I'd be happy with switching to from %d to %i as long as the PR includes
an entry in the Release Notes describing that change.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1950300
Title:
Cannot use hex numbers in HW links in EPICS 7
Status in EPICS Base:
New
Bug description:
In EPICS 3.14.12, it was possible to use hex numbers in hardware links
of type VME_IO and others like "#C0 S0x8b". (The parser used the
function cvtDecimalOrHexToShort for this.) In EPICS 7 this does not
work any longer because the string is parsed with %d instead of %i. As
many of our existing IOCs use hex numbers here, this makes transition
to EPICS 7 unnecessary hard.
Changing to %i will allow hex numbers, but will also allow octal
numbers. That may a problem as C011 uses to mean 11 in 3.14, not 9.
In that case, parsing with a single sscanf is not sufficient.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1950300/+subscriptions
- [Bug 1950300] [NEW] Cannot use hex numbers in HW links in EPICS 7 Dirk Zimoch via Core-talk
Build failed: EPICS Base 7 base-7.0-440 AppVeyor via Core-talk
Build completed: EPICS Base 7 base-7.0-441 AppVeyor via Core-talk
<2021>
2025
2026
[Bug 1950300] Re: Cannot use hex numbers in HW links in EPICS 7 mdavidsaver via Core-talk
[Bug 1950300] Re: Cannot use hex numbers in HW links in EPICS 7 Dirk Zimoch via Core-talk
<2021>
2025
2026
