testFairQueue  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testFairQueue.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testWildcard  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testWildcard.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o showauth  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         showauth.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testChannelAccess  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         channelAccessIFTest.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testCodec  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testCodec.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testRPC  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testRPC.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testRemoteClientImpl  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testRemoteClientImpl.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testChannelConnect  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testChannelConnect.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testServerContext  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testServerContext.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testmonitorfifo  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testmonitorfifo.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testsharedstate  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testsharedstate.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testGetPerformance  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testGetPerformance.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testMonitorPerformance  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testMonitorPerformance.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o rpcServiceExample  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         rpcServiceExample.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o rpcServiceAsyncExample  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         rpcServiceAsyncExample.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o rpcWildServiceExample  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         rpcWildServiceExample.o    -lpvAccess -lpvData -lCom
/usr/bin/g++ -o rpcClientExample  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         rpcClientExample.o    -lpvAccess -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testAtomicBoolean.t testAtomicBoolean
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testHexDump.t testHexDump
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testInetAddressUtils.t testInetAddressUtils
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 configurationTest.t configurationTest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testFairQueue.t testFairQueue
/usr/bin/g++ -o testClientFactory  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testClientFactory.o    -lpvAccess -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testWildcard.t testWildcard
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testChannelAccess.t testChannelAccess
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testCodec.t testCodec
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testRPC.t testRPC
/usr/bin/g++ -o testRAII  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testRAII.o    -lpvAccess -lpvData -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testServerContext.t testServerContext
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testmonitorfifo.t testmonitorfifo
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testsharedstate.t testsharedstate
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../testApp/remote/testServer.cpp
/usr/bin/g++ -o testServer  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testServer.o    -lpvAccess -lpvData -lCom
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/testApp/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess/testApp'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvAccess'
/Jenkins/jenkins/bin/make -C ./pvaClient install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvaClient'
/Jenkins/jenkins/bin/make -C ./configure install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvaClient/configure'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvaClient/configure/O.linux-x86_64'
Installing CFG file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/cfg/CONFIG_PVACLIENT_VERSION
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvaClient/configure/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvaClient/configure'
/Jenkins/jenkins/bin/make -C ./src install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvaClient/src'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvaClient/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientRPC.d  ../pvaClientRPC.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientNTMultiMonitor.d  ../pvaClientNTMultiMonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientNTMultiGet.d  ../pvaClientNTMultiGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientNTMultiData.d  ../pvaClientNTMultiData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientNTMultiPut.d  ../pvaClientNTMultiPut.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientMultiMonitorDouble.d  ../pvaClientMultiMonitorDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientMultiPutDouble.d  ../pvaClientMultiPutDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientMultiGetDouble.d  ../pvaClientMultiGetDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientMultiChannel.d  ../pvaClientMultiChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientPutGet.d  ../pvaClientPutGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientMonitor.d  ../pvaClientMonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientPut.d  ../pvaClientPut.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientGet.d  ../pvaClientGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientProcess.d  ../pvaClientProcess.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientChannel.d  ../pvaClientChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientMonitorData.d  ../pvaClientMonitorData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientGetData.d  ../pvaClientGetData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientPutData.d  ../pvaClientPutData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClientData.d  ../pvaClientData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaClient.d  ../pvaClient.cpp
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvaClient.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvaClientMultiChannel.h
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientPutData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientGetData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientMonitorData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientProcess.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientPut.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientMonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientPutGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientMultiChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientMultiGetDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientMultiPutDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientMultiMonitorDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientNTMultiPut.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientNTMultiData.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientNTMultiGet.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientNTMultiMonitor.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvaClientRPC.cpp
/usr/bin/ar -rc    libpvaClient.a     pvaClient.o pvaClientData.o pvaClientPutData.o pvaClientGetData.o pvaClientMonitorData.o pvaClientChannel.o pvaClientProcess.o pvaClientGet.o pvaClientPut.o pvaClientMonitor.o pvaClientPutGet.o pvaClientMultiChannel.o pvaClientMultiGetDouble.o pvaClientMultiPutDouble.o pvaClientMultiMonitorDouble.o pvaClientNTMultiPut.o pvaClientNTMultiData.o pvaClientNTMultiGet.o pvaClientNTMultiMonitor.o pvaClientRPC.o
/usr/bin/ranlib libpvaClient.a
/usr/bin/g++ -o libpvaClient.so.4.8.1 -shared -fPIC -Wl,-hlibpvaClient.so.4.8.1 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64          pvaClient.o pvaClientData.o pvaClientPutData.o pvaClientGetData.o pvaClientMonitorData.o pvaClientChannel.o pvaClientProcess.o pvaClientGet.o pvaClientPut.o pvaClientMonitor.o pvaClientPutGet.o pvaClientMultiChannel.o pvaClientMultiGetDouble.o pvaClientMultiPutDouble.o pvaClientMultiMonitorDouble.o pvaClientNTMultiPut.o pvaClientNTMultiData.o pvaClientNTMultiGet.o pvaClientNTMultiMonitor.o pvaClientRPC.o   -lnt -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvaClient.so.4.8.1
ln -s libpvaClient.so.4.8.1 /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvaClient.so
Installing library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvaClient.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvaClient/src/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvaClient/src'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvaClient'
/Jenkins/jenkins/bin/make -C ./pvDatabase install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/configure'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/configure/O.linux-x86_64'
Installing CFG file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/cfg/CONFIG_PVDATABASE_VERSION
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/convertRelease.pl checkRelease
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/configure/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/configure'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/src'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvdbcrTraceRecord.d  ../../src/special/pvdbcrTraceRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvdbcrProcessRecord.d  ../../src/special/pvdbcrProcessRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvdbcrRemoveRecord.d  ../../src/special/pvdbcrRemoveRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvdbcrAddRecord.d  ../../src/special/pvdbcrAddRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvdbcrScalarArrayRecord.d  ../../src/special/pvdbcrScalarArrayRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvdbcrScalarRecord.d  ../../src/special/pvdbcrScalarRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF scalarAlarmSupport.d  ../../src/support/scalarAlarmSupport.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF controlSupport.d  ../../src/support/controlSupport.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF registerChannelProviderLocal.d  ../../src/pvAccess/registerChannelProviderLocal.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF monitorFactory.d  ../../src/pvAccess/monitorFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF channelLocal.d  ../../src/pvAccess/channelLocal.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF channelProviderLocal.d  ../../src/pvAccess/channelProviderLocal.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvDatabase.d  ../../src/database/pvDatabase.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvRecord.d  ../../src/database/pvRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvTimestampPlugin.d  ../../src/copy/pvTimestampPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvDeadbandPlugin.d  ../../src/copy/pvDeadbandPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvArrayPlugin.d  ../../src/copy/pvArrayPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvCopy.d  ../../src/copy/pvCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvPlugin.d  ../../src/copy/pvPlugin.cpp
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvPlugin.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvStructureCopy.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvArrayPlugin.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvDeadbandPlugin.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvTimestampPlugin.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvDatabase.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/channelProviderLocal.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvSupport.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/controlSupport.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/scalarAlarmSupport.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvdbcrScalarRecord.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvdbcrScalarArrayRecord.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvdbcrAddRecord.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvdbcrRemoveRecord.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvdbcrProcessRecord.h
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/pvdbcrTraceRecord.h
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/registerChannelProviderLocal.dbd
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/pvdbcrScalarRecord.dbd
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/pvdbcrScalarArrayRecord.dbd
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/pvdbcrAddRecord.dbd
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/pvdbcrRemoveRecord.dbd
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/pvdbcrProcessRecord.dbd
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/pvdbcrTraceRecord.dbd
Installing dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/pvdbcrAllRecords.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/copy/pvPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/copy/pvCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/copy/pvArrayPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/copy/pvDeadbandPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/copy/pvTimestampPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/database/pvRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/database/pvDatabase.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pvAccess/channelProviderLocal.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pvAccess/channelLocal.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pvAccess/monitorFactory.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/pvAccess/registerChannelProviderLocal.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/support/controlSupport.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/support/scalarAlarmSupport.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/special/pvdbcrScalarRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/special/pvdbcrScalarArrayRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/special/pvdbcrAddRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/special/pvdbcrRemoveRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/special/pvdbcrTraceRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../src/special/pvdbcrProcessRecord.cpp
/usr/bin/ar -rc    libpvDatabase.a     pvPlugin.o pvCopy.o pvArrayPlugin.o pvDeadbandPlugin.o pvTimestampPlugin.o pvRecord.o pvDatabase.o channelProviderLocal.o channelLocal.o monitorFactory.o registerChannelProviderLocal.o controlSupport.o scalarAlarmSupport.o pvdbcrScalarRecord.o pvdbcrScalarArrayRecord.o pvdbcrAddRecord.o pvdbcrRemoveRecord.o pvdbcrProcessRecord.o pvdbcrTraceRecord.o
/usr/bin/ranlib libpvDatabase.a
/usr/bin/g++ -o libpvDatabase.so.4.6.1 -shared -fPIC -Wl,-hlibpvDatabase.so.4.6.1 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64          pvPlugin.o pvCopy.o pvArrayPlugin.o pvDeadbandPlugin.o pvTimestampPlugin.o pvRecord.o pvDatabase.o channelProviderLocal.o channelLocal.o monitorFactory.o registerChannelProviderLocal.o controlSupport.o scalarAlarmSupport.o pvdbcrScalarRecord.o pvdbcrScalarArrayRecord.o pvdbcrAddRecord.o pvdbcrRemoveRecord.o pvdbcrProcessRecord.o pvdbcrTraceRecord.o   -lpvData -lpvAccess -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvDatabase.so.4.6.1
ln -s libpvDatabase.so.4.6.1 /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvDatabase.so
Installing library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libpvDatabase.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/src/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/src'
/Jenkins/jenkins/bin/make -C ./test install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/test'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32 ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.vxWorks-ppc32sf ../..
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeMakefile.pl O.RTEMS-uC5282 ../..
mkdir -p O.Common
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/test/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVAServer.d  ../../test/src/testPVAServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testLocalProvider.d  ../../test/src/testLocalProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testExampleRecord.d  ../../test/src/testExampleRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVRecord.d  ../../test/src/testPVRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPVCopy.d  ../../test/src/testPVCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testPlugin.d  ../../test/src/testPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../test/src/testPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../test/src/testPVRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../test/src/testPVCopy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../test/src/testPVAServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../test/src/testLocalProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../../test/src/testExampleRecord.cpp
/usr/bin/g++ -o testPlugin  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPlugin.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o testPVCopy  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVCopy.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o testPVRecord  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVRecord.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o testExampleRecord  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testExampleRecord.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o testLocalProvider  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testLocalProvider.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o testPVAServer  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testPVAServer.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPlugin.t testPlugin
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVCopy.t testPVCopy
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVRecord.t testPVRecord
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testExampleRecord.t testExampleRecord
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testLocalProvider.t testLocalProvider
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testPVAServer.t testPVAServer
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/test/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase/test'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pvDatabase'
/Jenkins/jenkins/bin/make -C ./pva2pva install.linux-x86_64
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva'
/Jenkins/jenkins/bin/make -C ./configure install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/configure'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/configure/O.linux-x86_64'
Installing CFG file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/cfg/CONFIG_QSRV_VERSION
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/configure/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/configure'
/Jenkins/jenkins/bin/make -C ./p2pApp install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/p2pApp'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/p2pApp/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF gwmain.d  ../gwmain.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF utilitiesx.d  ../utilitiesx.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testmon.d  ../testmon.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF channel.d  ../channel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF moncache.d  ../moncache.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF chancache.d  ../chancache.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF server.d  ../server.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../gwmain.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../server.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../chancache.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../moncache.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../channel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../testmon.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../utilitiesx.cpp
/usr/bin/g++ -o p2p  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         gwmain.o server.o chancache.o moncache.o channel.o   -lpvAccessIOC -lpvAccess -lpvData -lCom
/usr/bin/g++ -o testmon  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testmon.o utilitiesx.o server.o chancache.o moncache.o channel.o   -lpvAccessIOC -lpvAccess -lpvData -lCom
Installing created executable /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/p2p
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testmon.t testmon
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/p2pApp/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/p2pApp'
/Jenkins/jenkins/bin/make -C ./pdbApp install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/pdbApp'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/pdbApp/O.linux-x86_64'
mkdir -p ../O.Common/pv
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -DEPICS_QSRV_MAJOR_VERSION="1" -DEPICS_QSRV_MINOR_VERSION="3" -DEPICS_QSRV_MAINTENANCE_VERSION="2" -DEPICS_QSRV_DEVELOPMENT_FLAG="1" -DEPICS_QSRV_ABI_MAJOR_VERSION="1" -DEPICS_QSRV_ABI_MINOR_VERSION="2" -t /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64    ../pv/qsrvVersionNum.h@ ../O.Common/pv/qsrvVersionNum.h
cp ../qsrv-new.dbd ../O.Common/qsrv.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF softMain.d  ../softMain.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvalink_channel.d  ../pvalink_channel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvalink_link.d  ../pvalink_link.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvalink_jlif.d  ../pvalink_jlif.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvalink_lset.d  ../pvalink_lset.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvalink.d  ../pvalink.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF tpool.d  ../tpool.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF dbf_copy.d  ../dbf_copy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF configparse.d  ../configparse.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pdbgroup.d  ../pdbgroup.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF imagedemo.d  ../imagedemo.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF demo.d  ../demo.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pdbsingle.d  ../pdbsingle.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pdb.d  ../pdb.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF qsrv.d  ../qsrv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvif.d  ../pvif.cpp
Creating dbd file softIocPVA.dbd
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd -o softIocPVA.dbd softIoc.dbd PVAServerRegister.dbd qsrv.dbd
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd    -o softIocPVA_registerRecordDeviceDriver.cpp ../O.Common/softIocPVA.dbd softIocPVA_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF softIocPVA_registerRecordDeviceDriver.d  softIocPVA_registerRecordDeviceDriver.cpp
Installing generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/qsrv.h
Installing generated generic include file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/pv/qsrvVersionNum.h
Installing created dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/softIocPVA.dbd
Installing created dbd file /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd/qsrv.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvif.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../qsrv.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pdb.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pdbsingle.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../demo.cpp
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../imagedemo.c
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pdbgroup.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../configparse.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../dbf_copy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../tpool.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvalink.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvalink_lset.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvalink_jlif.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvalink_link.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../softMain.cpp
../softMain.cpp: In function ‘int main(int, char**)’:
../softMain.cpp:264:17: warning: ‘void epicsThreadExitMain()’ is deprecated (declared at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/epicsThread.h:151) [-Wdeprecated-declarations]
                 epicsThreadExitMain();
../softMain.cpp:264:37: warning: ‘void epicsThreadExitMain()’ is deprecated (declared at /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/epicsThread.h:151) [-Wdeprecated-declarations]
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c softIocPVA_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64\""   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../pvalink_channel.cpp
/usr/bin/ar -rc    libqsrv.a    pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o dbf_copy.o tpool.o pvalink.o pvalink_lset.o pvalink_jlif.o pvalink_link.o pvalink_channel.o
/usr/bin/ranlib libqsrv.a
/usr/bin/g++ -o libqsrv.so.1.2 -shared -fPIC -Wl,-hlibqsrv.so.1.2 -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o dbf_copy.o tpool.o pvalink.o pvalink_lset.o pvalink_jlif.o pvalink_link.o pvalink_channel.o    -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom   -lpthread   -lreadline -lm -lrt -ldl -lgcc
Installing shared library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libqsrv.so.1.2
ln -s libqsrv.so.1.2 /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libqsrv.so
Installing library /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64/libqsrv.a
/usr/bin/g++ -o softIocPVA  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         softMain.o softIocPVA_registerRecordDeviceDriver.o    -lqsrv -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
Installing created executable /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/softIocPVA
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/pdbApp/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/pdbApp'
/Jenkins/jenkins/bin/make -C ./testApp install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/testApp'
mkdir -p O.Common
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/testApp/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testdbf_copy.d  ../testdbf_copy.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testgroupconfig.d  ../testgroupconfig.cpp
Creating dbd file pvaLinkTestIoc.dbd
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd -o pvaLinkTestIoc.dbd base.dbd qsrv.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testpvalink.d  ../testpvalink.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF check_consist.d  ../check_consist.cpp
Creating dbd file p2pTestIoc.dbd
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/dbdExpand.pl   -I. -I.. -I../O.Common -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd -o p2pTestIoc.dbd base.dbd
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testpdb.d  ../testpdb.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testpvif.d  ../testpvif.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testtest.d  ../testtest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF testweak.d  ../testweak.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF utilitiesx.d  ../utilitiesx.cpp
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd    -o pvaLinkTestIoc_registerRecordDeviceDriver.cpp ../O.Common/pvaLinkTestIoc.dbd pvaLinkTestIoc_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/dbd    -o p2pTestIoc_registerRecordDeviceDriver.cpp ../O.Common/p2pTestIoc.dbd p2pTestIoc_registerRecordDeviceDriver /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF pvaLinkTestIoc_registerRecordDeviceDriver.d  pvaLinkTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -MM -MF p2pTestIoc_registerRecordDeviceDriver.d  p2pTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../testtest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../testweak.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c p2pTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../utilitiesx.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../check_consist.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c pvaLinkTestIoc_registerRecordDeviceDriver.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../testpdb.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../testpvalink.cpp
/usr/bin/g++ -o testweak  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testweak.o utilitiesx.o   -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o testtest  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testtest.o utilitiesx.o   -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o testpdb  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testpdb.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o   -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../testgroupconfig.cpp
/usr/bin/g++ -o check_consist  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         check_consist.o utilitiesx.o   -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
/usr/bin/g++ -o testpvalink  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testpvalink.o pvaLinkTestIoc_registerRecordDeviceDriver.o utilitiesx.o   -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testweak.t testweak
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testtest.t testtest
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testpdb.t testpdb
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../testpvif.cpp
/usr/bin/g++ -o testgroupconfig  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testgroupconfig.o utilitiesx.o   -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testpvalink.t testpvalink
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testgroupconfig.t testgroupconfig
/usr/bin/g++ -o testpvif  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testpvif.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o   -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testpvif.t testpvif
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common   -D_X86_64_  -DUNIX  -Dlinux      -O3 -g   -Wall      -mtune=generic      -m64  -I. -I../O.Common -I. -I. -I.. -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include/os/Linux -I/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/include        -c ../testdbf_copy.cpp
/usr/bin/g++ -o testdbf_copy  -L/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64 -Wl,-rpath,/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/lib/linux-x86_64           -rdynamic -m64         testdbf_copy.o utilitiesx.o   -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/makeTestfile.pl linux-x86_64 linux-x86_64 testdbf_copy.t testdbf_copy
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/testApp/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/testApp'
/Jenkins/jenkins/bin/make -C ./iocBoot install.linux-x86_64
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/iocBoot'
/Jenkins/jenkins/bin/make -C ./iocimagedemo install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/iocBoot/iocimagedemo'
make[4]: Nothing to be done for 'install.linux-x86_64'.
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/iocBoot/iocimagedemo'
/Jenkins/jenkins/bin/make -C ./iocpvalink install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/iocBoot/iocpvalink'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/iocBoot/iocpvalink'
/Jenkins/jenkins/bin/make -C ./iocwfdemo install.linux-x86_64
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/iocBoot/iocwfdemo'
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/iocBoot/iocwfdemo'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva/iocBoot'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/pva2pva'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules'
+ echo ------------------------------------------------------------------
+ /Jenkins/jenkins/bin/make -k -j4 -Orecurse
/Jenkins/jenkins/bin/make -C ./configure install
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure'
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.linux-x86_64'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.linux-x86_64'
/Jenkins/jenkins/bin/make -C O.RTEMS-uC5282 -f ../Makefile TOP=../.. \
    T_A=RTEMS-uC5282 install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.RTEMS-uC5282'
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -x c -E -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/RTEMS -I../../include         ../toolchain.c > TOOLCHAIN.linux-x86_64.RTEMS-uC5282
Installing CFG file ../../cfg/TOOLCHAIN.linux-x86_64.RTEMS-uC5282
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.RTEMS-uC5282'
/Jenkins/jenkins/bin/make -C O.vxWorks-ppc32 -f ../Makefile TOP=../.. \
    T_A=vxWorks-ppc32 install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.vxWorks-ppc32'
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc -x c -E -DCPU=PPC32 -DvxWorks=vxWorks -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip ../toolchain.c > TOOLCHAIN.linux-x86_64.vxWorks-ppc32
Installing CFG file ../../cfg/TOOLCHAIN.linux-x86_64.vxWorks-ppc32
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.vxWorks-ppc32'
/Jenkins/jenkins/bin/make -C O.vxWorks-ppc32sf -f ../Makefile TOP=../.. \
    T_A=vxWorks-ppc32sf install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.vxWorks-ppc32sf'
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc -x c -E -DCPU=PPC32 -DvxWorks=vxWorks -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/vxWorks -I../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip ../toolchain.c > TOOLCHAIN.linux-x86_64.vxWorks-ppc32sf
Installing CFG file ../../cfg/TOOLCHAIN.linux-x86_64.vxWorks-ppc32sf
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure/O.vxWorks-ppc32sf'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/configure'
/Jenkins/jenkins/bin/make -C ./src install
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src'
/Jenkins/jenkins/bin/make -C ./tools install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools'
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.linux-x86_64'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.linux-x86_64'
/Jenkins/jenkins/bin/make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.vxWorks-ppc32'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.vxWorks-ppc32'
/Jenkins/jenkins/bin/make -C O.vxWorks-ppc32sf -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.vxWorks-ppc32sf'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.vxWorks-ppc32sf'
/Jenkins/jenkins/bin/make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.RTEMS-uC5282'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools/O.RTEMS-uC5282'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/tools'
/Jenkins/jenkins/bin/make -C template/base install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base'
/Jenkins/jenkins/bin/make -C O.linux-x86_64 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.linux-x86_64'
/Jenkins/jenkins/bin/make -C O.vxWorks-ppc32sf -f ../Makefile TOP=../../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.vxWorks-ppc32sf'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.vxWorks-ppc32sf'
/Jenkins/jenkins/bin/make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.vxWorks-ppc32'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.vxWorks-ppc32'
/Jenkins/jenkins/bin/make -C O.RTEMS-uC5282 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.RTEMS-uC5282'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base/O.RTEMS-uC5282'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/base'
/Jenkins/jenkins/bin/make -C template/ext install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.linux-x86_64'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.vxWorks-ppc32'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.vxWorks-ppc32'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.vxWorks-ppc32sf'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.vxWorks-ppc32sf'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.RTEMS-uC5282'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext/O.RTEMS-uC5282'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src/template/ext'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/src'
/Jenkins/jenkins/bin/make -C ./test install
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test'
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.linux-x86_64'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.linux-x86_64'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.vxWorks-ppc32'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.vxWorks-ppc32'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.vxWorks-ppc32sf'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.vxWorks-ppc32sf'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.RTEMS-uC5282'
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools/O.RTEMS-uC5282'
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test/tools'
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/test'
/Jenkins/jenkins/bin/make -C ./modules install
make[1]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules'
/Jenkins/jenkins/bin/make -C ./libcom install
make[2]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom'
make[3]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src'
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.linux-x86_64'
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
Installing generated generic include file ../../../../include/libComVersion.h
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.linux-x86_64'
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.RTEMS-uC5282'
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/RTEMS-uC5282  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
perl -CSD ../error/makeStatTbl.pl  ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
perl -CSD ../../../../bin/linux-x86_64/bldEnvData.pl  -t RTEMS-uC5282 \
	-c gcc -s RTEMS ../../../../configure
Generating envData.c
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/e_flex -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ../as/asLib_lex.l
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -basLib  ../as/asLib.y
/bin/mv asLib.tab.c asLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osiNTPTime.d  ../osi/osiNTPTime.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF yajl_parser.d  ../yajl/yajl_parser.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF yajl_lex.d  ../yajl/yajl_lex.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF yajl_gen.d  ../yajl/yajl_gen.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF yajl_encode.d  ../yajl/yajl_encode.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF yajl_buf.d  ../yajl/yajl_buf.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF yajl_alloc.d  ../yajl/yajl_alloc.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF yajl.d  ../yajl/yajl.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF timerQueueActiveMgr.d  ../timer/timerQueueActiveMgr.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF timerQueuePassive.d  ../timer/timerQueuePassive.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF timerQueueActive.d  ../timer/timerQueueActive.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF timerQueue.d  ../timer/timerQueue.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF timer.d  ../timer/timer.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsTimer.d  ../timer/epicsTimer.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF taskwd.d  ../taskwd/taskwd.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsRingBytes.d  ../ring/epicsRingBytes.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsRingPointer.d  ../ring/epicsRingPointer.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF threadPool.d  ../pool/threadPool.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF poolJob.d  ../pool/poolJob.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdFindAddr.d  ../osi/os/default/osdFindAddr.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdBackTrace.d  ../osi/os/default/osdBackTrace.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsStackTrace.d  ../osi/epicsStackTrace.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF devLibVMEOSD.d  ../osi/os/RTEMS-score/devLibVMEOSD.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF devLibVME.d  ../osi/devLibVME.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdgetexec.d  ../osi/os/default/osdgetexec.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdMessageQueue.d  ../osi/os/default/osdMessageQueue.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdNetIntf.d  ../osi/os/default/osdNetIntf.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdProcess.d  ../osi/os/RTEMS-score/osdProcess.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdMonotonic.d  ../osi/os/posix/osdMonotonic.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdEvent.d  ../osi/os/RTEMS-score/osdEvent.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdTime.d  ../osi/os/RTEMS-score/osdTime.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdSpin.d  ../osi/os/RTEMS-score/osdSpin.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdThreadHooks.d  ../osi/os/default/osdThreadHooks.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdMutex.d  ../osi/os/RTEMS-score/osdMutex.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdThreadExtra.d  ../osi/os/RTEMS-score/osdThreadExtra.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdStdio.d  ../osi/os/posix/osdStdio.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdThread.d  ../osi/os/RTEMS-score/osdThread.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsStdio.d  ../osi/epicsStdio.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsTempFile.d  ../osi/os/posix/epicsTempFile.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE    -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsReadline.d  ../osi/epicsReadline.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdEnv.d  ../osi/os/default/osdEnv.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdSignal.d  ../osi/os/RTEMS-score/osdSignal.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdPoolStatus.d  ../osi/os/RTEMS-score/osdPoolStatus.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdFindSymbol.d  ../osi/os/RTEMS-score/osdFindSymbol.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdInterrupt.d  ../osi/os/RTEMS/osdInterrupt.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdAssert.d  ../osi/os/default/osdAssert.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsSocketConvertErrnoToString.d  ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF systemCallIntMech.d  ../osi/os/posix/systemCallIntMech.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osiSock.d  ../osi/osiSock.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdSockUnsentCount.d  ../osi/os/default/osdSockUnsentCount.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdSockAddrReuse.d  ../osi/os/default/osdSockAddrReuse.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osiClockTime.d  ../osi/osiClockTime.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF osdSock.d  ../osi/os/posix/osdSock.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsAtomicOSD.d  ../osi/os/RTEMS-score/epicsAtomicOSD.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsMath.d  ../osi/epicsMath.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsGeneralTime.d  ../osi/epicsGeneralTime.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsMessageQueue.d  ../osi/epicsMessageQueue.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsEvent.d  ../osi/epicsEvent.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsTime.d  ../osi/epicsTime.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsMutex.d  ../osi/epicsMutex.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsUnitTest.d  ../misc/epicsUnitTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsThread.d  ../osi/epicsThread.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF truncateFile.d  ../misc/truncateFile.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsString.d  ../misc/epicsString.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF ipAddrToAsciiAsynchronous.d  ../misc/ipAddrToAsciiAsynchronous.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsStdlib.d  ../misc/epicsStdlib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsExit.d  ../misc/epicsExit.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsConvert.d  ../misc/epicsConvert.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF cantProceed.d  ../misc/cantProceed.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF adjustment.d  ../misc/adjustment.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF alarmString.d  ../misc/alarmString.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF aToIPAddr.d  ../misc/aToIPAddr.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF macUtil.d  ../macLib/macUtil.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF macEnv.d  ../macLib/macEnv.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF macCore.d  ../macLib/macCore.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF logClient.d  ../log/logClient.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF iocLog.d  ../log/iocLog.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF libComRegister.d  ../iocsh/libComRegister.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF registry.d  ../iocsh/registry.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF initHooks.d  ../iocsh/initHooks.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF iocsh.d  ../iocsh/iocsh.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF freeListLib.d  ../freeList/freeListLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF gpHashLib.d  ../gpHash/gpHashLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF fdManager.d  ../fdmgr/fdManager.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF fdmgr.d  ../fdmgr/fdmgr.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF errSymTbl.d  errSymTbl.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF errSymLib.d  ../error/errSymLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF errlog.d  ../error/errlog.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF envData.d  envData.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF envSubr.d  ../env/envSubr.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF ellSort.d  ../ellLib/ellSort.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF ellLib.d  ../ellLib/ellLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF dbmf.d  ../dbmf/dbmf.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF epicsSingletonMutex.d  ../cxxTemplates/epicsSingletonMutex.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF resourceLib.d  ../cxxTemplates/resourceLib.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF cvtFast.d  ../cvtFast/cvtFast.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF calcPerform.d  ../calc/calcPerform.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF postfix.d  ../calc/postfix.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF bucketLib.d  ../bucketLib/bucketLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF asTrapWrite.d  ../as/asTrapWrite.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -MM -MF asLib.d  asLib.c
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/RTEMS-uC5282  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdSock.h
mkdir ../../../../include/os/RTEMS
Installing OS dependent include file ../../../../include/os/RTEMS/osdInterrupt.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdMutex.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdEvent.h
Installing OS dependent include file ../../../../include/os/RTEMS/epicsMath.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdMessageQueue.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdStrtod.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdPoolStatus.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdThread.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdTime.h
Installing OS dependent include file ../../../../include/os/RTEMS/osiUnistd.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdWireFormat.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdWireConfig.h
Installing OS dependent include file ../../../../include/os/RTEMS/epicsAtomicOSD.h
Installing OS dependent include file ../../../../include/os/RTEMS/epicsGetopt.h
Installing OS dependent include file ../../../../include/os/RTEMS/osdVME.h
Installing OS dependent include file ../../../../include/os/RTEMS/epicsMMIO.h
Installing OS dependent include file ../../../../include/os/RTEMS/epicsMMIODef.h
Installing generated generic include file ../../../../include/libComVersion.h
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../as/asTrapWrite.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../bucketLib/bucketLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../calc/postfix.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../calc/calcPerform.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c asLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../cvtFast/cvtFast.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../cxxTemplates/epicsSingletonMutex.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../cxxTemplates/resourceLib.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../ellLib/ellLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../dbmf/dbmf.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../ellLib/ellSort.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c envData.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../env/envSubr.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../error/errlog.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c errSymTbl.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../error/errSymLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../fdmgr/fdmgr.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../fdmgr/fdManager.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../freeList/freeListLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../gpHash/gpHashLib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../iocsh/initHooks.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../iocsh/registry.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../iocsh/iocsh.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../iocsh/libComRegister.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../log/iocLog.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../macLib/macCore.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../log/logClient.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../macLib/macEnv.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../macLib/macUtil.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/alarmString.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/aToIPAddr.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/adjustment.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/cantProceed.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/epicsConvert.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/epicsExit.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/epicsStdlib.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/epicsString.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/truncateFile.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/ipAddrToAsciiAsynchronous.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../misc/epicsUnitTest.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/epicsThread.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/epicsEvent.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/epicsMutex.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/epicsMessageQueue.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/epicsMath.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/epicsAtomicOSD.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/epicsTime.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/osiClockTime.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/epicsGeneralTime.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/posix/osdSock.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/osdSockAddrReuse.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/osdSockUnsentCount.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/osiSock.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/posix/systemCallIntMech.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/osdAssert.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/osdFindSymbol.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS/osdInterrupt.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/osdPoolStatus.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/osdSignal.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE    -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/epicsReadline.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/osdEnv.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/posix/epicsTempFile.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/epicsStdio.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/posix/osdStdio.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/osdThread.c
In file included from ../osi/compiler/gcc/epicsAtomicCD.h:32,
                 from ../osi/epicsAtomic.h:107,
                 from ../osi/os/RTEMS-score/osdThread.c:40:
../osi/os/RTEMS-score/epicsAtomicOSD.h: In function 'epicsAtomicReadMemoryBarrier':
../osi/os/RTEMS-score/epicsAtomicOSD.h:38: error: implicit declaration of function 'epicsAtomicMemoryBarrierFallback'
../../../../configure/RULES_BUILD:258: recipe for target 'osdThread.o' failed
make[4]: *** [osdThread.o] Error 1
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/osdThreadExtra.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/osdThreadHooks.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/osdMutex.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/osdSpin.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/osdEvent.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/osdTime.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/osdProcess.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/posix/osdMonotonic.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/osdNetIntf.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/osdMessageQueue.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/osdgetexec.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/devLibVME.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/RTEMS-score/devLibVMEOSD.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/epicsStackTrace.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/osdBackTrace.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/os/default/osdFindAddr.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../pool/poolJob.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../pool/threadPool.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../ring/epicsRingPointer.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../ring/epicsRingBytes.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../taskwd/taskwd.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../timer/epicsTimer.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../timer/timer.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../timer/timerQueue.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../timer/timerQueueActive.cpp
                 from ../timer/timerQueueActive.cpp:18:
../osi/os/RTEMS-score/epicsAtomicOSD.h: In function 'void epicsAtomicReadMemoryBarrier()':
../osi/os/RTEMS-score/epicsAtomicOSD.h:38: error: 'epicsAtomicMemoryBarrierFallback' was not declared in this scope
../../../../configure/RULES_BUILD:266: recipe for target 'timerQueueActive.o' failed
make[4]: *** [timerQueueActive.o] Error 1
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../timer/timerQueueActiveMgr.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-g++ -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems     -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall       -DMY_DO_BOOTP=NULL     -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../timer/timerQueuePassive.cpp
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../yajl/yajl.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../yajl/yajl_alloc.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../yajl/yajl_buf.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../yajl/yajl_encode.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../yajl/yajl_gen.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../yajl/yajl_lex.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../yajl/yajl_parser.c
/usr/local/vw/rtems/rtems-4.10.2/bin/m68k-rtems4.10.2-gcc --pipe -B/usr/local/rtems/rtems-4.10.2/m68k-rtems4.10.2/uC5282/lib/ -specs bsp_specs -qrtems   -fasm   -mcpu=5282     -D_GNU_SOURCE -D_DEFAULT_SOURCE            -DUNIX      -O2 -g -g   -Wall -Werror-implicit-function-declaration       -DMY_DO_BOOTP=NULL    -D__LINUX_ERRNO_EXTENSIONS__ -DRTEMS_LEGACY_STACK  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/RTEMS-score -I../osi/os/RTEMS -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../osi/osiNTPTime.c
make[4]: Target 'install' not remade because of errors.
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.RTEMS-uC5282'
../../../configure/RULES_ARCHS:58: recipe for target 'install.RTEMS-uC5282' failed
make[3]: *** [install.RTEMS-uC5282] Error 2
/Jenkins/jenkins/bin/make -C O.vxWorks-ppc32 -f ../Makefile TOP=../../../.. \
    T_A=vxWorks-ppc32 install
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.vxWorks-ppc32'
perl -CSD ../error/makeStatTbl.pl  ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/vxWorks-ppc32  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
perl -CSD ../../../../bin/linux-x86_64/bldEnvData.pl  -t vxWorks-ppc32 \
	-c gcc -s vxWorks ../../../../configure
Generating envData.c
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/e_flex -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ../as/asLib_lex.l
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF strtoll.d  ../osi/os/vxWorks/strtoll.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF strtoull.d  ../osi/os/vxWorks/strtoull.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF logMsgToErrlog.d  ../osi/os/vxWorks/logMsgToErrlog.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF veclist.d  ../osi/os/vxWorks/veclist.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsDynLink.d  ../osi/os/vxWorks/epicsDynLink.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF atReboot.d  ../osi/os/vxWorks/atReboot.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osiNTPTime.d  ../osi/osiNTPTime.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF tz2timezone.d  ../osi/os/vxWorks/tz2timezone.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF yajl_parser.d  ../yajl/yajl_parser.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF yajl_lex.d  ../yajl/yajl_lex.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF yajl_gen.d  ../yajl/yajl_gen.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF yajl_encode.d  ../yajl/yajl_encode.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF yajl_buf.d  ../yajl/yajl_buf.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF yajl_alloc.d  ../yajl/yajl_alloc.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF yajl.d  ../yajl/yajl.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF timerQueuePassive.d  ../timer/timerQueuePassive.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF timerQueueActiveMgr.d  ../timer/timerQueueActiveMgr.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF timerQueueActive.d  ../timer/timerQueueActive.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF timerQueue.d  ../timer/timerQueue.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF timer.d  ../timer/timer.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF taskwd.d  ../taskwd/taskwd.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsTimer.d  ../timer/epicsTimer.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsRingBytes.d  ../ring/epicsRingBytes.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsRingPointer.d  ../ring/epicsRingPointer.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF threadPool.d  ../pool/threadPool.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF poolJob.d  ../pool/poolJob.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdFindAddr.d  ../osi/os/default/osdFindAddr.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdBackTrace.d  ../osi/os/default/osdBackTrace.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsStackTrace.d  ../osi/epicsStackTrace.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF devLibVMEOSD.d  ../osi/os/vxWorks/devLibVMEOSD.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF devLibVME.d  ../osi/devLibVME.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdgetexec.d  ../osi/os/default/osdgetexec.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdMessageQueue.d  ../osi/os/vxWorks/osdMessageQueue.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdProcess.d  ../osi/os/vxWorks/osdProcess.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdNetIntf.d  ../osi/os/default/osdNetIntf.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdMonotonic.d  ../osi/os/vxWorks/osdMonotonic.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdTime.d  ../osi/os/vxWorks/osdTime.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdEvent.d  ../osi/os/vxWorks/osdEvent.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdMutex.d  ../osi/os/vxWorks/osdMutex.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdSpin.d  ../osi/os/vxWorks/osdSpin.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdThreadHooks.d  ../osi/os/default/osdThreadHooks.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdThreadExtra.d  ../osi/os/vxWorks/osdThreadExtra.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdStdio.d  ../osi/os/vxWorks/osdStdio.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdThread.d  ../osi/os/vxWorks/osdThread.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsStdio.d  ../osi/epicsStdio.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsTempFile.d  ../osi/os/posix/epicsTempFile.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_LEDLIB   -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsReadline.d  ../osi/epicsReadline.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdEnv.d  ../osi/os/vxWorks/osdEnv.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdSignal.d  ../osi/os/vxWorks/osdSignal.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdPoolStatus.d  ../osi/os/vxWorks/osdPoolStatus.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdInterrupt.d  ../osi/os/vxWorks/osdInterrupt.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdAssert.d  ../osi/os/default/osdAssert.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdFindSymbol.d  ../osi/os/vxWorks/osdFindSymbol.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsSocketConvertErrnoToString.d  ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF systemCallIntMech.d  ../osi/os/posix/systemCallIntMech.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osiSock.d  ../osi/osiSock.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdSockUnsentCount.d  ../osi/os/default/osdSockUnsentCount.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdSockAddrReuse.d  ../osi/os/default/osdSockAddrReuse.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osiClockTime.d  ../osi/osiClockTime.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF osdSock.d  ../osi/os/vxWorks/osdSock.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsAtomicOSD.d  ../osi/os/vxWorks/epicsAtomicOSD.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsMath.d  ../osi/epicsMath.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsGeneralTime.d  ../osi/epicsGeneralTime.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsMessageQueue.d  ../osi/epicsMessageQueue.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsEvent.d  ../osi/epicsEvent.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsTime.d  ../osi/epicsTime.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsMutex.d  ../osi/epicsMutex.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsThread.d  ../osi/epicsThread.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsUnitTest.d  ../misc/epicsUnitTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF truncateFile.d  ../misc/truncateFile.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF ipAddrToAsciiAsynchronous.d  ../misc/ipAddrToAsciiAsynchronous.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsString.d  ../misc/epicsString.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsStdlib.d  ../misc/epicsStdlib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsExit.d  ../misc/epicsExit.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsConvert.d  ../misc/epicsConvert.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF cantProceed.d  ../misc/cantProceed.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF adjustment.d  ../misc/adjustment.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF alarmString.d  ../misc/alarmString.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF aToIPAddr.d  ../misc/aToIPAddr.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF macUtil.d  ../macLib/macUtil.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF macEnv.d  ../macLib/macEnv.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF macCore.d  ../macLib/macCore.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF logClient.d  ../log/logClient.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF iocLog.d  ../log/iocLog.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF registry.d  ../iocsh/registry.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF initHooks.d  ../iocsh/initHooks.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF libComRegister.d  ../iocsh/libComRegister.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF iocsh.d  ../iocsh/iocsh.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF gpHashLib.d  ../gpHash/gpHashLib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF freeListLib.d  ../freeList/freeListLib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF fdManager.d  ../fdmgr/fdManager.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF fdmgr.d  ../fdmgr/fdmgr.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF errSymTbl.d  errSymTbl.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF errSymLib.d  ../error/errSymLib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF errlog.d  ../error/errlog.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF envData.d  envData.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF ellSort.d  ../ellLib/ellSort.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF ellLib.d  ../ellLib/ellLib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF envSubr.d  ../env/envSubr.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF dbmf.d  ../dbmf/dbmf.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF epicsSingletonMutex.d  ../cxxTemplates/epicsSingletonMutex.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF resourceLib.d  ../cxxTemplates/resourceLib.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF cvtFast.d  ../cvtFast/cvtFast.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF postfix.d  ../calc/postfix.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF calcPerform.d  ../calc/calcPerform.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF bucketLib.d  ../bucketLib/bucketLib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF asTrapWrite.d  ../as/asTrapWrite.c
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -basLib  ../as/asLib.y
mv asLib.tab.c asLib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -MM -MF asLib.d  asLib.c
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/vxWorks-ppc32  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdSock.h
mkdir ../../../../include/os/vxWorks
Installing OS dependent include file ../../../../include/os/vxWorks/osdInterrupt.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdMutex.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdEvent.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsMath.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdMessageQueue.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdStrtod.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdPoolStatus.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdThread.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdTime.h
Installing OS dependent include file ../../../../include/os/vxWorks/osiUnistd.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdWireFormat.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdWireConfig.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsAtomicOSD.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsGetopt.h
Installing OS dependent include file ../../../../include/os/vxWorks/osdVME.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsMMIO.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsMMIODef.h
Installing OS dependent include file ../../../../include/os/vxWorks/camacLib.h
Installing OS dependent include file ../../../../include/os/vxWorks/epicsDynLink.h
Installing OS dependent include file ../../../../include/os/vxWorks/module_types.h
Installing OS dependent include file ../../../../include/os/vxWorks/task_params.h
Installing generated generic include file ../../../../include/libComVersion.h
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/vxComLibrary.c
../osi/os/vxWorks/vxComLibrary.c: In function 'vxComLibrary':
../osi/os/vxWorks/vxComLibrary.c:26: warning: 'symFindByNameEPICS' is deprecated (declared at ../osi/os/vxWorks/epicsDynLink.h:31)
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../as/asTrapWrite.c
In file included from ../as/asTrapWrite.c:24:
../freeList/freeList.h:44:2: warning: no newline at end of file
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c asLib.c
In file included from ../as/asLibRoutines.c:27,
                 from ../as/asLib.y:13:
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../bucketLib/bucketLib.c
In file included from ../bucketLib/bucketLib.c:28:
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../calc/postfix.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../calc/calcPerform.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../cvtFast/cvtFast.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../cxxTemplates/resourceLib.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../cxxTemplates/epicsSingletonMutex.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../dbmf/dbmf.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../ellLib/ellLib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../ellLib/ellSort.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c envData.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../env/envSubr.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../error/errlog.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../error/errSymLib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c errSymTbl.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../fdmgr/fdmgr.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../fdmgr/fdManager.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../freeList/freeListLib.c
In file included from ../freeList/freeListLib.c:27:
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../gpHash/gpHashLib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../iocsh/iocsh.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../iocsh/initHooks.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../iocsh/registry.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../iocsh/libComRegister.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../log/iocLog.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../log/logClient.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../macLib/macCore.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../macLib/macEnv.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../macLib/macUtil.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/alarmString.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/aToIPAddr.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/adjustment.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/cantProceed.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/epicsConvert.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/epicsExit.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/epicsString.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/epicsStdlib.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/truncateFile.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/epicsUnitTest.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../misc/ipAddrToAsciiAsynchronous.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/epicsMutex.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/epicsThread.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/epicsEvent.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/epicsMessageQueue.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/epicsMath.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/epicsTime.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/epicsAtomicOSD.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/epicsGeneralTime.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/osiClockTime.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdSock.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/default/osdSockAddrReuse.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/default/osdSockUnsentCount.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/osiSock.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/posix/systemCallIntMech.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/default/osdAssert.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdFindSymbol.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdInterrupt.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdPoolStatus.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdSignal.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_LEDLIB   -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/epicsReadline.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdEnv.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/posix/epicsTempFile.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/epicsStdio.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdStdio.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdThreadExtra.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdThread.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/default/osdThreadHooks.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMutex.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdSpin.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdEvent.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall    -DBUILD_TIME=1630697673  -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdTime.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMonotonic.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdProcess.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/default/osdNetIntf.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMessageQueue.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/default/osdgetexec.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/devLibVME.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/devLibVMEOSD.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/epicsStackTrace.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/default/osdBackTrace.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/default/osdFindAddr.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../pool/poolJob.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../ring/epicsRingPointer.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../pool/threadPool.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../ring/epicsRingBytes.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../taskwd/taskwd.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../timer/timer.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../timer/epicsTimer.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../timer/timerQueue.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../timer/timerQueueActive.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../yajl/yajl.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../timer/timerQueueActiveMgr.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../timer/timerQueuePassive.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../yajl/yajl_alloc.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../yajl/yajl_buf.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../yajl/yajl_encode.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../yajl/yajl_gen.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../yajl/yajl_lex.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../yajl/yajl_parser.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/osiNTPTime.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/atReboot.cpp
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/epicsDynLink.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/veclist.c
../osi/os/vxWorks/veclist.c: In function 'veclist':
../osi/os/vxWorks/veclist.c:76: warning: 'symFindByValue' is deprecated (declared at /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/symLib.h:119)
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/tz2timezone.c
In file included from /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/taskLib.h:259,
                 from /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/envLib.h:38,
                 from ../osi/os/vxWorks/tz2timezone.c:60:
/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vsbConfig.h:42:2: warning: #warning "VxWorks Source Build (VSB) project not specified; using default VxWorks UP configuration under $WIND_BASE/target/lib/h/config"
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/strtoll.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/strtoull.c
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h -I/usr/local/vw/vxWorks-6.8/vxworks-6.8/target/h/wrn/coreip -c ../osi/os/vxWorks/logMsgToErrlog.cpp
Installing created executable ../../../../bin/vxWorks-ppc32/vxComLibrary.o
mkdir ../../../../bin/vxWorks-ppc32
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/arppc -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o osiNTPTime.o tz2timezone.o atReboot.o epicsDynLink.o veclist.o logMsgToErrlog.o strtoll.o strtoull.o
/usr/local/vw/vxWorks-6.8/gnu/4.1.2-vxworks-6.8/x86-linux2/bin/ranlibppc libCom.a
Installing library ../../../../lib/vxWorks-ppc32/libCom.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.vxWorks-ppc32'
/Jenkins/jenkins/bin/make -C O.vxWorks-ppc32sf -f ../Makefile TOP=../../../.. \
    T_A=vxWorks-ppc32sf install
make[4]: Entering directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.vxWorks-ppc32sf'
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/vxWorks-ppc32sf  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
perl -CSD ../error/makeStatTbl.pl  ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
perl -CSD ../../../../bin/linux-x86_64/bldEnvData.pl  -t vxWorks-ppc32sf \
	-c gcc -s vxWorks ../../../../configure
Generating envData.c
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/e_flex -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ../as/asLib_lex.l
/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/antelope -basLib  ../as/asLib.y
mv asLib.tab.c asLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF strtoull.d  ../osi/os/vxWorks/strtoull.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF strtoll.d  ../osi/os/vxWorks/strtoll.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF logMsgToErrlog.d  ../osi/os/vxWorks/logMsgToErrlog.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsDynLink.d  ../osi/os/vxWorks/epicsDynLink.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF veclist.d  ../osi/os/vxWorks/veclist.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF atReboot.d  ../osi/os/vxWorks/atReboot.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osiNTPTime.d  ../osi/osiNTPTime.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF tz2timezone.d  ../osi/os/vxWorks/tz2timezone.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF yajl_parser.d  ../yajl/yajl_parser.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF yajl_lex.d  ../yajl/yajl_lex.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF yajl_gen.d  ../yajl/yajl_gen.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF yajl_encode.d  ../yajl/yajl_encode.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF yajl_buf.d  ../yajl/yajl_buf.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF yajl_alloc.d  ../yajl/yajl_alloc.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF yajl.d  ../yajl/yajl.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF timerQueuePassive.d  ../timer/timerQueuePassive.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF timerQueueActiveMgr.d  ../timer/timerQueueActiveMgr.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF timerQueueActive.d  ../timer/timerQueueActive.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF timerQueue.d  ../timer/timerQueue.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF timer.d  ../timer/timer.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsTimer.d  ../timer/epicsTimer.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF taskwd.d  ../taskwd/taskwd.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsRingBytes.d  ../ring/epicsRingBytes.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsRingPointer.d  ../ring/epicsRingPointer.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF threadPool.d  ../pool/threadPool.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF poolJob.d  ../pool/poolJob.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdFindAddr.d  ../osi/os/default/osdFindAddr.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdBackTrace.d  ../osi/os/default/osdBackTrace.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsStackTrace.d  ../osi/epicsStackTrace.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF devLibVMEOSD.d  ../osi/os/vxWorks/devLibVMEOSD.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF devLibVME.d  ../osi/devLibVME.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdgetexec.d  ../osi/os/default/osdgetexec.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdMessageQueue.d  ../osi/os/vxWorks/osdMessageQueue.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdNetIntf.d  ../osi/os/default/osdNetIntf.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdProcess.d  ../osi/os/vxWorks/osdProcess.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdMonotonic.d  ../osi/os/vxWorks/osdMonotonic.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdEvent.d  ../osi/os/vxWorks/osdEvent.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdTime.d  ../osi/os/vxWorks/osdTime.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdSpin.d  ../osi/os/vxWorks/osdSpin.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdMutex.d  ../osi/os/vxWorks/osdMutex.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdThreadHooks.d  ../osi/os/default/osdThreadHooks.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdThreadExtra.d  ../osi/os/vxWorks/osdThreadExtra.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdStdio.d  ../osi/os/vxWorks/osdStdio.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdThread.d  ../osi/os/vxWorks/osdThread.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsStdio.d  ../osi/epicsStdio.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsTempFile.d  ../osi/os/posix/epicsTempFile.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_LEDLIB   -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsReadline.d  ../osi/epicsReadline.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdSignal.d  ../osi/os/vxWorks/osdSignal.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdEnv.d  ../osi/os/vxWorks/osdEnv.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdPoolStatus.d  ../osi/os/vxWorks/osdPoolStatus.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdInterrupt.d  ../osi/os/vxWorks/osdInterrupt.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdFindSymbol.d  ../osi/os/vxWorks/osdFindSymbol.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdAssert.d  ../osi/os/default/osdAssert.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsSocketConvertErrnoToString.d  ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF systemCallIntMech.d  ../osi/os/posix/systemCallIntMech.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osiSock.d  ../osi/osiSock.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdSockUnsentCount.d  ../osi/os/default/osdSockUnsentCount.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdSockAddrReuse.d  ../osi/os/default/osdSockAddrReuse.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osdSock.d  ../osi/os/vxWorks/osdSock.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF osiClockTime.d  ../osi/osiClockTime.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsAtomicOSD.d  ../osi/os/vxWorks/epicsAtomicOSD.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsGeneralTime.d  ../osi/epicsGeneralTime.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsMath.d  ../osi/epicsMath.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsMessageQueue.d  ../osi/epicsMessageQueue.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsTime.d  ../osi/epicsTime.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsEvent.d  ../osi/epicsEvent.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsMutex.d  ../osi/epicsMutex.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsThread.d  ../osi/epicsThread.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsUnitTest.d  ../misc/epicsUnitTest.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF truncateFile.d  ../misc/truncateFile.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsString.d  ../misc/epicsString.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF ipAddrToAsciiAsynchronous.d  ../misc/ipAddrToAsciiAsynchronous.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsStdlib.d  ../misc/epicsStdlib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsExit.d  ../misc/epicsExit.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsConvert.d  ../misc/epicsConvert.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF cantProceed.d  ../misc/cantProceed.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF adjustment.d  ../misc/adjustment.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF aToIPAddr.d  ../misc/aToIPAddr.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF alarmString.d  ../misc/alarmString.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF macUtil.d  ../macLib/macUtil.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF macEnv.d  ../macLib/macEnv.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF macCore.d  ../macLib/macCore.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF logClient.d  ../log/logClient.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF iocLog.d  ../log/iocLog.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF libComRegister.d  ../iocsh/libComRegister.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF registry.d  ../iocsh/registry.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF initHooks.d  ../iocsh/initHooks.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF iocsh.d  ../iocsh/iocsh.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF gpHashLib.d  ../gpHash/gpHashLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF freeListLib.d  ../freeList/freeListLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF fdManager.d  ../fdmgr/fdManager.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF errSymTbl.d  errSymTbl.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF errSymLib.d  ../error/errSymLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF fdmgr.d  ../fdmgr/fdmgr.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF errlog.d  ../error/errlog.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF envData.d  envData.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF ellSort.d  ../ellLib/ellSort.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF envSubr.d  ../env/envSubr.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF ellLib.d  ../ellLib/ellLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF dbmf.d  ../dbmf/dbmf.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF epicsSingletonMutex.d  ../cxxTemplates/epicsSingletonMutex.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF resourceLib.d  ../cxxTemplates/resourceLib.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF cvtFast.d  ../cvtFast/cvtFast.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF postfix.d  ../calc/postfix.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF calcPerform.d  ../calc/calcPerform.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF bucketLib.d  ../bucketLib/bucketLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF asTrapWrite.d  ../as/asTrapWrite.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -MM -MF asLib.d  asLib.c
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/linux-x86_64/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/bin/vxWorks-ppc32sf  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="20"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
Installing OS dependent include file ../../../../include/os/vxWorks/task_params.h
Installing generated generic include file ../../../../include/libComVersion.h
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h     -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/vxComLibrary.c
../osi/os/vxWorks/vxComLibrary.c: In function 'vxComLibrary':
../osi/os/vxWorks/vxComLibrary.c:26: warning: 'symFindByNameEPICS' is deprecated (declared at ../osi/os/vxWorks/epicsDynLink.h:30)
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../as/asTrapWrite.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c asLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../bucketLib/bucketLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../calc/postfix.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../cvtFast/cvtFast.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../calc/calcPerform.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../cxxTemplates/resourceLib.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../cxxTemplates/epicsSingletonMutex.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../dbmf/dbmf.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../ellLib/ellLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../ellLib/ellSort.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c envData.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../env/envSubr.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../error/errlog.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../error/errSymLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c errSymTbl.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../fdmgr/fdmgr.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../freeList/freeListLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../gpHash/gpHashLib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../fdmgr/fdManager.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../iocsh/iocsh.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../iocsh/initHooks.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../iocsh/registry.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../iocsh/libComRegister.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../log/iocLog.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../log/logClient.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../macLib/macEnv.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../macLib/macCore.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../macLib/macUtil.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/alarmString.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/aToIPAddr.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/adjustment.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/cantProceed.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/epicsConvert.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/epicsExit.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/epicsStdlib.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/truncateFile.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/epicsString.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/epicsUnitTest.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../misc/ipAddrToAsciiAsynchronous.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/epicsThread.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/epicsMutex.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/epicsEvent.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/epicsMessageQueue.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/epicsMath.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/epicsAtomicOSD.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/epicsTime.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/epicsGeneralTime.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/osiClockTime.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/default/osdSockAddrReuse.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdSock.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/default/osdSockUnsentCount.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/osiSock.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/posix/systemCallIntMech.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/default/epicsSocketConvertErrnoToString.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/default/osdAssert.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdFindSymbol.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdInterrupt.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdPoolStatus.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdSignal.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdEnv.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_LEDLIB   -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/epicsReadline.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/posix/epicsTempFile.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/epicsStdio.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdStdio.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdThread.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdThreadExtra.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/default/osdThreadHooks.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMutex.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdSpin.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdEvent.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMonotonic.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdProcess.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall    -DBUILD_TIME=1630697674  -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdTime.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/default/osdgetexec.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/osdMessageQueue.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/default/osdNetIntf.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/devLibVMEOSD.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/devLibVME.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/epicsStackTrace.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/default/osdBackTrace.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/default/osdFindAddr.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../pool/poolJob.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../ring/epicsRingPointer.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../pool/threadPool.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../ring/epicsRingBytes.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../taskwd/taskwd.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../timer/epicsTimer.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../timer/timer.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../timer/timerQueue.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../timer/timerQueueActive.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../timer/timerQueueActiveMgr.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../yajl/yajl.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../yajl/yajl_alloc.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../timer/timerQueuePassive.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../yajl/yajl_buf.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../yajl/yajl_encode.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../yajl/yajl_gen.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../yajl/yajl_parser.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../yajl/yajl_lex.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/osiNTPTime.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/atReboot.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/epicsDynLink.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/veclist.c
../osi/os/vxWorks/veclist.c: In function 'veclist':
../osi/os/vxWorks/veclist.c:76: warning: 'symFindByValue' is deprecated (declared at /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/symLib.h:187)
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/tz2timezone.c
Installing created executable ../../../../bin/vxWorks-ppc32sf/vxComLibrary.o
mkdir ../../../../bin/vxWorks-ppc32sf
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/strtoll.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/logMsgToErrlog.cpp
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ccppc            -DCPU=PPC32  -DvxWorks=vxWorks -include /usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/vxWorks.h  -DBUILDING_libCom_API   -O2   -Wall -Werror-implicit-function-declaration      -mstrict-align -mlongcall -msoft-float    -fno-builtin  -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/vxWorks -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/vxWorks -I../../../../include        -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h -I/usr/local/vw/vxWorks-6.9/vxworks-6.9/target/h/wrn/coreip -c ../osi/os/vxWorks/strtoull.c
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/arppc -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o osiNTPTime.o tz2timezone.o atReboot.o epicsDynLink.o veclist.o logMsgToErrlog.o strtoll.o strtoull.o
/usr/local/vw/vxWorks-6.9/gnu/4.3.3-vxworks-6.9/x86-linux2/bin/ranlibppc libCom.a
Installing library ../../../../lib/vxWorks-ppc32sf/libCom.a
make[4]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src/O.vxWorks-ppc32sf'
make[3]: Target 'install' not remade because of errors.
make[3]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom/src'
../../configure/RULES_DIRS:85: recipe for target 'src.install' failed
make[2]: *** [src.install] Error 2
make[2]: Target 'install' not remade because of errors.
make[2]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules/libcom'
../configure/RULES_DIRS:85: recipe for target 'libcom.install' failed
make[1]: *** [libcom.install] Error 2
make[1]: Target 'install' not remade because of errors.
make[1]: Leaving directory '/Jenkins/jenkins/jobs/epics-7.0/workspace/OS/linux64/modules'
configure/RULES_DIRS:85: recipe for target 'modules.install' failed
make: *** [modules.install] Error 2
make: Target 'all' not remade because of errors.
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Did not find any matching files.
Notifying upstream projects of job completion
Email was triggered for: Failure - Any
Sending email for trigger: Failure - Any
Sending email to: core-talk at aps.anl.gov
epics-7.0 » linux64 - Build # 360 - Fixed! APS Jenkins via Core-talk
epics-7.0 » linux64 - Build # 358 - Still Failing! APS Jenkins via Core-talk
Prev: Build completed: EPICS Base 7 base-7.0-382 AppVeyor via Core-talk
Next: epics-7.0 » linux32 - Build # 359 - Fixed! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: epics-7.0 » linux64 - Build # 358 - Still Failing! APS Jenkins via Core-talk
Next: epics-7.0 » linux64 - Build # 360 - Fixed! APS Jenkins via Core-talk
ANJ, 03 Sep 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
