2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Subject: Re: Strange UDP message on VxWorks 6.9
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: EPICS core-talk <core-talk at aps.anl.gov>
Date: Mon, 22 Nov 2021 19:04:50 +0000
On Nov 19, 2021, at 2:26 PM, Michael Davidsaver via Core-talk <core-talk at aps.anl.gov> wrote:
On 11/19/21 6:05 AM, Zimoch Dirk (PSI) wrote:
BTW: Some other tests harnesses require dbd files like linkTest.dbd that do not get installed (even though the *Harness.munch files are installed).
I'll defer this to Andrew.
Currently the configure/os/CONFIG.Common.vxWorksCommon definitions don’t support building .munch files for TESTPROD (or TESTPROD_vxWorks) targets, only for PROD (and hence PROD_vxWorks) targets.
The VxWorks test harnesses aren't actually intended to be installed — the .dbd files aren’t the only files that the test code needs to access. Because of the above limitation though we have to build them as PROD targets, and the files get installed because of that. Test programs are intended to be run after doing a cd to the appropriate O.<arch> directory which is where ‘make runtests’ and friends run them from for all of the host architectures. In my scripts for running the tests on VxWorks I cd to the test build directories, load the .munch files and run the harness programs directly and they work fine for me.
I don’t have time to work on fixing the TESTPROD builds myself and I’m not sure that it’s really worth the effort, although I wouldn’t object to it being done.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Strange UDP message on VxWorks 6.9 Zimoch Dirk (PSI) via Core-talk
Re: Strange UDP message on VxWorks 6.9 Michael Davidsaver via Core-talk
AW: Strange UDP message on VxWorks 6.9 Zimoch Dirk (PSI) via Core-talk
Re: AW: Strange UDP message on VxWorks 6.9 Michael Davidsaver via Core-talk
Prev: [Bug 1951848] Re: Failing EPICS 7 libCom tests on VxWorks 6.7 and 6.9 Dirk Zimoch via Core-talk
Next: [Bug 1951848] Re: Failing EPICS 7 libCom tests on VxWorks 6.7 and 6.9 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  2026
Prev: Re: AW: Strange UDP message on VxWorks 6.9 Michael Davidsaver via Core-talk
Next: Re: Strange UDP message on VxWorks 6.9 Zimoch Dirk (PSI) via Core-talk
ANJ, 23 Nov 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
