2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Definition (or not) of alarm limits
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: Timo Korhonen <Timo.Korhonen at ess.eu>
Cc: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 8 Mar 2022 08:11:11 -0800
On 3/8/22 00:39, Timo Korhonen via Core-talk wrote:
Hi all,
We noticed recently that if for instance the lower alarm limits are not explicitly defined in the EPICS database, CS-Studio reports all limits to be NaN. See here https://github.com/ControlSystemStudio/cs-studio/issues/2716 <https://github.com/ControlSystemStudio/cs-studio/issues/2716> for a description and a following discussion.
Kay pointed out that even when the limits are explicitly defined as 0, the IOC reports them as NaN. Now this starts to smell like a bug. But before I submit a bug report, I wanted to ask if there is a reason behind this behavior? Maybe it is a feature and not a bug?
The code in question (for aiRecord) seems reasonably clear.
Defining a level without a severity (implicitly NO_ALARM) isn't meaningful.
        pad->upper_alarm_limit = prec->hhsv ? prec->hihi : epicsNAN;
        pad->upper_warning_limit = prec->hsv ? prec->high : epicsNAN;
        pad->lower_warning_limit = prec->lsv ? prec->low : epicsNAN;
        pad->lower_alarm_limit = prec->llsv ? prec->lolo : epicsNAN;
https://github.com/epics-base/epics-base/blob/91941af992f6c32ef4f4ef55a2952f581aeee36a/modules/database/src/std/rec/aiRecord.c#L295-L298
There is another interesting case, described by Kay in the above issue report, when only one HIGH and not HIHI is defined. How should this case be interpreted? The “Process Database Concepts” documentation ( https://docs.epics-controls.org/en/latest/guides/EPICS_Process_Database_Concepts.html#alarm-conditions-configured-in-the-database <https://docs.epics-controls.org/en/latest/guides/EPICS_Process_Database_Concepts.html#alarm-conditions-configured-in-the-database> ) indicates that the alarm limits express a range, however not very explicitly. But this is not consistent with this case.
Any thoughts?
Timo
Re: Definition (or not) of alarm limits Timo Korhonen via Core-talk
Prev: Re: Definition (or not) of alarm limits Andrew Johnson via Core-talk
Next: Re: Definition (or not) of alarm limits Timo Korhonen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
