See <https://jenkins.aps.anl.gov/job/epics-pvData/380/display/redirect?page=changes>
Changes:
[Michael Davidsaver] printJSON() use yajl_gen
[Michael Davidsaver] .ci: update
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building on the built-in node in workspace <https://jenkins.aps.anl.gov/job/epics-pvData/ws/>
The recommended git tool is: NONE
No credentials specified
> git rev-parse --resolve-git-dir <https://jenkins.aps.anl.gov/job/epics-pvData/ws/.git> # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://github.com/epics-base/pvDataCPP.git # timeout=10
Cleaning workspace
> git rev-parse --verify HEAD # timeout=10
Resetting working tree
> git reset --hard # timeout=10
> git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pvDataCPP.git
> git --version # timeout=10
> git --version # 'git version 1.8.3.1'
Setting http proxy: webproxy1.anl.gov:9091
> git fetch --tags --progress https://github.com/epics-base/pvDataCPP.git +refs/heads/*:refs/remotes/origin/* # timeout=10
> git rev-parse refs/remotes/origin/master^{commit} # timeout=10
Checking out Revision 8039c75b3e776ace5a0982b0c68d5e655343ddf9 (refs/remotes/origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f 8039c75b3e776ace5a0982b0c68d5e655343ddf9 # timeout=10
Commit message: ".ci: update"
> git rev-list --no-walk d3b4976ea2b0d78075511f14d7f7bf9620dd4d14 # timeout=10
[workspace] $ /bin/sh -xe /tmp/jenkins4071482910730189889.sh
+ echo 'PVCOMMON = /Jenkins/jenkins/jobs/epics-pvCommon/workspace'
+ echo 'EPICS_BASE = /Jenkins/jenkins/jobs/epics-base-3.16/workspace'
+ make linux-x86_64
make -C ./configure linux-x86_64
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvData/ws/configure'>
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir -p O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. T_A=linux-x86_64
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvData/ws/configure/O.linux-x86_64'>
Installing CFG file ../../cfg/CONFIG_PVDATA_VERSION
mkdir ../../cfg
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvData/ws/configure/O.linux-x86_64'>
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvData/ws/configure'>
make -C ./src linux-x86_64
make[1]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvData/ws/src'>
mkdir -p O.Common
make[2]: Entering directory '<https://jenkins.aps.anl.gov/job/epics-pvData/ws/src/O.linux-x86_64'>
mkdir -p ../O.Common/pv
perl -CSD /Jenkins/jenkins/jobs/epics-base-3.16/workspace/bin/linux-x86_64/expandVars.pl -DEPICS_PVD_MAJOR_VERSION="8" -DEPICS_PVD_MINOR_VERSION="0" -DEPICS_PVD_MAINTENANCE_VERSION="5" -DEPICS_PVD_DEVELOPMENT_FLAG="1" -t ../.. -a linux-x86_64 ../pv/pvdVersionNum.h@ ../O.Common/pv/pvdVersionNum.h
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF print.d ../../src/json/print.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF parseinto.d ../../src/json/parseinto.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF parseany.d ../../src/json/parseany.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF parsehelper.d ../../src/json/parsehelper.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF bitSetUtil.d ../../src/pvMisc/bitSetUtil.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF requestmapper.d ../../src/copy/requestmapper.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF createRequest.d ../../src/copy/createRequest.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF pvTimeStamp.d ../../src/property/pvTimeStamp.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF timeStamp.d ../../src/property/timeStamp.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF pvEnumerated.d ../../src/property/pvEnumerated.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF pvDisplay.d ../../src/property/pvDisplay.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF pvControl.d ../../src/property/pvControl.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF pvAlarm.d ../../src/property/pvAlarm.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF alarm.d ../../src/property/alarm.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF printer.d ../../src/factory/printer.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF StandardPVField.d ../../src/factory/StandardPVField.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF StandardField.d ../../src/factory/StandardField.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF Compare.d ../../src/factory/Compare.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF pvSubArrayCopy.d ../../src/factory/pvSubArrayCopy.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF Convert.d ../../src/factory/Convert.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF PVDataCreateFactory.d ../../src/factory/PVDataCreateFactory.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF PVUnionArray.d ../../src/factory/PVUnionArray.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF PVUnion.d ../../src/factory/PVUnion.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF PVStructureArray.d ../../src/factory/PVStructureArray.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF PVStructure.d ../../src/factory/PVStructure.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF PVScalarArray.d ../../src/factory/PVScalarArray.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF PVArray.d ../../src/factory/PVArray.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF PVScalar.d ../../src/factory/PVScalar.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF PVField.d ../../src/factory/PVField.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF FieldCreateFactory.d ../../src/factory/FieldCreateFactory.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF TypeFunc.d ../../src/factory/TypeFunc.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF valueBuilder.d ../../src/pv/valueBuilder.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF pvdVersion.d ../../src/pv/pvdVersion.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF anyscalar.d ../../src/misc/anyscalar.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF reftrack.d ../../src/misc/reftrack.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF debugPtr.d ../../src/misc/debugPtr.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF pvUnitTest.d ../../src/misc/pvUnitTest.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF parseToPOD.d ../../src/misc/parseToPOD.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF thread.d ../../src/misc/thread.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF typeCast.d ../../src/misc/typeCast.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF status.d ../../src/misc/status.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF timer.d ../../src/misc/timer.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF event.d ../../src/misc/event.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF serializeHelper.d ../../src/misc/serializeHelper.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF epicsException.d ../../src/misc/epicsException.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF bitSet.d ../../src/misc/bitSet.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -MM -MF byteBuffer.d ../../src/misc/byteBuffer.cpp
Installing generic include file ../../include/pv/noDefaultMethods.h
mkdir ../../include
mkdir ../../include/pv
Installing generic include file ../../include/pv/lock.h
Installing generic include file ../../include/pv/serialize.h
Installing generic include file ../../include/pv/bitSet.h
Installing generic include file ../../include/pv/byteBuffer.h
Installing generic include file ../../include/pv/epicsException.h
Installing generic include file ../../include/pv/serializeHelper.h
Installing generic include file ../../include/pv/event.h
Installing generic include file ../../include/pv/thread.h
Installing generic include file ../../include/pv/timer.h
Installing generic include file ../../include/pv/status.h
Installing generic include file ../../include/pv/sharedPtr.h
Installing generic include file ../../include/pv/debugPtr.h
Installing generic include file ../../include/pv/typeCast.h
Installing generic include file ../../include/pv/sharedVector.h
Installing generic include file ../../include/pv/templateMeta.h
Installing generic include file ../../include/pv/current_function.h
Installing generic include file ../../include/pv/pvUnitTest.h
Installing generic include file ../../include/pv/reftrack.h
Installing generic include file ../../include/pv/anyscalar.h
Installing generic include file ../../include/pv/pvType.h
Installing generic include file ../../include/pv/pvIntrospect.h
Installing generic include file ../../include/pv/valueBuilder.h
Installing generic include file ../../include/pv/pvData.h
Installing generic include file ../../include/pv/convert.h
Installing generic include file ../../include/pv/standardField.h
Installing generic include file ../../include/pv/standardPVField.h
Installing generic include file ../../include/pv/pvSubArrayCopy.h
Installing generic include file ../../include/pv/typemap.h
Installing generic include file ../../include/pv/pvdVersion.h
Installing generated generic include file ../../include/pv/pvdVersionNum.h
Installing generic include file ../../include/pv/factory.h
Installing generic include file ../../include/pv/alarm.h
Installing generic include file ../../include/pv/pvAlarm.h
Installing generic include file ../../include/pv/control.h
Installing generic include file ../../include/pv/pvControl.h
Installing generic include file ../../include/pv/display.h
Installing generic include file ../../include/pv/pvDisplay.h
Installing generic include file ../../include/pv/pvEnumerated.h
Installing generic include file ../../include/pv/timeStamp.h
Installing generic include file ../../include/pv/pvTimeStamp.h
Installing generic include file ../../include/pv/createRequest.h
Installing generic include file ../../include/pv/bitSetUtil.h
Installing generic include file ../../include/pv/json.h
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/byteBuffer.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/bitSet.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/epicsException.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/serializeHelper.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/event.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/timer.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/status.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/typeCast.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/thread.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/parseToPOD.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/pvUnitTest.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/debugPtr.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/reftrack.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/misc/anyscalar.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/pv/pvdVersion.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/pv/valueBuilder.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/TypeFunc.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/FieldCreateFactory.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/PVField.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/PVScalar.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/PVArray.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/PVScalarArray.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/PVStructure.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/PVStructureArray.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/PVUnion.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/PVUnionArray.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/PVDataCreateFactory.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/Convert.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/pvSubArrayCopy.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/Compare.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/StandardField.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/StandardPVField.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/factory/printer.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/property/alarm.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/property/pvAlarm.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/property/pvControl.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/property/pvDisplay.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/property/pvEnumerated.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/property/timeStamp.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/property/pvTimeStamp.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/copy/createRequest.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/copy/requestmapper.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/pvMisc/bitSetUtil.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/json/parsehelper.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/json/parseany.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/json/parseinto.cpp
/usr/bin/g++ -D_GNU_SOURCE -D_DEFAULT_SOURCE -DPVD_INTERNAL -D_X86_64_ -DUNIX -Dlinux -O3 -g -Wall -mtune=generic -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../src/misc -I../../src/pv -I../../src/factory -I../../src/property -I../../src/copy -I../../src/pvMisc -I../../src/json -I../../include/compiler/gcc -I../../include/os/Linux -I../../include -I/Jenkins/jenkins/jobs/epics-pvCommon/workspace/include -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/compiler/gcc -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include/os/Linux -I/Jenkins/jenkins/jobs/epics-base-3.16/workspace/include -c ../../src/json/print.cpp
../../src/json/print.cpp: In constructor ‘{anonymous}::args::args(std::ostream&, const epics::pvData::JSONPrintOptions&)’:
../../src/json/print.cpp:87:33: error: ‘yajl_gen_json5’ was not declared in this scope
yajl_gen_config(handle, yajl_gen_json5, (int)opts.json5);
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_BUILD:242: recipe for target 'print.o' failed
make[2]: *** [print.o] Error 1
make[2]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvData/ws/src/O.linux-x86_64'>
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_ARCHS:62: recipe for target 'linux-x86_64' failed
make[1]: *** [linux-x86_64] Error 2
make[1]: Leaving directory '<https://jenkins.aps.anl.gov/job/epics-pvData/ws/src'>
/Jenkins/jenkins/jobs/epics-base-3.16/workspace/configure/RULES_DIRS:84: recipe for target 'src.linux-x86_64' failed
make: *** [src.linux-x86_64] Error 2
Build step 'Execute shell' marked build as failure
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.linux-x86_64/*.tap
Did not find any matching files.
- Jenkins build is back to normal : epics-pvData #381 APS Jenkins via Core-talk
Build failed in Jenkins: epics-example-linux32 #890 APS Jenkins via Core-talk
Re: Windows builds — can anyone explain this? Johnson, Andrew N. via Core-talk
<2022>
2025
2026
Jenkins build is back to normal : epics-example-linux32 #891 APS Jenkins via Core-talk
<2022>
2025
2026
