2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: unknown type name 'DBLINK'
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 14 Mar 2022 12:07:26 -0500
Hello Heinz,
That looks like great news. Will you be submitting a PR for any EPICS changes needed to build against RTEMS-6?
While we're adding support for these OS versions and BSPs we should document for each RTEMS BSP exactly how to configure the board to load and boot the OS, along with any specific instructions for configuring the build. Exactly where that information is published isn't particularly important as long as we make it easy to find.
- Andrew
On 3/12/22 2:32 PM, Heinz Junkes via Core-talk wrote:
MVME6100> tftpGet -a04000000 -c141.14.139.12 -s141.14.131.192 -m255.255.240.0 -g141.14.128.128 -flibComTestHarness.boot
Network Loading from: /dev/enet0
Loading File: libComTestHarness.boot
Load Address: 04000000
Download Buffer Size = User Defined
Client IP Address      = 141.14.139.12
Server IP Address      = 141.14.131.192
Gateway IP Address     = 141.14.128.128
Subnet IP Address Mask = 255.255.240.0
Network File Load in Progress...
Bytes Received =&6617180, Bytes Loaded =&6617180
Bytes/Second   =&3308590, Elapsed Time =2 Second(s)
MVME6100> waitProbe
System I/O Probe Complete
MVME6100> netShut
/dev/-----------------------------------------
config addr is 0xf1000cf8
config data is 0xf1000cfc
Welcome to RTEMS rtems-6.0.0 (PowerPC/Generic (classic FPU)/beatnik)
CPU: MPC7457
Board Type: MVME6100-0163 (S/N D00967A)
Bus Clock Freq:   133333333 Hz
CPU Clock Freq:  1266666654 Hz
Memory:           536870912 bytes
Now BSP_mem_size = 0x1fe00000
Configuration.work_space_size = 2033c50
Page table setup finished; will activate it NOW...
Going to start PCI buses scanning and initialization
Number of PCI buses found is : 3
MSR 0x2003032
Exit from bspstart
unable to find the universe in pci config space
Tundra Tsi148 PCI-VME bridge detected at 0x81100000, IRQ 84
Tsi148 Outbound Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0e000000 0x90000000 A32, SUP, D32, SCT
1:    0x00000000 0x00ff0000 0x9f000000 A24, SUP, D32, SCT
2:    0x00000000 0x00010000 0x9fff0000 A16, SUP, D32, SCT
7:    0x00000000 0x01000000 0x9e000000 CSR, SUP, D32, SCT
Tsi148 Inbound Ports:
0:    0x90000000 0x1fe00000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
vmeTsi148 IRQ manager: looking for registers on VME...
Trying to find CSR on VME...
vmeTsi148 - IRQ manager using VME CSR to flush FIFO
Registering /dev/console as minor 0 (==/dev/ttyS0)
WARNING: OS Clock time was read before being set.
Using 1990-01-
0 2i n0i0t:C0o0n:s0o0l.e0 0-0-0-0 0I nUfToC
stdin: fileno: 0, ttyname: /dev/console
stdout: fileno: 1, ttyname: /dev/console
stderr: fileno: 2, ttyname: /dev/console
time set to : 04/14/14 07:30:06.000001229 UTC
Startup.
epicsThreadSetPriority called by non epics thread
***** RTEMS Version: rtems-6.0.0 (PowerPC/Generic (classic FPU)/beatnik) *****
***** Initializing network (libbsd, dhcpcd) *****
nexus0: <RTEMS Nexus device>
mve0 on nexus0
miibus0: <MII bus> on mve0
ukphy0: <Generic IEEE 802.3u media interface> PHY 0 on miibus0
ukphy0:  none, 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, auto
info: mve0: Ethernet address: ec:9e:cd:23:c8:41
***** ifconfig lo0 *****
info: lo0: link state changed to UP
***** add dhcpcd hook *****
***** Start default network dhcpcd *****
--Info (hpj)-- bsd task prio IRQS: 96  -----
i
--Info (hpj)-- bsd task prio TIME: 98  -----
n
 ---- Waiting for DHCP ...
fo: version 6.2.1 starting
info: mve0: link state changed to DOWN
debug: mve0: executing `ioc boot' PREINIT
dhcpcd ---> 'interface=mve0'
  'interface' = 'mve0'
dhcpcd ---> 'reason=PREINIT'
  'reason' = 'PREINIT'
dhcpcd ---> 'pid=1'
dhcpcd ---> 'ifmetric=201'
dhcpcd ---> 'ifwireless=0’
   EPICS Test Harness Results
All tests successful.
Programs=38, Tests=3128, 355 wallclock secs
On 12. Mar 2022, at 20:45, Michael Davidsaver <mdavidsaver at gmail.com> wrote:
On 3/12/22 11:24, Heinz Junkes wrote:
Bull's eye
I could have thought of it myself ;-(
more ./rtems/6/powerpc-rtems6/beatnik/lib/include/link.h
Ok.  So the first '-I'
.../powerpc-rtems6-gcc  -fasm  -I/home/rtems/MVME6100_WORK/rtems/6/powerpc-rtems6/beatnik/lib/include ...
needs to be shifted to the end, or included with '-isystem /...'.
https://gcc.gnu.org/onlinedocs/gcc/Directory-Options.html
Complexity comes for free, Simplicity you have to work for.
Re: unknown type name 'DBLINK' Heinz Junkes via Core-talk
Re: unknown type name 'DBLINK' Michael Davidsaver via Core-talk
Prev: Re: unknown type name 'DBLINK' Heinz Junkes via Core-talk
Next: Re: unknown type name 'DBLINK' Heinz Junkes via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
