2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: epics-7.0 » mac - Build # 370 - Failure!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 3 Nov 2021 14:13:39 -0500 (CDT)
Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=mac/370/
This job failed to build.
Started by upstream project "epics-7.0" build number 370
originally caused by:
 Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on mac-1 (mac) in workspace /Users/jenkins/workspace/epics-7.0/OS/mac
The recommended git tool is: NONE
No credentials specified
 > git rev-parse --resolve-git-dir /Users/jenkins/workspace/epics-7.0/OS/mac/.git # timeout=10
Fetching changes from the remote Git repository
 > git config remote.origin.url https://git.launchpad.net/epics-base/ # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base/
 > git --version # timeout=10
 > git --version # 'git version 2.21.1 (Apple Git-122.3)'
Setting http proxy: webproxy1.anl.gov:9091
 > git fetch --tags --force --progress -- https://git.launchpad.net/epics-base/ +refs/heads/*:refs/remotes/origin/* # timeout=10
Checking out Revision 4340e7644557dff847fdc839e203e4c7fc695b35 (refs/remotes/origin/7.0)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f 4340e7644557dff847fdc839e203e4c7fc695b35 # timeout=10
Commit message: "drop unused dbCaGetUpdateCount()"
 > git rev-list --no-walk 955dcfc7b58afad1efc7b9a01bac3d8242bfc32b # timeout=10
Cleaning workspace
 > git rev-parse --verify HEAD # timeout=10
Resetting working tree
 > git reset --hard # timeout=10
 > git clean -fdx # timeout=10
 > git submodule foreach --recursive git reset --hard # timeout=10
 > git submodule foreach git clean -fdx # timeout=10
 > git remote # timeout=10
 > git submodule init # timeout=10
 > git submodule sync # timeout=10
 > git config --get remote.origin.url # timeout=10
 > git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
 > git config --get submodule.modules/pvData.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
 > git config --get submodule.modules/pvAccess.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
 > git config --get submodule.modules/normativeTypes.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
 > git config --get submodule.modules/pvaClient.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
 > git config --get submodule.modules/pvDatabase.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > git config --get submodule.modules/pva2pva.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > git config --get submodule..ci.url # timeout=10
 > git config -f .gitmodules --get submodule..ci.path # timeout=10
 > git submodule update modules/pvData # timeout=10
 > git submodule update modules/pvAccess # timeout=10
 > git submodule update modules/normativeTypes # timeout=10
 > git submodule update modules/pvaClient # timeout=10
 > git submodule update modules/pvDatabase # timeout=10
 > git submodule update modules/pva2pva # timeout=10
 > git submodule update .ci # timeout=10
No emails were triggered.
[mac] $ /bin/sh -xe /var/folders/6f/2q91ldsx2rncqbx80st_4r700000gn/T/jenkins4897709733254251907.sh
+ git submodule foreach 'git checkout master && git pull'
Entering '.ci'
Already on 'master'
Your branch is up to date with 'origin/master'.
Already up to date.
Entering 'modules/normativeTypes'
Already on 'master'
Already up to date.
Entering 'modules/pvAccess'
Previous HEAD position was 284de4fb Set next development version
Switched to branch 'master'
Your branch is behind 'origin/master' by 2 commits, and can be fast-forwarded.
  (use "git pull" to update your local branch)
Updating e452aa7d..284de4fb
Fast-forward
 Doxyfile                          | 2 +-
 configure/CONFIG_PVACCESS_VERSION | 2 +-
 documentation/Doxyfile            | 2 +-
 3 files changed, 3 insertions(+), 3 deletions(-)
Entering 'modules/pvData'
Already on 'master'
Already up to date.
Entering 'modules/pvDatabase'
Already on 'master'
Already up to date.
Entering 'modules/pva2pva'
Already on 'master'
From https://github.com/epics-base/pva2pva
   61ec071..f07d14b  master     -> origin/master
 + 4a481b1...c8d001c gh-pages   -> origin/gh-pages  (forced update)
Updating 61ec071..f07d14b
Fast-forward
 .github/workflows/ci-scripts-build.yml | 121 ++++++++++++++++++++++-----------
 documentation/qsrvpage.dox             |   6 +-
 2 files changed, 84 insertions(+), 43 deletions(-)
Entering 'modules/pvaClient'
Already on 'master'
Already up to date.
+ csac=configure/os/CONFIG_SITE.darwin-x86.Common
+ echo 'CROSS_COMPILER_TARGET_ARCHS :='
+ case $EPICS_HOST_ARCH in
+ echo 'CROSS_COMPILER_TARGET_ARCHS += ios-arm'
+ EXTRA='-j4 -Orecurse'
+ echo ------------------------------------------------------------------
+ /Users/jenkins/bin/make -j4 -Orecurse host
fcntl(): Bad file descriptor
/Users/jenkins/bin/make -C ./configure install.darwin-x86
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure'
mkdir -p O.Common
perl -CSD ../src/tools/makeMakefile.pl O.ios-arm ../..
perl -CSD ../src/tools/makeMakefile.pl O.darwin-x86 ../..
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
    T_A=darwin-x86 install
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure/O.darwin-x86'
cc -x c -E              -DUNIX  -Ddarwin    -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/clang -I../../include/os/Darwin -I../../include         ../toolchain.c > TOOLCHAIN.darwin-x86.darwin-x86
Installing CFG file ../../cfg/TOOLCHAIN.darwin-x86.darwin-x86
mkdir ../../cfg
Installing CFG file ../../cfg/CONFIG_LIBCOM_VERSION
Installing CFG file ../../cfg/CONFIG_CA_VERSION
Installing CFG file ../../cfg/CONFIG_CA_MODULE
Installing CFG file ../../cfg/CONFIG_LIBCOM_MODULE
Installing CFG file ../../cfg/CONFIG_DATABASE_VERSION
Installing CFG file ../../cfg/CONFIG_DATABASE_MODULE
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure/O.darwin-x86'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure'
/Users/jenkins/bin/make -C ./src install.darwin-x86
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src'
/Users/jenkins/bin/make -C ./tools install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools'
mkdir -p O.Common
perl -CSD ../../src/tools/makeMakefile.pl O.darwin-x86 ../../..
perl -CSD ../../src/tools/makeMakefile.pl O.ios-arm ../../..
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools/O.darwin-x86'
Installing PERL_MODULES file ../../../lib/perl/EPICS/Path.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Release.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Readfile.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Copy.pm
mkdir ../../../lib
mkdir ../../../lib/perl
mkdir ../../../lib/perl/EPICS
Installing PERL_MODULES file ../../../lib/perl/EPICS/PodHtml.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/Getopts.pm
Installing PERL_MODULES file ../../../lib/perl/EPICS/PodXHtml.pm
Installing PERL_MODULES file ../../../lib/perl/EpicsHostArch.pl
Installing html ../../../html/./style.css
mkdir ../../../html
mkdir ../../../html/.
perl -CSD ../../../src/tools/podToHtml.pl -s -o Path.html ../EPICS/Path.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o makeAPIheader.html ../makeAPIheader.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o munch.html ../munch.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o podToHtml.html ../podToHtml.pl
perl -CSD ../../../src/tools/podToHtml.pl -s -o podRemove.html ../podRemove.pl
Installing script ../../../bin/darwin-x86/assembleSnippets.pl
mkdir ../../../bin
mkdir ../../../bin/darwin-x86
Installing script ../../../bin/darwin-x86/convertRelease.pl
Installing script ../../../bin/darwin-x86/cvsclean.pl
Installing script ../../../bin/darwin-x86/depclean.pl
Installing script ../../../bin/darwin-x86/dos2unix.pl
Installing script ../../../bin/darwin-x86/epicsProve.pl
Installing script ../../../bin/darwin-x86/expandVars.pl
Installing script ../../../bin/darwin-x86/fullPathName.pl
Installing script ../../../bin/darwin-x86/installEpics.pl
Installing script ../../../bin/darwin-x86/makeAPIheader.pl
Installing script ../../../bin/darwin-x86/makeMakefile.pl
Installing script ../../../bin/darwin-x86/makeTestfile.pl
Installing script ../../../bin/darwin-x86/mkmf.pl
Installing script ../../../bin/darwin-x86/munch.pl
Installing script ../../../bin/darwin-x86/podToHtml.pl
Installing script ../../../bin/darwin-x86/podRemove.pl
Installing script ../../../bin/darwin-x86/replaceVAR.pl
Installing script ../../../bin/darwin-x86/tap-to-junit-xml.pl
Installing script ../../../bin/darwin-x86/testFailures.pl
Installing script ../../../bin/darwin-x86/useManifestTool.pl
Installing script ../../../bin/darwin-x86/genVersionHeader.pl
Installing script ../../../bin/darwin-x86/makeRPath.py
Installing generated html ../../../html/./EPICS/Path.html
mkdir ../../../html/./EPICS
Installing generated html ../../../html/./makeAPIheader.html
Installing generated html ../../../html/./munch.html
Installing generated html ../../../html/./podToHtml.html
Installing generated html ../../../html/./podRemove.html
perl -CSD ../../../src/tools/podToHtml.pl -s -o Getopts.html ../EPICS/Getopts.pm
Installing generated html ../../../html/./EPICS/Getopts.html
perl -CSD ../../../src/tools/podToHtml.pl -s -o Readfile.html ../EPICS/Readfile.pm
perl -CSD ../../../src/tools/podToHtml.pl -s -o fullPathName.html ../fullPathName.pl
Installing generated html ../../../html/./EPICS/Readfile.html
Installing generated html ../../../html/./fullPathName.html
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools/O.darwin-x86'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools'
/Users/jenkins/bin/make -C template/base install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../../../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base/O.darwin-x86'
Installing script ../../../../bin/darwin-x86/makeBaseApp.pl
Installing ../../../../templates/makeBaseApp/top/Makefile
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG
mkdir ../../../../templates
mkdir ../../../../templates/makeBaseApp
mkdir ../../../../templates/makeBaseApp/top
mkdir ../../../../templates/makeBaseApp/top/configure
Installing ../../../../templates/makeBaseApp/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseApp/top/configure/Makefile
Installing ../../../../templates/makeBaseApp/top/configure/RELEASE
Installing ../../../../templates/makeBaseApp/top/configure/RULES.ioc
Installing ../../../../templates/makeBaseApp/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseApp/top/configure/RULES_TOP
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base/O.darwin-x86'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base'
/Users/jenkins/bin/make -C template/ext install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext'
mkdir -p O.Common
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext/O.darwin-x86'
Installing script ../../../../bin/darwin-x86/makeBaseExt.pl
Installing ../../../../templates/makeBaseExt/top/Makefile
mkdir ../../../../templates/makeBaseExt
mkdir ../../../../templates/makeBaseExt/top
Installing ../../../../templates/makeBaseExt/top/README
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG
mkdir ../../../../templates/makeBaseExt/top/configure
Installing ../../../../templates/makeBaseExt/top/configure/Makefile
Installing ../../../../templates/makeBaseExt/top/configure/CONFIG_SITE
Installing ../../../../templates/makeBaseExt/top/configure/RELEASE
Installing ../../../../templates/makeBaseExt/top/configure/RULES
Installing ../../../../templates/makeBaseExt/top/configure/RULES_DIRS
Installing ../../../../templates/makeBaseExt/top/configure/RULES_TOP
Installing ../../../../templates/makeBaseExt/top/configure/RULES_IDL
Installing ../../../../templates/makeBaseExt/top/configure/RULES_PYTHON
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
mkdir ../../../../templates/makeBaseExt/top/configure/os
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.windows-x64.windows-x64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86.win32-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86.linux-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
Installing ../../../../templates/makeBaseExt/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
Installing ../../../../templates/makeBaseExt/top/src/Makefile
mkdir ../../../../templates/makeBaseExt/top/src
Installing ../../../../templates/makeBaseExt/top/exampleExt/caExample.c
Installing ../../../../templates/makeBaseExt/top/exampleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/exampleExt
Installing ../../../../templates/makeBaseExt/top/exampleExt/RELEASE_NOTES.HTM
Installing ../../../../templates/makeBaseExt/top/simpleExt/Makefile
mkdir ../../../../templates/makeBaseExt/top/simpleExt
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext/O.darwin-x86'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src'
/Users/jenkins/bin/make -C ./test install.darwin-x86
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test'
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools'
mkdir -p O.Common
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../.. -a darwin-x86 ../Snippets.plt Snippets.t
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools/O.darwin-x86'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test'
/Users/jenkins/bin/make -C ./modules install.darwin-x86
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules'
Creating RELEASE.darwin-x86.local with
    EPICS_BASE = /Users/jenkins/workspace/epics-7.0/OS/mac
/Users/jenkins/bin/make -C ./libcom install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom'
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/src'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/src/O.darwin-x86'
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
perl -CSD ../misc/makeEpicsVersion.pl -o epicsVersion.h   ../../../../configure/CONFIG_BASE_VERSION
Building epicsVersion.h from ../../../../configure/CONFIG_BASE_VERSION
Found EPICS Version 7.0.6.2-DEV
Installing created executable ../../../../bin/darwin-x86/bldEnvData.pl
perl -CSD ../error/makeStatTbl.pl  ../osi/devLib.h ../osi/epicsTime.h ../as/asLib.h ../misc/epicsStdlib.h ../pool/epicsThreadPool.h ../error/errMdef.h ../../../../modules/database/src/ioc/db/dbAccessDefs.h ../../../../modules/database/src/ioc/dbStatic/dbStaticLib.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeAPIheader.pl -o ../O.Common/libComAPI.h libCom
Installing generated generic include file ../../../../include/libComAPI.h
mkdir ../../../../include
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_gen.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_gen.o ../yajl/yajl_gen.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_lex.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_lex.o ../yajl/yajl_lex.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_buf.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_buf.o ../yajl/yajl_buf.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_encode.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_encode.o ../yajl/yajl_encode.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_alloc.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_alloc.o ../yajl/yajl_alloc.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_parser.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_parser.o ../yajl/yajl_parser.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl.o ../yajl/yajl.c
perl -CSD ../../../../bin/darwin-x86/bldEnvData.pl  -t darwin-x86 \
	-c clang -s Darwin ../../../../configure
Generating envData.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timerQueueActiveMgr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         timerQueueActiveMgr.o ../timer/timerQueueActiveMgr.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timerQueue.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         timerQueue.o ../timer/timerQueue.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timerQueuePassive.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         timerQueuePassive.o ../timer/timerQueuePassive.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timerQueueActive.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         timerQueueActive.o ../timer/timerQueueActive.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timer.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         timer.o ../timer/timer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTimer.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTimer.o ../timer/epicsTimer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsRingBytes.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsRingBytes.o ../ring/epicsRingBytes.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsRingPointer.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsRingPointer.o ../ring/epicsRingPointer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m threadPool.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         threadPool.o ../pool/threadPool.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m poolJob.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         poolJob.o ../pool/poolJob.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdFindAddr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdFindAddr.o ../osi/os/Darwin/osdFindAddr.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m taskwd.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         taskwd.o ../taskwd/taskwd.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStackTrace.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStackTrace.o ../osi/epicsStackTrace.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdBackTrace.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdBackTrace.o ../osi/os/Darwin/osdBackTrace.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdgetexec.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdgetexec.o ../osi/os/Darwin/osdgetexec.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLibVMEOSD.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         devLibVMEOSD.o ../osi/os/default/devLibVMEOSD.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLibVME.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         devLibVME.o ../osi/devLibVME.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdProcess.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdProcess.o ../osi/os/posix/osdProcess.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdMessageQueue.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdMessageQueue.o ../osi/os/default/osdMessageQueue.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdMonotonic.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdMonotonic.o ../osi/os/Darwin/osdMonotonic.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdSpin.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdSpin.o ../osi/os/posix/osdSpin.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdTime.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdTime.o ../osi/os/Darwin/osdTime.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdEvent.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdEvent.o ../osi/os/posix/osdEvent.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdNetIntf.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdNetIntf.o ../osi/os/Darwin/osdNetIntf.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdMutex.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdMutex.o ../osi/os/posix/osdMutex.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdThreadHooks.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdThreadHooks.o ../osi/os/default/osdThreadHooks.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdThreadExtra.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdThreadExtra.o ../osi/os/posix/osdThreadExtra.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdThread.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdThread.o ../osi/os/posix/osdThread.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStdio.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStdio.o ../osi/epicsStdio.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTempFile.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTempFile.o ../osi/os/posix/epicsTempFile.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdStdio.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdStdio.o ../osi/os/posix/osdStdio.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdSignal.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdSignal.o ../osi/os/posix/osdSignal.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsReadline.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsReadline.o ../osi/epicsReadline.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdInterrupt.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdInterrupt.o ../osi/os/default/osdInterrupt.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdEnv.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdEnv.o ../osi/os/default/osdEnv.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdPoolStatus.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdPoolStatus.o ../osi/os/default/osdPoolStatus.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdFindSymbol.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdFindSymbol.o ../osi/os/posix/osdFindSymbol.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsSocketConvertErrnoToString.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsSocketConvertErrnoToString.o ../osi/os/default/epicsSocketConvertErrnoToString.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m systemCallIntMech.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         systemCallIntMech.o ../osi/os/posix/systemCallIntMech.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdAssert.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdAssert.o ../osi/os/default/osdAssert.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osiSock.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osiSock.o ../osi/osiSock.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdSockUnsentCount.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdSockUnsentCount.o ../osi/os/Darwin/osdSockUnsentCount.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdSockAddrReuse.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdSockAddrReuse.o ../osi/os/default/osdSockAddrReuse.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osdSock.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osdSock.o ../osi/os/posix/osdSock.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsAtomicOSD.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsAtomicOSD.o ../osi/os/posix/epicsAtomicOSD.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsGeneralTime.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsGeneralTime.o ../osi/epicsGeneralTime.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMath.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMath.o ../osi/epicsMath.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osiClockTime.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osiClockTime.o ../osi/osiClockTime.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMessageQueue.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMessageQueue.o ../osi/epicsMessageQueue.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsEvent.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsEvent.o ../osi/epicsEvent.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTime.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTime.o ../osi/epicsTime.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMutex.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMutex.o ../osi/epicsMutex.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThread.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThread.o ../osi/epicsThread.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m truncateFile.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         truncateFile.o ../misc/truncateFile.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsString.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsString.o ../misc/epicsString.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ipAddrToAsciiAsynchronous.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ipAddrToAsciiAsynchronous.o ../misc/ipAddrToAsciiAsynchronous.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsUnitTest.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsUnitTest.o ../misc/epicsUnitTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsConvert.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsConvert.o ../misc/epicsConvert.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cantProceed.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         cantProceed.o ../misc/cantProceed.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStdlib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStdlib.o ../misc/epicsStdlib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m aToIPAddr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         aToIPAddr.o ../misc/aToIPAddr.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsExit.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsExit.o ../misc/epicsExit.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m adjustment.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         adjustment.o ../misc/adjustment.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m alarmString.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         alarmString.o ../misc/alarmString.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m macEnv.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         macEnv.o ../macLib/macEnv.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m macUtil.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         macUtil.o ../macLib/macUtil.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m macCore.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         macCore.o ../macLib/macCore.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocLog.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         iocLog.o ../log/iocLog.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m logClient.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         logClient.o ../log/logClient.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registry.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         registry.o ../iocsh/registry.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m libComRegister.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         libComRegister.o ../iocsh/libComRegister.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocsh.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         iocsh.o ../iocsh/iocsh.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m initHooks.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         initHooks.o ../iocsh/initHooks.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m gpHashLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         gpHashLib.o ../gpHash/gpHashLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m errSymTbl.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         errSymTbl.o errSymTbl.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m freeListLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         freeListLib.o ../freeList/freeListLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m errlog.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         errlog.o ../error/errlog.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m errSymLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         errSymLib.o ../error/errSymLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m envData.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         envData.o envData.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m fdManager.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         fdManager.o ../fdmgr/fdManager.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m envSubr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         envSubr.o ../env/envSubr.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ellSort.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ellSort.o ../ellLib/ellSort.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ellLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ellLib.o ../ellLib/ellLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m fdmgr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         fdmgr.o ../fdmgr/fdmgr.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsSingletonMutex.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsSingletonMutex.o ../cxxTemplates/epicsSingletonMutex.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m resourceLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         resourceLib.o ../cxxTemplates/resourceLib.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbmf.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         dbmf.o ../dbmf/dbmf.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cvtFast.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         cvtFast.o ../cvtFast/cvtFast.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m calcPerform.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         calcPerform.o ../calc/calcPerform.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m postfix.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         postfix.o ../calc/postfix.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m bucketLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         bucketLib.o ../bucketLib/bucketLib.c
Installing generic include file ../../../../include/valgrind/valgrind.h
mkdir ../../../../include/valgrind
Installing generic include file ../../../../include/asLib.h
Installing generated generic include file ../../../../include/libComVersion.h
Installing generic include file ../../../../include/bucketLib.h
Installing generic include file ../../../../include/postfix.h
Installing generic include file ../../../../include/asTrapWrite.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asTrapWrite.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         asTrapWrite.o ../as/asTrapWrite.c
Installing generic include file ../../../../include/cvtFast.h
Installing generic include file ../../../../include/epicsAlgorithm.h
Installing generic include file ../../../../include/resourceLib.h
Installing generic include file ../../../../include/tsDLList.h
Installing generic include file ../../../../include/tsSLList.h
Installing generic include file ../../../../include/tsFreeList.h
Installing generic include file ../../../../include/epicsSingleton.h
Installing generic include file ../../../../include/epicsGuard.h
Installing generic include file ../../../../include/tsMinMax.h
Installing generic include file ../../../../include/dbmf.h
Installing generic include file ../../../../include/ellLib.h
Installing generic include file ../../../../include/envDefs.h
Installing generic include file ../../../../include/epicsPrint.h
Installing generic include file ../../../../include/errMdef.h
Installing generic include file ../../../../include/errSymTbl.h
Installing generic include file ../../../../include/errlog.h
Installing generic include file ../../../../include/fdManager.h
Installing generic include file ../../../../include/fdmgr.h
Installing generic include file ../../../../include/freeList.h
Installing generic include file ../../../../include/gpHash.h
Installing generic include file ../../../../include/iocsh.h
Installing generic include file ../../../../include/initHooks.h
Installing generic include file ../../../../include/registry.h
Installing generic include file ../../../../include/libComRegister.h
Installing generic include file ../../../../include/iocLog.h
Installing generic include file ../../../../include/logClient.h
Installing generic include file ../../../../include/macLib.h
Installing generic include file ../../../../include/flex.skel.static
Installing generic include file ../../../../include/alarm.h
Installing generic include file ../../../../include/adjustment.h
Installing generic include file ../../../../include/cantProceed.h
Installing generic include file ../../../../include/dbDefs.h
Installing generic include file ../../../../include/epicsConvert.h
Installing generic include file ../../../../include/epicsExit.h
Installing generic include file ../../../../include/epicsStdlib.h
Installing generic include file ../../../../include/epicsString.h
Installing generic include file ../../../../include/epicsTypes.h
Installing generic include file ../../../../include/shareLib.h
Installing generic include file ../../../../include/epicsExport.h
Installing generic include file ../../../../include/alarmString.h
Installing generic include file ../../../../include/locationException.h
Installing generic include file ../../../../include/ipAddrToAsciiAsynchronous.h
Installing generic include file ../../../../include/compilerDependencies.h
Installing generic include file ../../../../include/epicsUnitTest.h
Installing generic include file ../../../../include/testMain.h
Installing generated generic include file ../../../../include/epicsVersion.h
Installing compiler dependent include file ../../../../include/compiler/clang/compilerSpecific.h
mkdir ../../../../include/compiler
mkdir ../../../../include/compiler/clang
Installing generic include file ../../../../include/osiFileName.h
Installing generic include file ../../../../include/osiSock.h
Installing OS dependent include file ../../../../include/os/Darwin/osdSock.h
mkdir ../../../../include/os
mkdir ../../../../include/os/Darwin
Installing generic include file ../../../../include/epicsInterrupt.h
Installing OS dependent include file ../../../../include/os/Darwin/osdInterrupt.h
Installing generic include file ../../../../include/epicsMutex.h
Installing OS dependent include file ../../../../include/os/Darwin/osdMutex.h
Installing generic include file ../../../../include/epicsSpin.h
Installing generic include file ../../../../include/epicsEvent.h
Installing OS dependent include file ../../../../include/os/Darwin/osdEvent.h
Installing OS dependent include file ../../../../include/os/Darwin/epicsMath.h
Installing OS dependent include file ../../../../include/os/Darwin/osdMessageQueue.h
Installing OS dependent include file ../../../../include/os/Darwin/osdStrtod.h
Installing generic include file ../../../../include/epicsAssert.h
Installing generic include file ../../../../include/epicsFindSymbol.h
Installing generic include file ../../../../include/osiPoolStatus.h
Installing OS dependent include file ../../../../include/os/Darwin/osdPoolStatus.h
Installing OS dependent include file ../../../../include/os/Darwin/osdThread.h
Installing generic include file ../../../../include/epicsThread.h
Installing generic include file ../../../../include/epicsTime.h
Installing generic include file ../../../../include/epicsGeneralTime.h
Installing OS dependent include file ../../../../include/os/Darwin/osdTime.h
Installing generic include file ../../../../include/generalTimeSup.h
Installing generic include file ../../../../include/osiClockTime.h
Installing generic include file ../../../../include/epicsSignal.h
Installing generic include file ../../../../include/osiProcess.h
Installing OS dependent include file ../../../../include/os/Darwin/osiUnistd.h
Installing generic include file ../../../../include/epicsAtomic.h
Installing OS dependent include file ../../../../include/os/Darwin/osdWireConfig.h
Installing generic include file ../../../../include/epicsAtomicDefault.h
Installing OS dependent include file ../../../../include/os/Darwin/epicsAtomicOSD.h
Installing compiler dependent include file ../../../../include/compiler/clang/epicsAtomicCD.h
Installing generic include file ../../../../include/osiWireFormat.h
Installing generic include file ../../../../include/epicsReadline.h
Installing OS dependent include file ../../../../include/os/Darwin/osdWireFormat.h
Installing generic include file ../../../../include/epicsMessageQueue.h
Installing generic include file ../../../../include/epicsStdio.h
Installing generic include file ../../../../include/epicsStdioRedirect.h
Installing generic include file ../../../../include/epicsEndian.h
Installing generic include file ../../../../include/epicsTempFile.h
Installing generic include file ../../../../include/epicsStackTrace.h
Installing generic include file ../../../../include/devLib.h
Installing OS dependent include file ../../../../include/os/Darwin/epicsGetopt.h
Installing generic include file ../../../../include/devLibVME.h
Installing generic include file ../../../../include/devLibVMEImpl.h
Installing OS dependent include file ../../../../include/os/Darwin/osdVME.h
Installing generic include file ../../../../include/epicsAtomicGCC.h
Installing generic include file ../../../../include/epicsThreadPool.h
Installing OS dependent include file ../../../../include/os/Darwin/epicsMMIODef.h
Installing OS dependent include file ../../../../include/os/Darwin/epicsMMIO.h
Installing generic include file ../../../../include/epicsRingPointer.h
Installing generic include file ../../../../include/epicsRingBytes.h
Installing generic include file ../../../../include/taskwd.h
Installing generic include file ../../../../include/epicsTimer.h
Installing generic include file ../../../../include/yajl_alloc.h
Installing generic include file ../../../../include/yajl_common.h
Installing generic include file ../../../../include/yajl_gen.h
Installing generic include file ../../../../include/yajl_parse.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m symtab.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         symtab.o ../yacc/symtab.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m verbose.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         verbose.o ../yacc/verbose.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m skeleton.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         skeleton.o ../yacc/skeleton.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m warshall.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         warshall.o ../yacc/warshall.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m reader.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         reader.o ../yacc/reader.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m output.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         output.o ../yacc/output.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m mkpar.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         mkpar.o ../yacc/mkpar.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lr0.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         lr0.o ../yacc/lr0.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m antelope.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         antelope.o ../yacc/antelope.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lalr.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         lalr.o ../yacc/lalr.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m error.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         error.o ../yacc/error.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m closure.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         closure.o ../yacc/closure.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocLogServer.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         iocLogServer.o ../log/iocLogServer.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m sym.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         sym.o ../flex/sym.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tblcmp.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         tblcmp.o ../flex/tblcmp.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m nfa.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         nfa.o ../flex/nfa.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m misc.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         misc.o ../flex/misc.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ecs.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ecs.o ../flex/ecs.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dfa.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         dfa.o ../flex/dfa.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m gen.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         gen.o ../flex/gen.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ccl.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ccl.o ../flex/ccl.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/ecs.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/misc.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/nfa.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/sym.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/tblcmp.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/closure.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/error.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/lalr.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/lr0.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/antelope.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/mkpar.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/output.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/reader.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/skeleton.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/symtab.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/verbose.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yacc/warshall.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/ccl.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/dfa.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../flex/gen.c
c++ -o antelope  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            closure.o error.o lalr.o lr0.o antelope.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o
Installing created executable ../../../../bin/darwin-x86/antelope
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/antelope -bparse -l -d ../flex/parse.y
mv parse.tab.c parse.c
mv parse.tab.h parse.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m parse.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         parse.o parse.c
cc         -DDEFAULT_SKELETON_FILE=flex.skel.static     -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c parse.c
c++ -o e_flex  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ccl.o dfa.o ecs.o gen.o misc.o nfa.o sym.o tblcmp.o parse.o
Installing created executable ../../../../bin/darwin-x86/e_flex
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/e_flex -S../../../../include/flex.skel.static -8 -I -oasLib_lex.c ../as/asLib_lex.l
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/antelope -basLib  ../as/asLib.y
mv asLib.tab.c asLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asLib.d -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         asLib.o asLib.c
Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../.. -D INSTALL_BIN=/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../libComVersion.h@ libComVersion.h
Installing PERL_MODULES file ../../../../lib/perl/EPICS/macLib.pm
Expanding ../log/S99logServer@ to S99logServer
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -a darwin-x86 -t ../../../.. -D INSTALL_BIN=/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86  -DEPICS_LIBCOM_MAJOR_VERSION="3"  -DEPICS_LIBCOM_MINOR_VERSION="21"  -DEPICS_LIBCOM_MAINTENANCE_VERSION="1"  -DEPICS_LIBCOM_DEVELOPMENT_FLAG="1"  ../log/S99logServer@ S99logServer
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../as/asTrapWrite.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../calc/postfix.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../calc/calcPerform.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../bucketLib/bucketLib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../cvtFast/cvtFast.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../dbmf/dbmf.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ellLib/ellLib.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../cxxTemplates/epicsSingletonMutex.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ellLib/ellSort.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c envData.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../env/envSubr.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../cxxTemplates/resourceLib.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../error/errlog.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c errSymTbl.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../error/errSymLib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../freeList/freeListLib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../gpHash/gpHashLib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c asLib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../iocsh/initHooks.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../iocsh/registry.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../iocsh/iocsh.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../iocsh/libComRegister.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../log/iocLog.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../log/logClient.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../macLib/macCore.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../macLib/macEnv.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/alarmString.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../macLib/macUtil.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/aToIPAddr.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/adjustment.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/cantProceed.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/epicsConvert.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/epicsExit.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/epicsStdlib.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/truncateFile.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/epicsString.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/epicsUnitTest.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../fdmgr/fdmgr.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../misc/ipAddrToAsciiAsynchronous.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsMutex.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsEvent.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsMessageQueue.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsThread.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsMath.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/epicsAtomicOSD.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/osiClockTime.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsGeneralTime.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdSockAddrReuse.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdSock.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsTime.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdSockUnsentCount.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/osiSock.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/systemCallIntMech.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/epicsSocketConvertErrnoToString.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdAssert.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdFindSymbol.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdInterrupt.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdPoolStatus.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdSignal.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdEnv.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/epicsTempFile.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration   -DEPICS_COMMANDLINE_LIBRARY=EPICS_COMMANDLINE_LIBRARY_READLINE    -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsReadline.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdStdio.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsStdio.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdThreadExtra.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdThreadHooks.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdMutex.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdSpin.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdThread.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdEvent.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/posix/osdProcess.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdTime.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdNetIntf.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/osdMessageQueue.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/devLibVME.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/default/devLibVMEOSD.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdgetexec.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/epicsStackTrace.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdFindAddr.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdBackTrace.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../pool/poolJob.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../pool/threadPool.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ring/epicsRingPointer.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ring/epicsRingBytes.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../taskwd/taskwd.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/epicsTimer.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/timer.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osi/os/Darwin/osdMonotonic.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/timerQueue.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/timerQueueActive.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/timerQueueActiveMgr.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_alloc.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_buf.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_encode.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_gen.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../timer/timerQueuePassive.cpp
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_parser.c
cc              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl/yajl_lex.c
Installing created executable ../../../../bin/darwin-x86/S99logServer
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../log/iocLogServer.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCom_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I../osi/compiler/clang -I../osi/compiler/default -I. -I../osi/os/Darwin -I../osi/os/posix -I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring -I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../fdmgr/fdManager.cpp
c++ -o libCom.3.21.1.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libCom.3.21.1.dylib -compatibility_version 3.21.1 -current_version 3.21.1 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o          -lreadline -lm
Installing shared library ../../../../lib/darwin-x86/libCom.3.21.1.dylib
ln -s libCom.3.21.1.dylib ../../../../lib/darwin-x86/libCom.dylib
/usr/bin/ar -rc    libCom.a    asLib.o asTrapWrite.o bucketLib.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsSingletonMutex.o dbmf.o ellLib.o ellSort.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o initHooks.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o alarmString.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsAtomicOSD.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osdSockUnsentCount.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o osdInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdThreadExtra.o osdThreadHooks.o osdMutex.o osdSpin.o osdEvent.o osdTime.o osdMonotonic.o osdProcess.o osdNetIntf.o osdMessageQueue.o osdgetexec.o devLibVME.o devLibVMEOSD.o epicsStackTrace.o osdBackTrace.o osdFindAddr.o poolJob.o threadPool.o epicsRingPointer.o epicsRingBytes.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o yajl.o yajl_alloc.o yajl_buf.o yajl_encode.o yajl_gen.o yajl_lex.o yajl_parser.o
/usr/bin/ranlib libCom.a
Installing library ../../../../lib/darwin-x86/libCom.a
c++ -o iocLogServer  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            iocLogServer.o    -lCom
Installing created executable ../../../../bin/darwin-x86/iocLogServer
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/src/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/src'
/Users/jenkins/bin/make -C ./vxWorks install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/vxWorks'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../../..
mkdir -p O.Common
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../../../..
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../.. \
    T_A=darwin-x86 install
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/vxWorks/O.darwin-x86'
make[4]: Nothing to be done for 'install'.
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/vxWorks/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/vxWorks'
/Users/jenkins/bin/make -C ./RTEMS install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/RTEMS'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/RTEMS/O.darwin-x86'
Installing generic include file ../../../../include/epicsMemFs.h
Installing generic include file ../../../../include/epicsRtemsInitHooks.h
Installing generic include file ../../../../include/epicsNtp.h
Installing script ../../../../bin/darwin-x86/epicsMakeMemFs.pl
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/RTEMS/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/RTEMS'
/Users/jenkins/bin/make -C ./test install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/test'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/test/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m buckTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         buckTest.o ../buckTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cvtFastPerform.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         cvtFastPerform.o ../cvtFastPerform.cpp
INSTALL_LOCATION=../../../..
perl -CSD ../../../../modules/database/src/std/softIoc/makeInstallDir.pl "../../../.." > epicsInstallDir.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsAtomicPerform.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsAtomicPerform.o ../epicsAtomicPerform.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMaxThreads.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMaxThreads.o ../epicsMaxThreads.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadPerform.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadPerform.o ../epicsThreadPerform.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testexecname.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         testexecname.o ../testexecname.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m yajl_test.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         yajl_test.o ../yajl_test.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m osiSockTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         osiSockTest.o ../osiSockTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocshTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         iocshTest.o ../iocshTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ipAddrToAsciiTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ipAddrToAsciiTest.o ../ipAddrToAsciiTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStackTraceTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStackTraceTest.o ../epicsStackTraceTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m taskwdTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         taskwdTest.o ../taskwdTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMessageQueueTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMessageQueueTest.o ../epicsMessageQueueTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m blockingSockTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         blockingSockTest.o ../blockingSockTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cvtFastTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         cvtFastTest.o ../cvtFastTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m aslibtest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         aslibtest.o ../aslibtest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m macLibTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         macLibTest.o ../macLibTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m macDefExpandTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         macDefExpandTest.o ../macDefExpandTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsAtomicTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsAtomicTest.o ../epicsAtomicTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsSpinTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsSpinTest.o ../epicsSpinTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMutexTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMutexTest.o ../epicsMutexTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ringBytesTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ringBytesTest.o ../ringBytesTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ringPointerTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         ringPointerTest.o ../ringPointerTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsEventTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsEventTest.o ../epicsEventTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTimerTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTimerTest.o ../epicsTimerTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsExitTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsExitTest.o ../epicsExitTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadHooksTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadHooksTest.o ../epicsThreadHooksTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m initHookTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         initHookTest.o ../initHookTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadPrivateTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadPrivateTest.o ../epicsThreadPrivateTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadPoolTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadPoolTest.o ../epicsThreadPoolTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadPriorityTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadPriorityTest.o ../epicsThreadPriorityTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadClassTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadClassTest.o ../epicsThreadClassTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadOnceTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadOnceTest.o ../epicsThreadOnceTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsThreadTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsThreadTest.o ../epicsThreadTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTimeZoneTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTimeZoneTest.o ../epicsTimeZoneTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStringTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStringTest.o ../epicsStringTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTimeTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTimeTest.o ../epicsTimeTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsSockResolveTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsSockResolveTest.o ../epicsSockResolveTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStdioTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStdioTest.o ../epicsStdioTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsStdlibTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsStdlibTest.o ../epicsStdlibTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsEnvUnsetTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsEnvUnsetTest.o ../epicsEnvUnsetTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsErrlogTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsErrlogTest.o ../epicsErrlogTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsEnvTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsEnvTest.o ../epicsEnvTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsEllTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsEllTest.o ../epicsEllTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMathTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMathTest.o ../epicsMathTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsMMIOTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsMMIOTest.o ../epicsMMIOTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsAlgorithmTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsAlgorithmTest.o ../epicsAlgorithmTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsInlineTest4.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsInlineTest4.o ../epicsInlineTest4.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsCalcTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsCalcTest.o ../epicsCalcTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsInlineTest3.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsInlineTest3.o ../epicsInlineTest3.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsInlineTest2.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsInlineTest2.o ../epicsInlineTest2.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsInlineTest1.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsInlineTest1.o ../epicsInlineTest1.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsUnitTestTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsUnitTestTest.o ../epicsUnitTestTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsTypesTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsTypesTest.o ../epicsTypesTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsLoadTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         epicsLoadTest.o ../epicsLoadTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsInlineTest2.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsInlineTest1.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsTypesTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsUnitTestTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsInlineTest4.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsInlineTest3.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsAlgorithmTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsMathTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsMMIOTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsEnvTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsEnvUnsetTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsEllTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsStdioTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsCalcTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsErrlogTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsSockResolveTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsStdlibTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsStringTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsTimeZoneTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadOnceTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadClassTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadPriorityTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadHooksTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../initHookTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadPoolTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadPrivateTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsExitTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsTimeTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ringBytesTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ringPointerTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsSpinTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsEventTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsTimerTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsMutexTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../macDefExpandTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../macLibTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsAtomicTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../taskwdTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../aslibtest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsStackTraceTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../blockingSockTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsMessageQueueTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../ipAddrToAsciiTest.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../testexecname.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../cvtFastTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../osiSockTest.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../yajl_test.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsMaxThreads.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../buckTest.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsThreadPerform.cpp
c++          -DBUILDING_SHARED_LIBRARIES     -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsLoadTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../.. -a darwin-x86 ../epicsUnitTestTest.plt epicsUnitTestTest.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../.. -a darwin-x86 ../macLib.plt macLib.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../.. -a darwin-x86 ../yajlTest.plt yajlTest.t
c++ -o epicsUnitTestTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsUnitTestTest.o    -lCom
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../iocshTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../cvtFastPerform.cpp
c++ -o epicsTypesTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsTypesTest.o    -lCom
c++ -o epicsInlineTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsInlineTest1.o epicsInlineTest2.o epicsInlineTest3.o epicsInlineTest4.o    -lCom
c++ -o epicsCalcTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsCalcTest.o    -lCom
c++ -o epicsAlgorithmTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsAlgorithmTest.o    -lCom
c++ -o epicsMathTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsMathTest.o    -lCom
c++ -o epicsMMIOTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsMMIOTest.o    -lCom
c++ -o epicsEllTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsEllTest.o    -lCom
c++ -o epicsEnvTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsEnvTest.o    -lCom
c++ -o epicsEnvUnsetTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsEnvUnsetTest.o    -lCom
c++ -o epicsErrlogTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsErrlogTest.o    -lCom
c++ -o epicsStdioTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsStdioTest.o    -lCom
c++ -o epicsStdlibTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsStdlibTest.o    -lCom
c++ -o epicsSockResolveTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsSockResolveTest.o    -lCom
c++ -o epicsStringTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsStringTest.o    -lCom
c++ -o epicsTimeTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsTimeTest.o    -lCom
c++ -o epicsTimeZoneTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsTimeZoneTest.o    -lCom
c++ -o epicsThreadTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadTest.o    -lCom
c++ -o epicsThreadClassTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadClassTest.o    -lCom
c++ -o epicsThreadOnceTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadOnceTest.o    -lCom
c++ -o epicsThreadPriorityTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadPriorityTest.o    -lCom
c++ -o epicsThreadPrivateTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadPrivateTest.o    -lCom
c++ -o epicsThreadHooksTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadHooksTest.o    -lCom
c++ -o epicsThreadPoolTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadPoolTest.o    -lCom
c++ -o initHookTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            initHookTest.o    -lCom
c++ -o epicsExitTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsExitTest.o    -lCom
c++ -o epicsTimerTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsTimerTest.o    -lCom
c++ -o ringPointerTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ringPointerTest.o    -lCom
c++ -o ringBytesTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ringBytesTest.o    -lCom
c++ -o epicsEventTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsEventTest.o    -lCom
c++ -o epicsMutexTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsMutexTest.o    -lCom
c++ -o epicsSpinTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsSpinTest.o    -lCom
c++ -o epicsAtomicTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsAtomicTest.o    -lCom
c++ -o macDefExpandTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            macDefExpandTest.o    -lCom
c++ -o cvtFastTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            cvtFastTest.o    -lCom
c++ -o macLibTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            macLibTest.o    -lCom
c++ -o aslibtest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            aslibtest.o    -lCom
c++ -o taskwdTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            taskwdTest.o    -lCom
c++ -o blockingSockTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            blockingSockTest.o    -lCom
c++ -o epicsMessageQueueTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsMessageQueueTest.o    -lCom
c++ -o epicsStackTraceTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsStackTraceTest.o    -lCom
c++ -o ipAddrToAsciiTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ipAddrToAsciiTest.o    -lCom
c++ -o osiSockTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            osiSockTest.o    -lCom
c++ -o testexecname  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testexecname.o    -lCom
c++ -o yajl_test  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            yajl_test.o    -lCom
c++ -o iocshTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            iocshTest.o    -lCom
c++ -o epicsLoadTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsLoadTest.o    -lCom
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../include/compiler/clang -I../../../../include/os/Darwin -I../../../../include         -c ../epicsAtomicPerform.cpp
c++ -o epicsThreadPerform  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsThreadPerform.o    -lCom
c++ -o epicsMaxThreads  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsMaxThreads.o    -lCom
c++ -o buckTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            buckTest.o    -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsTypesTest.t epicsTypesTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsInlineTest.t epicsInlineTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsCalcTest.t epicsCalcTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsAlgorithmTest.t epicsAlgorithmTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsMathTest.t epicsMathTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsMMIOTest.t epicsMMIOTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsEllTest.t epicsEllTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsEnvTest.t epicsEnvTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsEnvUnsetTest.t epicsEnvUnsetTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsErrlogTest.t epicsErrlogTest
c++ -o cvtFastPerform  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            cvtFastPerform.o    -lCom
c++ -o epicsAtomicPerform  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicsAtomicPerform.o    -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsStdioTest.t epicsStdioTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsStdlibTest.t epicsStdlibTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsSockResolveTest.t epicsSockResolveTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsStringTest.t epicsStringTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsTimeTest.t epicsTimeTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsTimeZoneTest.t epicsTimeZoneTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadTest.t epicsThreadTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadClassTest.t epicsThreadClassTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadOnceTest.t epicsThreadOnceTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadPriorityTest.t epicsThreadPriorityTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadPrivateTest.t epicsThreadPrivateTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadHooksTest.t epicsThreadHooksTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsThreadPoolTest.t epicsThreadPoolTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 initHookTest.t initHookTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsExitTest.t epicsExitTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ringPointerTest.t ringPointerTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsTimerTest.t epicsTimerTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ringBytesTest.t ringBytesTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsEventTest.t epicsEventTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsMutexTest.t epicsMutexTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsSpinTest.t epicsSpinTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsAtomicTest.t epicsAtomicTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 macDefExpandTest.t macDefExpandTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 cvtFastTest.t cvtFastTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 macLibTest.t macLibTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 aslibtest.t aslibtest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 taskwdTest.t taskwdTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 blockingSockTest.t blockingSockTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsMessageQueueTest.t epicsMessageQueueTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsStackTraceTest.t epicsStackTraceTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ipAddrToAsciiTest.t ipAddrToAsciiTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 osiSockTest.t osiSockTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testexecname.t testexecname
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 iocshTest.t iocshTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 epicsLoadTest.t epicsLoadTest
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/test/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom/test'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/libcom'
/Users/jenkins/bin/make -C ./ca install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca'
/Users/jenkins/bin/make -C ./src install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src'
/Users/jenkins/bin/make -C ./template install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/template'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../../../../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../../../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../../.. \
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/template/O.darwin-x86'
Installing ../../../../../templates/makeBaseApp/top/caClientApp/caExample.c
Installing ../../../../../templates/makeBaseApp/top/caClientApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/caClientApp
Installing ../../../../../templates/makeBaseApp/top/caClientApp/caMonitor.c
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/caPerlApp
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/cainfo.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/caput.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/caget.pl
Installing ../../../../../templates/makeBaseApp/top/caPerlApp/camonitor.pl
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/template/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/template'
/Users/jenkins/bin/make -C ./client install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/client'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/client/O.darwin-x86'
Expanding ../caVersion.h@ to ../O.Common/caVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -D INSTALL_BIN=/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86  -DEPICS_CA_MAJOR_VERSION="4"  -DEPICS_CA_MINOR_VERSION="14"  -DEPICS_CA_MAINTENANCE_VERSION="2"  -DEPICS_CA_DEVELOPMENT_FLAG="1"  ../caVersion.h@ caVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeAPIheader.pl -o ../O.Common/libCaAPI.h libCa
Installing generated generic include file ../../../../../include/libCaAPI.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caEventRateMain.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caEventRateMain.o ../caEventRateMain.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caConnTest.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caConnTest.o ../caConnTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caEventRate.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caEventRate.o ../caEventRate.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caConnTestMain.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caConnTestMain.o ../caConnTestMain.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m acctst.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         acctst.o ../acctst.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m acctstMain.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         acctstMain.o ../acctstMain.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m catime.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         catime.o ../catime.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m casw.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         casw.o ../casw.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m catimeMain.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         catimeMain.o ../catimeMain.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caRepeater.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caRepeater.o ../caRepeater.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ca_test.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         ca_test.o ../test/ca_test.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ca_test_main.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         ca_test_main.o ../test/ca_test_main.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m hostNameCache.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         hostNameCache.o ../hostNameCache.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m comBuf.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         comBuf.o ../comBuf.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m msgForMultiplyDefinedPV.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         msgForMultiplyDefinedPV.o ../msgForMultiplyDefinedPV.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m comQueSend.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         comQueSend.o ../comQueSend.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m localHostName.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         localHostName.o ../localHostName.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m syncGroupWriteNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         syncGroupWriteNotify.o ../syncGroupWriteNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m syncGroupReadNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         syncGroupReadNotify.o ../syncGroupReadNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m syncGroupNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         syncGroupNotify.o ../syncGroupNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m CASG.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         CASG.o ../CASG.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m syncgrp.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         syncgrp.o ../syncgrp.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m putCallback.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         putCallback.o ../putCallback.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m getCopy.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         getCopy.o ../getCopy.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m getCallback.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         getCallback.o ../getCallback.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m oldSubscription.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         oldSubscription.o ../oldSubscription.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m oldChannelNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         oldChannelNotify.o ../oldChannelNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ca_client_context.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         ca_client_context.o ../ca_client_context.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m bhe.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         bhe.o ../bhe.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tcpRecvWatchdog.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         tcpRecvWatchdog.o ../tcpRecvWatchdog.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tcpSendWatchdog.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         tcpSendWatchdog.o ../tcpSendWatchdog.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m netSubscription.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         netSubscription.o ../netSubscription.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m netWriteNotifyIO.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         netWriteNotifyIO.o ../netWriteNotifyIO.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m netReadNotifyIO.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         netReadNotifyIO.o ../netReadNotifyIO.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m noopiiu.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         noopiiu.o ../noopiiu.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tcpiiu.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         tcpiiu.o ../tcpiiu.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m udpiiu.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         udpiiu.o ../udpiiu.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m netiiu.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         netiiu.o ../netiiu.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m nciu.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         nciu.o ../nciu.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m baseNMIU.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         baseNMIU.o ../baseNMIU.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m repeaterSubscribeTimer.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         repeaterSubscribeTimer.o ../repeaterSubscribeTimer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m disconnectGovernorTimer.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         disconnectGovernorTimer.o ../disconnectGovernorTimer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m searchTimer.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         searchTimer.o ../searchTimer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m repeater.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         repeater.o ../repeater.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m test_event.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         test_event.o ../test_event.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m convert.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         convert.o ../convert.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocinf.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         iocinf.o ../iocinf.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m access.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         access.o ../access.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacWriteNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacWriteNotify.o ../cacWriteNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacStateNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacStateNotify.o ../cacStateNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacReadNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacReadNotify.o ../cacReadNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacContextNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacContextNotify.o ../cacContextNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacChannelNotify.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacChannelNotify.o ../cacChannelNotify.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cacChannel.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cacChannel.o ../cacChannel.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cac.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cac.o ../cac.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m comQueRecv.d -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         comQueRecv.o ../comQueRecv.cpp
Installing generic include file ../../../../../include/cadef.h
Installing generic include file ../../../../../include/caerr.h
Installing generic include file ../../../../../include/caProto.h
Installing generic include file ../../../../../include/caeventmask.h
Installing generic include file ../../../../../include/db_access.h
Installing generic include file ../../../../../include/addrList.h
Installing generic include file ../../../../../include/cacIO.h
Installing generic include file ../../../../../include/caDiagnostics.h
Installing generic include file ../../../../../include/net_convert.h
Installing html ../../../../../html/./CAref.html
Expanding ../S99caRepeater@ to S99caRepeater
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -a darwin-x86 -t ../../../../.. -D INSTALL_BIN=/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86  -DEPICS_CA_MAJOR_VERSION="4"  -DEPICS_CA_MINOR_VERSION="14"  -DEPICS_CA_MAINTENANCE_VERSION="2"  -DEPICS_CA_DEVELOPMENT_FLAG="1"  ../S99caRepeater@ S99caRepeater
Installing generated generic include file ../../../../../include/caVersion.h
Installing created executable ../../../../../bin/darwin-x86/S99caRepeater
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacChannelNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacChannel.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacContextNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacReadNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacWriteNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cacStateNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../iocinf.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../access.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../test_event.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cac.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../convert.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../disconnectGovernorTimer.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../searchTimer.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../repeater.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../baseNMIU.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../repeaterSubscribeTimer.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../netiiu.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../nciu.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../udpiiu.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../noopiiu.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../netReadNotifyIO.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../tcpiiu.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../netWriteNotifyIO.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../netSubscription.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../tcpSendWatchdog.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../tcpRecvWatchdog.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../bhe.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../oldChannelNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../ca_client_context.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../oldSubscription.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../getCallback.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../getCopy.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../putCallback.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../syncgrp.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../syncGroupNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../CASG.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../syncGroupReadNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../syncGroupWriteNotify.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../localHostName.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../comQueRecv.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../comBuf.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../hostNameCache.cpp
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../comQueSend.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../test/ca_test_main.c
c++              -DUNIX  -Ddarwin   -DBUILDING_libCa_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../msgForMultiplyDefinedPV.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../test/ca_test.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caRepeater.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../catimeMain.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../catime.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../acctstMain.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caConnTestMain.cpp
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../acctst.c
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caConnTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../casw.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caEventRateMain.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../test -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caEventRate.cpp
c++ -o libca.4.14.2.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libca.4.14.2.dylib -compatibility_version 4.14.2 -current_version 4.14.2 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64             cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o   -lCom      -lreadline -lm
/usr/bin/ar -rc    libca.a     cac.o cacChannel.o cacChannelNotify.o cacContextNotify.o cacReadNotify.o cacWriteNotify.o cacStateNotify.o access.o iocinf.o convert.o test_event.o repeater.o searchTimer.o disconnectGovernorTimer.o repeaterSubscribeTimer.o baseNMIU.o nciu.o netiiu.o udpiiu.o tcpiiu.o noopiiu.o netReadNotifyIO.o netWriteNotifyIO.o netSubscription.o tcpSendWatchdog.o tcpRecvWatchdog.o bhe.o ca_client_context.o oldChannelNotify.o oldSubscription.o getCallback.o getCopy.o putCallback.o syncgrp.o CASG.o syncGroupNotify.o syncGroupReadNotify.o syncGroupWriteNotify.o localHostName.o comQueRecv.o comQueSend.o comBuf.o hostNameCache.o msgForMultiplyDefinedPV.o
/usr/bin/ranlib libca.a
Installing shared library ../../../../../lib/darwin-x86/libca.4.14.2.dylib
ln -s libca.4.14.2.dylib ../../../../../lib/darwin-x86/libca.dylib
Installing library ../../../../../lib/darwin-x86/libca.a
c++ -o ca_test  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ca_test_main.o ca_test.o    -lca -lCom -lca -lCom
c++ -o caRepeater  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caRepeater.o    -lca -lCom
c++ -o catime  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            catimeMain.o catime.o    -lca -lCom
c++ -o acctst  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            acctstMain.o acctst.o    -lca -lCom
c++ -o caConnTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caConnTestMain.o caConnTest.o    -lca -lCom
c++ -o casw  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            casw.o    -lca -lCom
c++ -o caEventRate  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caEventRateMain.o caEventRate.o    -lca -lCom
Installing created executable ../../../../../bin/darwin-x86/ca_test
Installing created executable ../../../../../bin/darwin-x86/caRepeater
Installing created executable ../../../../../bin/darwin-x86/catime
Installing created executable ../../../../../bin/darwin-x86/acctst
Installing created executable ../../../../../bin/darwin-x86/caConnTest
Installing created executable ../../../../../bin/darwin-x86/casw
Installing created executable ../../../../../bin/darwin-x86/caEventRate
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/client/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/client'
/Users/jenkins/bin/make -C ./tools install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/tools'
mkdir -p O.Common
    T_A=darwin-x86 install
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/tools/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caput.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caput.o ../caput.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cainfo.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cainfo.o ../cainfo.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m camonitor.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         camonitor.o ../camonitor.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caget.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caget.o ../caget.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tool_lib.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         tool_lib.o ../tool_lib.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caget.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../tool_lib.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../camonitor.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../cainfo.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../caput.c
c++ -o caget  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caget.o tool_lib.o   -lca -lCom
c++ -o camonitor  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            camonitor.o tool_lib.o   -lca -lCom
c++ -o cainfo  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            cainfo.o tool_lib.o   -lca -lCom
c++ -o caput  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caput.o tool_lib.o   -lca -lCom
Installing created executable ../../../../../bin/darwin-x86/caget
Installing created executable ../../../../../bin/darwin-x86/camonitor
Installing created executable ../../../../../bin/darwin-x86/cainfo
Installing created executable ../../../../../bin/darwin-x86/caput
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/tools/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/tools'
/Users/jenkins/bin/make -C ./perl install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/perl'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/perl/O.darwin-x86'
rm -f Cap5.c Cap5.c_new
perl -CSD /opt/local/bin/xsubpp -typemap /opt/local/lib/perl5/5.22/ExtUtils/typemap ../Cap5.xs > Cap5.c_new && mv Cap5.c_new Cap5.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m Cap5.d -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include    -I/opt/local/lib/perl5/5.22/darwin-thread-multi-2level/CORE     Cap5.o Cap5.c
Installing PERL_MODULES file ../../../../../lib/perl/CA.pm
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podToHtml.pl -s -o CA.html ../CA.pm
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration   -pipe -Os  -fno-common -DPERL_DARWIN -I/opt/local/include -fno-strict-aliasing -fstack-protector -I/opt/local/include -DPERL_USE_SAFE_PUTENV    -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include    -I/opt/local/lib/perl5/5.22/darwin-thread-multi-2level/CORE     -c Cap5.c
Installing script ../../../../../bin/darwin-x86/capr.pl
Installing generated html ../../../../../html/./CA.html
c++ -o Cap5.bundle -bundle -undefined dynamic_lookup -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            Cap5.o    -lca -lCom      -lreadline -lm
Installing loadable shared library ../../../../../lib/perl/5.22.2/darwin-thread-multi-2level/Cap5.bundle
mkdir ../../../../../lib/perl/5.22.2
mkdir ../../../../../lib/perl/5.22.2/darwin-thread-multi-2level
Installing loadable shared library ../../../../../lib/darwin-x86/Cap5.bundle
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/perl/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src/perl'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca/src'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/ca'
/Users/jenkins/bin/make -C ./pvData install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData'
/Users/jenkins/bin/make -C ./configure install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/configure'
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/configure/O.darwin-x86'
Installing CFG file /Users/jenkins/workspace/epics-7.0/OS/mac/cfg/CONFIG_PVDATA_VERSION
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/convertRelease.pl checkRelease
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/configure/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/configure'
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/src'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/src/O.darwin-x86'
mkdir -p ../O.Common/pv
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -DEPICS_PVD_MAJOR_VERSION="8" -DEPICS_PVD_MINOR_VERSION="0" -DEPICS_PVD_MAINTENANCE_VERSION="5" -DEPICS_PVD_DEVELOPMENT_FLAG="1" -t /Users/jenkins/workspace/epics-7.0/OS/mac    ../pv/pvdVersionNum.h@ ../O.Common/pv/pvdVersionNum.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m parseany.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        parseany.o ../../src/json/parseany.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m parseinto.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        parseinto.o ../../src/json/parseinto.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m parsehelper.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        parsehelper.o ../../src/json/parsehelper.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m bitSetUtil.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        bitSetUtil.o ../../src/pvMisc/bitSetUtil.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m requestmapper.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        requestmapper.o ../../src/copy/requestmapper.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m createRequest.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        createRequest.o ../../src/copy/createRequest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvTimeStamp.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvTimeStamp.o ../../src/property/pvTimeStamp.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timeStamp.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        timeStamp.o ../../src/property/timeStamp.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvEnumerated.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvEnumerated.o ../../src/property/pvEnumerated.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvDisplay.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvDisplay.o ../../src/property/pvDisplay.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvControl.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvControl.o ../../src/property/pvControl.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvAlarm.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvAlarm.o ../../src/property/pvAlarm.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m alarm.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        alarm.o ../../src/property/alarm.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m printer.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        printer.o ../../src/factory/printer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m StandardPVField.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        StandardPVField.o ../../src/factory/StandardPVField.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m StandardField.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        StandardField.o ../../src/factory/StandardField.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m Compare.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        Compare.o ../../src/factory/Compare.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvSubArrayCopy.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvSubArrayCopy.o ../../src/factory/pvSubArrayCopy.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m Convert.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        Convert.o ../../src/factory/Convert.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVDataCreateFactory.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVDataCreateFactory.o ../../src/factory/PVDataCreateFactory.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVUnionArray.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVUnionArray.o ../../src/factory/PVUnionArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVUnion.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVUnion.o ../../src/factory/PVUnion.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVStructureArray.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVStructureArray.o ../../src/factory/PVStructureArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVStructure.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVStructure.o ../../src/factory/PVStructure.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVScalarArray.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVScalarArray.o ../../src/factory/PVScalarArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVArray.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVArray.o ../../src/factory/PVArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVScalar.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVScalar.o ../../src/factory/PVScalar.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVField.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVField.o ../../src/factory/PVField.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m FieldCreateFactory.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        FieldCreateFactory.o ../../src/factory/FieldCreateFactory.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m TypeFunc.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        TypeFunc.o ../../src/factory/TypeFunc.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m valueBuilder.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        valueBuilder.o ../../src/pv/valueBuilder.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvdVersion.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvdVersion.o ../../src/pv/pvdVersion.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m anyscalar.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        anyscalar.o ../../src/misc/anyscalar.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m reftrack.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        reftrack.o ../../src/misc/reftrack.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m debugPtr.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        debugPtr.o ../../src/misc/debugPtr.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvUnitTest.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvUnitTest.o ../../src/misc/pvUnitTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m parseToPOD.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        parseToPOD.o ../../src/misc/parseToPOD.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m thread.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        thread.o ../../src/misc/thread.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m typeCast.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        typeCast.o ../../src/misc/typeCast.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m status.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        status.o ../../src/misc/status.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m timer.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        timer.o ../../src/misc/timer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m event.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        event.o ../../src/misc/event.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m serializeHelper.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        serializeHelper.o ../../src/misc/serializeHelper.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsException.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        epicsException.o ../../src/misc/epicsException.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m bitSet.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        bitSet.o ../../src/misc/bitSet.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m byteBuffer.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        byteBuffer.o ../../src/misc/byteBuffer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m print.d -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        print.o ../../src/json/print.cpp
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/noDefaultMethods.h
mkdir /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/lock.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/serialize.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/byteBuffer.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/bitSet.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/epicsException.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/serializeHelper.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/event.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/thread.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/timer.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/status.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/sharedPtr.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/debugPtr.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/typeCast.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/sharedVector.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/templateMeta.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/current_function.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvUnitTest.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/reftrack.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/anyscalar.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvType.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvIntrospect.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/valueBuilder.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvData.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/convert.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/standardField.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/standardPVField.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvSubArrayCopy.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/typemap.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvdVersion.h
Installing generated generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvdVersionNum.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/factory.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/alarm.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvAlarm.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/control.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvControl.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/display.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvDisplay.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvEnumerated.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/timeStamp.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvTimeStamp.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/createRequest.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/bitSetUtil.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/json.h
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/byteBuffer.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/epicsException.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/bitSet.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/serializeHelper.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/event.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/status.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/timer.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/thread.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/parseToPOD.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/debugPtr.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/pvUnitTest.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/typeCast.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pv/pvdVersion.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/anyscalar.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/misc/reftrack.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pv/valueBuilder.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/TypeFunc.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVScalar.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVField.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVScalarArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVStructureArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVStructure.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/FieldCreateFactory.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVUnion.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVUnionArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/Convert.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/Compare.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/pvSubArrayCopy.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/StandardPVField.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/StandardField.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/alarm.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/pvAlarm.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/printer.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/pvControl.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/pvDisplay.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/PVDataCreateFactory.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/timeStamp.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/pvEnumerated.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/property/pvTimeStamp.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pvMisc/bitSetUtil.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/copy/requestmapper.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/json/parsehelper.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/copy/createRequest.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/json/parseany.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/json/print.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/json/parseinto.cpp
c++ -o libpvData.8.0.5.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvData.8.0.5.dylib -compatibility_version 8.0.5 -current_version 8.0.5 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64             byteBuffer.o bitSet.o epicsException.o serializeHelper.o event.o timer.o status.o typeCast.o thread.o parseToPOD.o pvUnitTest.o debugPtr.o reftrack.o anyscalar.o pvdVersion.o valueBuilder.o TypeFunc.o FieldCreateFactory.o PVField.o PVScalar.o PVArray.o PVScalarArray.o PVStructure.o PVStructureArray.o PVUnion.o PVUnionArray.o PVDataCreateFactory.o Convert.o pvSubArrayCopy.o Compare.o StandardField.o StandardPVField.o printer.o alarm.o pvAlarm.o pvControl.o pvDisplay.o pvEnumerated.o timeStamp.o pvTimeStamp.o createRequest.o requestmapper.o bitSetUtil.o parsehelper.o parseany.o parseinto.o print.o   -lCom      -lreadline -lm
Installing shared library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvData.8.0.5.dylib
ln -s libpvData.8.0.5.dylib /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvData.dylib
/usr/bin/ar -rc    libpvData.a     byteBuffer.o bitSet.o epicsException.o serializeHelper.o event.o timer.o status.o typeCast.o thread.o parseToPOD.o pvUnitTest.o debugPtr.o reftrack.o anyscalar.o pvdVersion.o valueBuilder.o TypeFunc.o FieldCreateFactory.o PVField.o PVScalar.o PVArray.o PVScalarArray.o PVStructure.o PVStructureArray.o PVUnion.o PVUnionArray.o PVDataCreateFactory.o Convert.o pvSubArrayCopy.o Compare.o StandardField.o StandardPVField.o printer.o alarm.o pvAlarm.o pvControl.o pvDisplay.o pvEnumerated.o timeStamp.o pvTimeStamp.o createRequest.o requestmapper.o bitSetUtil.o parsehelper.o parseany.o parseinto.o print.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libpvData.a(byteBuffer.o) has no symbols
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libpvData.a(debugPtr.o) has no symbols
/usr/bin/ranlib libpvData.a
Installing library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvData.a
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/src/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/src'
/Users/jenkins/bin/make -C ./examples install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/examples'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
    T_A=darwin-x86 install
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/examples/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m unittest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        unittest.o ../unittest.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../unittest.cpp
c++ -o unittest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            unittest.o    -lpvData -lCom
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/examples/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/examples'
/Users/jenkins/bin/make -C ./testApp install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/testApp'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/testApp/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testProperty.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testProperty.o ../../testApp/property/testProperty.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testValueBuilder.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testValueBuilder.o ../../testApp/pv/testValueBuilder.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testFieldBuilder.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testFieldBuilder.o ../../testApp/pv/testFieldBuilder.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testOperators.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testOperators.o ../../testApp/pv/testOperators.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVStructureArray.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVStructureArray.o ../../testApp/pv/testPVStructureArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVScalarArray.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVScalarArray.o ../../testApp/pv/testPVScalarArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testConvert.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testConvert.o ../../testApp/pv/testConvert.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVUnion.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVUnion.o ../../testApp/pv/testPVUnion.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVData.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVData.o ../../testApp/pv/testPVData.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testStandardPVField.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testStandardPVField.o ../../testApp/pv/testStandardPVField.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testStandardField.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testStandardField.o ../../testApp/pv/testStandardField.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVType.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVType.o ../../testApp/pv/testPVType.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testIntrospect.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testIntrospect.o ../../testApp/pv/testIntrospect.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testBitSetUtil.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testBitSetUtil.o ../../testApp/pv/testBitSetUtil.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testprinter.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testprinter.o ../../testApp/misc/testprinter.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testanyscalar.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testanyscalar.o ../../testApp/misc/testanyscalar.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m test_reftrack.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        test_reftrack.o ../../testApp/misc/test_reftrack.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testjson.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testjson.o ../../testApp/misc/testjson.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testUnitTest.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testUnitTest.o ../../testApp/misc/testUnitTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testTypeCast.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testTypeCast.o ../../testApp/misc/testTypeCast.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testTimeStamp.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testTimeStamp.o ../../testApp/misc/testTimeStamp.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testSerialization.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testSerialization.o ../../testApp/misc/testSerialization.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testDebugPtr.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testDebugPtr.o ../../testApp/misc/testDebugPtr.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testSharedVector.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testSharedVector.o ../../testApp/misc/testSharedVector.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testBaseException.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testBaseException.o ../../testApp/misc/testBaseException.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testByteBuffer.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testByteBuffer.o ../../testApp/misc/testByteBuffer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testByteOrder.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testByteOrder.o ../../testApp/misc/testByteOrder.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testOverrunBitSet.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testOverrunBitSet.o ../../testApp/misc/testOverrunBitSet.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testBitSet.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testBitSet.o ../../testApp/misc/testBitSet.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testTimer.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testTimer.o ../../testApp/misc/testTimer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testEvent.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testEvent.o ../../testApp/misc/testEvent.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testThread.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testThread.o ../../testApp/misc/testThread.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testCreateRequest.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testCreateRequest.o ../../testApp/copy/testCreateRequest.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testEvent.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testThread.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testTimer.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testByteOrder.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testBitSet.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testOverrunBitSet.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testBaseException.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testDebugPtr.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testByteBuffer.cpp
../../testApp/misc/testByteBuffer.cpp:164:27: warning: 'getArray' is deprecated [-Wdeprecated-declarations]
    testOk1(strncmp(buff->getArray(),&src[2],6)==0);
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/byteBuffer.h:682:54: note: 'getArray' has been explicitly marked deprecated here
    EPICS_ALWAYS_INLINE const char* getArray() const EPICS_DEPRECATED
/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang/compilerSpecific.h:54:41: note: expanded from macro 'EPICS_DEPRECATED'
#define EPICS_DEPRECATED __attribute__((deprecated))
../../testApp/misc/testByteBuffer.cpp:191:26: warning: 'getArray' is deprecated [-Wdeprecated-declarations]
    testOk1(strncmp(buf->getArray(),expect,6)==0);
2 warnings generated.
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testTimeStamp.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testSharedVector.cpp
../../testApp/misc/testSharedVector.cpp:157:9: warning: explicitly assigning value of variable of type 'pvd::shared_vector<pvd::int32>' (aka 'shared_vector<int>') to itself [-Wself-assign-overloaded]
    one = one; // no-op
1 warning generated.
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testUnitTest.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testjson.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testTypeCast.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/test_reftrack.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testSerialization.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testanyscalar.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testBitSetUtil.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testPVType.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/misc/testprinter.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testIntrospect.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testStandardField.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testStandardPVField.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testConvert.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testPVUnion.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testPVStructureArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testPVScalarArray.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testPVData.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testOperators.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testValueBuilder.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/pv/testFieldBuilder.cpp
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/property/testProperty.cpp
c++ -o testThread  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testThread.o    -lpvData -lCom
c++ -o testEvent  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testEvent.o    -lpvData -lCom
c++ -o testTimer  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testTimer.o    -lpvData -lCom
c++ -o testBitSet  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testBitSet.o    -lpvData -lCom
c++ -o testOverrunBitSet  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testOverrunBitSet.o    -lpvData -lCom
c++ -o testByteOrder  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testByteOrder.o    -lpvData -lCom
c++ -o testByteBuffer  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testByteBuffer.o    -lpvData -lCom
c++ -o testBaseException  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testBaseException.o    -lpvData -lCom
c++ -o testSharedVector  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testSharedVector.o    -lpvData -lCom
c++ -o testDebugPtr  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testDebugPtr.o    -lpvData -lCom
c++ -o testSerialization  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testSerialization.o    -lpvData -lCom
c++ -o testTimeStamp  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testTimeStamp.o    -lpvData -lCom
c++ -o testTypeCast  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testTypeCast.o    -lpvData -lCom
c++ -o testUnitTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testUnitTest.o    -lpvData -lCom
c++ -o testjson  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testjson.o    -lpvData -lCom
c++ -o test_reftrack  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            test_reftrack.o    -lpvData -lCom
c++ -o testanyscalar  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testanyscalar.o    -lpvData -lCom
c++ -o testprinter  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testprinter.o    -lpvData -lCom
c++ -o testBitSetUtil  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testBitSetUtil.o    -lpvData -lCom
c++ -o testIntrospect  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testIntrospect.o    -lpvData -lCom
c++           -DPVD_INTERNAL    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/misc -I../../testApp/pv -I../../testApp/property -I../../testApp/copy -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/copy/testCreateRequest.cpp
c++ -o testPVType  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVType.o    -lpvData -lCom
c++ -o testStandardField  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testStandardField.o    -lpvData -lCom
c++ -o testStandardPVField  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testStandardPVField.o    -lpvData -lCom
c++ -o testPVData  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVData.o    -lpvData -lCom
c++ -o testPVUnion  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVUnion.o    -lpvData -lCom
c++ -o testConvert  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testConvert.o    -lpvData -lCom
c++ -o testPVScalarArray  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVScalarArray.o    -lpvData -lCom
c++ -o testPVStructureArray  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVStructureArray.o    -lpvData -lCom
c++ -o testOperators  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testOperators.o    -lpvData -lCom
c++ -o testFieldBuilder  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testFieldBuilder.o    -lpvData -lCom
c++ -o testValueBuilder  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testValueBuilder.o    -lpvData -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testThread.t testThread
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testEvent.t testEvent
c++ -o testCreateRequest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testCreateRequest.o    -lpvData -lCom
c++ -o testProperty  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testProperty.o    -lpvData -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testTimer.t testTimer
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testBitSet.t testBitSet
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testOverrunBitSet.t testOverrunBitSet
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testByteBuffer.t testByteBuffer
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testBaseException.t testBaseException
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testSharedVector.t testSharedVector
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testDebugPtr.t testDebugPtr
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testSerialization.t testSerialization
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testTimeStamp.t testTimeStamp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testTypeCast.t testTypeCast
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testUnitTest.t testUnitTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testjson.t testjson
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 test_reftrack.t test_reftrack
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testanyscalar.t testanyscalar
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testprinter.t testprinter
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testBitSetUtil.t testBitSetUtil
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testIntrospect.t testIntrospect
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVType.t testPVType
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testStandardField.t testStandardField
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testStandardPVField.t testStandardPVField
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVData.t testPVData
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVUnion.t testPVUnion
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testConvert.t testConvert
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVScalarArray.t testPVScalarArray
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVStructureArray.t testPVStructureArray
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testOperators.t testOperators
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testFieldBuilder.t testFieldBuilder
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testValueBuilder.t testValueBuilder
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testProperty.t testProperty
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testCreateRequest.t testCreateRequest
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/testApp/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData/testApp'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvData'
/Users/jenkins/bin/make -C ./normativeTypes install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes'
/Users/jenkins/bin/make -C ./configure install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/configure'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/configure/O.darwin-x86'
Installing CFG file /Users/jenkins/workspace/epics-7.0/OS/mac/cfg/CONFIG_NTYPES_VERSION
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/convertRelease.pl checkRelease
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/configure/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/configure'
/Users/jenkins/bin/make -C ./src install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/src'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/src/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntndarrayAttribute.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntndarrayAttribute.o ../ntndarrayAttribute.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m nthistogram.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        nthistogram.o ../nthistogram.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m nturi.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        nturi.o ../nturi.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntcontinuum.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntcontinuum.o ../ntcontinuum.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntaggregate.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntaggregate.o ../ntaggregate.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntattribute.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntattribute.o ../ntattribute.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntunion.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntunion.o ../ntunion.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntenum.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntenum.o ../ntenum.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntmatrix.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntmatrix.o ../ntmatrix.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntndarray.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntndarray.o ../ntndarray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntscalarMultiChannel.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntscalarMultiChannel.o ../ntscalarMultiChannel.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntmultiChannel.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntmultiChannel.o ../ntmultiChannel.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m nttable.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        nttable.o ../nttable.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntnameValue.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntnameValue.o ../ntnameValue.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntscalarArray.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntscalarArray.o ../ntscalarArray.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntfield.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntfield.o ../ntfield.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntscalar.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntscalar.o ../ntscalar.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntid.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntid.o ../ntid.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntutils.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntutils.o ../ntutils.cpp
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/nt.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntutils.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntid.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntfield.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntscalar.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntscalarArray.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntnameValue.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/nttable.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntmultiChannel.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntscalarMultiChannel.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntndarray.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntmatrix.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntenum.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntunion.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntaggregate.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntattribute.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntcontinuum.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/nthistogram.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/nturi.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/ntndarrayAttribute.h
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntutils.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntid.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntfield.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntscalar.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntscalarArray.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntnameValue.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../nttable.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntmultiChannel.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntscalarMultiChannel.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntmatrix.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntndarray.cpp
../ntndarray.cpp:264:15: warning: non-type template argument referring to function 'isValue' with internal linkage is a C++11 extension [-Wc++11-extensions]
        .has<&isValue>("value")
../ntndarray.cpp:222:13: note: non-type template argument refers to function here
    Result& isValue(Result& result)
../ntndarray.cpp:265:15: warning: non-type template argument referring to function 'isCodec' with internal linkage is a C++11 extension [-Wc++11-extensions]
        .has<&isCodec>("codec")
../ntndarray.cpp:235:13: note: non-type template argument refers to function here
    Result& isCodec(Result& result)
../ntndarray.cpp:268:15: warning: non-type template argument referring to function 'isDimension' with internal linkage is a C++11 extension [-Wc++11-extensions]
        .has<&isDimension>("dimension")
../ntndarray.cpp:243:13: note: non-type template argument refers to function here
    Result& isDimension(Result& result)
3 warnings generated.
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntenum.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntunion.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntaggregate.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntattribute.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntcontinuum.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../nthistogram.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../nturi.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntndarrayAttribute.cpp
c++ -o libnt.6.0.2.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libnt.6.0.2.dylib -compatibility_version 6.0.2 -current_version 6.0.2 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64             ntutils.o ntid.o ntfield.o ntscalar.o ntscalarArray.o ntnameValue.o nttable.o ntmultiChannel.o ntscalarMultiChannel.o ntndarray.o ntmatrix.o ntenum.o ntunion.o ntaggregate.o ntattribute.o ntcontinuum.o nthistogram.o nturi.o ntndarrayAttribute.o   -lpvData -lCom      -lreadline -lm
Installing shared library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libnt.6.0.2.dylib
ln -s libnt.6.0.2.dylib /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libnt.dylib
/usr/bin/ar -rc    libnt.a     ntutils.o ntid.o ntfield.o ntscalar.o ntscalarArray.o ntnameValue.o nttable.o ntmultiChannel.o ntscalarMultiChannel.o ntndarray.o ntmatrix.o ntenum.o ntunion.o ntaggregate.o ntattribute.o ntcontinuum.o nthistogram.o nturi.o ntndarrayAttribute.o
/usr/bin/ranlib libnt.a
Installing library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libnt.a
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/src/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/src'
/Users/jenkins/bin/make -C ./test install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/test'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
    T_A=darwin-x86 install
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/test/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntutilsTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntutilsTest.o ../ntutilsTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m validatorTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        validatorTest.o ../validatorTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntndarrayAttributeTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntndarrayAttributeTest.o ../ntndarrayAttributeTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntattributeTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntattributeTest.o ../ntattributeTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntaggregateTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntaggregateTest.o ../ntaggregateTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntunionTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntunionTest.o ../ntunionTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntenumTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntenumTest.o ../ntenumTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntmatrixTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntmatrixTest.o ../ntmatrixTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntndarrayTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntndarrayTest.o ../ntndarrayTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m nttableTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        nttableTest.o ../nttableTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntscalarMultiChannelTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntscalarMultiChannelTest.o ../ntscalarMultiChannelTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntmultiChannelTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntmultiChannelTest.o ../ntmultiChannelTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntnameValueTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntnameValueTest.o ../ntnameValueTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntscalarArrayTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntscalarArrayTest.o ../ntscalarArrayTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntscalarTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntscalarTest.o ../ntscalarTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ntfieldTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ntfieldTest.o ../ntfieldTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m nthistogramTest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        nthistogramTest.o ../nthistogramTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntfieldTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntscalarTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntscalarArrayTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntnameValueTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntmultiChannelTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntscalarMultiChannelTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntndarrayTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntmatrixTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../nttableTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntenumTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntunionTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntaggregateTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntattributeTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntndarrayAttributeTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntutilsTest.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../ntcontinuumTest.cpp
c++ -o ntfieldTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntfieldTest.o    -lnt -lpvData -lCom
c++ -o ntscalarTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntscalarTest.o    -lnt -lpvData -lCom
c++ -o ntscalarArrayTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntscalarArrayTest.o    -lnt -lpvData -lCom
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../nthistogramTest.cpp
c++ -o ntnameValueTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntnameValueTest.o    -lnt -lpvData -lCom
c++ -o ntmultiChannelTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntmultiChannelTest.o    -lnt -lpvData -lCom
c++ -o ntscalarMultiChannelTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntscalarMultiChannelTest.o    -lnt -lpvData -lCom
c++ -o nttableTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            nttableTest.o    -lnt -lpvData -lCom
c++ -o ntndarrayTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntndarrayTest.o    -lnt -lpvData -lCom
c++ -o ntmatrixTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntmatrixTest.o    -lnt -lpvData -lCom
c++ -o ntenumTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntenumTest.o    -lnt -lpvData -lCom
c++ -o ntunionTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntunionTest.o    -lnt -lpvData -lCom
c++ -o ntaggregateTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntaggregateTest.o    -lnt -lpvData -lCom
c++ -o ntattributeTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntattributeTest.o    -lnt -lpvData -lCom
c++ -o ntndarrayAttributeTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntndarrayAttributeTest.o    -lnt -lpvData -lCom
c++ -o ntcontinuumTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntcontinuumTest.o    -lnt -lpvData -lCom
c++ -o nthistogramTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            nthistogramTest.o    -lnt -lpvData -lCom
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../validatorTest.cpp
c++ -o ntutilsTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ntutilsTest.o    -lnt -lpvData -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntfieldTest.t ntfieldTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntscalarTest.t ntscalarTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntscalarArrayTest.t ntscalarArrayTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntnameValueTest.t ntnameValueTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntmultiChannelTest.t ntmultiChannelTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntscalarMultiChannelTest.t ntscalarMultiChannelTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 nttableTest.t nttableTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntndarrayTest.t ntndarrayTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntmatrixTest.t ntmatrixTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntenumTest.t ntenumTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntunionTest.t ntunionTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntaggregateTest.t ntaggregateTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntattributeTest.t ntattributeTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntndarrayAttributeTest.t ntndarrayAttributeTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntcontinuumTest.t ntcontinuumTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 nthistogramTest.t nthistogramTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 ntutilsTest.t ntutilsTest
c++ -o validatorTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            validatorTest.o    -lnt -lpvData -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 validatorTest.t validatorTest
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/test/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes/test'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/normativeTypes'
/Users/jenkins/bin/make -C ./database install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database'
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src'
/Users/jenkins/bin/make -C ./tools install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/tools'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../../../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../../../../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../../.. \
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/tools/O.darwin-x86'
Installing PERL_MODULES file ../../../../../lib/perl/DBD.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Base.pm
mkdir ../../../../../lib/perl/DBD
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Breaktable.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Device.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Driver.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Link.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Function.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Menu.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Output.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Parser.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Recfield.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Recordtype.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Record.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Registrar.pm
Installing PERL_MODULES file ../../../../../lib/perl/DBD/Variable.pm
Installing PERL_MODULES file ../../../../../lib/perl/EPICS/IOC.pm
Expanding ../epics-base.pc@ to epics-base.pc
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -a darwin-x86 -DFINAL_LOCATION="/Users/jenkins/workspace/epics-7.0/OS/mac" -DOS_CLASS="Darwin" -DCMPLR_CLASS="clang" -DC_CFLAGS="-DUNIX -Ddarwin -arch x86_64 -fno-common" -DLDFLAGS="-arch x86_64" -DLDLIBS="-lreadline -lm" -DEPICS_VERSION="7" -DEPICS_REVISION="0" -DEPICS_MODIFICATION="6" -DEPICS_PATCH_LEVEL="2" -DCC="cc" -DCCC="c++" -DCPP="cc -x c -E" -DAR="/usr/bin/ar -rc" -DLD="/usr/bin/ld -r" -DEPICS_BASE_HOST_LIBS="ca Com" -DEPICS_BASE_IOC_LIBS="dbRecStd dbCore ca Com" -t ../../../../..    ../epics-base.pc@ epics-base.pc
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podToHtml.pl -s -o IOC.html ../EPICS/IOC.pm
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podToHtml.pl -s -o dbdToHtml.html ../dbdToHtml.pl
Installing script ../../../../../bin/darwin-x86/makeIncludeDbd.pl
Installing script ../../../../../bin/darwin-x86/dbdToMenuH.pl
Installing script ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl
Installing script ../../../../../bin/darwin-x86/dbdExpand.pl
Installing script ../../../../../bin/darwin-x86/dbExpand.pl
Installing script ../../../../../bin/darwin-x86/dbdToHtml.pl
Installing script ../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl
Installing PKGCONFIG file ../../../../../lib/pkgconfig/epics-base.pc
mkdir ../../../../../lib/pkgconfig
Expanding epics-base-darwin-x86.pc@ to epics-base-darwin-x86.pc
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -a darwin-x86 -DFINAL_LOCATION="/Users/jenkins/workspace/epics-7.0/OS/mac" -DOS_CLASS="Darwin" -DCMPLR_CLASS="clang" -DC_CFLAGS="-DUNIX -Ddarwin -arch x86_64 -fno-common" -DLDFLAGS="-arch x86_64" -DLDLIBS="-lreadline -lm" -DEPICS_VERSION="7" -DEPICS_REVISION="0" -DEPICS_MODIFICATION="6" -DEPICS_PATCH_LEVEL="2" -DCC="cc" -DCCC="c++" -DCPP="cc -x c -E" -DAR="/usr/bin/ar -rc" -DLD="/usr/bin/ld -r" -DEPICS_BASE_HOST_LIBS="ca Com" -DEPICS_BASE_IOC_LIBS="dbRecStd dbCore ca Com" -t ../../../../..    epics-base-darwin-x86.pc@ epics-base-darwin-x86.pc
Installing generated html ../../../../../html/./EPICS/IOC.html
Installing generated html ../../../../../html/./dbdToHtml.html
Installing PKGCONFIG file ../../../../../lib/pkgconfig/epics-base-darwin-x86.pc
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/tools/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/tools'
/Users/jenkins/bin/make -C ./template install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/template'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/template/O.darwin-x86'
Installing ../../../../../templates/makeBaseApp/top/iocApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp
Installing ../../../../../templates/makeBaseApp/top/iocApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp/Db
Installing ../../../../../templates/makeBaseApp/top/iocApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocApp/src
Installing ../../../../../templates/makeBaseApp/top/iocApp/src/_APPNAME_Main.cpp
Installing ../../../../../templates/makeBaseApp/top/supportApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp
Installing ../../../../../templates/makeBaseApp/top/supportApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp/Db
Installing ../../../../../templates/makeBaseApp/top/supportApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/supportApp/src
Installing ../../../../../templates/makeBaseApp/top/supportApp/src/_APPNAME_.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp/Db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/circle.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample1.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbExample2.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/_APPNAME_Version.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/dbSubExample.db
Installing ../../../../../templates/makeBaseApp/top/exampleApp/Db/user.substitutions
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleApp/src
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dev_APPNAME_Version.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dev_APPNAME_Version.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxRecord.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/devXxxSoft.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/xxxSupport.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncProgram.st
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.stt
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/sncExample.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Main.cpp
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/dbSubExample.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.c
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/_APPNAME_Hello.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleApp/src/initTrace.dbd
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/Makefile
mkdir ../../../../../templates/makeBaseApp/top/exampleBoot
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/nfsCommands@RTEMS
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@Common
mkdir ../../../../../templates/makeBaseApp/top/exampleBoot/ioc
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@win32
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@windows
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/Makefile@cygwin
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@Common
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@vxWorks
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/st.cmd@RTEMS
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@Common
Installing ../../../../../templates/makeBaseApp/top/exampleBoot/ioc/README@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/Makefile
mkdir ../../../../../templates/makeBaseApp/top/iocBoot
Installing ../../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/nfsCommands@RTEMS
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@Common
mkdir ../../../../../templates/makeBaseApp/top/iocBoot/ioc
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@win32
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@cygwin
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/Makefile@windows
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Common
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@Cross
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@vxWorks
Installing ../../../../../templates/makeBaseApp/top/iocBoot/ioc/st.cmd@RTEMS
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/template/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/template'
/Users/jenkins/bin/make -C ./ioc install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/ioc'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/ioc/O.darwin-x86'
Expanding ../databaseVersion.h@ to ../O.Common/databaseVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../..   -DEPICS_DATABASE_MAJOR_VERSION="3"  -DEPICS_DATABASE_MINOR_VERSION="21"  -DEPICS_DATABASE_MAINTENANCE_VERSION="1"  -DEPICS_DATABASE_DEVELOPMENT_FLAG="1"  ../databaseVersion.h@ databaseVersion.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuConvert.dbd ../bpt/menuConvert.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuAlarmSevr.dbd ../db/menuAlarmSevr.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuAlarmStat.dbd ../db/menuAlarmStat.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuFtype.dbd ../db/menuFtype.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuIvoa.dbd ../db/menuIvoa.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuOmsl.dbd ../db/menuOmsl.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuPini.dbd ../db/menuPini.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuPost.dbd ../db/menuPost.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuYesNo.dbd ../db/menuYesNo.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuPriority.dbd ../db/menuPriority.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuSimm.dbd ../db/menuSimm.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o dbCommonRecord.dbd ../db/dbCommonRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o menuScan.dbd ../db/menuScan.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeAPIheader.pl -o ../O.Common/dbCoreAPI.h dbCore
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/e_flex -S../../../../../include/flex.skel.static -8 -I -odbLoadTemplate_lex.c ../dbtemplate/dbLoadTemplate_lex.l
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/e_flex -S../../../../../include/flex.skel.static -8 -I -odbLex.c ../dbStatic/dbLex.l
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/genVersionHeader.pl   -t ../../../../.. -N EPICS_VCS_VERSION -V "" ../O.Common/epicsVCS.h
Creating VCS header ../O.Common/epicsVCS.h
    EPICS_VCS_VERSION = "R7.0.6.1-21-g4340e7644557dff847fd-dirty"
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuConvert.h ../O.Common/menuConvert.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmSevr.h ../O.Common/menuAlarmSevr.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmStat.h ../O.Common/menuAlarmStat.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuFtype.h ../O.Common/menuFtype.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuIvoa.h ../O.Common/menuIvoa.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuOmsl.h ../O.Common/menuOmsl.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPini.h ../O.Common/menuPini.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPost.h ../O.Common/menuPost.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuYesNo.h ../O.Common/menuYesNo.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPriority.h ../O.Common/menuPriority.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuSimm.h ../O.Common/menuSimm.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToMenuH.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuScan.h ../O.Common/menuScan.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl -I ../db  -I ../O.Common -o dbCommon.h ../O.Common/dbCommonRecord.dbd
Installing generated generic include file ../../../../../include/dbCoreAPI.h
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/antelope -bdbLoadTemplate  ../dbtemplate/dbLoadTemplate.y
mv dbLoadTemplate.tab.c dbLoadTemplate.c
/Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/antelope -bdbYacc  ../dbStatic/dbYacc.y
mv dbYacc.tab.c dbYacc.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbServer.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbServer.o ../db/dbServer.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbUnitTest.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbUnitTest.o ../db/dbUnitTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbStaticLib.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbStaticLib.o ../dbStatic/dbStaticLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbState.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbState.o ../db/dbState.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m chfPlugin.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         chfPlugin.o ../db/chfPlugin.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbIocRegister.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbIocRegister.o ../db/dbIocRegister.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbContextReadNotifyCache.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbContextReadNotifyCache.o ../db/dbContextReadNotifyCache.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbSubscriptionIO.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbSubscriptionIO.o ../db/dbSubscriptionIO.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbChannelIO.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbChannelIO.o ../db/dbChannelIO.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbContext.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbContext.o ../db/dbContext.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cvtBpt.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cvtBpt.o ../db/cvtBpt.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbCaTest.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbCaTest.o ../db/dbCaTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbCa.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbCa.o ../db/dbCa.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m callback.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         callback.o ../db/callback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m recGbl.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         recGbl.o ../db/recGbl.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m db_test.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         db_test.o ../db/db_test.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m db_access.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         db_access.o ../db/db_access.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbTest.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbTest.o ../db/dbTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbEvent.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbEvent.o ../db/dbEvent.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbScan.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbScan.o ../db/dbScan.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbNotify.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbNotify.o ../db/dbNotify.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbLink.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbLink.o ../db/dbLink.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbJLink.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbJLink.o ../db/dbJLink.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbExtractArray.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbExtractArray.o ../db/dbExtractArray.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbFastLinkConv.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbFastLinkConv.o ../db/dbFastLinkConv.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbDbLink.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbDbLink.o ../db/dbDbLink.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbConvertJSON.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbConvertJSON.o ../db/dbConvertJSON.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbConvert.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbConvert.o ../db/dbConvert.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbConstLink.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbConstLink.o ../db/dbConstLink.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbChannel.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbChannel.o ../db/dbChannel.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbBkpt.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbBkpt.o ../db/dbBkpt.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbAccess.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbAccess.o ../db/dbAccess.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbLock.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbLock.o ../db/dbLock.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asIocRegister.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         asIocRegister.o ../as/asIocRegister.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asCa.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         asCa.o ../as/asCa.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asDbLib.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         asDbLib.o ../as/asDbLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m msi.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         msi.o ../dbtemplate/msi.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m makeBpt.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         makeBpt.o ../bpt/makeBpt.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ascheck.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         ascheck.o ../as/ascheck.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m online_notify.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         online_notify.o ../rsrv/online_notify.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m rsrvIocRegister.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         rsrvIocRegister.o ../rsrv/rsrvIocRegister.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m cast_server.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         cast_server.o ../rsrv/cast_server.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m camsgtask.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         camsgtask.o ../rsrv/camsgtask.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caservertask.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         caservertask.o ../rsrv/caservertask.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m camessage.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include    -I/ca/client     camessage.o ../rsrv/camessage.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caserverio.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include    -I/ca/client     caserverio.o ../rsrv/caserverio.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registryCommon.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         registryCommon.o ../registry/registryCommon.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registryIocRegister.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         registryIocRegister.o ../registry/registryIocRegister.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registryFunction.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         registryFunction.o ../registry/registryFunction.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registryJLinks.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         registryJLinks.o ../registry/registryJLinks.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registryDriverSupport.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         registryDriverSupport.o ../registry/registryDriverSupport.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registryDeviceSupport.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         registryDeviceSupport.o ../registry/registryDeviceSupport.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registryRecordType.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         registryRecordType.o ../registry/registryRecordType.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registerAllRecordDeviceDrivers.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         registerAllRecordDeviceDrivers.o ../misc/registerAllRecordDeviceDrivers.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dlload.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dlload.o ../misc/dlload.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocshRegisterCommon.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         iocshRegisterCommon.o ../misc/iocshRegisterCommon.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m miscIocRegister.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         miscIocRegister.o ../misc/miscIocRegister.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicsRelease.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         epicsRelease.o ../misc/epicsRelease.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m iocInit.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         iocInit.o ../misc/iocInit.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbtoolsIocRegister.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbtoolsIocRegister.o ../dbtemplate/dbtoolsIocRegister.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbStaticIocRegister.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbStaticIocRegister.o ../dbStatic/dbStaticIocRegister.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbLoadTemplate.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbLoadTemplate.o dbLoadTemplate.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbStaticRun.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbStaticRun.o ../dbStatic/dbStaticRun.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbPvdLib.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbPvdLib.o ../dbStatic/dbPvdLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbYacc.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbYacc.o dbYacc.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbPutNotifyBlocker.d -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbPutNotifyBlocker.o ../db/dbPutNotifyBlocker.cpp
Keeping VCS header ../O.Common/epicsVCS.h
Installing generic include file ../../../../../include/asDbLib.h
Installing generic include file ../../../../../include/asCa.h
Installing generic include file ../../../../../include/asIocRegister.h
Installing generic include file ../../../../../include/cvtTable.h
Installing generic include file ../../../../../include/callback.h
Installing generic include file ../../../../../include/dbAccess.h
Installing generic include file ../../../../../include/dbAddr.h
Installing generic include file ../../../../../include/dbAccessDefs.h
Installing generic include file ../../../../../include/dbBkpt.h
Installing generic include file ../../../../../include/dbCa.h
Installing generic include file ../../../../../include/dbChannel.h
Installing generic include file ../../../../../include/dbConstLink.h
Installing generic include file ../../../../../include/dbConvert.h
Installing generic include file ../../../../../include/dbConvertFast.h
Installing generic include file ../../../../../include/dbDbLink.h
Installing generic include file ../../../../../include/dbConvertJSON.h
Installing generic include file ../../../../../include/dbExtractArray.h
Installing generic include file ../../../../../include/dbEvent.h
Installing generic include file ../../../../../include/dbJLink.h
Installing generic include file ../../../../../include/dbLink.h
Installing generic include file ../../../../../include/dbLock.h
Installing generic include file ../../../../../include/dbNotify.h
Installing generic include file ../../../../../include/dbScan.h
Installing generic include file ../../../../../include/dbServer.h
Installing generic include file ../../../../../include/dbTest.h
Installing generic include file ../../../../../include/dbCaTest.h
Installing generic include file ../../../../../include/db_test.h
Installing generic include file ../../../../../include/db_field_log.h
Installing generic include file ../../../../../include/recGbl.h
Installing generic include file ../../../../../include/dbIocRegister.h
Installing generic include file ../../../../../include/chfPlugin.h
Installing generic include file ../../../../../include/dbState.h
Installing generic include file ../../../../../include/db_access_routines.h
Installing generic include file ../../../../../include/db_convert.h
Installing generic include file ../../../../../include/dbUnitTest.h
Installing generic include file ../../../../../include/dbBase.h
Installing generic include file ../../../../../include/dbFldTypes.h
Installing generic include file ../../../../../include/dbStaticLib.h
Installing generic include file ../../../../../include/dbStaticPvt.h
Installing generic include file ../../../../../include/link.h
Installing generic include file ../../../../../include/special.h
Installing generic include file ../../../../../include/guigroup.h
Installing generic include file ../../../../../include/devSup.h
Installing generic include file ../../../../../include/drvSup.h
Installing generic include file ../../../../../include/recSup.h
Installing generic include file ../../../../../include/dbStaticIocRegister.h
Installing generic include file ../../../../../include/dbLoadTemplate.h
Installing generic include file ../../../../../include/dbtoolsIocRegister.h
Installing generic include file ../../../../../include/epicsRelease.h
Installing generic include file ../../../../../include/iocInit.h
Installing generic include file ../../../../../include/miscIocRegister.h
Installing generic include file ../../../../../include/iocshRegisterCommon.h
Installing generic include file ../../../../../include/registryRecordType.h
Installing generic include file ../../../../../include/registryDeviceSupport.h
Installing generic include file ../../../../../include/registryDriverSupport.h
Installing generic include file ../../../../../include/registryJLinks.h
Installing generic include file ../../../../../include/registryFunction.h
Installing generic include file ../../../../../include/registryCommon.h
Installing generic include file ../../../../../include/registryIocRegister.h
Installing generic include file ../../../../../include/rsrv.h
Installing generated generic include file ../../../../../include/menuConvert.h
Installing generated generic include file ../../../../../include/menuAlarmSevr.h
Installing generated generic include file ../../../../../include/menuAlarmStat.h
Installing generated generic include file ../../../../../include/menuFtype.h
Installing generated generic include file ../../../../../include/menuIvoa.h
Installing generated generic include file ../../../../../include/menuOmsl.h
Installing generated generic include file ../../../../../include/menuPini.h
Installing generated generic include file ../../../../../include/menuPost.h
Installing generated generic include file ../../../../../include/menuPriority.h
Installing generated generic include file ../../../../../include/menuYesNo.h
Installing generated generic include file ../../../../../include/menuSimm.h
Installing generated generic include file ../../../../../include/menuScan.h
Installing generated generic include file ../../../../../include/dbCommon.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o dbCommon.dbd ../db/dbCommon.dbd.pod
Creating dbd file menuGlobal.dbd
perl -CSD ../../../../../bin/darwin-x86/makeIncludeDbd.pl menuAlarmSevr.dbd menuAlarmStat.dbd menuFtype.dbd menuIvoa.dbd menuOmsl.dbd menuPini.dbd menuPost.dbd menuPriority.dbd menuYesNo.dbd menuSimm.dbd menuGlobal.dbd
Installing dbd file ../../../../../dbd/system.dbd
mkdir ../../../../../dbd
Installing dbd file ../../../../../dbd/dlload.dbd
Installing dbd file ../../../../../dbd/dbCore.dbd
Installing dbd file ../../../../../dbd/rsrv.dbd
Installing created dbd file ../../../../../dbd/menuConvert.dbd
Installing created dbd file ../../../../../dbd/menuAlarmSevr.dbd
Installing created dbd file ../../../../../dbd/menuAlarmStat.dbd
Installing created dbd file ../../../../../dbd/menuFtype.dbd
Installing created dbd file ../../../../../dbd/menuIvoa.dbd
Installing created dbd file ../../../../../dbd/menuOmsl.dbd
Installing created dbd file ../../../../../dbd/menuPini.dbd
Installing created dbd file ../../../../../dbd/menuPost.dbd
Installing created dbd file ../../../../../dbd/menuPriority.dbd
Installing created dbd file ../../../../../dbd/menuYesNo.dbd
Installing created dbd file ../../../../../dbd/menuSimm.dbd
Installing created dbd file ../../../../../dbd/menuScan.dbd
Installing created dbd file ../../../../../dbd/dbCommon.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuConvert.html ../bpt/menuConvert.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuFtype.html ../db/menuFtype.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuIvoa.html ../db/menuIvoa.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuSimm.html ../db/menuSimm.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPini.html ../db/menuPini.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuYesNo.html ../db/menuYesNo.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmSevr.html ../db/menuAlarmSevr.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuAlarmStat.html ../db/menuAlarmStat.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuOmsl.html ../db/menuOmsl.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPriority.html ../db/menuPriority.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuPost.html ../db/menuPost.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o menuScan.html ../db/menuScan.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../dbd -o dbCommonRecord.html ../db/dbCommonRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podToHtml.pl -s -s -o dbCommonInput.html ../db/dbCommonInput.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podToHtml.pl -s -s -o dbCommonOutput.html ../db/dbCommonOutput.pod
Installing html ../../../../../html/./msi.html
Installing created dbd file ../../../../../dbd/menuGlobal.dbd
Installing generated html ../../../../../html/./menuConvert.html
Installing generated html ../../../../../html/./menuFtype.html
Installing generated html ../../../../../html/./menuIvoa.html
Installing generated html ../../../../../html/./menuSimm.html
Installing generated html ../../../../../html/./menuPini.html
Installing generated html ../../../../../html/./menuYesNo.html
Installing generated html ../../../../../html/./menuAlarmSevr.html
Installing generated html ../../../../../html/./menuAlarmStat.html
Installing generated html ../../../../../html/./menuOmsl.html
Installing generated html ../../../../../html/./menuPriority.html
Installing generated html ../../../../../html/./menuPost.html
Installing generated html ../../../../../html/./menuScan.html
Installing generated html ../../../../../html/./dbCommonRecord.html
Installing generated html ../../../../../html/./dbCommonInput.html
Installing generated html ../../../../../html/./dbCommonOutput.html
Installing generated generic include file ../../../../../include/databaseVersion.h
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../bpt/makeBpt.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../as/asDbLib.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../as/asCa.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../as/asIocRegister.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbLock.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbAccess.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbBkpt.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbConstLink.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbChannel.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbConvertJSON.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbDbLink.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbFastLinkConv.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbExtractArray.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbConvert.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbJLink.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbLink.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbNotify.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbScan.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbEvent.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/db_access.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/db_test.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/recGbl.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/callback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbCa.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbCaTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/cvtBpt.c
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbChannelIO.cpp
../db/dbChannelIO.cpp:152:13: warning: result of comparison of constant -1 with expression of type 'unsigned short' is always true [-Wtautological-constant-out-of-range-compare]
            dbf_type_to_text ( dbChannelExportCAType ( this->dbch ) ),
../../../../../include/db_access.h:679:16: note: expanded from macro 'dbf_type_to_text'
    (  ((type) >= -1 && (type) < dbf_text_dim-2) ? \
1 warning generated.
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbContext.cpp
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbSubscriptionIO.cpp
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbPutNotifyBlocker.cpp
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbContextReadNotifyCache.cpp
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbIocRegister.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/chfPlugin.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbState.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbUnitTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../db/dbServer.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dbStatic/dbPvdLib.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c dbYacc.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dbStatic/dbStaticLib.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dbStatic/dbStaticRun.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dbStatic/dbStaticIocRegister.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c dbLoadTemplate.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dbtemplate/dbtoolsIocRegister.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../misc/epicsRelease.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../misc/iocInit.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../misc/miscIocRegister.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../misc/dlload.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../misc/iocshRegisterCommon.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../registry/registryRecordType.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../registry/registryDeviceSupport.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../registry/registryDriverSupport.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../registry/registryJLinks.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../registry/registryFunction.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../registry/registryCommon.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../registry/registryIocRegister.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include    -I/ca/client     -c ../rsrv/caserverio.c
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../misc/registerAllRecordDeviceDrivers.cpp
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rsrv/camsgtask.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rsrv/caservertask.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rsrv/cast_server.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rsrv/online_notify.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include    -I/ca/client     -c ../rsrv/camessage.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbCore_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rsrv/rsrvIocRegister.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../as/ascheck.c
c++ -o libdbCore.3.21.1.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libdbCore.3.21.1.dylib -compatibility_version 3.21.1 -current_version 3.21.1 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            asDbLib.o asCa.o asIocRegister.o dbLock.o dbAccess.o dbBkpt.o dbChannel.o dbConstLink.o dbConvert.o dbConvertJSON.o dbDbLink.o dbFastLinkConv.o dbExtractArray.o dbJLink.o dbLink.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o dbIocRegister.o chfPlugin.o dbState.o dbUnitTest.o dbServer.o dbStaticLib.o dbYacc.o dbPvdLib.o dbStaticRun.o dbStaticIocRegister.o dbLoadTemplate.o dbtoolsIocRegister.o epicsRelease.o iocInit.o miscIocRegister.o dlload.o iocshRegisterCommon.o registerAllRecordDeviceDrivers.o registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryJLinks.o registryFunction.o registryCommon.o registryIocRegister.o caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o rsrvIocRegister.o    -lca -lCom      -lreadline -lm
/usr/bin/ar -rc    libdbCore.a    asDbLib.o asCa.o asIocRegister.o dbLock.o dbAccess.o dbBkpt.o dbChannel.o dbConstLink.o dbConvert.o dbConvertJSON.o dbDbLink.o dbFastLinkConv.o dbExtractArray.o dbJLink.o dbLink.o dbNotify.o dbScan.o dbEvent.o dbTest.o db_access.o db_test.o recGbl.o callback.o dbCa.o dbCaTest.o cvtBpt.o dbContext.o dbChannelIO.o dbSubscriptionIO.o dbPutNotifyBlocker.o dbContextReadNotifyCache.o dbIocRegister.o chfPlugin.o dbState.o dbUnitTest.o dbServer.o dbStaticLib.o dbYacc.o dbPvdLib.o dbStaticRun.o dbStaticIocRegister.o dbLoadTemplate.o dbtoolsIocRegister.o epicsRelease.o iocInit.o miscIocRegister.o dlload.o iocshRegisterCommon.o registerAllRecordDeviceDrivers.o registryRecordType.o registryDeviceSupport.o registryDriverSupport.o registryJLinks.o registryFunction.o registryCommon.o registryIocRegister.o caserverio.o caservertask.o camsgtask.o camessage.o cast_server.o online_notify.o rsrvIocRegister.o
/usr/bin/ranlib libdbCore.a
Installing shared library ../../../../../lib/darwin-x86/libdbCore.3.21.1.dylib
ln -s libdbCore.3.21.1.dylib ../../../../../lib/darwin-x86/libdbCore.dylib
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../as -I../bpt -I../db -I../dbStatic -I../dbtemplate -I../misc -I../registry -I../rsrv -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dbtemplate/msi.cpp
Installing library ../../../../../lib/darwin-x86/libdbCore.a
c++ -o makeBpt  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            makeBpt.o    -lCom
c++ -o ascheck  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ascheck.o    -ldbCore -lca -lCom -lCom
c++ -o msi  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            msi.o    -lCom -lCom
Installing created executable ../../../../../bin/darwin-x86/makeBpt
Installing created executable ../../../../../bin/darwin-x86/ascheck
Installing created executable ../../../../../bin/darwin-x86/msi
../../../../../bin/darwin-x86/makeBpt ../bpt/bptTypeKdegC.data bptTypeKdegC.dbd
../../../../../bin/darwin-x86/makeBpt ../bpt/bptTypeJdegF.data bptTypeJdegF.dbd
../../../../../bin/darwin-x86/makeBpt ../bpt/bptTypeJdegC.data bptTypeJdegC.dbd
../../../../../bin/darwin-x86/makeBpt ../bpt/bptTypeKdegF.data bptTypeKdegF.dbd
Installing created dbd file ../../../../../dbd/bptTypeJdegF.dbd
Installing created dbd file ../../../../../dbd/bptTypeKdegC.dbd
Installing created dbd file ../../../../../dbd/bptTypeJdegC.dbd
Installing created dbd file ../../../../../dbd/bptTypeKdegF.dbd
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/ioc/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/ioc'
/Users/jenkins/bin/make -C ./std install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/std'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../../../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../../../../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../../.. \
    T_A=darwin-x86 install
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/std/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o aaiRecord.dbd ../rec/aaiRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o aaoRecord.dbd ../rec/aaoRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o aiRecord.dbd ../rec/aiRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o aoRecord.dbd ../rec/aoRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o aSubRecord.dbd ../rec/aSubRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o biRecord.dbd ../rec/biRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o calcRecord.dbd ../rec/calcRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o boRecord.dbd ../rec/boRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o calcoutRecord.dbd ../rec/calcoutRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o compressRecord.dbd ../rec/compressRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o dfanoutRecord.dbd ../rec/dfanoutRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o eventRecord.dbd ../rec/eventRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o histogramRecord.dbd ../rec/histogramRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o fanoutRecord.dbd ../rec/fanoutRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o int64inRecord.dbd ../rec/int64inRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o int64outRecord.dbd ../rec/int64outRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o longinRecord.dbd ../rec/longinRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o longoutRecord.dbd ../rec/longoutRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o lsiRecord.dbd ../rec/lsiRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o lsoRecord.dbd ../rec/lsoRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o mbbiRecord.dbd ../rec/mbbiRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o mbbiDirectRecord.dbd ../rec/mbbiDirectRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o mbboRecord.dbd ../rec/mbboRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o mbboDirectRecord.dbd ../rec/mbboDirectRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o printfRecord.dbd ../rec/printfRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o permissiveRecord.dbd ../rec/permissiveRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o selRecord.dbd ../rec/selRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o seqRecord.dbd ../rec/seqRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o stateRecord.dbd ../rec/stateRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o stringinRecord.dbd ../rec/stringinRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o stringoutRecord.dbd ../rec/stringoutRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o subRecord.dbd ../rec/subRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o subArrayRecord.dbd ../rec/subArrayRecord.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeAPIheader.pl -o ../O.Common/dbRecStdAPI.h dbRecStd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o waveformRecord.dbd ../rec/waveformRecord.dbd.pod
FINAL_LOCATION=/Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD ../softIoc/makeInstallDir.pl "/Users/jenkins/workspace/epics-7.0/OS/mac" > epicsInstallDir.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o filters.dbd ../filters/filters.dbd.pod
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/podRemove.pl -o links.dbd ../link/links.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aaiRecord.h ../O.Common/aaiRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aaoRecord.h ../O.Common/aaoRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aiRecord.h ../O.Common/aiRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aoRecord.h ../O.Common/aoRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aSubRecord.h ../O.Common/aSubRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o biRecord.h ../O.Common/biRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o boRecord.h ../O.Common/boRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o calcRecord.h ../O.Common/calcRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o calcoutRecord.h ../O.Common/calcoutRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o compressRecord.h ../O.Common/compressRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o dfanoutRecord.h ../O.Common/dfanoutRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o eventRecord.h ../O.Common/eventRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o fanoutRecord.h ../O.Common/fanoutRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o histogramRecord.h ../O.Common/histogramRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o int64inRecord.h ../O.Common/int64inRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o int64outRecord.h ../O.Common/int64outRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o longinRecord.h ../O.Common/longinRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o longoutRecord.h ../O.Common/longoutRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o lsiRecord.h ../O.Common/lsiRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o lsoRecord.h ../O.Common/lsoRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbbiRecord.h ../O.Common/mbbiRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbbiDirectRecord.h ../O.Common/mbbiDirectRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbboRecord.h ../O.Common/mbboRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbboDirectRecord.h ../O.Common/mbboDirectRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o permissiveRecord.h ../O.Common/permissiveRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o printfRecord.h ../O.Common/printfRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o selRecord.h ../O.Common/selRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o seqRecord.h ../O.Common/seqRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stateRecord.h ../O.Common/stateRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stringinRecord.h ../O.Common/stringinRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stringoutRecord.h ../O.Common/stringoutRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o subRecord.h ../O.Common/subRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o subArrayRecord.h ../O.Common/subArrayRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o waveformRecord.h ../O.Common/waveformRecord.dbd
Installing generated generic include file ../../../../../include/dbRecStdAPI.h
Creating dbd file stdRecords.dbd
perl -CSD ../../../../../bin/darwin-x86/makeIncludeDbd.pl aaiRecord.dbd aaoRecord.dbd aiRecord.dbd aoRecord.dbd aSubRecord.dbd biRecord.dbd boRecord.dbd calcRecord.dbd calcoutRecord.dbd compressRecord.dbd dfanoutRecord.dbd eventRecord.dbd fanoutRecord.dbd histogramRecord.dbd int64inRecord.dbd int64outRecord.dbd longinRecord.dbd longoutRecord.dbd lsiRecord.dbd lsoRecord.dbd mbbiRecord.dbd mbbiDirectRecord.dbd mbboRecord.dbd mbboDirectRecord.dbd permissiveRecord.dbd printfRecord.dbd selRecord.dbd seqRecord.dbd stateRecord.dbd stringinRecord.dbd stringoutRecord.dbd subRecord.dbd subArrayRecord.dbd waveformRecord.dbd stdRecords.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lnkDebug.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         lnkDebug.o ../link/lnkDebug.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lnkCalc.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         lnkCalc.o ../link/lnkCalc.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lnkConst.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         lnkConst.o ../link/lnkConst.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m utag.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         utag.o ../filters/utag.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m decimate.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         decimate.o ../filters/decimate.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m sync.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         sync.o ../filters/sync.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m arr.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         arr.o ../filters/arr.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbnd.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dbnd.o ../filters/dbnd.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ts.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         ts.o ../filters/ts.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asSubRecordFunctions.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         asSubRecordFunctions.o ../dev/asSubRecordFunctions.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devEnviron.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devEnviron.o ../dev/devEnviron.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devStdio.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devStdio.o ../dev/devStdio.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devTimestamp.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devTimestamp.o ../dev/devTimestamp.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devGeneralTime.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devGeneralTime.o ../dev/devGeneralTime.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lnkState.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         lnkState.o ../link/lnkState.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devSoSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devSoSoftCallback.o ../dev/devSoSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devPrintfSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devPrintfSoftCallback.o ../dev/devPrintfSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbboDirectSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbboDirectSoftCallback.o ../dev/devMbboDirectSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbboSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbboSoftCallback.o ../dev/devMbboSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLsoSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devLsoSoftCallback.o ../dev/devLsoSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLoSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devLoSoftCallback.o ../dev/devLoSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devI64outSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devI64outSoftCallback.o ../dev/devI64outSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devCalcoutSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devCalcoutSoftCallback.o ../dev/devCalcoutSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devBoSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devBoSoftCallback.o ../dev/devBoSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devSiSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devSiSoftCallback.o ../dev/devSiSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devAoSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devAoSoftCallback.o ../dev/devAoSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbbiSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbbiSoftCallback.o ../dev/devMbbiSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbbiDirectSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbbiDirectSoftCallback.o ../dev/devMbbiDirectSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLiSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devLiSoftCallback.o ../dev/devLiSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devI64inSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devI64inSoftCallback.o ../dev/devI64inSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devBiSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devBiSoftCallback.o ../dev/devBiSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devAiSoftCallback.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devAiSoftCallback.o ../dev/devAiSoftCallback.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devSoSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devSoSoft.o ../dev/devSoSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devWfSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devWfSoft.o ../dev/devWfSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devPrintfSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devPrintfSoft.o ../dev/devPrintfSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devSiSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devSiSoft.o ../dev/devSiSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devSASoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devSASoft.o ../dev/devSASoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbboSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbboSoft.o ../dev/devMbboSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbboSoftRaw.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbboSoftRaw.o ../dev/devMbboSoftRaw.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbboDirectSoftRaw.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbboDirectSoftRaw.o ../dev/devMbboDirectSoftRaw.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbboDirectSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbboDirectSoft.o ../dev/devMbboDirectSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbbiSoftRaw.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbbiSoftRaw.o ../dev/devMbbiSoftRaw.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbbiSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbbiSoft.o ../dev/devMbbiSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbbiDirectSoftRaw.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbbiDirectSoftRaw.o ../dev/devMbbiDirectSoftRaw.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devMbbiDirectSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devMbbiDirectSoft.o ../dev/devMbbiDirectSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLsoSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devLsoSoft.o ../dev/devLsoSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLsiSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devLsiSoft.o ../dev/devLsiSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLiSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devLiSoft.o ../dev/devLiSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devLoSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devLoSoft.o ../dev/devLoSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devI64outSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devI64outSoft.o ../dev/devI64outSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devI64inSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devI64inSoft.o ../dev/devI64inSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devHistogramSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devHistogramSoft.o ../dev/devHistogramSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devCalcoutSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devCalcoutSoft.o ../dev/devCalcoutSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devEventSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devEventSoft.o ../dev/devEventSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devBoDbState.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devBoDbState.o ../dev/devBoDbState.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devBoSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devBoSoft.o ../dev/devBoSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devBoSoftRaw.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devBoSoftRaw.o ../dev/devBoSoftRaw.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devBiDbState.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devBiDbState.o ../dev/devBiDbState.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devBiSoftRaw.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devBiSoftRaw.o ../dev/devBiSoftRaw.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devBiSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devBiSoft.o ../dev/devBiSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devAoSoftRaw.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devAoSoftRaw.o ../dev/devAoSoftRaw.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devAoSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devAoSoft.o ../dev/devAoSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devAiSoftRaw.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devAiSoftRaw.o ../dev/devAiSoftRaw.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devAiSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devAiSoft.o ../dev/devAiSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m waveformRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         waveformRecord.o ../rec/waveformRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devAaiSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devAaiSoft.o ../dev/devAaiSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devAaoSoft.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         devAaoSoft.o ../dev/devAaoSoft.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m subRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         subRecord.o ../rec/subRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m subArrayRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         subArrayRecord.o ../rec/subArrayRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m stringinRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         stringinRecord.o ../rec/stringinRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m stringoutRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         stringoutRecord.o ../rec/stringoutRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m stateRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         stateRecord.o ../rec/stateRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m seqRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         seqRecord.o ../rec/seqRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m selRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         selRecord.o ../rec/selRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m mbboDirectRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         mbboDirectRecord.o ../rec/mbboDirectRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m printfRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         printfRecord.o ../rec/printfRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m permissiveRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         permissiveRecord.o ../rec/permissiveRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m mbboRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         mbboRecord.o ../rec/mbboRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m mbbiDirectRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         mbbiDirectRecord.o ../rec/mbbiDirectRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m mbbiRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         mbbiRecord.o ../rec/mbbiRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lsoRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         lsoRecord.o ../rec/lsoRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lsiRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         lsiRecord.o ../rec/lsiRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m longoutRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         longoutRecord.o ../rec/longoutRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m longinRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         longinRecord.o ../rec/longinRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m int64outRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         int64outRecord.o ../rec/int64outRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m int64inRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         int64inRecord.o ../rec/int64inRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m histogramRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         histogramRecord.o ../rec/histogramRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m fanoutRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         fanoutRecord.o ../rec/fanoutRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m eventRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         eventRecord.o ../rec/eventRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dfanoutRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         dfanoutRecord.o ../rec/dfanoutRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m compressRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         compressRecord.o ../rec/compressRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m calcoutRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         calcoutRecord.o ../rec/calcoutRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m calcRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         calcRecord.o ../rec/calcRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m boRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         boRecord.o ../rec/boRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m biRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         biRecord.o ../rec/biRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m aSubRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         aSubRecord.o ../rec/aSubRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m aoRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         aoRecord.o ../rec/aoRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m aiRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         aiRecord.o ../rec/aiRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m aaoRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         aaoRecord.o ../rec/aaoRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m aaiRecord.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         aaiRecord.o ../rec/aaiRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m softMain.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         softMain.o ../softIoc/softMain.cpp
Creating dbd file softIoc.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o softIoc.dbd base.dbd dlload.dbd system.dbd
perl -CSD ../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd    -o softIoc_registerRecordDeviceDriver.cpp ../O.Common/softIoc.dbd softIoc_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m softIoc_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         softIoc_registerRecordDeviceDriver.o softIoc_registerRecordDeviceDriver.cpp
Installing ../../../../../db/softIocExit.db
mkdir ../../../../../db
Installing generated generic include file ../../../../../include/aaiRecord.h
Installing generated generic include file ../../../../../include/aaoRecord.h
Installing generated generic include file ../../../../../include/aiRecord.h
Installing generated generic include file ../../../../../include/aoRecord.h
Installing generated generic include file ../../../../../include/aSubRecord.h
Installing generated generic include file ../../../../../include/biRecord.h
Installing generated generic include file ../../../../../include/boRecord.h
Installing generated generic include file ../../../../../include/calcRecord.h
Installing generated generic include file ../../../../../include/calcoutRecord.h
Installing generated generic include file ../../../../../include/compressRecord.h
Installing generated generic include file ../../../../../include/dfanoutRecord.h
Installing generated generic include file ../../../../../include/eventRecord.h
Installing generated generic include file ../../../../../include/fanoutRecord.h
Installing generated generic include file ../../../../../include/histogramRecord.h
Installing generated generic include file ../../../../../include/int64inRecord.h
Installing generated generic include file ../../../../../include/int64outRecord.h
Installing generated generic include file ../../../../../include/longinRecord.h
Installing generated generic include file ../../../../../include/longoutRecord.h
Installing generated generic include file ../../../../../include/lsiRecord.h
Installing generated generic include file ../../../../../include/lsoRecord.h
Installing generated generic include file ../../../../../include/mbbiRecord.h
Installing generated generic include file ../../../../../include/mbbiDirectRecord.h
Installing generated generic include file ../../../../../include/mbboRecord.h
Installing generated generic include file ../../../../../include/mbboDirectRecord.h
Installing generated generic include file ../../../../../include/permissiveRecord.h
Installing generated generic include file ../../../../../include/printfRecord.h
Installing generated generic include file ../../../../../include/selRecord.h
Installing generated generic include file ../../../../../include/seqRecord.h
Installing generated generic include file ../../../../../include/stateRecord.h
Installing generated generic include file ../../../../../include/stringinRecord.h
Installing generated generic include file ../../../../../include/stringoutRecord.h
Installing generated generic include file ../../../../../include/subRecord.h
Installing generated generic include file ../../../../../include/subArrayRecord.h
Installing generated generic include file ../../../../../include/waveformRecord.h
Installing created dbd file ../../../../../dbd/stdRecords.dbd
Installing dbd file ../../../../../dbd/devSoft.dbd
Installing created dbd file ../../../../../dbd/filters.dbd
Installing created dbd file ../../../../../dbd/links.dbd
Installing dbd file ../../../../../dbd/base.dbd
Installing dbd file ../../../../../dbd/asSub.dbd
Installing created dbd file ../../../../../dbd/softIoc.dbd
Installing created dbd file ../../../../../dbd/aaiRecord.dbd
Installing created dbd file ../../../../../dbd/aaoRecord.dbd
Installing created dbd file ../../../../../dbd/aiRecord.dbd
Installing created dbd file ../../../../../dbd/aoRecord.dbd
Installing created dbd file ../../../../../dbd/aSubRecord.dbd
Installing created dbd file ../../../../../dbd/biRecord.dbd
Installing created dbd file ../../../../../dbd/boRecord.dbd
Installing created dbd file ../../../../../dbd/calcRecord.dbd
Installing created dbd file ../../../../../dbd/calcoutRecord.dbd
Installing created dbd file ../../../../../dbd/compressRecord.dbd
Installing created dbd file ../../../../../dbd/dfanoutRecord.dbd
Installing created dbd file ../../../../../dbd/eventRecord.dbd
Installing created dbd file ../../../../../dbd/fanoutRecord.dbd
Installing created dbd file ../../../../../dbd/histogramRecord.dbd
Installing created dbd file ../../../../../dbd/int64inRecord.dbd
Installing created dbd file ../../../../../dbd/int64outRecord.dbd
Installing created dbd file ../../../../../dbd/longinRecord.dbd
Installing created dbd file ../../../../../dbd/longoutRecord.dbd
Installing created dbd file ../../../../../dbd/lsiRecord.dbd
Installing created dbd file ../../../../../dbd/lsoRecord.dbd
Installing created dbd file ../../../../../dbd/mbbiRecord.dbd
Installing created dbd file ../../../../../dbd/mbbiDirectRecord.dbd
Installing created dbd file ../../../../../dbd/mbboRecord.dbd
Installing created dbd file ../../../../../dbd/mbboDirectRecord.dbd
Installing created dbd file ../../../../../dbd/permissiveRecord.dbd
Installing created dbd file ../../../../../dbd/printfRecord.dbd
Installing created dbd file ../../../../../dbd/selRecord.dbd
Installing created dbd file ../../../../../dbd/seqRecord.dbd
Installing created dbd file ../../../../../dbd/stateRecord.dbd
Installing created dbd file ../../../../../dbd/stringinRecord.dbd
Installing created dbd file ../../../../../dbd/stringoutRecord.dbd
Installing created dbd file ../../../../../dbd/subRecord.dbd
Installing created dbd file ../../../../../dbd/subArrayRecord.dbd
Installing created dbd file ../../../../../dbd/waveformRecord.dbd
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o histogramRecord.html ../rec/histogramRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o calcRecord.html ../rec/calcRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stringinRecord.html ../rec/stringinRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o subRecord.html ../rec/subRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o int64outRecord.html ../rec/int64outRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aSubRecord.html ../rec/aSubRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o permissiveRecord.html ../rec/permissiveRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o dfanoutRecord.html ../rec/dfanoutRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbbiDirectRecord.html ../rec/mbbiDirectRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aoRecord.html ../rec/aoRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbbiRecord.html ../rec/mbbiRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aiRecord.html ../rec/aiRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aaiRecord.html ../rec/aaiRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o printfRecord.html ../rec/printfRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o seqRecord.html ../rec/seqRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stateRecord.html ../rec/stateRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o eventRecord.html ../rec/eventRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbboRecord.html ../rec/mbboRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o aaoRecord.html ../rec/aaoRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o stringoutRecord.html ../rec/stringoutRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o lsiRecord.html ../rec/lsiRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o subArrayRecord.html ../rec/subArrayRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o selRecord.html ../rec/selRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o fanoutRecord.html ../rec/fanoutRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o mbboDirectRecord.html ../rec/mbboDirectRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o longinRecord.html ../rec/longinRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o longoutRecord.html ../rec/longoutRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o boRecord.html ../rec/boRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o lsoRecord.html ../rec/lsoRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o int64inRecord.html ../rec/int64inRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o waveformRecord.html ../rec/waveformRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o biRecord.html ../rec/biRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o calcoutRecord.html ../rec/calcoutRecord.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o compressRecord.html ../rec/compressRecord.dbd.pod
Installing html ../../../../../html/./image/compress-1.png
mkdir ../../../../../html/./image
Installing html ../../../../../html/./image/compress-2.png
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o filters.html ../filters/filters.dbd.pod
perl -CSD ../../../../../bin/darwin-x86/dbdToHtml.pl   -I. -I.. -I../O.Common -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../dbd -o links.html ../link/links.dbd.pod
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/aaiRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/aaoRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/aiRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/aoRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/biRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/boRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/calcRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/aSubRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/calcoutRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/dfanoutRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/compressRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/eventRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/fanoutRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/int64inRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/histogramRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/int64outRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/longinRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/lsiRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/longoutRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/lsoRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/mbbiRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/mbbiDirectRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/permissiveRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/mbboRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/mbboDirectRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/stateRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/printfRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/seqRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/selRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/stringinRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/stringoutRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/subArrayRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devAaiSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/subRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devAaoSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../rec/waveformRecord.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devAiSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devAiSoftRaw.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devAoSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devAoSoftRaw.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devBiSoftRaw.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devBiSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devBiDbState.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devBoSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devBoDbState.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devBoSoftRaw.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devCalcoutSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devEventSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devHistogramSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devI64inSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devI64outSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devLiSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devLoSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devLsiSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devLsoSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbbiDirectSoftRaw.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbbiDirectSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbbiSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbbiSoftRaw.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbboDirectSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbboDirectSoftRaw.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbboSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbboSoftRaw.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devPrintfSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devSASoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devSiSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devSoSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devWfSoft.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devBiSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devAiSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devI64inSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devLiSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbbiDirectSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbbiSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devSiSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devAoSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devBoSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devCalcoutSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devI64outSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devLoSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devLsoSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbboSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devMbboDirectSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devPrintfSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devSoSoftCallback.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devTimestamp.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devGeneralTime.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devStdio.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/devEnviron.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../dev/asSubRecordFunctions.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../filters/ts.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../filters/dbnd.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../filters/sync.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../filters/arr.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../filters/decimate.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../filters/utag.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../link/lnkState.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../link/lnkConst.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../link/lnkCalc.c
Installing generated html ../../../../../html/./histogramRecord.html
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin   -DBUILDING_dbRecStd_API   -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../link/lnkDebug.c
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c softIoc_registerRecordDeviceDriver.cpp
Installing generated html ../../../../../html/./calcRecord.html
Installing generated html ../../../../../html/./stringinRecord.html
Installing generated html ../../../../../html/./subRecord.html
Installing generated html ../../../../../html/./int64outRecord.html
Installing generated html ../../../../../html/./aSubRecord.html
Installing generated html ../../../../../html/./permissiveRecord.html
Installing generated html ../../../../../html/./dfanoutRecord.html
Installing generated html ../../../../../html/./mbbiDirectRecord.html
Installing generated html ../../../../../html/./aoRecord.html
Installing generated html ../../../../../html/./mbbiRecord.html
Installing generated html ../../../../../html/./aiRecord.html
Installing generated html ../../../../../html/./aaiRecord.html
Installing generated html ../../../../../html/./printfRecord.html
Installing generated html ../../../../../html/./seqRecord.html
Installing generated html ../../../../../html/./stateRecord.html
Installing generated html ../../../../../html/./eventRecord.html
Installing generated html ../../../../../html/./mbboRecord.html
Installing generated html ../../../../../html/./aaoRecord.html
Installing generated html ../../../../../html/./stringoutRecord.html
Installing generated html ../../../../../html/./lsiRecord.html
Installing generated html ../../../../../html/./subArrayRecord.html
Installing generated html ../../../../../html/./selRecord.html
Installing generated html ../../../../../html/./fanoutRecord.html
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../rec -I../dev -I../filters -I../link -I../softIoc -I../../../../../include/compiler/clang -I../../../../../include/os/Darwin -I../../../../../include         -c ../softIoc/softMain.cpp
Installing generated html ../../../../../html/./longinRecord.html
Installing generated html ../../../../../html/./mbboDirectRecord.html
Installing generated html ../../../../../html/./longoutRecord.html
Installing generated html ../../../../../html/./boRecord.html
Installing generated html ../../../../../html/./int64inRecord.html
Installing generated html ../../../../../html/./lsoRecord.html
Installing generated html ../../../../../html/./waveformRecord.html
Installing generated html ../../../../../html/./calcoutRecord.html
Installing generated html ../../../../../html/./biRecord.html
Installing generated html ../../../../../html/./links.html
Installing generated html ../../../../../html/./filters.html
Installing generated html ../../../../../html/./compressRecord.html
c++ -o libdbRecStd.3.21.1.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libdbRecStd.3.21.1.dylib -compatibility_version 3.21.1 -current_version 3.21.1 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o aSubRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o int64inRecord.o int64outRecord.o longinRecord.o longoutRecord.o lsiRecord.o lsoRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o printfRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o devAaiSoft.o devAaoSoft.o devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBiDbState.o devBoSoft.o devBoSoftRaw.o devBoDbState.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devI64inSoft.o devI64outSoft.o devLiSoft.o devLoSoft.o devLsiSoft.o devLsoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devPrintfSoft.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devAiSoftCallback.o devBiSoftCallback.o devI64inSoftCallback.o devLiSoftCallback.o devMbbiDirectSoftCallback.o devMbbiSoftCallback.o devSiSoftCallback.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devI64outSoftCallback.o devLoSoftCallback.o devLsoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devPrintfSoftCallback.o devSoSoftCallback.o devGeneralTime.o devTimestamp.o devStdio.o devEnviron.o asSubRecordFunctions.o ts.o dbnd.o arr.o sync.o decimate.o utag.o lnkConst.o lnkCalc.o lnkState.o lnkDebug.o    -ldbCore -lca -lCom      -lreadline -lm
Installing shared library ../../../../../lib/darwin-x86/libdbRecStd.3.21.1.dylib
ln -s libdbRecStd.3.21.1.dylib ../../../../../lib/darwin-x86/libdbRecStd.dylib
/usr/bin/ar -rc    libdbRecStd.a    aaiRecord.o aaoRecord.o aiRecord.o aoRecord.o aSubRecord.o biRecord.o boRecord.o calcRecord.o calcoutRecord.o compressRecord.o dfanoutRecord.o eventRecord.o fanoutRecord.o histogramRecord.o int64inRecord.o int64outRecord.o longinRecord.o longoutRecord.o lsiRecord.o lsoRecord.o mbbiRecord.o mbbiDirectRecord.o mbboRecord.o mbboDirectRecord.o permissiveRecord.o printfRecord.o selRecord.o seqRecord.o stateRecord.o stringinRecord.o stringoutRecord.o subRecord.o subArrayRecord.o waveformRecord.o devAaiSoft.o devAaoSoft.o devAiSoft.o devAiSoftRaw.o devAoSoft.o devAoSoftRaw.o devBiSoft.o devBiSoftRaw.o devBiDbState.o devBoSoft.o devBoSoftRaw.o devBoDbState.o devCalcoutSoft.o devEventSoft.o devHistogramSoft.o devI64inSoft.o devI64outSoft.o devLiSoft.o devLoSoft.o devLsiSoft.o devLsoSoft.o devMbbiDirectSoft.o devMbbiDirectSoftRaw.o devMbbiSoft.o devMbbiSoftRaw.o devMbboDirectSoft.o devMbboDirectSoftRaw.o devMbboSoft.o devMbboSoftRaw.o devPrintfSoft.o devSASoft.o devSiSoft.o devSoSoft.o devWfSoft.o devAiSoftCallback.o devBiSoftCallback.o devI64inSoftCallback.o devLiSoftCallback.o devMbbiDirectSoftCallback.o devMbbiSoftCallback.o devSiSoftCallback.o devAoSoftCallback.o devBoSoftCallback.o devCalcoutSoftCallback.o devI64outSoftCallback.o devLoSoftCallback.o devLsoSoftCallback.o devMbboSoftCallback.o devMbboDirectSoftCallback.o devPrintfSoftCallback.o devSoSoftCallback.o devGeneralTime.o devTimestamp.o devStdio.o devEnviron.o asSubRecordFunctions.o ts.o dbnd.o arr.o sync.o decimate.o utag.o lnkConst.o lnkCalc.o lnkState.o lnkDebug.o
/usr/bin/ranlib libdbRecStd.a
Installing library ../../../../../lib/darwin-x86/libdbRecStd.a
c++ -o softIoc  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            softIoc_registerRecordDeviceDriver.o softMain.o    -ldbRecStd -ldbCore -lca -lCom
Installing created executable ../../../../../bin/darwin-x86/softIoc
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/std/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src/std'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/src'
/Users/jenkins/bin/make -C ./test install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test'
/Users/jenkins/bin/make -C ioc/dbtemplate install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/dbtemplate'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../../../../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../../../../../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../../../.. \
    T_A=darwin-x86 install
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/dbtemplate/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbltExpand.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbltExpand.o ../dbltExpand.c
cc              -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbltExpand.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../../.. -a darwin-x86 ../msi.plt msi.t
c++ -o dbltExpand  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            dbltExpand.o    -ldbCore -lca -lCom
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/dbtemplate/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/dbtemplate'
/Users/jenkins/bin/make -C std/link install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/link'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/link/O.darwin-x86'
perl -CSD ../../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o ioRecord.h ../ioRecord.dbd
Creating dbd file linkTest.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o linkTest.dbd menuGlobal.dbd menuConvert.dbd menuScan.dbd links.dbd ioRecord.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lnkCalcTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         lnkCalcTest.o ../lnkCalcTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lnkStateTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         lnkStateTest.o ../lnkStateTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ioRecord.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         ioRecord.o ../ioRecord.c
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o linkTest_registerRecordDeviceDriver.cpp ../O.Common/linkTest.dbd linkTest_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m linkTest_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         linkTest_registerRecordDeviceDriver.o linkTest_registerRecordDeviceDriver.cpp
cc           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../ioRecord.c
cc           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../lnkStateTest.c
c++           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c linkTest_registerRecordDeviceDriver.cpp
cc           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../lnkCalcTest.c
/usr/bin/ar -rc    libRecs.a    ioRecord.o
/usr/bin/ranlib libRecs.a
c++ -o libRecs.7.0.6.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libRecs.7.0.6.dylib -compatibility_version 7.0.6 -current_version 7.0.6 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            ioRecord.o    -ldbCore -lca -lCom      -lreadline -lm
c++ -o lnkStateTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/link/O.darwin-x86        -arch x86_64            lnkStateTest.o linkTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
c++ -o lnkCalcTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/link/O.darwin-x86        -arch x86_64            lnkCalcTest.o linkTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 lnkStateTest.t lnkStateTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 lnkCalcTest.t lnkCalcTest
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/link/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/link'
/Users/jenkins/bin/make -C ./tools install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/tools'
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../../.. \
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/tools/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../Base.plt Base.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../Breaktable.plt Breaktable.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../DBD.plt DBD.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../Device.plt Device.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../Driver.plt Driver.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../Function.plt Function.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../Menu.plt Menu.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../Recfield.plt Recfield.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../Recordtype.plt Recordtype.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../Registrar.plt Registrar.t
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -t ../../../../.. -a darwin-x86 ../Variable.plt Variable.t
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/tools/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/tools'
/Users/jenkins/bin/make -C std/filters install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/filters'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/filters/O.darwin-x86'
perl -CSD ../../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o arrRecord.h ../arrRecord.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdToRecordtypeH.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o xRecord.h ../xRecord.dbd
Creating dbd file filterTest.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o filterTest.dbd menuGlobal.dbd menuConvert.dbd menuScan.dbd filters.dbd xRecord.dbd arrRecord.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m decTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         decTest.o ../decTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m syncTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         syncTest.o ../syncTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m arrTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         arrTest.o ../arrTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbndTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbndTest.o ../dbndTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tsTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         tsTest.o ../tsTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m arrRecord.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         arrRecord.o ../arrRecord.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m xRecord.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         xRecord.o ../xRecord.c
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o filterTest_registerRecordDeviceDriver.cpp ../O.Common/filterTest.dbd filterTest_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m filterTest_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         filterTest_registerRecordDeviceDriver.o filterTest_registerRecordDeviceDriver.cpp
cc           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../xRecord.c
cc           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../arrRecord.c
cc           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../tsTest.c
c++           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c filterTest_registerRecordDeviceDriver.cpp
cc           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbndTest.c
c++           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../arrTest.cpp
cc           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../syncTest.c
cc           -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../decTest.c
/usr/bin/ar -rc    libRecs.a    xRecord.o arrRecord.o
c++ -o libRecs.7.0.6.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libRecs.7.0.6.dylib -compatibility_version 7.0.6 -current_version 7.0.6 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            xRecord.o arrRecord.o    -ldbCore -lca -lCom      -lreadline -lm
c++ -o tsTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/filters/O.darwin-x86        -arch x86_64            tsTest.o filterTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
c++ -o dbndTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/filters/O.darwin-x86        -arch x86_64            dbndTest.o filterTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
c++ -o arrTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/filters/O.darwin-x86        -arch x86_64            arrTest.o filterTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
c++ -o syncTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/filters/O.darwin-x86        -arch x86_64            syncTest.o filterTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
c++ -o decTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/filters/O.darwin-x86        -arch x86_64            decTest.o filterTest_registerRecordDeviceDriver.o    -lRecs -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 tsTest.t tsTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbndTest.t dbndTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 arrTest.t arrTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 syncTest.t syncTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 decTest.t decTest
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/filters/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/filters'
/Users/jenkins/bin/make -C ioc/db install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m jlinkz.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         jlinkz.o ../jlinkz.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m xLink.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         xLink.o ../xLink.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbLinkdset.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbLinkdset.o ../dbLinkdset.c
Creating dbd file dbTestIoc.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o dbTestIoc.dbd menuGlobal.dbd menuConvert.dbd menuScan.dbd xRecord.dbd arrRecord.dbd xLink.dbd devx.dbd jlinkz.dbd dbLinkdset.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbStaticTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbStaticTest.o ../dbStaticTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbPutGetTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbPutGetTest.o ../dbPutGetTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m recGblCheckDeadbandTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         recGblCheckDeadbandTest.o ../recGblCheckDeadbandTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m benchdbConvert.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         benchdbConvert.o ../benchdbConvert.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m arrShorthandTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         arrShorthandTest.o ../arrShorthandTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m chfPluginTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         chfPluginTest.o ../chfPluginTest.c
Creating dbd file dbChArrTest.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o dbChArrTest.dbd arrRecord.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbChArrTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbChArrTest.o ../dbChArrTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbChannelTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbChannelTest.o ../dbChannelTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m scanIoTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         scanIoTest.o ../scanIoTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbDbLinkTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbDbLinkTest.o ../dbDbLinkTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbCACTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbCACTest.o ../dbCACTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbCaLinkTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbCaLinkTest.o ../dbCaLinkTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbCaStatsTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbCaStatsTest.o ../dbCaStatsTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbServerTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbServerTest.o ../dbServerTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbStateTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbStateTest.o ../dbStateTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m callbackParallelTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         callbackParallelTest.o ../callbackParallelTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m callbackTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         callbackTest.o ../callbackTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testdbConvert.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         testdbConvert.o ../testdbConvert.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbStressLock.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbStressLock.o ../dbStressLock.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbLockTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbLockTest.o ../dbLockTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbPutLinkTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbPutLinkTest.o ../dbPutLinkTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbShutdownTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbShutdownTest.o ../dbShutdownTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbScanTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbScanTest.o ../dbScanTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m devx.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         devx.o ../devx.c
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o dbTestIoc_registerRecordDeviceDriver.cpp ../O.Common/dbTestIoc.dbd dbTestIoc_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o dbChArrTest_registerRecordDeviceDriver.cpp ../O.Common/dbChArrTest.dbd dbChArrTest_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbTestIoc_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbTestIoc_registerRecordDeviceDriver.o dbTestIoc_registerRecordDeviceDriver.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbChArrTest_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbChArrTest_registerRecordDeviceDriver.o dbChArrTest_registerRecordDeviceDriver.cpp
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../arrRecord.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../xRecord.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbLinkdset.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../xLink.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../devx.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../jlinkz.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbScanTest.c
c++           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c dbTestIoc_registerRecordDeviceDriver.cpp
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbShutdownTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbPutLinkTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbLockTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbStressLock.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../testdbConvert.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../callbackTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../callbackParallelTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbStateTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbServerTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbCaStatsTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbCaLinkTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbDbLinkTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../scanIoTest.c
c++           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbCACTest.cpp
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbChannelTest.c
c++           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c dbChArrTest_registerRecordDeviceDriver.cpp
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../arrShorthandTest.c
c++           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbChArrTest.cpp
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../benchdbConvert.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../recGblCheckDeadbandTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbPutGetTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../chfPluginTest.c
cc           -I ../../../../src/ioc/db -DUSE_TYPED_RSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbStaticTest.c
c++ -o libdbTestIoc.7.0.6.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libdbTestIoc.7.0.6.dylib -compatibility_version 7.0.6 -current_version 7.0.6 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            arrRecord.o xRecord.o dbLinkdset.o xLink.o devx.o jlinkz.o    -ldbCore -lca -lCom      -lreadline -lm
/usr/bin/ar -rc    libdbTestIoc.a    arrRecord.o xRecord.o dbLinkdset.o xLink.o devx.o jlinkz.o
/usr/bin/ranlib libdbTestIoc.a
c++ -o dbScanTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbScanTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbShutdownTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbShutdownTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbPutLinkTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbPutLinkTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbLockTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbLockTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbStressTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbStressLock.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o testdbConvert  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            testdbConvert.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o callbackTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            callbackTest.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o callbackParallelTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            callbackParallelTest.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbStateTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbStateTest.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbServerTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbServerTest.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbCaStatsTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbCaStatsTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbCaLinkTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbCaLinkTest.o dbCACTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbDbLinkTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbDbLinkTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o scanIoTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            scanIoTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbChannelTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbChannelTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o dbChArrTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbChArrTest.o dbChArrTest_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o chfPluginTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            chfPluginTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o arrShorthandTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            arrShorthandTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o benchdbConvert  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            benchdbConvert.o    -ldbTestIoc -ldbCore -lca -lCom
c++ -o recGblCheckDeadbandTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            recGblCheckDeadbandTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbScanTest.t dbScanTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbShutdownTest.t dbShutdownTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbPutLinkTest.t dbPutLinkTest
c++ -o testPutGetTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbPutGetTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbLockTest.t dbLockTest
c++ -o dbStaticTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86        -arch x86_64            dbStaticTest.o dbTestIoc_registerRecordDeviceDriver.o    -ldbTestIoc -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbStressTest.t dbStressTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testdbConvert.t testdbConvert
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 callbackTest.t callbackTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 callbackParallelTest.t callbackParallelTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbStateTest.t dbStateTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbServerTest.t dbServerTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbCaStatsTest.t dbCaStatsTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbCaLinkTest.t dbCaLinkTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbDbLinkTest.t dbDbLinkTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbChannelTest.t dbChannelTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 scanIoTest.t scanIoTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbChArrTest.t dbChArrTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 chfPluginTest.t chfPluginTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 arrShorthandTest.t arrShorthandTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 recGblCheckDeadbandTest.t recGblCheckDeadbandTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPutGetTest.t testPutGetTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 dbStaticTest.t dbStaticTest
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/ioc/db'
/Users/jenkins/bin/make -C std/rec install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec'
mkdir -p O.Common
make[5]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbHeaderTestxx.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbHeaderTestxx.o ../dbHeaderTestxx.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbHeaderTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         dbHeaderTest.o ../dbHeaderTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asTestLib.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         asTestLib.o ../asTestLib.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m linkFilterTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         linkFilterTest.o ../linkFilterTest.c
Creating dbd file asyncproctest.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o asyncproctest.dbd base.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asyncproctest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         asyncproctest.o ../asyncproctest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m mbbioDirectTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         mbbioDirectTest.o ../mbbioDirectTest.c
Creating dbd file simmTest.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o simmTest.dbd base.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m simmTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         simmTest.o ../simmTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m regressTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         regressTest.o ../regressTest.c
Creating dbd file regressTest.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o regressTest.dbd base.dbd
Creating dbd file scanEventTest.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o scanEventTest.dbd base.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m scanEventTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         scanEventTest.o ../scanEventTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m analogMonitorTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         analogMonitorTest.o ../analogMonitorTest.c
Creating dbd file analogMonitorTest.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o analogMonitorTest.dbd base.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         asTest.o ../asTest.c
Creating dbd file asTestIoc.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o asTestIoc.dbd base.dbd asTest.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m seqTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         seqTest.o ../seqTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m softTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         softTest.o ../softTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asyncSoftTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         asyncSoftTest.o ../asyncSoftTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m compressTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         compressTest.o ../compressTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m linkInitTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         linkInitTest.o ../linkInitTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m linkRetargetLinkTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         linkRetargetLinkTest.o ../linkRetargetLinkTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m recMiscTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         recMiscTest.o ../recMiscTest.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m arrayOpTest.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         arrayOpTest.o ../arrayOpTest.c
../../../../../../bin/darwin-x86/msi -D    -I. -I.. -I../O.Common -I../../../../../../db -o ../O.Common/simmTest.db -S../simmTest.substitutions  > simmTest.db.d
Creating dbd file recTestIoc.dbd
perl -CSD ../../../../../../bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I../../../../../../dbd -o recTestIoc.dbd base.dbd
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o asyncproctest_registerRecordDeviceDriver.cpp ../O.Common/asyncproctest.dbd asyncproctest_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o simmTest_registerRecordDeviceDriver.cpp ../O.Common/simmTest.dbd simmTest_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o regressTest_registerRecordDeviceDriver.cpp ../O.Common/regressTest.dbd regressTest_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o scanEventTest_registerRecordDeviceDriver.cpp ../O.Common/scanEventTest.dbd scanEventTest_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o asTestIoc_registerRecordDeviceDriver.cpp ../O.Common/asTestIoc.dbd asTestIoc_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asyncproctest_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         asyncproctest_registerRecordDeviceDriver.o asyncproctest_registerRecordDeviceDriver.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m simmTest_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         simmTest_registerRecordDeviceDriver.o simmTest_registerRecordDeviceDriver.cpp
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o recTestIoc_registerRecordDeviceDriver.cpp ../O.Common/recTestIoc.dbd recTestIoc_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m regressTest_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         regressTest_registerRecordDeviceDriver.o regressTest_registerRecordDeviceDriver.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m scanEventTest_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         scanEventTest_registerRecordDeviceDriver.o scanEventTest_registerRecordDeviceDriver.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m asTestIoc_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         asTestIoc_registerRecordDeviceDriver.o asTestIoc_registerRecordDeviceDriver.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m recTestIoc_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         recTestIoc_registerRecordDeviceDriver.o recTestIoc_registerRecordDeviceDriver.cpp
perl -CSD ../../../../../../bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I../../../../../../dbd    -o analogMonitorTest_registerRecordDeviceDriver.cpp ../O.Common/analogMonitorTest.dbd analogMonitorTest_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m analogMonitorTest_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         analogMonitorTest_registerRecordDeviceDriver.o analogMonitorTest_registerRecordDeviceDriver.cpp
Inflating database from ../simmTest.substitutions
../../../../../../bin/darwin-x86/msi    -I. -I.. -I../O.Common -I../../../../../../db -o simmTest.db -S../simmTest.substitutions
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../arrayOpTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../asTestLib.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbHeaderTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration   -DLINK_DYNAMIC    -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../recMiscTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../linkRetargetLinkTest.c
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c recTestIoc_registerRecordDeviceDriver.cpp
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../linkInitTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../asyncSoftTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../compressTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../seqTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../softTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../asTest.c
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../dbHeaderTestxx.cpp
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../analogMonitorTest.c
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c asTestIoc_registerRecordDeviceDriver.cpp
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c analogMonitorTest_registerRecordDeviceDriver.cpp
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../scanEventTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../regressTest.c
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c scanEventTest_registerRecordDeviceDriver.cpp
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c regressTest_registerRecordDeviceDriver.cpp
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c simmTest_registerRecordDeviceDriver.cpp
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../mbbioDirectTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../simmTest.c
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../linkFilterTest.c
c++           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c asyncproctest_registerRecordDeviceDriver.cpp
cc           -DUSE_TYPED_RSET -DUSE_TYPED_DSET    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../../../../../include/compiler/clang -I../../../../../../include/os/Darwin -I../../../../../../include         -c ../asyncproctest.c
/usr/bin/ar -rc    libdbRecStdTest.a    asTestLib.o
/usr/bin/ranlib libdbRecStdTest.a
c++ -o libdbRecStdTest.7.0.6.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libdbRecStdTest.7.0.6.dylib -compatibility_version 7.0.6 -current_version 7.0.6 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            asTestLib.o    -ldbRecStd -ldbCore -lca -lCom      -lreadline -lm
c++ -o arrayOpTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            arrayOpTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o recMiscTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            recMiscTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o linkRetargetLinkTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            linkRetargetLinkTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o linkInitTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            linkInitTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o compressTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            compressTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o asyncSoftTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            asyncSoftTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o softTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            softTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o seqTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            seqTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o asTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            asTest.o asTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o analogMonitorTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            analogMonitorTest.o analogMonitorTest_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o scanEventTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            scanEventTest.o scanEventTest_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o regressTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            regressTest.o regressTest_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o simmTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            simmTest.o simmTest_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
c++ -o mbbioDirectTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            mbbioDirectTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 arrayOpTest.t arrayOpTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 recMiscTest.t recMiscTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 linkInitTest.t linkInitTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 linkRetargetLinkTest.t linkRetargetLinkTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 compressTest.t compressTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 asyncSoftTest.t asyncSoftTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 seqTest.t seqTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 softTest.t softTest
c++ -o linkFilterTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            linkFilterTest.o recTestIoc_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 asTest.t asTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 analogMonitorTest.t analogMonitorTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 scanEventTest.t scanEventTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 regressTest.t regressTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 simmTest.t simmTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 mbbioDirectTest.t mbbioDirectTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 linkFilterTest.t linkFilterTest
c++ -o asyncproctest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86 -L/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86        -arch x86_64            asyncproctest.o asyncproctest_registerRecordDeviceDriver.o    -ldbRecStdTest -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 asyncproctest.t asyncproctest
make[5]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec/O.darwin-x86'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test/std/rec'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database/test'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/database'
/Users/jenkins/bin/make -C ./pvAccess install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess'
/Users/jenkins/bin/make -C ./configure install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/configure'
mkdir -p O.Common
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../..
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
    T_A=darwin-x86 install
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/configure/O.darwin-x86'
Installing CFG file /Users/jenkins/workspace/epics-7.0/OS/mac/cfg/CONFIG_PVACCESS_VERSION
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/convertRelease.pl checkRelease
Installing CFG file /Users/jenkins/workspace/epics-7.0/OS/mac/cfg/CONFIG_PVACCESS_MODULE
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/configure/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/configure'
/Users/jenkins/bin/make -C ./src install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src/O.darwin-x86'
mkdir -p ../O.Common/pv
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -DEPICS_PVA_MAJOR_VERSION="7" -DEPICS_PVA_MINOR_VERSION="1" -DEPICS_PVA_MAINTENANCE_VERSION="6" -DEPICS_PVA_DEVELOPMENT_FLAG="1" -t /Users/jenkins/workspace/epics-7.0/OS/mac    ../pva/pvaVersionNum.h@ ../O.Common/pv/pvaVersionNum.h
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m rpcClient.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        rpcClient.o ../../src/rpcClient/rpcClient.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pipelineService.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pipelineService.o ../../src/pipelineService/pipelineService.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pipelineServer.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pipelineServer.o ../../src/pipelineService/pipelineServer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m rpcService.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        rpcService.o ../../src/rpcService/rpcService.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m sharedstate_put.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        sharedstate_put.o ../../src/server/sharedstate_put.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m sharedstate_rpc.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        sharedstate_rpc.o ../../src/server/sharedstate_rpc.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m sharedstate_channel.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        sharedstate_channel.o ../../src/server/sharedstate_channel.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m rpcServer.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        rpcServer.o ../../src/rpcService/rpcServer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m sharedstate_pv.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        sharedstate_pv.o ../../src/server/sharedstate_pv.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m beaconServerStatusProvider.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        beaconServerStatusProvider.o ../../src/server/beaconServerStatusProvider.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m server.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        server.o ../../src/server/server.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m beaconEmitter.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        beaconEmitter.o ../../src/server/beaconEmitter.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m baseChannelRequester.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        baseChannelRequester.o ../../src/server/baseChannelRequester.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m serverChannelImpl.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        serverChannelImpl.o ../../src/server/serverChannelImpl.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m responseHandlers.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        responseHandlers.o ../../src/server/responseHandlers.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m security.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        security.o ../../src/remote/security.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m serializationHelper.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        serializationHelper.o ../../src/remote/serializationHelper.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m codec.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        codec.o ../../src/remote/codec.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m clientContextImpl.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        clientContextImpl.o ../../src/remoteClient/clientContextImpl.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m transportRegistry.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        transportRegistry.o ../../src/remote/transportRegistry.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m abstractResponseHandler.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        abstractResponseHandler.o ../../src/remote/abstractResponseHandler.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m blockingTCPAcceptor.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        blockingTCPAcceptor.o ../../src/remote/blockingTCPAcceptor.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m channelSearchManager.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        channelSearchManager.o ../../src/remote/channelSearchManager.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m beaconHandler.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        beaconHandler.o ../../src/remote/beaconHandler.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m blockingTCPConnector.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        blockingTCPConnector.o ../../src/remote/blockingTCPConnector.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m blockingUDPConnector.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        blockingUDPConnector.o ../../src/remote/blockingUDPConnector.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m blockingUDPTransport.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        blockingUDPTransport.o ../../src/remote/blockingUDPTransport.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m ChannelAccessFactory.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        ChannelAccessFactory.o ../../src/factory/ChannelAccessFactory.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m clientInfo.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        clientInfo.o ../../src/client/clientInfo.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m clientMonitor.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        clientMonitor.o ../../src/client/clientMonitor.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m clientRPC.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        clientRPC.o ../../src/client/clientRPC.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m clientPut.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        clientPut.o ../../src/client/clientPut.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m clientSync.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        clientSync.o ../../src/client/clientSync.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m clientGet.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        clientGet.o ../../src/client/clientGet.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m monitor.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        monitor.o ../../src/client/monitor.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvAccess.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvAccess.o ../../src/client/pvAccess.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m client.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        client.o ../../src/client/client.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m wildcard.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        wildcard.o ../../src/utils/wildcard.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m requester.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        requester.o ../../src/utils/requester.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m referenceCountingLock.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        referenceCountingLock.o ../../src/utils/referenceCountingLock.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m logger.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        logger.o ../../src/utils/logger.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m configuration.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        configuration.o ../../src/utils/configuration.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m introspectionRegistry.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        introspectionRegistry.o ../../src/utils/introspectionRegistry.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m hexDump.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        hexDump.o ../../src/utils/hexDump.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m inetAddressUtil.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        inetAddressUtil.o ../../src/utils/inetAddressUtil.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m getgroups.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        getgroups.o ../../src/utils/getgroups.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m clientFactory.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        clientFactory.o ../../src/pva/clientFactory.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaVersion.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaVersion.o ../../src/pva/pvaVersion.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m serverContext.d -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        serverContext.o ../../src/server/serverContext.cpp
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvaConstants.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvaDefs.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvaVersion.h
Installing generated generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvaVersionNum.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/clientFactory.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/hexDump.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/logger.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/introspectionRegistry.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/referenceCountingLock.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/configuration.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/likely.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/wildcard.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/destroyable.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/fairQueue.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/requester.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/monitor.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvAccess.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pva/client.h
mkdir /Users/jenkins/workspace/epics-7.0/OS/mac/include/pva
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/serializationHelper.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/security.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/serverContext.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/beaconServerStatusProvider.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pva/sharedstate.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pva/server.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/rpcService.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/rpcServer.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pipelineService.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/rpcClient.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvAccessMB.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pipelineServer.h
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pva/clientFactory.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/utils/hexDump.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pva/pvaVersion.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/utils/logger.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/utils/getgroups.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/utils/inetAddressUtil.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/utils/referenceCountingLock.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/utils/wildcard.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/utils/introspectionRegistry.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/utils/requester.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/utils/configuration.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/client/monitor.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/client/pvAccess.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/client/client.cpp
../../src/client/client.cpp:209:22: warning: expression with side effects will be evaluated despite being used as an operand to 'typeid' [-Wpotentially-evaluated-expression]
        strm<<typeid(*impl->channel.get()).name()<<" : ";
../../src/client/client.cpp:350:24: warning: expression with side effects will be evaluated despite being used as an operand to 'typeid' [-Wpotentially-evaluated-expression]
             << typeid(*op.impl->channel.get()).name()<<", "
../../src/client/client.cpp:365:24: warning: expression with side effects will be evaluated despite being used as an operand to 'typeid' [-Wpotentially-evaluated-expression]
             << typeid(*op.impl->provider.get()).name()<<", "
3 warnings generated.
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/client/clientSync.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/client/clientGet.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/client/clientPut.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/client/clientRPC.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/client/clientMonitor.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/client/clientInfo.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/blockingUDPConnector.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/beaconHandler.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/factory/ChannelAccessFactory.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/blockingUDPTransport.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/abstractResponseHandler.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/blockingTCPConnector.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/channelSearchManager.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/blockingTCPAcceptor.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/serializationHelper.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/transportRegistry.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/security.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remote/codec.cpp
../../src/remote/codec.cpp:568:19: warning: unused variable 'PADDING_BYTES' [-Wunused-const-variable]
static const char PADDING_BYTES[] =
1 warning generated.
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/serverChannelImpl.cpp
../../src/server/serverChannelImpl.cpp:107:46: warning: expression with side effects will be evaluated despite being used as an operand to 'typeid' [-Wpotentially-evaluated-expression]
    fprintf(fd,"CHANNEL      : %s\n", typeid(*_channel).name());
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/serverContext.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/baseChannelRequester.cpp
../../src/server/baseChannelRequester.cpp:69:20: warning: expression with side effects will be evaluated despite being used as an operand to 'typeid' [-Wpotentially-evaluated-expression]
    name << typeid(*_transport).name() << "/" << _ioid;
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/beaconEmitter.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/beaconServerStatusProvider.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/server.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/responseHandlers.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/sharedstate_rpc.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/sharedstate_pv.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/sharedstate_channel.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/rpcService/rpcService.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/server/sharedstate_put.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/remoteClient/clientContextImpl.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pipelineService/pipelineService.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/rpcClient/rpcClient.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/rpcService/rpcServer.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/pva -I../../src/utils -I../../src/client -I../../src/factory -I../../src/remote -I../../src/remoteClient -I../../src/server -I../../src/rpcService -I../../src/rpcClient -I../../src/pipelineService -I../../src/mb -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pipelineService/pipelineServer.cpp
c++ -o libpvAccess.7.1.6.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccess.7.1.6.dylib -compatibility_version 7.1.6 -current_version 7.1.6 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            pvaVersion.o clientFactory.o getgroups.o hexDump.o inetAddressUtil.o logger.o introspectionRegistry.o configuration.o referenceCountingLock.o requester.o wildcard.o pvAccess.o monitor.o client.o clientSync.o clientGet.o clientPut.o clientRPC.o clientMonitor.o clientInfo.o ChannelAccessFactory.o blockingUDPTransport.o blockingUDPConnector.o beaconHandler.o blockingTCPConnector.o channelSearchManager.o abstractResponseHandler.o blockingTCPAcceptor.o transportRegistry.o serializationHelper.o codec.o security.o clientContextImpl.o responseHandlers.o serverContext.o serverChannelImpl.o baseChannelRequester.o beaconEmitter.o beaconServerStatusProvider.o server.o sharedstate_pv.o sharedstate_channel.o sharedstate_rpc.o sharedstate_put.o rpcService.o rpcServer.o rpcClient.o pipelineService.o pipelineServer.o    -lpvData -lCom      -lreadline -lm
Installing shared library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccess.7.1.6.dylib
ln -s libpvAccess.7.1.6.dylib /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccess.dylib
/usr/bin/ar -rc    libpvAccess.a    pvaVersion.o clientFactory.o getgroups.o hexDump.o inetAddressUtil.o logger.o introspectionRegistry.o configuration.o referenceCountingLock.o requester.o wildcard.o pvAccess.o monitor.o client.o clientSync.o clientGet.o clientPut.o clientRPC.o clientMonitor.o clientInfo.o ChannelAccessFactory.o blockingUDPTransport.o blockingUDPConnector.o beaconHandler.o blockingTCPConnector.o channelSearchManager.o abstractResponseHandler.o blockingTCPAcceptor.o transportRegistry.o serializationHelper.o codec.o security.o clientContextImpl.o responseHandlers.o serverContext.o serverChannelImpl.o baseChannelRequester.o beaconEmitter.o beaconServerStatusProvider.o server.o sharedstate_pv.o sharedstate_channel.o sharedstate_rpc.o sharedstate_put.o rpcService.o rpcServer.o rpcClient.o pipelineService.o pipelineServer.o
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ranlib: file: libpvAccess.a(pipelineService.o) has no symbols
/usr/bin/ranlib libpvAccess.a
Installing library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccess.a
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src'
/Users/jenkins/bin/make -C src/ioc install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src/ioc'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../.. \
    T_A=darwin-x86 install
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src/ioc/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVAClientRegister.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVAClientRegister.o ../PVAClientRegister.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m reftrackioc.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        reftrackioc.o ../reftrackioc.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m PVAServerRegister.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        PVAServerRegister.o ../PVAServerRegister.cpp
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/syncChannelFind.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/iocshelper.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/iocreftrack.h
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/PVACommonRegister.dbd
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/PVAServerRegister.dbd
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/PVAClientRegister.dbd
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../PVAClientRegister.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../PVAServerRegister.cpp
../PVAServerRegister.cpp:179:40: warning: non-type template argument referring to function 'startPVAServer' with internal linkage is a C++11 extension [-Wc++11-extensions]
    epics::iocshRegister<const char*, &startPVAServer>("startPVAServer", "provider names");
../PVAServerRegister.cpp:57:6: note: non-type template argument refers to function here
void startPVAServer(const char *names)
../PVAServerRegister.cpp:180:27: warning: non-type template argument referring to function 'stopPVAServer' with internal linkage is a C++11 extension [-Wc++11-extensions]
    epics::iocshRegister<&stopPVAServer>("stopPVAServer");
../PVAServerRegister.cpp:77:6: note: non-type template argument refers to function here
void stopPVAServer()
../PVAServerRegister.cpp:181:32: warning: non-type template argument referring to function 'pvasr' with internal linkage is a C++11 extension [-Wc++11-extensions]
    epics::iocshRegister<int, &pvasr>("pvasr", "detail");
../PVAServerRegister.cpp:91:6: note: non-type template argument refers to function here
void pvasr(int lvl)
../PVAServerRegister.cpp:182:32: warning: non-type template argument referring to function 'pval' with internal linkage is a C++11 extension [-Wc++11-extensions]
    epics::iocshRegister<int, &pval>("pval", "detail");
../PVAServerRegister.cpp:135:6: note: non-type template argument refers to function here
void pval(int lvl)
In file included from ../PVAServerRegister.cpp:33:
../pv/iocshelper.h:116:48: warning: non-type template argument referring to function 'startPVAServer' with internal linkage is a C++11 extension [-Wc++11-extensions]
    iocshRegister(&info.def, &detail::call1<A, fn>);
../PVAServerRegister.cpp:179:12: note: in instantiation of function template specialization 'epics::iocshRegister<const char *, &(anonymous namespace)::startPVAServer>' requested here
../pv/iocshelper.h:108:45: warning: non-type template argument referring to function 'stopPVAServer' with internal linkage is a C++11 extension [-Wc++11-extensions]
    iocshRegister(&info.def, &detail::call0<fn>);
../PVAServerRegister.cpp:180:12: note: in instantiation of function template specialization 'epics::iocshRegister<&(anonymous namespace)::stopPVAServer>' requested here
../pv/iocshelper.h:116:48: warning: non-type template argument referring to function 'pvasr' with internal linkage is a C++11 extension [-Wc++11-extensions]
../PVAServerRegister.cpp:181:12: note: in instantiation of function template specialization 'epics::iocshRegister<int, &(anonymous namespace)::pvasr>' requested here
void pvasr(int lvl)
../pv/iocshelper.h:116:48: warning: non-type template argument referring to function 'pval' with internal linkage is a C++11 extension [-Wc++11-extensions]
../PVAServerRegister.cpp:182:12: note: in instantiation of function template specialization 'epics::iocshRegister<int, &(anonymous namespace)::pval>' requested here
void pval(int lvl)
8 warnings generated.
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../reftrackioc.cpp
../reftrackioc.cpp:86:32: warning: non-type template argument referring to function 'refshow' with internal linkage is a C++11 extension [-Wc++11-extensions]
    epics::iocshRegister<int, &refshow>("refshow", "detail level");
../reftrackioc.cpp:38:6: note: non-type template argument refers to function here
void refshow(int lvl)
../reftrackioc.cpp:87:27: warning: non-type template argument referring to function 'refsave' with internal linkage is a C++11 extension [-Wc++11-extensions]
    epics::iocshRegister<&refsave>("refsave");
../reftrackioc.cpp:51:6: note: non-type template argument refers to function here
void refsave()
../reftrackioc.cpp:88:32: warning: non-type template argument referring to function 'refdiff' with internal linkage is a C++11 extension [-Wc++11-extensions]
    epics::iocshRegister<int, &refdiff>("refdiff", "detail level");
../reftrackioc.cpp:61:6: note: non-type template argument refers to function here
void refdiff(int lvl)
../reftrackioc.cpp:89:40: warning: non-type template argument referring to function 'refmon' with internal linkage is a C++11 extension [-Wc++11-extensions]
    epics::iocshRegister<double, int, &refmon>("refmon", "update period", "detail level");
../reftrackioc.cpp:71:6: note: non-type template argument refers to function here
void refmon(double period, int lvl)
In file included from ../reftrackioc.cpp:12:
../pv/iocshelper.h:116:48: warning: non-type template argument referring to function 'refshow' with internal linkage is a C++11 extension [-Wc++11-extensions]
../reftrackioc.cpp:86:12: note: in instantiation of function template specialization 'epics::iocshRegister<int, &(anonymous namespace)::refshow>' requested here
../pv/iocshelper.h:108:45: warning: non-type template argument referring to function 'refsave' with internal linkage is a C++11 extension [-Wc++11-extensions]
../reftrackioc.cpp:87:12: note: in instantiation of function template specialization 'epics::iocshRegister<&(anonymous namespace)::refsave>' requested here
void refsave()
../pv/iocshelper.h:116:48: warning: non-type template argument referring to function 'refdiff' with internal linkage is a C++11 extension [-Wc++11-extensions]
../reftrackioc.cpp:88:12: note: in instantiation of function template specialization 'epics::iocshRegister<int, &(anonymous namespace)::refdiff>' requested here
../pv/iocshelper.h:127:51: warning: non-type template argument referring to function 'refmon' with internal linkage is a C++11 extension [-Wc++11-extensions]
    iocshRegister(&info.def, &detail::call2<A, B, fn>);
../reftrackioc.cpp:89:12: note: in instantiation of function template specialization 'epics::iocshRegister<double, int, &(anonymous namespace)::refmon>' requested here
/usr/bin/ar -rc    libpvAccessIOC.a    PVAServerRegister.o PVAClientRegister.o reftrackioc.o
/usr/bin/ranlib libpvAccessIOC.a
c++ -o libpvAccessIOC.7.1.6.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccessIOC.7.1.6.dylib -compatibility_version 7.1.6 -current_version 7.1.6 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            PVAServerRegister.o PVAClientRegister.o reftrackioc.o    -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom      -lreadline -lm
Installing shared library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccessIOC.7.1.6.dylib
ln -s libpvAccessIOC.7.1.6.dylib /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccessIOC.dylib
Installing library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccessIOC.a
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src/ioc/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src/ioc'
/Users/jenkins/bin/make -C src/ca install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src/ca'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src/ca/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m notifierConveyor.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        notifierConveyor.o ../notifierConveyor.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbdToPv.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        dbdToPv.o ../dbdToPv.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caChannel.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        caChannel.o ../caChannel.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caContext.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        caContext.o ../caContext.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m caProvider.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        caProvider.o ../caProvider.cpp
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/caProvider.h
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../caContext.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../caProvider.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../notifierConveyor.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../caChannel.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../dbdToPv.cpp
c++ -o libpvAccessCA.7.1.6.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccessCA.7.1.6.dylib -compatibility_version 7.1.6 -current_version 7.1.6 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            caProvider.o caContext.o caChannel.o dbdToPv.o notifierConveyor.o    -lpvAccess -lpvData -lca -lCom      -lreadline -lm
/usr/bin/ar -rc    libpvAccessCA.a    caProvider.o caContext.o caChannel.o dbdToPv.o notifierConveyor.o
/usr/bin/ranlib libpvAccessCA.a
Installing shared library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccessCA.7.1.6.dylib
ln -s libpvAccessCA.7.1.6.dylib /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccessCA.dylib
Installing library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvAccessCA.a
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src/ca/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/src/ca'
/Users/jenkins/bin/make -C ./testCa install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/testCa'
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/testCa/O.darwin-x86'
rm -f ../O.Common/testIoc.dbd
cp /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/softIoc.dbd ../O.Common/testIoc.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testCaProvider.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testCaProvider.o ../testCaProvider.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testConveyor.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testConveyor.o ../testConveyor.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd    -o testIoc_registerRecordDeviceDriver.cpp ../O.Common/testIoc.dbd testIoc_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testIoc_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testIoc_registerRecordDeviceDriver.o testIoc_registerRecordDeviceDriver.cpp
c++           -I../../src/ca    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../testConveyor.cpp
c++           -I../../src/ca    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../testCaProvider.cpp
c++           -I../../src/ca    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c testIoc_registerRecordDeviceDriver.cpp
c++ -o testConveyor  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testConveyor.o    -lpvAccess -lpvAccessCA -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testCaProvider  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testCaProvider.o testIoc_registerRecordDeviceDriver.o    -lpvAccess -lpvAccessCA -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testConveyor.t testConveyor
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testCaProvider.t testCaProvider
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/testCa/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/testCa'
/Users/jenkins/bin/make -C ./pvtoolsSrc install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/pvtoolsSrc'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/pvtoolsSrc/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvlist.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvlist.o ../pvlist.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvutils.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvutils.o ../pvutils.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvinfo.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvinfo.o ../pvinfo.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvcall.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvcall.o ../pvcall.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvput.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvput.o ../pvput.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvmonitor.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvmonitor.o ../pvmonitor.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvget.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvget.o ../pvget.cpp
c++           -I../../src/utils -I../../src/remote    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvget.cpp
c++           -I../../src/utils -I../../src/remote    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvutils.cpp
c++           -I../../src/utils -I../../src/remote    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvmonitor.cpp
c++           -I../../src/utils -I../../src/remote    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvput.cpp
c++           -I../../src/utils -I../../src/remote    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvcall.cpp
c++           -I../../src/utils -I../../src/remote    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvinfo.cpp
c++           -I../../src/utils -I../../src/remote    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvlist.cpp
c++ -o pvget  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            pvget.o pvutils.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
c++ -o pvmonitor  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            pvmonitor.o pvutils.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
c++ -o pvput  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            pvput.o pvutils.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
c++ -o pvcall  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            pvcall.o pvutils.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
c++ -o pvinfo  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            pvinfo.o pvutils.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
c++ -o pvlist  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            pvlist.o    -lpvAccessCA -lpvAccess -lpvData -lca -lCom
Installing created executable /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/pvget
Installing created executable /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/pvmonitor
Installing created executable /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/pvput
Installing created executable /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/pvcall
Installing created executable /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/pvinfo
Installing created executable /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/pvlist
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/pvtoolsSrc/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/pvtoolsSrc'
/Users/jenkins/bin/make -C ./examples install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/examples'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/examples/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m minimonitor.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        minimonitor.o ../minimonitor.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m miniput.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        miniput.o ../miniput.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m miniget.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        miniget.o ../miniget.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m lazycounter.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        lazycounter.o ../lazycounter.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m epicschat.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        epicschat.o ../epicschat.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m mailbox.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        mailbox.o ../mailbox.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m spamme.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        spamme.o ../spamme.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m monitorme.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        monitorme.o ../monitorme.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m putme.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        putme.o ../putme.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m getme.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        getme.o ../getme.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../getme.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../putme.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../monitorme.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../spamme.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../mailbox.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../epicschat.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../lazycounter.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../miniget.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../miniput.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../minimonitor.cpp
c++ -o getme  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            getme.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
c++ -o putme  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            putme.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
c++ -o monitorme  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            monitorme.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
c++ -o spamme  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            spamme.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
c++ -o mailbox  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            mailbox.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
c++ -o epicschat  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            epicschat.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
c++ -o lazycounter  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            lazycounter.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
c++ -o miniget  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            miniget.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
c++ -o miniput  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            miniput.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
c++ -o minimonitor  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            minimonitor.o    -lpvAccessCA -lca -lpvAccess -lpvData -lCom
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/examples/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/examples'
/Users/jenkins/bin/make -C ./testApp install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/testApp'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/testApp/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testRAII.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testRAII.o ../../testApp/remote/testRAII.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testClientFactory.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testClientFactory.o ../../testApp/remote/testClientFactory.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m rpcClientExample.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        rpcClientExample.o ../../testApp/remote/rpcClientExample.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m rpcWildServiceExample.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        rpcWildServiceExample.o ../../testApp/remote/rpcWildServiceExample.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m rpcServiceAsyncExample.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        rpcServiceAsyncExample.o ../../testApp/remote/rpcServiceAsyncExample.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m rpcServiceExample.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        rpcServiceExample.o ../../testApp/remote/rpcServiceExample.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testMonitorPerformance.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testMonitorPerformance.o ../../testApp/remote/testMonitorPerformance.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testGetPerformance.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testGetPerformance.o ../../testApp/remote/testGetPerformance.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testsharedstate.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testsharedstate.o ../../testApp/remote/testsharedstate.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testServer.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testServer.o ../../testApp/remote/testServer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testmonitorfifo.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testmonitorfifo.o ../../testApp/remote/testmonitorfifo.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testServerContext.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testServerContext.o ../../testApp/remote/testServerContext.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testChannelConnect.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testChannelConnect.o ../../testApp/remote/testChannelConnect.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testRemoteClientImpl.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testRemoteClientImpl.o ../../testApp/remote/testRemoteClientImpl.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testRPC.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testRPC.o ../../testApp/remote/testRPC.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testCodec.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testCodec.o ../../testApp/remote/testCodec.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m channelAccessIFTest.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        channelAccessIFTest.o ../../testApp/remote/channelAccessIFTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m showauth.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        showauth.o ../../testApp/utils/showauth.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testWildcard.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testWildcard.o ../../testApp/utils/testWildcard.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testFairQueue.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testFairQueue.o ../../testApp/utils/testFairQueue.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m configurationTest.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        configurationTest.o ../../testApp/utils/configurationTest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testInetAddressUtils.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testInetAddressUtils.o ../../testApp/utils/testInetAddressUtils.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testHexDump.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testHexDump.o ../../testApp/utils/testHexDump.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testAtomicBoolean.d -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testAtomicBoolean.o ../../testApp/utils/testAtomicBoolean.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/utils/testAtomicBoolean.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/utils/testHexDump.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/utils/testInetAddressUtils.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/utils/configurationTest.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/utils/testWildcard.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/utils/testFairQueue.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/utils/showauth.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testRPC.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testChannelConnect.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testCodec.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testRemoteClientImpl.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testServerContext.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testmonitorfifo.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testsharedstate.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/channelAccessIFTest.cpp
In file included from ../../testApp/remote/channelAccessIFTest.cpp:29:
../../testApp/remote/testServer.cpp:2261:21: warning: 'addBoundedString' is deprecated [-Wdeprecated-declarations]
                    addBoundedString("value", 8)->
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvIntrospect.h:1095:87: note: 'addBoundedString' has been explicitly marked deprecated here
    FieldBuilderPtr addBoundedString(std::string const & name, std::size_t maxLength) PVD_DEPRECATED_52;
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvIntrospect.h:27:27: note: expanded from macro 'PVD_DEPRECATED_52'
#define PVD_DEPRECATED_52 PVD_DEPRECATED("See https://github.com/epics-base/pvDataCPP/issues/52";)
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/serialize.h:24:31: note: expanded from macro 'PVD_DEPRECATED'
#  define PVD_DEPRECATED(msg) EPICS_DEPRECATED
/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang/compilerSpecific.h:54:41: note: expanded from macro 'EPICS_DEPRECATED'
#define EPICS_DEPRECATED __attribute__((deprecated))
../../testApp/remote/testServer.cpp:2270:21: warning: 'addBoundedArray' is deprecated [-Wdeprecated-declarations]
                    addBoundedArray("value", pvDouble, 8)->
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvIntrospect.h:1129:105: note: 'addBoundedArray' has been explicitly marked deprecated here
    FieldBuilderPtr addBoundedArray(std::string const & name, ScalarType scalarType, std::size_t bound) PVD_DEPRECATED_52;
../../testApp/remote/testServer.cpp:2279:21: warning: 'addFixedArray' is deprecated [-Wdeprecated-declarations]
                    addFixedArray("value", pvDouble, 8)->
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvIntrospect.h:1120:102: note: 'addFixedArray' has been explicitly marked deprecated here
    FieldBuilderPtr addFixedArray(std::string const & name, ScalarType scalarType, std::size_t size) PVD_DEPRECATED_52;
3 warnings generated.
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testGetPerformance.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testMonitorPerformance.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/rpcServiceExample.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/rpcServiceAsyncExample.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/rpcWildServiceExample.cpp
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/rpcClientExample.cpp
c++ -o testAtomicBoolean  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testAtomicBoolean.o    -lpvAccess -lpvData -lCom
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testClientFactory.cpp
c++ -o testHexDump  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testHexDump.o    -lpvAccess -lpvData -lCom
c++ -o testInetAddressUtils  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testInetAddressUtils.o    -lpvAccess -lpvData -lCom
c++ -o configurationTest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            configurationTest.o    -lpvAccess -lpvData -lCom
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testRAII.cpp
c++ -o testFairQueue  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testFairQueue.o    -lpvAccess -lpvData -lCom
c++ -o testWildcard  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testWildcard.o    -lpvAccess -lpvData -lCom
c++ -o showauth  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            showauth.o    -lpvAccess -lpvData -lCom
c++ -o testChannelAccess  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            channelAccessIFTest.o    -lpvAccess -lpvData -lCom
c++ -o testCodec  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testCodec.o    -lpvAccess -lpvData -lCom
c++ -o testRPC  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testRPC.o    -lpvAccess -lpvData -lCom
c++ -o testRemoteClientImpl  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testRemoteClientImpl.o    -lpvAccess -lpvData -lCom
c++ -o testChannelConnect  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testChannelConnect.o    -lpvAccess -lpvData -lCom
c++ -o testServerContext  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testServerContext.o    -lpvAccess -lpvData -lCom
c++ -o testmonitorfifo  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testmonitorfifo.o    -lpvAccess -lpvData -lCom
c++ -o testsharedstate  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testsharedstate.o    -lpvAccess -lpvData -lCom
c++ -o testGetPerformance  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testGetPerformance.o    -lpvAccess -lpvData -lCom
c++ -o testMonitorPerformance  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testMonitorPerformance.o    -lpvAccess -lpvData -lCom
c++ -o rpcServiceExample  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            rpcServiceExample.o    -lpvAccess -lpvData -lCom
c++ -o rpcServiceAsyncExample  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            rpcServiceAsyncExample.o    -lpvAccess -lpvData -lCom
c++ -o rpcWildServiceExample  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            rpcWildServiceExample.o    -lpvAccess -lpvData -lCom
c++ -o rpcClientExample  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            rpcClientExample.o    -lpvAccess -lpvData -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testAtomicBoolean.t testAtomicBoolean
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testHexDump.t testHexDump
c++ -o testRAII  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testRAII.o    -lpvAccess -lpvData -lCom
c++ -o testClientFactory  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testClientFactory.o    -lpvAccess -lpvData -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testInetAddressUtils.t testInetAddressUtils
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 configurationTest.t configurationTest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testFairQueue.t testFairQueue
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testWildcard.t testWildcard
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testChannelAccess.t testChannelAccess
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testRPC.t testRPC
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testCodec.t testCodec
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testServerContext.t testServerContext
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testmonitorfifo.t testmonitorfifo
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testsharedstate.t testsharedstate
c++           -I../../src/utils -I../../src/server -I../../src/remote -I../../src/remoteClient    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../testApp/utils -I../../testApp/remote -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../testApp/remote/testServer.cpp
c++ -o testServer  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testServer.o    -lpvAccess -lpvData -lCom
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/testApp/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess/testApp'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvAccess'
/Users/jenkins/bin/make -C ./pvaClient install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvaClient'
/Users/jenkins/bin/make -C ./configure install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvaClient/configure'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
    T_A=darwin-x86 install
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvaClient/configure/O.darwin-x86'
Installing CFG file /Users/jenkins/workspace/epics-7.0/OS/mac/cfg/CONFIG_PVACLIENT_VERSION
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvaClient/configure/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvaClient/configure'
/Users/jenkins/bin/make -C ./src install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvaClient/src'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvaClient/src/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientRPC.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientRPC.o ../pvaClientRPC.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientNTMultiMonitor.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientNTMultiMonitor.o ../pvaClientNTMultiMonitor.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientNTMultiGet.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientNTMultiGet.o ../pvaClientNTMultiGet.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientNTMultiData.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientNTMultiData.o ../pvaClientNTMultiData.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientNTMultiPut.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientNTMultiPut.o ../pvaClientNTMultiPut.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientMultiMonitorDouble.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientMultiMonitorDouble.o ../pvaClientMultiMonitorDouble.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientMultiPutDouble.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientMultiPutDouble.o ../pvaClientMultiPutDouble.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientMultiGetDouble.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientMultiGetDouble.o ../pvaClientMultiGetDouble.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientMultiChannel.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientMultiChannel.o ../pvaClientMultiChannel.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientPutGet.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientPutGet.o ../pvaClientPutGet.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientMonitor.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientMonitor.o ../pvaClientMonitor.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientPut.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientPut.o ../pvaClientPut.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientGet.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientGet.o ../pvaClientGet.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientProcess.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientProcess.o ../pvaClientProcess.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientChannel.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientChannel.o ../pvaClientChannel.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientMonitorData.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientMonitorData.o ../pvaClientMonitorData.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientGetData.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientGetData.o ../pvaClientGetData.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientPutData.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientPutData.o ../pvaClientPutData.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClientData.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClientData.o ../pvaClientData.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaClient.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaClient.o ../pvaClient.cpp
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvaClient.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvaClientMultiChannel.h
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClient.cpp
In file included from ../pvaClient.cpp:19:
../pv/pvaClient.h:1614:10: warning: 'epics::pvaClient::PvaClientMonitor::monitorConnect' hides overloaded virtual function [-Woverloaded-virtual]
    void monitorConnect(
../pv/pvaClient.h:1482:18: note: hidden overloaded virtual function 'epics::pvaClient::PvaClientMonitorRequester::monitorConnect' declared here: type mismatch at 2nd parameter ('const epics::pvaClient::PvaClientMonitorPtr &' (aka 'const shared_ptr<epics::pvaClient::PvaClientMonitor> &') vs 'const epics::pvData::MonitorPtr &' (aka 'const shared_ptr<epics::pvAccess::Monitor> &'))
    virtual void monitorConnect(epics::pvData::Status const & status,
../pv/pvaClient.h:1618:10: warning: 'epics::pvaClient::PvaClientMonitor::unlisten' hides overloaded virtual function [-Woverloaded-virtual]
    void unlisten(epics::pvData::MonitorPtr const & monitor);
../pv/pvaClient.h:1495:18: note: hidden overloaded virtual function 'epics::pvaClient::PvaClientMonitorRequester::unlisten' declared here: different number of parameters (0 vs 1)
    virtual void unlisten()
2 warnings generated.
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientData.cpp
In file included from ../pvaClientData.cpp:28:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientPutData.cpp
In file included from ../pvaClientPutData.cpp:20:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientGetData.cpp
In file included from ../pvaClientGetData.cpp:20:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientMonitorData.cpp
In file included from ../pvaClientMonitorData.cpp:20:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientChannel.cpp
In file included from ../pvaClientChannel.cpp:19:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientProcess.cpp
In file included from ../pvaClientProcess.cpp:16:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientGet.cpp
In file included from ../pvaClientGet.cpp:16:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientPut.cpp
In file included from ../pvaClientPut.cpp:16:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientMonitor.cpp
In file included from ../pvaClientMonitor.cpp:18:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientPutGet.cpp
In file included from ../pvaClientPutGet.cpp:15:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientMultiChannel.cpp
In file included from ../pvaClientMultiChannel.cpp:18:
In file included from ../pv/pvaClientMultiChannel.h:28:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientMultiGetDouble.cpp
In file included from ../pvaClientMultiGetDouble.cpp:17:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientMultiPutDouble.cpp
In file included from ../pvaClientMultiPutDouble.cpp:17:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientMultiMonitorDouble.cpp
In file included from ../pvaClientMultiMonitorDouble.cpp:17:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientNTMultiPut.cpp
In file included from ../pvaClientNTMultiPut.cpp:18:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientNTMultiData.cpp
In file included from ../pvaClientNTMultiData.cpp:16:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientNTMultiGet.cpp
In file included from ../pvaClientNTMultiGet.cpp:16:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientNTMultiMonitor.cpp
In file included from ../pvaClientNTMultiMonitor.cpp:19:
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvaClientRPC.cpp
In file included from ../pvaClientRPC.cpp:19:
c++ -o libpvaClient.4.8.1.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvaClient.4.8.1.dylib -compatibility_version 4.8.1 -current_version 4.8.1 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64             pvaClient.o pvaClientData.o pvaClientPutData.o pvaClientGetData.o pvaClientMonitorData.o pvaClientChannel.o pvaClientProcess.o pvaClientGet.o pvaClientPut.o pvaClientMonitor.o pvaClientPutGet.o pvaClientMultiChannel.o pvaClientMultiGetDouble.o pvaClientMultiPutDouble.o pvaClientMultiMonitorDouble.o pvaClientNTMultiPut.o pvaClientNTMultiData.o pvaClientNTMultiGet.o pvaClientNTMultiMonitor.o pvaClientRPC.o   -lnt -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom      -lreadline -lm
/usr/bin/ar -rc    libpvaClient.a     pvaClient.o pvaClientData.o pvaClientPutData.o pvaClientGetData.o pvaClientMonitorData.o pvaClientChannel.o pvaClientProcess.o pvaClientGet.o pvaClientPut.o pvaClientMonitor.o pvaClientPutGet.o pvaClientMultiChannel.o pvaClientMultiGetDouble.o pvaClientMultiPutDouble.o pvaClientMultiMonitorDouble.o pvaClientNTMultiPut.o pvaClientNTMultiData.o pvaClientNTMultiGet.o pvaClientNTMultiMonitor.o pvaClientRPC.o
/usr/bin/ranlib libpvaClient.a
Installing shared library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvaClient.4.8.1.dylib
ln -s libpvaClient.4.8.1.dylib /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvaClient.dylib
Installing library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvaClient.a
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvaClient/src/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvaClient/src'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvaClient'
/Users/jenkins/bin/make -C ./pvDatabase install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase'
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/configure'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/configure/O.darwin-x86'
Installing CFG file /Users/jenkins/workspace/epics-7.0/OS/mac/cfg/CONFIG_PVDATABASE_VERSION
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/convertRelease.pl checkRelease
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/configure/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/configure'
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/src'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/src/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvdbcrTraceRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvdbcrTraceRecord.o ../../src/special/pvdbcrTraceRecord.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvdbcrProcessRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvdbcrProcessRecord.o ../../src/special/pvdbcrProcessRecord.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvdbcrRemoveRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvdbcrRemoveRecord.o ../../src/special/pvdbcrRemoveRecord.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvdbcrAddRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvdbcrAddRecord.o ../../src/special/pvdbcrAddRecord.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvdbcrScalarArrayRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvdbcrScalarArrayRecord.o ../../src/special/pvdbcrScalarArrayRecord.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvdbcrScalarRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvdbcrScalarRecord.o ../../src/special/pvdbcrScalarRecord.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m scalarAlarmSupport.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        scalarAlarmSupport.o ../../src/support/scalarAlarmSupport.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m controlSupport.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        controlSupport.o ../../src/support/controlSupport.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m registerChannelProviderLocal.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        registerChannelProviderLocal.o ../../src/pvAccess/registerChannelProviderLocal.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m monitorFactory.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        monitorFactory.o ../../src/pvAccess/monitorFactory.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m channelLocal.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        channelLocal.o ../../src/pvAccess/channelLocal.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m channelProviderLocal.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        channelProviderLocal.o ../../src/pvAccess/channelProviderLocal.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvDatabase.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvDatabase.o ../../src/database/pvDatabase.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvRecord.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvRecord.o ../../src/database/pvRecord.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvTimestampPlugin.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvTimestampPlugin.o ../../src/copy/pvTimestampPlugin.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvDeadbandPlugin.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvDeadbandPlugin.o ../../src/copy/pvDeadbandPlugin.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvArrayPlugin.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvArrayPlugin.o ../../src/copy/pvArrayPlugin.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvCopy.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvCopy.o ../../src/copy/pvCopy.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvPlugin.d -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvPlugin.o ../../src/copy/pvPlugin.cpp
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvPlugin.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvStructureCopy.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvArrayPlugin.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvDeadbandPlugin.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvTimestampPlugin.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvDatabase.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/channelProviderLocal.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvSupport.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/controlSupport.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/scalarAlarmSupport.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvdbcrScalarRecord.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvdbcrScalarArrayRecord.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvdbcrAddRecord.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvdbcrRemoveRecord.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvdbcrProcessRecord.h
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/pvdbcrTraceRecord.h
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/registerChannelProviderLocal.dbd
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/pvdbcrScalarRecord.dbd
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/pvdbcrScalarArrayRecord.dbd
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/pvdbcrAddRecord.dbd
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/pvdbcrRemoveRecord.dbd
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/pvdbcrProcessRecord.dbd
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/pvdbcrTraceRecord.dbd
Installing dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/pvdbcrAllRecords.dbd
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/copy/pvPlugin.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/copy/pvCopy.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/copy/pvArrayPlugin.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/copy/pvDeadbandPlugin.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/copy/pvTimestampPlugin.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/database/pvRecord.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/database/pvDatabase.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pvAccess/channelProviderLocal.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pvAccess/channelLocal.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pvAccess/monitorFactory.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/pvAccess/registerChannelProviderLocal.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/support/controlSupport.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/support/scalarAlarmSupport.cpp
In file included from ../../src/support/scalarAlarmSupport.cpp:22:
../pv/scalarAlarmSupport.h:48:18: warning: 'epics::pvDatabase::ScalarAlarmSupport::init' hides overloaded virtual function [-Woverloaded-virtual]
    virtual bool init(
../pv/pvSupport.h:49:18: note: hidden overloaded virtual function 'epics::pvDatabase::PVSupport::init' declared here: different number of parameters (2 vs 3)
    virtual bool init(
../pv/scalarAlarmSupport.h:88:7: warning: private field 'AlarmRange' is not used [-Wunused-private-field]
    } AlarmRange;
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/special/pvdbcrScalarRecord.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/special/pvdbcrScalarArrayRecord.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/special/pvdbcrAddRecord.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/special/pvdbcrRemoveRecord.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/special/pvdbcrProcessRecord.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/copy -I../../src/database -I../../src/pvAccess -I../../src/support -I../../src/special -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../src/special/pvdbcrTraceRecord.cpp
/usr/bin/ar -rc    libpvDatabase.a     pvPlugin.o pvCopy.o pvArrayPlugin.o pvDeadbandPlugin.o pvTimestampPlugin.o pvRecord.o pvDatabase.o channelProviderLocal.o channelLocal.o monitorFactory.o registerChannelProviderLocal.o controlSupport.o scalarAlarmSupport.o pvdbcrScalarRecord.o pvdbcrScalarArrayRecord.o pvdbcrAddRecord.o pvdbcrRemoveRecord.o pvdbcrProcessRecord.o pvdbcrTraceRecord.o
/usr/bin/ranlib libpvDatabase.a
c++ -o libpvDatabase.4.6.1.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvDatabase.4.6.1.dylib -compatibility_version 4.6.1 -current_version 4.6.1 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64             pvPlugin.o pvCopy.o pvArrayPlugin.o pvDeadbandPlugin.o pvTimestampPlugin.o pvRecord.o pvDatabase.o channelProviderLocal.o channelLocal.o monitorFactory.o registerChannelProviderLocal.o controlSupport.o scalarAlarmSupport.o pvdbcrScalarRecord.o pvdbcrScalarArrayRecord.o pvdbcrAddRecord.o pvdbcrRemoveRecord.o pvdbcrProcessRecord.o pvdbcrTraceRecord.o   -lpvData -lpvAccess -lCom      -lreadline -lm
Installing shared library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvDatabase.4.6.1.dylib
ln -s libpvDatabase.4.6.1.dylib /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvDatabase.dylib
Installing library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libpvDatabase.a
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/src/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/src'
/Users/jenkins/bin/make -C ./test install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/test'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/test/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVAServer.d -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVAServer.o ../../test/src/testPVAServer.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testLocalProvider.d -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testLocalProvider.o ../../test/src/testLocalProvider.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testExampleRecord.d -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testExampleRecord.o ../../test/src/testExampleRecord.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVRecord.d -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVRecord.o ../../test/src/testPVRecord.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPVCopy.d -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPVCopy.o ../../test/src/testPVCopy.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testPlugin.d -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testPlugin.o ../../test/src/testPlugin.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../test/src/testPVRecord.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../test/src/testPlugin.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../test/src/testPVCopy.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../test/src/testExampleRecord.cpp
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../test/src/testPVAServer.cpp
c++ -o testPlugin  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPlugin.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testPVCopy  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVCopy.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testPVRecord  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVRecord.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++              -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I../../test/src -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../../test/src/testLocalProvider.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPlugin.t testPlugin
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVCopy.t testPVCopy
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVRecord.t testPVRecord
c++ -o testPVAServer  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testPVAServer.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testExampleRecord  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testExampleRecord.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testLocalProvider  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testLocalProvider.o    -lpvDatabase -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testExampleRecord.t testExampleRecord
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testLocalProvider.t testLocalProvider
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testPVAServer.t testPVAServer
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/test/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase/test'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pvDatabase'
/Users/jenkins/bin/make -C ./pva2pva install.darwin-x86
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva'
/Users/jenkins/bin/make -C ./configure install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/configure'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.darwin-x86 ../..
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeMakefile.pl O.ios-arm ../..
mkdir -p O.Common
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../.. \
    T_A=darwin-x86 install
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/configure/O.darwin-x86'
Installing CFG file /Users/jenkins/workspace/epics-7.0/OS/mac/cfg/CONFIG_QSRV_VERSION
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/configure/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/configure'
/Users/jenkins/bin/make -C ./p2pApp install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/p2pApp'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/p2pApp/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m utilitiesx.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        utilitiesx.o ../utilitiesx.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m gwmain.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        gwmain.o ../gwmain.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testmon.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testmon.o ../testmon.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m channel.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        channel.o ../channel.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m moncache.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        moncache.o ../moncache.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m chancache.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        chancache.o ../chancache.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m server.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        server.o ../server.cpp
c++           -DUSE_TYPED_RSET -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../gwmain.cpp
../gwmain.cpp:245:57: warning: non-type template argument referring to function 'iocsh_drop' with internal linkage is a C++11 extension [-Wc++11-extensions]
        epics::iocshRegister<const char*, const char*, &iocsh_drop>("drop", "client", "channel");
../gwmain.cpp:205:6: note: non-type template argument refers to function here
void iocsh_drop(const char *client, const char *channel)
../gwmain.cpp:246:49: warning: non-type template argument referring to function 'gwsr' with internal linkage is a C++11 extension [-Wc++11-extensions]
        epics::iocshRegister<int, const char*, &gwsr>("gwsr", "level", "channel");
../gwmain.cpp:216:6: note: non-type template argument refers to function here
void gwsr(int lvl, const char *server)
../gwmain.cpp:247:62: warning: non-type template argument referring to function 'gwcr' with internal linkage is a C++11 extension [-Wc++11-extensions]
        epics::iocshRegister<int, const char*, const char*, &gwcr>("gwcr", "level", "client", "channel");
../gwmain.cpp:227:6: note: non-type template argument refers to function here
void gwcr(int lvl, const char *client, const char *channel)
../gwmain.cpp:283:17: warning: variable 'lvl' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
        else if(arg.debug>=4)
../gwmain.cpp:285:23: note: uninitialized use occurs here
        SET_LOG_LEVEL(lvl);
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/logger.h:50:50: note: expanded from macro 'SET_LOG_LEVEL'
#define SET_LOG_LEVEL(level) pvAccessSetLogLevel(level)
../gwmain.cpp:283:14: note: remove the 'if' if its condition is always true
../gwmain.cpp:272:9: note: variable 'lvl' is declared here
        pva::pvAccessLogLevel lvl;
In file included from ../gwmain.cpp:26:
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/iocshelper.h:127:51: warning: non-type template argument referring to function 'iocsh_drop' with internal linkage is a C++11 extension [-Wc++11-extensions]
    iocshRegister(&info.def, &detail::call2<A, B, fn>);
../gwmain.cpp:245:16: note: in instantiation of function template specialization 'epics::iocshRegister<const char *, const char *, &(anonymous namespace)::iocsh_drop>' requested here
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/iocshelper.h:127:51: warning: non-type template argument referring to function 'gwsr' with internal linkage is a C++11 extension [-Wc++11-extensions]
../gwmain.cpp:246:16: note: in instantiation of function template specialization 'epics::iocshRegister<int, const char *, &(anonymous namespace)::gwsr>' requested here
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/iocshelper.h:140:54: warning: non-type template argument referring to function 'gwcr' with internal linkage is a C++11 extension [-Wc++11-extensions]
    iocshRegister(&info.def, &detail::call3<A, B, C, fn>);
../gwmain.cpp:247:16: note: in instantiation of function template specialization 'epics::iocshRegister<int, const char *, const char *, &(anonymous namespace)::gwcr>' requested here
7 warnings generated.
c++           -DUSE_TYPED_RSET -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../server.cpp
c++           -DUSE_TYPED_RSET -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../chancache.cpp
c++           -DUSE_TYPED_RSET -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../moncache.cpp
c++           -DUSE_TYPED_RSET -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../channel.cpp
c++           -DUSE_TYPED_RSET -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../testmon.cpp
c++           -DUSE_TYPED_RSET -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../utilitiesx.cpp
c++ -o p2p  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            gwmain.o server.o chancache.o moncache.o channel.o   -lpvAccessIOC -lpvAccess -lpvData -lCom
c++ -o testmon  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testmon.o utilitiesx.o server.o chancache.o moncache.o channel.o   -lpvAccessIOC -lpvAccess -lpvData -lCom
Installing created executable /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/p2p
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testmon.t testmon
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/p2pApp/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/p2pApp'
/Users/jenkins/bin/make -C ./pdbApp install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/pdbApp'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/pdbApp/O.darwin-x86'
mkdir -p ../O.Common/pv
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/expandVars.pl -DEPICS_QSRV_MAJOR_VERSION="1" -DEPICS_QSRV_MINOR_VERSION="3" -DEPICS_QSRV_MAINTENANCE_VERSION="2" -DEPICS_QSRV_DEVELOPMENT_FLAG="1" -DEPICS_QSRV_ABI_MAJOR_VERSION="1" -DEPICS_QSRV_ABI_MINOR_VERSION="2" -t /Users/jenkins/workspace/epics-7.0/OS/mac    ../pv/qsrvVersionNum.h@ ../O.Common/pv/qsrvVersionNum.h
cp ../qsrv-new.dbd ../O.Common/qsrv.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m softMain.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        softMain.o ../softMain.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvalink_channel.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvalink_channel.o ../pvalink_channel.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvalink_link.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvalink_link.o ../pvalink_link.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvalink_jlif.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvalink_jlif.o ../pvalink_jlif.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvalink_lset.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvalink_lset.o ../pvalink_lset.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvalink.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvalink.o ../pvalink.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m tpool.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        tpool.o ../tpool.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m dbf_copy.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        dbf_copy.o ../dbf_copy.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m configparse.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        configparse.o ../configparse.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pdbgroup.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pdbgroup.o ../pdbgroup.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m imagedemo.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        imagedemo.o ../imagedemo.c
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m demo.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        demo.o ../demo.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pdbsingle.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pdbsingle.o ../pdbsingle.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pdb.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pdb.o ../pdb.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m qsrv.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        qsrv.o ../qsrv.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvif.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvif.o ../pvif.cpp
Creating dbd file softIocPVA.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd -o softIocPVA.dbd softIoc.dbd PVAServerRegister.dbd qsrv.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd    -o softIocPVA_registerRecordDeviceDriver.cpp ../O.Common/softIocPVA.dbd softIocPVA_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m softIocPVA_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        softIocPVA_registerRecordDeviceDriver.o softIocPVA_registerRecordDeviceDriver.cpp
Installing generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/qsrv.h
Installing generated generic include file /Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/qsrvVersionNum.h
Installing created dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/softIocPVA.dbd
Installing created dbd file /Users/jenkins/workspace/epics-7.0/OS/mac/dbd/qsrv.dbd
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvif.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../qsrv.cpp
../qsrv.cpp:131:45: warning: non-type template argument referring to function 'dbgl' with internal linkage is a C++11 extension [-Wc++11-extensions]
    epics::iocshRegister<int, const char*, &dbgl>("dbgl", "level", "pattern");
../qsrv.cpp:92:6: note: non-type template argument refers to function here
void dbgl(int lvl, const char *pattern)
../qsrv.cpp:132:40: warning: non-type template argument referring to function 'dbLoadGroupWrap' with internal linkage is a C++11 extension [-Wc++11-extensions]
    epics::iocshRegister<const char*, &dbLoadGroupWrap>("dbLoadGroup", "jsonfile");
../qsrv.cpp:87:6: note: non-type template argument refers to function here
void dbLoadGroupWrap(const char* fname)
In file included from ../qsrv.cpp:19:
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/iocshelper.h:127:51: warning: non-type template argument referring to function 'dbgl' with internal linkage is a C++11 extension [-Wc++11-extensions]
../qsrv.cpp:131:12: note: in instantiation of function template specialization 'epics::iocshRegister<int, const char *, &(anonymous namespace)::dbgl>' requested here
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/iocshelper.h:116:48: warning: non-type template argument referring to function 'dbLoadGroupWrap' with internal linkage is a C++11 extension [-Wc++11-extensions]
    iocshRegister(&info.def, &detail::call1<A, fn>);
../qsrv.cpp:132:12: note: in instantiation of function template specialization 'epics::iocshRegister<const char *, &(anonymous namespace)::dbLoadGroupWrap>' requested here
4 warnings generated.
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pdb.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pdbsingle.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../demo.cpp
cc           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall -Werror-implicit-function-declaration       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../imagedemo.c
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../configparse.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pdbgroup.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../dbf_copy.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../tpool.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvalink.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvalink_jlif.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvalink_lset.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvalink_link.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c softIocPVA_registerRecordDeviceDriver.cpp
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../softMain.cpp
../softMain.cpp:264:17: warning: 'epicsThreadExitMain' is deprecated [-Wdeprecated-declarations]
                epicsThreadExitMain();
/Users/jenkins/workspace/epics-7.0/OS/mac/include/epicsThread.h:151:56: note: 'epicsThreadExitMain' has been explicitly marked deprecated here
LIBCOM_API void epicsStdCall epicsThreadExitMain(void) EPICS_DEPRECATED;
/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang/compilerSpecific.h:54:41: note: expanded from macro 'EPICS_DEPRECATED'
#define EPICS_DEPRECATED __attribute__((deprecated))
1 warning generated.
c++           -DUSE_TYPED_RSET -DQSRV_API_BUILDING -I../../common -I../../p2pApp -DEPICS_BASE="\"/Users/jenkins/workspace/epics-7.0/OS/mac\""    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common -fPIC -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../pvalink_channel.cpp
/usr/bin/ar -rc    libqsrv.a    pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o dbf_copy.o tpool.o pvalink.o pvalink_lset.o pvalink_jlif.o pvalink_link.o pvalink_channel.o
/usr/bin/ranlib libqsrv.a
c++ -o libqsrv.1.2.dylib -dynamiclib -flat_namespace -undefined dynamic_lookup -install_name /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libqsrv.1.2.dylib -compatibility_version 1.2 -current_version 1.2 -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            pvif.o qsrv.o pdb.o pdbsingle.o demo.o imagedemo.o pdbgroup.o configparse.o dbf_copy.o tpool.o pvalink.o pvalink_lset.o pvalink_jlif.o pvalink_link.o pvalink_channel.o    -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom      -lreadline -lm
Installing shared library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libqsrv.1.2.dylib
ln -s libqsrv.1.2.dylib /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libqsrv.dylib
Installing library /Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86/libqsrv.a
c++ -o softIocPVA  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            softMain.o softIocPVA_registerRecordDeviceDriver.o    -lqsrv -lpvAccessIOC -lpvAccessCA -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
Installing created executable /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/softIocPVA
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/pdbApp/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/pdbApp'
/Users/jenkins/bin/make -C ./testApp install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/testApp'
mkdir -p O.Common
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/testApp/O.darwin-x86'
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testdbf_copy.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testdbf_copy.o ../testdbf_copy.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testgroupconfig.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testgroupconfig.o ../testgroupconfig.cpp
Creating dbd file pvaLinkTestIoc.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd -o pvaLinkTestIoc.dbd base.dbd qsrv.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testpvalink.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testpvalink.o ../testpvalink.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m check_consist.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        check_consist.o ../check_consist.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testpdb.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testpdb.o ../testpdb.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testpvif.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testpvif.o ../testpvif.cpp
Creating dbd file p2pTestIoc.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/dbdExpand.pl   -I. -I.. -I../O.Common -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd -o p2pTestIoc.dbd base.dbd
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testtest.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testtest.o ../testtest.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m testweak.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        testweak.o ../testweak.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd    -o pvaLinkTestIoc_registerRecordDeviceDriver.cpp ../O.Common/pvaLinkTestIoc.dbd pvaLinkTestIoc_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m pvaLinkTestIoc_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        pvaLinkTestIoc_registerRecordDeviceDriver.o pvaLinkTestIoc_registerRecordDeviceDriver.cpp
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/registerRecordDeviceDriver.pl   -I. -I.. -I../O.Common -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd -I/Users/jenkins/workspace/epics-7.0/OS/mac/dbd    -o p2pTestIoc_registerRecordDeviceDriver.cpp ../O.Common/p2pTestIoc.dbd p2pTestIoc_registerRecordDeviceDriver /Users/jenkins/workspace/epics-7.0/OS/mac
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/mkmf.pl  -m p2pTestIoc_registerRecordDeviceDriver.d -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        p2pTestIoc_registerRecordDeviceDriver.o p2pTestIoc_registerRecordDeviceDriver.cpp
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../testtest.cpp
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c p2pTestIoc_registerRecordDeviceDriver.cpp
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../testweak.cpp
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../check_consist.cpp
../check_consist.cpp:11:21: warning: 'Destroyable' is deprecated [-Wdeprecated-declarations]
    pvd::Destroyable::shared_pointer D;
/Users/jenkins/workspace/epics-7.0/OS/mac/include/pv/destroyable.h:61:56: note: 'Destroyable' has been explicitly marked deprecated here
    typedef ::epics::pvAccess::Destroyable Destroyable EPICS_DEPRECATED;
../check_consist.cpp:12:37: warning: 'Destroyable' is deprecated [-Wdeprecated-declarations]
    Destroyer(const pvd::Destroyable::shared_pointer& d) : D(d) {}
2 warnings generated.
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../testpvif.cpp
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c pvaLinkTestIoc_registerRecordDeviceDriver.cpp
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../testpvalink.cpp
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../testpdb.cpp
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../utilitiesx.cpp
c++ -o testweak  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testweak.o utilitiesx.o   -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testtest  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testtest.o utilitiesx.o   -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testpvif  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testpvif.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o   -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testpdb  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testpdb.o p2pTestIoc_registerRecordDeviceDriver.o utilitiesx.o   -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o check_consist  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            check_consist.o utilitiesx.o   -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
c++ -o testpvalink  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testpvalink.o pvaLinkTestIoc_registerRecordDeviceDriver.o utilitiesx.o   -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testweak.t testweak
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testtest.t testtest
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testpvif.t testpvif
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testpdb.t testpdb
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testpvalink.t testpvalink
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../testgroupconfig.cpp
c++ -o testgroupconfig  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testgroupconfig.o utilitiesx.o   -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testgroupconfig.t testgroupconfig
c++           -DUSE_TYPED_RSET -I../../pdbApp -I../../p2pApp -I../../common    -DUNIX  -Ddarwin      -O3 -g   -Wall       -arch x86_64    -fno-common  -I. -I../O.Common -I. -I. -I.. -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/compiler/clang -I/Users/jenkins/workspace/epics-7.0/OS/mac/include/os/Darwin -I/Users/jenkins/workspace/epics-7.0/OS/mac/include        -c ../testdbf_copy.cpp
c++ -o testdbf_copy  -L/Users/jenkins/workspace/epics-7.0/OS/mac/lib/darwin-x86        -arch x86_64            testdbf_copy.o utilitiesx.o   -lqsrv -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom -lpvAccess -lpvData -ldbRecStd -ldbCore -lca -lCom
perl -CSD /Users/jenkins/workspace/epics-7.0/OS/mac/bin/darwin-x86/makeTestfile.pl darwin-x86 darwin-x86 testdbf_copy.t testdbf_copy
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/testApp/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/testApp'
/Users/jenkins/bin/make -C ./iocBoot install.darwin-x86
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/iocBoot'
/Users/jenkins/bin/make -C ./iocpvalink install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/iocBoot/iocpvalink'
make[4]: Nothing to be done for 'install.darwin-x86'.
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/iocBoot/iocpvalink'
/Users/jenkins/bin/make -C ./iocwfdemo install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/iocBoot/iocwfdemo'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/iocBoot/iocwfdemo'
/Users/jenkins/bin/make -C ./iocimagedemo install.darwin-x86
make[4]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/iocBoot/iocimagedemo'
make[4]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/iocBoot/iocimagedemo'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva/iocBoot'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules/pva2pva'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/modules'
+ echo ------------------------------------------------------------------
+ /Users/jenkins/bin/make -k -j4 -Orecurse
fcntl(): Bad file descriptor
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure'
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure/O.darwin-x86'
make[2]: Nothing to be done for 'install'.
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure/O.darwin-x86'
/Users/jenkins/bin/make -C O.ios-arm -f ../Makefile TOP=../.. \
    T_A=ios-arm install
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure/O.ios-arm'
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -x c -E              -DUNIX     -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/clang -I../../include/os/iOS -I../../include         ../toolchain.c > TOOLCHAIN.darwin-x86.ios-arm
Installing CFG file ../../cfg/TOOLCHAIN.darwin-x86.ios-arm
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure/O.ios-arm'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/configure'
/Users/jenkins/bin/make -C ./src install
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src'
/Users/jenkins/bin/make -C ./tools install
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools'
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools/O.darwin-x86'
make[3]: Nothing to be done for 'install'.
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools/O.darwin-x86'
/Users/jenkins/bin/make -C O.ios-arm -f ../Makefile TOP=../../.. \
    T_A=ios-arm install
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools/O.ios-arm'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools/O.ios-arm'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/tools'
/Users/jenkins/bin/make -C template/base install
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base'
/Users/jenkins/bin/make -C O.darwin-x86 -f ../Makefile TOP=../../../.. \
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base/O.darwin-x86'
/Users/jenkins/bin/make -C O.ios-arm -f ../Makefile TOP=../../../.. \
    T_A=ios-arm install
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base/O.ios-arm'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base/O.ios-arm'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/base'
/Users/jenkins/bin/make -C template/ext install
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext'
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext/O.darwin-x86'
    T_A=ios-arm install
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext/O.ios-arm'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext/O.ios-arm'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src/template/ext'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/src'
/Users/jenkins/bin/make -C ./test install
make[1]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test'
make[2]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools'
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools/O.darwin-x86'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools/O.darwin-x86'
    T_A=ios-arm install
make[3]: Entering directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools/O.ios-arm'
make[3]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools/O.ios-arm'
make[2]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test/tools'
make[1]: Leaving directory '/Users/jenkins/workspace/epics-7.0/OS/mac/test'
FATAL: command execution failed
java.io.EOFException
	at java.io.ObjectInputStream$PeekInputStream.readFully(ObjectInputStream.java:2759)
	at java.io.ObjectInputStream$BlockDataInputStream.readShort(ObjectInputStream.java:3234)
	at java.io.ObjectInputStream.readStreamHeader(ObjectInputStream.java:913)
	at java.io.ObjectInputStream.<init>(ObjectInputStream.java:375)
	at hudson.remoting.ObjectInputStreamEx.<init>(ObjectInputStreamEx.java:49)
	at hudson.remoting.Command.readFrom(Command.java:142)
	at hudson.remoting.Command.readFrom(Command.java:128)
	at hudson.remoting.AbstractSynchronousByteArrayCommandTransport.read(AbstractSynchronousByteArrayCommandTransport.java:35)
	at hudson.remoting.SynchronousCommandTransport$ReaderThread.run(SynchronousCommandTransport.java:61)
Caused: java.io.IOException: Unexpected termination of the channel
	at hudson.remoting.SynchronousCommandTransport$ReaderThread.run(SynchronousCommandTransport.java:75)
Caused: java.io.IOException: Backing channel 'mac-1' is disconnected.
	at hudson.remoting.RemoteInvocationHandler.channelOrFail(RemoteInvocationHandler.java:216)
	at hudson.remoting.RemoteInvocationHandler.invoke(RemoteInvocationHandler.java:286)
	at com.sun.proxy.$Proxy74.isAlive(Unknown Source)
	at hudson.Launcher$RemoteLauncher$ProcImpl.isAlive(Launcher.java:1213)
	at hudson.Launcher$RemoteLauncher$ProcImpl.join(Launcher.java:1205)
	at hudson.tasks.CommandInterpreter.join(CommandInterpreter.java:194)
	at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:144)
	at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:91)
	at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:20)
	at hudson.model.AbstractBuild$AbstractBuildExecution.perform(AbstractBuild.java:806)
	at hudson.model.Build$BuildExecution.build(Build.java:198)
	at hudson.model.Build$BuildExecution.doRun(Build.java:163)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:514)
	at hudson.model.Run.execute(Run.java:1888)
	at hudson.matrix.MatrixRun.run(MatrixRun.java:153)
	at hudson.model.ResourceController.execute(ResourceController.java:99)
	at hudson.model.Executor.run(Executor.java:432)
FATAL: Unable to delete script file /var/folders/6f/2q91ldsx2rncqbx80st_4r700000gn/T/jenkins4897709733254251907.sh
Caused: hudson.remoting.ChannelClosedException: Channel "hudson.remoting.Channel@335ec2d1:mac-1": Remote call on mac-1 failed. The channel is closing down or has closed down
	at hudson.remoting.Channel.call(Channel.java:994)
	at hudson.FilePath.act(FilePath.java:1164)
	at hudson.FilePath.act(FilePath.java:1153)
	at hudson.FilePath.delete(FilePath.java:1677)
	at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:162)
Build step 'Execute shell' marked build as failure
ERROR: Step ‘Publish TAP Results’ failed: no workspace for epics-7.0/OS=mac #370
Notifying upstream projects of job completion
Email was triggered for: Failure - Any
Sending email for trigger: Failure - Any
Sending email to: core-talk at aps.anl.gov
epics-7.0 » mac - Build # 371 - Fixed! APS Jenkins via Core-talk
Prev: Re: pvMonitor questions Michael Davidsaver via Core-talk
Next: epics-7.0 » mac - Build # 371 - Fixed! APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
ANJ, 03 Nov 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
