See <https://jenkins.aps.anl.gov/job/3.15-pvaClient-win64/379/display/redirect>
Changes:
Started by upstream project "3.15-pvAccess-win64s" build number 362
originally caused by:
Started by upstream project "3.15-pvAccess-win64" build number 363
Started by upstream project "3.15-pvData-win64s" build number 140
Started by upstream project "3.15-pvData-win64" build number 139
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/3.15-pvaClient-win64/ws/>
The recommended git tool is: NONE
No credentials specified
> C:/Program Files/Git/cmd/git.exe rev-parse --resolve-git-dir C:\jenkins\win64-2\workspace\3.15-pvaClient-win64\.git # timeout=10
Fetching changes from the remote Git repository
> C:/Program Files/Git/cmd/git.exe config remote.origin.url https://github.com/epics-base/pvaClientCPP.git # timeout=10
Cleaning workspace
> C:/Program Files/Git/cmd/git.exe rev-parse --verify HEAD # timeout=10
Resetting working tree
> C:/Program Files/Git/cmd/git.exe reset --hard # timeout=10
> C:/Program Files/Git/cmd/git.exe clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pvaClientCPP.git
> C:/Program Files/Git/cmd/git.exe --version # timeout=10
> git --version # 'git version 2.20.1.windows.1'
Setting http proxy: webproxy1.anl.gov:9091
> C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress -- https://github.com/epics-base/pvaClientCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
> C:/Program Files/Git/cmd/git.exe rev-parse "refs/remotes/origin/master^{commit}" # timeout=10
Checking out Revision 8ed07fef96e41d35d47ab61276e29eb1a81e7fec (refs/remotes/origin/master)
> C:/Program Files/Git/cmd/git.exe config core.sparsecheckout # timeout=10
> C:/Program Files/Git/cmd/git.exe checkout -f 8ed07fef96e41d35d47ab61276e29eb1a81e7fec # timeout=10
Commit message: "Set next development version"
> C:/Program Files/Git/cmd/git.exe rev-list --no-walk 8ed07fef96e41d35d47ab61276e29eb1a81e7fec # timeout=10
[3.15-pvaClient-win64] $ cmd /c call C:\Users\jenkins\AppData\Local\Temp\jenkins8812514954846063571.bat
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>SET TA=win64
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>SET BV=3.15.6
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>SET MO=-j4 -O --no-print-directory
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>SET WS=C:/Jenkins/win64-2/workspace
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>echo # RELEASE for jenkins-3.15-pvaClient-win64-379 1>configure/RELEASE
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>echo PVACCESS = C:/Jenkins/win64-2/workspace/3.15-pvAccess-win64 1>>configure/RELEASE
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>echo NORMATIVE = C:/Jenkins/win64-2/workspace/3.15-normativeTypes-win64 1>>configure/RELEASE
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>echo PVDATA = C:/Jenkins/win64-2/workspace/3.15-pvData-win64 1>>configure/RELEASE
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>echo EPICS_BASE = C:/epics/base-3.15.6 1>>configure/RELEASE
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>make -j4 -O --no-print-directory
make -C ./configure install
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/makeMakefile.pl O.windows-x64 ../..
perl -CSD -MExtUtils::Command -e mkpath O.Common
make -C O.windows-x64 -f ../Makefile TOP=../.. \
T_A=windows-x64 install
"Installing CFG file ../../cfg/CONFIG_PVACLIENT_VERSION"
mkdir ../../cfg
make -C ./src install
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientRPC.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientRPC.obj ../pvaClientRPC.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientNTMultiMonitor.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientNTMultiMonitor.obj ../pvaClientNTMultiMonitor.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientNTMultiGet.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientNTMultiGet.obj ../pvaClientNTMultiGet.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientNTMultiData.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientNTMultiData.obj ../pvaClientNTMultiData.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientNTMultiPut.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientNTMultiPut.obj ../pvaClientNTMultiPut.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientMultiMonitorDouble.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientMultiMonitorDouble.obj ../pvaClientMultiMonitorDouble.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientMultiPutDouble.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientMultiPutDouble.obj ../pvaClientMultiPutDouble.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientMultiGetDouble.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientMultiGetDouble.obj ../pvaClientMultiGetDouble.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientMultiChannel.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientMultiChannel.obj ../pvaClientMultiChannel.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientPutGet.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientPutGet.obj ../pvaClientPutGet.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientMonitor.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientMonitor.obj ../pvaClientMonitor.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientPut.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientPut.obj ../pvaClientPut.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientGet.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientGet.obj ../pvaClientGet.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientProcess.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientProcess.obj ../pvaClientProcess.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientChannel.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientChannel.obj ../pvaClientChannel.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientMonitorData.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientMonitorData.obj ../pvaClientMonitorData.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientGetData.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientGetData.obj ../pvaClientGetData.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientPutData.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientPutData.obj ../pvaClientPutData.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClientData.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClientData.obj ../pvaClientData.cpp
perl -CSD C:/epics/base-3.15.6/bin/windows-x64/mkmf.pl -m pvaClient.d -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/msvc -I../../include/os/WIN32 -I../../include -IC:/Jenkins/win64-2/workspace/3.15-pvAccess-win64/include -IC:/Jenkins/win64-2/workspace/3.15-pvData-win64/include -IC:/epics/base-3.15.6/include/compiler/msvc -IC:/epics/base-3.15.6/include/os/WIN32 -IC:/epics/base-3.15.6/include pvaClient.obj ../pvaClient.cpp
make[2]: *** No rule to make target '../../lib/windows-x64/nt.lib', needed by 'pvaClient.dll'. Stop.
make[2]: *** Waiting for unfinished jobs....
mkdir ../../include
mkdir ../../include/pv
make[1]: *** [C:/epics/base-3.15.6/configure/RULES_ARCHS:58: install.windows-x64] Error 2
make: *** [C:/epics/base-3.15.6/configure/RULES_DIRS:84: src.install] Error 2
C:\jenkins\win64-2\workspace\3.15-pvaClient-win64>exit 2
Build step 'Execute Windows batch command' marked build as failure
- Jenkins build is back to normal : 3.15-pvaClient-win64 #380 APS Jenkins via Core-talk
Jenkins build is back to normal : 3.15-pva2pva-win64 #343 APS Jenkins via Core-talk
Jenkins build is back to normal : 3.15-pva2pva-win64s #332 APS Jenkins via Core-talk
<2021>
2025
2026
Jenkins build is back to normal : 3.15-normativeTypes-win64s #171 APS Jenkins via Core-talk
<2021>
2025
2026
