2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: [Bug 1971737] Re: EPICS 3.13 clients cannot connect to EPICS 7 or 3.16
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Thu, 05 May 2022 21:49:21 -0000
The 3.13 IOCs are very old MV2300s with only 32MB RAM of which 28 are in use. The larger record size in 3.14+ is overloading them. There are plans to remove them in the SLS-2 upgrade in a few years, so nobody is interested to upgrade their hardware right now. But I would like to migrate as many other IOCs from 3.14 to 7 before the SLS-2 upgrade.
I was thinking of reverting those parts of your modifications that prevent the 3.13 IOCs from connecting. The commit message suggests that it was not your intention to remove support for 3.13 clients but for much older versions (3.12? 2.x?).
I consider doing that during the codeathon.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1971737
Title:
Status in EPICS Base:
  New
Bug description:
  Since commit 95fd255d "rsrv: ignore CA client version older than v4.4"
  from Jul 30 2016, EPICS 3.13 clients cannot connect any more, even
  though their CA version is V4.8.
  The reason is that camessage drops the incoming CA_PROTO_SEARCH
  messages because the 3.13 client has not yet sent a CA_PROTO_VERSION
  message and thus the code reads client->minor_version_number as 0.
  This is a huge hindrance for upgrading 3.14 IOCs to EPICS 7 when there
  are still 3.13 IOC (which cannot be upgraded yet) in the network which
  need to connect.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1971737/+subscriptions
[Bug 1971737] [NEW] EPICS 3.13 clients cannot connect to EPICS 7 or 3.16 Dirk Zimoch via Core-talk
Prev: [Bug 1971737] Re: EPICS 3.13 clients cannot connect to EPICS 7 or 3.16 mdavidsaver via Core-talk
Next: [Bug 1971737] Re: EPICS 3.13 clients cannot connect to EPICS 7 or 3.16 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
