2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-example-win64 #735
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 27 Nov 2021 15:27:16 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-example-win64/735/display/redirect>
Changes:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/epics-example-win64/ws/>
The recommended git tool is: NONE
No credentials specified
 > C:/Program Files/Git/cmd/git.exe rev-parse --resolve-git-dir C:\jenkins\win64-2\workspace\epics-example-win64\.git # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://github.com/epics-base/exampleCPP.git # timeout=10
Cleaning workspace
 > C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
 > C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
 > C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/exampleCPP.git
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
 > git --version # 'git version 2.20.1.windows.1'
Setting http proxy: webproxy1.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress -- https://github.com/epics-base/exampleCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
 > C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/master^{commit}" # timeout=10
Checking out Revision bf816da88471171afc6c6b5ed6f912289336c30e (refs/remotes/origin/master)
 > C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
 > C:/Program Files/Git/cmd/git.exe checkout -f bf816da88471171afc6c6b5ed6f912289336c30e # timeout=10
Commit message: "add putAlarm and putTimeStamp"
 > C:/Program Files/Git/cmd/git.exe rev-list --no-walk bf816da88471171afc6c6b5ed6f912289336c30e # timeout=10
[epics-example-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins1251014550394737152.bat
C:\jenkins\win64-2\workspace\epics-example-win64>SET TA=win64
C:\jenkins\win64-2\workspace\epics-example-win64>SET BV=7.0
C:\jenkins\win64-2\workspace\epics-example-win64>SET CR=configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-example-win64>SET MO=-j4 -O --no-print-directory
C:\jenkins\win64-2\workspace\epics-example-win64>SET WS=C:/Jenkins/win64-2/workspace
C:\jenkins\win64-2\workspace\epics-example-win64>echo # RELEASE for jenkins-epics-example-win64-735 1>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-example-win64>echo PVDATABASE = C:/Jenkins/win64-2/workspace/epics-pvDatabase-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-example-win64>echo PVACLIENT = C:/Jenkins/win64-2/workspace/epics-pvaClient-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-example-win64>echo PVA2PVA = C:/Jenkins/win64-2/workspace/epics-pva2pva-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-example-win64>echo PVACCESS = C:/Jenkins/win64-2/workspace/epics-pvAccess-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-example-win64>echo NORMATIVE = C:/Jenkins/win64-2/workspace/epics-normativeTypes-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-example-win64>echo PVDATA = C:/Jenkins/win64-2/workspace/epics-pvData-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-example-win64>echo EPICS_BASE = C:/Jenkins/win64-2/workspace/epics-base-7.0-win64 1>>configure/RELEASE.local
C:\jenkins\win64-2\workspace\epics-example-win64>make -j4 -O --no-print-directory
make -C ./configure install
make -C ./scalarLimit install
make -C ./powerSupplyRecord install
make -C ./controlRecord install
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
    T_A=windows-x64 install
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/convertRelease.pl checkRelease
make -C ./helloPutGetRecord install
make -C ./src install
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/mkmf.pl  -m powerSupplyMonitor.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include      -IC:/Jenkins/win64-2/workspace/epics-pvaClient-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvAccess-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvData-win64/include -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/compiler/msvc -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/os/WIN32 -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include        powerSupplyMonitor.obj ../powerSupplyMonitor.cpp
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/mkmf.pl  -m scalarLimitRecord.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include      -IC:/Jenkins/win64-2/workspace/epics-pvaClient-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvAccess-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvData-win64/include -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/compiler/msvc -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/os/WIN32 -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include        scalarLimitRecord.obj ../scalarLimitRecord.cpp
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/mkmf.pl  -m powerSupplyClient.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include      -IC:/Jenkins/win64-2/workspace/epics-pvaClient-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvAccess-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvData-win64/include -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/compiler/msvc -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/os/WIN32 -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include        powerSupplyClient.obj ../powerSupplyClient.cpp
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/mkmf.pl  -m controlRecord.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include      -IC:/Jenkins/win64-2/workspace/epics-pvaClient-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvAccess-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvData-win64/include -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/compiler/msvc -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/os/WIN32 -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include        controlRecord.obj ../controlRecord.cpp
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/mkmf.pl  -m powerSupplyRecord.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include      -IC:/Jenkins/win64-2/workspace/epics-pvaClient-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvAccess-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvData-win64/include -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/compiler/msvc -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/os/WIN32 -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include        powerSupplyRecord.obj ../powerSupplyRecord.cpp
"Installing generic include file ../../include/scalarLimit/scalarLimitRecord.h"
mkdir ../../include
mkdir ../../include/scalarLimit
make[3]: *** No rule to make target '../../lib/windows-x64/pvDatabase.lib', needed by 'scalarLimitRecord.dll'.  Stop.
make[3]: *** Waiting for unfinished jobs....
"Installing dbd file ../../dbd/scalarLimitRecord.dbd"
mkdir ../../dbd
make[2]: *** [C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make[1]: *** [C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/configure/RULES_DIRS:85: src.install] Error 2
make: *** [C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/configure/RULES_DIRS:85: scalarLimit.install] Error 2
make: *** Waiting for unfinished jobs....
make[3]: *** No rule to make target '../../lib/windows-x64/pvDatabase.lib', needed by 'controlRecord.dll'.  Stop.
"Installing generic include file ../../include/pvcontrol/controlRecord.h"
mkdir ../../include
mkdir ../../include/pvcontrol
"Installing dbd file ../../dbd/controlRecord.dbd"
mkdir ../../dbd
make: *** [C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/configure/RULES_DIRS:85: controlRecord.install] Error 2
"Installing generic include file ../../include/powerSupply/powerSupplyRecord.h"
mkdir ../../include
mkdir ../../include/powerSupply
make[3]: *** No rule to make target '../../lib/windows-x64/pvDatabase.lib', needed by 'powerSupplyRecord.dll'.  Stop.
"Installing dbd file ../../dbd/powerSupplyRecord.dbd"
mkdir ../../dbd
make: *** [C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/configure/RULES_DIRS:85: powerSupplyRecord.install] Error 2
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/mkmf.pl  -m helloPutGetClient.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include      -IC:/Jenkins/win64-2/workspace/epics-pvaClient-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvAccess-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvData-win64/include -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/compiler/msvc -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/os/WIN32 -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include        helloPutGetClient.obj ../helloPutGetClient.cpp
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/mkmf.pl  -m helloNoWaitPutGetClient.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include      -IC:/Jenkins/win64-2/workspace/epics-pvaClient-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvAccess-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvData-win64/include -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/compiler/msvc -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/os/WIN32 -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include        helloNoWaitPutGetClient.obj ../helloNoWaitPutGetClient.cpp
perl -CSD C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/bin/windows-x64/mkmf.pl  -m helloPutGetRecord.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include      -IC:/Jenkins/win64-2/workspace/epics-pvaClient-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvAccess-win64/include      -IC:/Jenkins/win64-2/workspace/epics-pvData-win64/include -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/compiler/msvc -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include/os/WIN32 -IC:/Jenkins/win64-2/workspace/epics-base-7.0-win64/include        helloPutGetRecord.obj ../helloPutGetRecord.cpp
make[3]: *** No rule to make target '../../lib/windows-x64/pvDatabase.lib', needed by 'helloPutGetRecord.dll'.  Stop.
"Installing generic include file ../../include/helloPutGet/helloPutGetRecord.h"
mkdir ../../include
mkdir ../../include/helloPutGet
"Installing dbd file ../../dbd/helloPutGetRecord.dbd"
mkdir ../../dbd
make: *** [C:/Jenkins/win64-2/workspace/epics-base-7.0-win64/configure/RULES_DIRS:85: helloPutGetRecord.install] Error 2
C:\jenkins\win64-2\workspace\epics-example-win64>exit 2
Build step 'Execute Windows batch command' marked build as failure
[MSBuild] Skipping execution of recorder since overall result is 'FAILURE'
Jenkins build is back to normal : epics-example-win64 #736 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: 3.15-pva2pva-win64s #331 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-pvAccess-mac #437 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-pva2pva-win64 #430 APS Jenkins via Core-talk
Next: Jenkins build is back to normal : epics-example-win64 #736 APS Jenkins via Core-talk
ANJ, 27 Nov 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
