2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-7 #396
From: Jenkins EPICS PSI via Core-talk <core-talk at aps.anl.gov>
To: <dirk.zimoch at psi.ch>, <core-talk at aps.anl.gov>
Date: Fri, 28 Jan 2022 20:28:43 +0100
See <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/396/display/redirect?page=changes>
Changes:
[mdavidsaver] yajl: doc
Started by an SCM change
Building in workspace <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://github.com/epics-base/epics-base.git
 > git init <http://gfa-sls2-test.psi.ch:8080/job/EPICS-7/ws/> # timeout=10
Fetching upstream changes from https://github.com/epics-base/epics-base.git
 > git --version # timeout=10
 > git fetch --tags --progress https://github.com/epics-base/epics-base.git +refs/heads/*:refs/remotes/origin/*
 > git config remote.origin.url https://github.com/epics-base/epics-base.git # timeout=10
 > git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
 > git rev-parse origin/7.0^{commit} # timeout=10
Checking out Revision d9fd73a850b8cf21ac58872ded9a1763d68574af (origin/7.0)
 > git config core.sparsecheckout # timeout=10
 > git checkout -f d9fd73a850b8cf21ac58872ded9a1763d68574af
Commit message: "yajl: doc"
 > git rev-list --no-walk d508962211b0fe2a838e3d492e43e405cd965b8e # timeout=10
 > git remote # timeout=10
 > git submodule init # timeout=10
 > git submodule sync # timeout=10
 > git config --get remote.origin.url # timeout=10
 > git config -f .gitmodules --get-regexp ^submodule\.(.+)\.url # timeout=10
 > git config --get submodule.modules/pvData.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvData.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvData
 > git config --get submodule.modules/pvAccess.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvAccess.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvAccess
 > git config --get submodule.modules/normativeTypes.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/normativeTypes.path # timeout=10
 > git submodule update --init --recursive --remote modules/normativeTypes
 > git config --get submodule.modules/pvaClient.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvaClient.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvaClient
 > git config --get submodule.modules/pvDatabase.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pvDatabase.path # timeout=10
 > git submodule update --init --recursive --remote modules/pvDatabase
 > git config --get submodule.modules/pva2pva.url # timeout=10
 > git config -f .gitmodules --get submodule.modules/pva2pva.path # timeout=10
 > git submodule update --init --recursive --remote modules/pva2pva
 > git config --get submodule..ci.url # timeout=10
 > git config -f .gitmodules --get submodule..ci.path # timeout=10
 > git submodule update --init --recursive --remote .ci
[EPICS-7] $ /bin/sh -xe /tmp/jenkins7427453197749161397.sh
+ git describe --always --long --dirty --tags
R7.0.6.1-61-gd9fd73a-dirty
+ patch -p1
/tmp/jenkins7427453197749161397.sh: line 3: /net/sls-hafs/export/exchange/home/zimoch/epics/PSIconfig-7.patch: No such file or directory
Build step 'Execute shell' marked build as failure
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : EPICS-7 #397 Jenkins EPICS PSI via Core-talk
Build failed in Jenkins: EPICS-7 #395 Jenkins EPICS PSI via Core-talk
Prev: RE: Windows builds — can anyone explain this? Freddie Akeroyd - STFC UKRI via Core-talk
Next: [Bug 1959457] [NEW] pvget/pvput for aai/aao record types, with data type=enum, wrong results Jerzy Tarasiuk via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Build failed in Jenkins: EPICS-7 #395 Jenkins EPICS PSI via Core-talk
Next: Jenkins build is back to normal : EPICS-7 #397 Jenkins EPICS PSI via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
