See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win64/536/display/redirect?page=changes>
Changes:
[Andrew Johnson] Adjust build rules for POD to HTML conversion
[Andrew Johnson] Reference doc tweaks to the dfanout record
Started by upstream project "epics-base-3.15" build number 542
originally caused by:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-win64/ws/>
The recommended git tool is: NONE
No credentials specified
> C:/Program Files/Git/cmd/git.exe rev-parse --resolve-git-dir C:\jenkins\win64-2\workspace\epics-base-3.15-win64\.git # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
> C:/Program Files/Git/cmd/git.exe --version # timeout=10
> git --version # 'git version 2.20.1.windows.1'
Setting http proxy: webproxy1.anl.gov:9091
> C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress -- https://git.launchpad.net/epics-base +refs/heads/3.15:refs/remotes/origin/3.15 # timeout=10
> C:/Program Files/Git/cmd/git.exe rev-parse "origin/3.15^{commit}" # timeout=10
Checking out Revision e7ea81c7a29631179aaba92567ad62951b8dfd8b (origin/3.15)
> C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
> C:/Program Files/Git/cmd/git.exe checkout -f e7ea81c7a29631179aaba92567ad62951b8dfd8b # timeout=10
Commit message: "Reference doc tweaks to the dfanout record"
> C:/Program Files/Git/cmd/git.exe rev-list --no-walk 67fcd656568649b81d5a806910deb024630b8611 # timeout=10
Cleaning workspace
> C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
> C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
> C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
[epics-base-3.15-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins1420150405502635530.bat
jenkins@JEEVES C:\jenkins\win64-2\workspace\epics-base-3.15-win64>make -O -j4 host
'make' is not recognized as an internal or external command,
operable program or batch file.
jenkins@JEEVES C:\jenkins\win64-2\workspace\epics-base-3.15-win64>exit 9009
Build step 'Execute Windows batch command' marked build as failure
- Jenkins build is back to normal : epics-base-3.15-win64 #537 APS Jenkins via Core-talk
Build failed in Jenkins: epics-base-3.15-win32s #503 APS Jenkins via Core-talk
Build failed in Jenkins: epics-base-3.15-win64s #518 APS Jenkins via Core-talk
<2021>
2025
2026
Jenkins build is back to normal : epics-base-3.15-win32s #504 APS Jenkins via Core-talk
<2021>
2025
2026
