2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: [Bug 1702254] Re: add -fno-strict-aliasing for more architectures in R3.16 src/ca/legacy Makefiles
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 11 Oct 2021 18:19:00 -0000
** Changed in: epics-base/3.16
       Status: Fix Committed => Fix Released
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1702254
Title:
  Makefiles
Status in EPICS Base:
  Fix Released
Status in EPICS Base 3.16 series:
  Fix Released
Status in EPICS Base 7.0 series:
  Fix Released
Bug description:
  In addition to the existing
  USR_CXXFLAGS_Linux = -fno-strict-aliasing
  USR_CXXFLAGS_RTEMS = -fno-strict-aliasing
  add this line to src/ca/legacy/gdd/Makefile:
  USR_CXXFLAGS_vxWorks = -fno-strict-aliasing
  Add all three lines to src/ca/legacy/pcas/build/Makefile.
  The vxWorks 6 compilers between 6.2 and 6.7 all print warnings about
  broken strict aliasing rules and all understand that flag. The vxWorks
  5 compiler does not understand the flag but 3.16 does not build with
  vxWorks 5 anyway.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1702254/+subscriptions
Prev: [Bug 1938459] Re: int64in only checks lower 32 bits for change Andrew Johnson via Core-talk
Next: [Bug 1782308] Re: channel filters should ignore unknown filter tags Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Build failed: EPICS Base 7 base-7.0-402 AppVeyor via Core-talk
ANJ, 11 Oct 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
