2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: epics-pvaPy-linux32 #955
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 1 Dec 2021 15:54:19 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/955/display/redirect?page=changes>
Changes:
[Veseli, Sinisa] add utility method
[Veseli, Sinisa] add distributor plugin prototype
[Veseli, Sinisa] update default base version
[...truncated 5.55 KB...]
checking for boost... yes
checking for boost python... yes
checking for boost python numpy... no
checking for boost numpy... no
checking for python development library... yes
checking for epics base... yes
checking for epics4... yes
configure: Determined BOOST_PYTHON_NUMPY_CPPFLAGS:
configure: Determined BOOST_PYTHON_NUMPY_LDFLAGS:
configure: Determined BOOST_NUMPY_CPPFLAGS:
configure: Determined BOOST_NUMPY_LDFLAGS:
configure: Determined BOOST_CPPFLAGS: -I/usr/include
configure: Determined BOOST_LDFLAGS: -L/usr/lib
configure: Determined PYTHON_CPPFLAGS: -I/usr/include/python2.6
configure: Determined PYTHON_LDFLAGS: -L/usr/lib -lpython2.6
configure: Determined PVAPY_CPPFLAGS: -I/usr/include -I/usr/include/python2.6
configure: Determined PVAPY_LDFLAGS: -L/usr/lib -lpython2.6
configure: Determined PVAPY_LD_LIBRARY_PATH: /usr/lib
configure: Created <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/configure/RELEASE.local> file
configure: Created <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/configure/CONFIG_SITE.local> file
configure: Created <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/bin/linux-x86/pvapy_setup_pythonpath.2.6.sh> file
configure: Created <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/bin/linux-x86/pvapy_setup_full.2.6.sh> file
configure: Created <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/bin/linux-x86/pvapy_setup_pythonpath.2.6.csh> file
configure: Created <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/bin/linux-x86/pvapy_setup_full.2.6.csh> file
+ make -j4
make -C ./configure install
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/configure'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/bin/linux-x86/makeMakefile.pl> O.linux-x86 ../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../.. \
    T_A=linux-x86 install
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/configure/O.linux-x86'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/bin/linux-x86/convertRelease.pl> checkRelease
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/configure/O.linux-x86'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/configure'>
make -C ./src install
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/src'>
make -C ./pvaccess install
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/src/pvaccess'>
perl -CSD <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/bin/linux-x86/makeMakefile.pl> O.linux-x86 ../../..
mkdir -p O.Common
make -C O.linux-x86 -f ../Makefile TOP=../../.. \
make[3]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/src/pvaccess/O.linux-x86'>
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PyPvRecord.d  ../PyPvRecord.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvaServer.d  ../PvaServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvaServer.d  ../pvaccess.PvaServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF StringUtility.d  ../StringUtility.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF RpcTimeout.d  ../RpcTimeout.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF RpcServer.d  ../RpcServer.cpp
In file included from ../PvaServer.h:14,
                 from ../pvaccess.PvaServer.cpp:7:
../PyPvRecord.h:12:27: error: pv/pvDatabase.h: No such file or directory
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF RpcServiceImpl.d  ../RpcServiceImpl.cpp
../PvaServer.cpp:8:37: error: pv/channelProviderLocal.h: No such file or directory
In file included from ../PyPvRecord.cpp:5:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF RpcClient.d  ../RpcClient.cpp
                 from ../PvaServer.cpp:13:
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF RequesterImpl.d  ../RequesterImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PyUtility.d  ../PyUtility.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PyPvDataUtility.d  ../PyPvDataUtility.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PyGilManager.d  ../PyGilManager.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvValueAlarm.d  ../PvValueAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvUtility.d  ../PvUtility.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvUShort.d  ../PvUShort.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvUnion.d  ../PvUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvULong.d  ../PvULong.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvUInt.d  ../PvUInt.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvUByte.d  ../PvUByte.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvTimeStamp.d  ../PvTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvString.d  ../PvString.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvShort.d  ../PvShort.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvScalarArray.d  ../PvScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvScalar.d  ../PvScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvProvider.d  ../PvProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvObject.d  ../PvObject.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvLong.d  ../PvLong.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvInt.d  ../PvInt.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvFloat.d  ../PvFloat.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvDouble.d  ../PvDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvDisplay.d  ../PvDisplay.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvDimension.d  ../PvDimension.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvControl.d  ../PvControl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvCodec.d  ../PvCodec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvByte.d  ../PvByte.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvBoolean.d  ../PvBoolean.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvAlarm.d  ../PvAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvaPyLogger.d  ../PvaPyLogger.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvaExceptionTranslator.d  ../PvaExceptionTranslator.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvaException.d  ../PvaException.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvaConstants.d  ../PvaConstants.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF PvaClient.d  ../PvaClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF ObjectNotFound.d  ../ObjectNotFound.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF ObjectAlreadyExists.d  ../ObjectAlreadyExists.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF NtType.d  ../NtType.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF NtTable.d  ../NtTable.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF NtScalar.d  ../NtScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF NtNdArray.d  ../NtNdArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF NtAttribute.d  ../NtAttribute.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF MultiChannel.d  ../MultiChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF InvalidState.d  ../InvalidState.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF InvalidRequest.d  ../InvalidRequest.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF InvalidDataType.d  ../InvalidDataType.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF InvalidArgument.d  ../InvalidArgument.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF GetFieldRequesterImpl.d  ../GetFieldRequesterImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF FieldNotFound.d  ../FieldNotFound.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF DataDistributorPlugin.d  ../DataDistributorPlugin.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF ChannelTimeout.d  ../ChannelTimeout.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF ChannelRequesterImpl.d  ../ChannelRequesterImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF ChannelPutRequesterImpl.d  ../ChannelPutRequesterImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF ChannelMonitorRequesterImpl.d  ../ChannelMonitorRequesterImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF ChannelGetRequesterImpl.d  ../ChannelGetRequesterImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF Channel.d  ../Channel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF CaClient.d  ../CaClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.ScalarArrayPyOwner.d  ../pvaccess.ScalarArrayPyOwner.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.RpcServer.d  ../pvaccess.RpcServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.RpcClient.d  ../pvaccess.RpcClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.MultiChannel.d  ../pvaccess.MultiChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.Channel.d  ../pvaccess.Channel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.NtType.d  ../pvaccess.NtType.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.NtTable.d  ../pvaccess.NtTable.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.NtScalar.d  ../pvaccess.NtScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.NtNdArray.d  ../pvaccess.NtNdArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.NtAttribute.d  ../pvaccess.NtAttribute.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvValueAlarm.d  ../pvaccess.PvValueAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvTimeStamp.d  ../pvaccess.PvTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvDisplay.d  ../pvaccess.PvDisplay.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvDimension.d  ../pvaccess.PvDimension.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvControl.d  ../pvaccess.PvControl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvCodec.d  ../pvaccess.PvCodec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvAlarm.d  ../pvaccess.PvAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvUnion.d  ../pvaccess.PvUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvScalarArray.d  ../pvaccess.PvScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvString.d  ../pvaccess.PvString.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvDouble.d  ../pvaccess.PvDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvFloat.d  ../pvaccess.PvFloat.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvULong.d  ../pvaccess.PvULong.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvLong.d  ../pvaccess.PvLong.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvUInt.d  ../pvaccess.PvUInt.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvInt.d  ../pvaccess.PvInt.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvUShort.d  ../pvaccess.PvUShort.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvShort.d  ../pvaccess.PvShort.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvUByte.d  ../pvaccess.PvUByte.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvByte.d  ../pvaccess.PvByte.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvBoolean.d  ../pvaccess.PvBoolean.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvScalar.d  ../pvaccess.PvScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvObject.d  ../pvaccess.PvObject.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvProvider.d  ../pvaccess.PvProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.PvType.d  ../pvaccess.PvType.cpp
perl -p -e "s?PVAPY_VERSION?4.0.3?g" ../../../src/pvaccess/pvaccess.constants.cpp.template > pvaccess.constants.cpp
perl -p -e "s?version =.*?version = \"4.0.3\"?g" ../../../documentation/sphinx/conf.py > ../../../documentation/sphinx/conf.py.2
perl -p -e "s?release =.*?release = \"4.0.3\"?g" ../../../documentation/sphinx/conf.py.2 > ../../../documentation/sphinx/conf.py
rm -f ../../../documentation/sphinx/conf.py.2
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.d  ../pvaccess.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -MM -MF pvaccess.constants.d  pvaccess.constants.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c pvaccess.constants.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvType.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvProvider.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvObject.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvBoolean.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvByte.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvUByte.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvShort.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvUShort.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvInt.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvUInt.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvLong.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvULong.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvFloat.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvDouble.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvString.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvScalarArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvUnion.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvCodec.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvControl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvDimension.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvDisplay.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvTimeStamp.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.PvValueAlarm.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.NtAttribute.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.NtNdArray.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.NtScalar.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.NtTable.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.NtType.cpp
../pvaccess.PvObject.cpp: In function ���void wrapPvObject()���:
../pvaccess.PvObject.cpp:17: note: variable tracking size limit exceeded with -fvar-tracking-assignments, retrying without
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.Channel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.MultiChannel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.RpcClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.RpcServer.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../pvaccess.ScalarArrayPyOwner.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../CaClient.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../Channel.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../ChannelGetRequesterImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../ChannelMonitorRequesterImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../ChannelPutRequesterImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../ChannelRequesterImpl.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../ChannelTimeout.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../DataDistributorPlugin.cpp
In file included from ../DataDistributorPlugin.cpp:13:
../DataDistributorPlugin.h:13:25: error: pv/pvPlugin.h: No such file or directory
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../FieldNotFound.cpp
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_  -DUNIX  -Dlinux     -O3 -g   -Wall     -DPVA_API_VERSION=480 -DPVA_RPC_API_VERSION=480 -DHAVE_BOOST_NUMPY=0 -DHAVE_BOOST_PYTHON_NUMPY=0 -I/usr/include -I/usr/include/python2.6  -mtune=generic     -m32 -D_FILE_OFFSET_BITS=64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvaClientCPP/include>      -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/normativeTypesCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvAccessCPP/include>   -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/pvDataCPP/include> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/compiler/gcc> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include/os/Linux> -I<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/include>        -c ../GetFieldRequesterImpl.cpp
../DataDistributorPlugin.h:85: error: expected class-name before ���{��� token
../DataDistributorPlugin.h:103: error: ���PVFilterPtr��� does not name a type
../DataDistributorPlugin.h:118: error: expected class-name before ���{��� token
../DataDistributorPlugin.h:129: error: expected unqualified-id before ���&��� token
../DataDistributorPlugin.h:129: error: expected ���)��� before ���&��� token
../DataDistributorPlugin.h:129: error: expected ���;��� before ���&��� token
../DataDistributorPlugin.h:143: error: ISO C++ forbids declaration of ���PVCopyPtr��� with no type
../DataDistributorPlugin.h:143: error: expected ���,��� or ���...��� before ���&��� token
../DataDistributorPlugin.cpp: In static member function ���static bool epics::pvCopy::DataDistributorPlugin::initialize()���:
../DataDistributorPlugin.cpp:195: error: ���PVPluginRegistry��� has not been declared
../DataDistributorPlugin.cpp: At global scope:
../DataDistributorPlugin.cpp:199: error: ���PVFilterPtr��� does not name a type
../DataDistributorPlugin.cpp:214: error: ISO C++ forbids declaration of ���PVCopyPtr��� with no type
../DataDistributorPlugin.cpp:214: error: expected ���,��� or ���...��� before ���&��� token
../DataDistributorPlugin.cpp: In static member function ���static epics::pvCopy::DataDistributorFilterPtr epics::pvCopy::DataDistributorFilter::create(const std::string&, int)���:
../DataDistributorPlugin.cpp:261: error: ���master��� was not declared in this scope
../DataDistributorPlugin.cpp:261: error: expected primary-expression before ���(��� token
../DataDistributorPlugin.cpp:261: error: expected primary-expression before ���,��� token
../DataDistributorPlugin.cpp:265: error: ISO C++ forbids declaration of ���PVCopyPtr��� with no type
../DataDistributorPlugin.cpp:265: error: expected ���,��� or ���...��� before ���&��� token
../DataDistributorPlugin.cpp:265: error: prototype for ���epics::pvCopy::DataDistributorFilter::DataDistributorFilter(int, const std::string&, const std::string&, int, int, int)��� does not match any in class ���epics::pvCopy::DataDistributorFilter���
../DataDistributorPlugin.h:118: error: candidates are: epics::pvCopy::DataDistributorFilter::DataDistributorFilter(const epics::pvCopy::DataDistributorFilter&)
../DataDistributorPlugin.h:118: error:                 epics::pvCopy::DataDistributorFilter::DataDistributorFilter()
<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/configure/RULES_BUILD>:242: recipe for target 'DataDistributorPlugin.o' failed
make[3]: *** [DataDistributorPlugin.o] Error 1
make[3]: *** Waiting for unfinished jobs....
../pvaccess.Channel.cpp: In function ���void wrapChannel()���:
../pvaccess.Channel.cpp:17: note: variable tracking size limit exceeded with -fvar-tracking-assignments, retrying without
make[3]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/src/pvaccess/O.linux-x86'>
<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/configure/RULES_ARCHS>:58: recipe for target 'install.linux-x86' failed
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/src/pvaccess'>
<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/configure/RULES_DIRS>:84: recipe for target 'pvaccess.install' failed
make[1]: *** [pvaccess.install] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/src'>
<https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/epics/base/configure/RULES_DIRS>:84: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Build step 'Execute shell' marked build as failure
Build failed in Jenkins: epics-pvaPy-linux32 #956 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-pvaPy #922 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-pvaPy #923 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Jenkins build is back to normal : epics-pvaPy #925 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-pvaPy-linux32 #956 APS Jenkins via Core-talk
ANJ, 06 Dec 2021 · Home · News · About · Talk · Base · Modules · Extensions ·
