2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: [Bug 1971737] Re: EPICS 3.13 clients cannot connect to EPICS 7 or 3.16
From: mdavidsaver via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Fri, 06 May 2022 15:16:54 -0000
> ... I have no package capture but I have added printf debugging to
camessage. ...
Could you record some?  I would help me (and others) to avoid further
unintended breakage if there were some "as built" records of CA from the
era before IOCs could run on Linux.  Otherwise, I'm left using the
conditionals in the source code to guess how packets were structured.
> ... There are plans to remove them in the SLS-2 upgrade in a few years
Were I in your place, I would move these ancient IOCs behind a cagateway
(built against 3.14) and then try my best to forget about them.
Alternately, maybe we can collect donations next week to start a 3.13
retirement fund?
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1971737
Title:
Status in EPICS Base:
  New
Bug description:
  Since commit 95fd255d "rsrv: ignore CA client version older than v4.4"
  from Jul 30 2016, EPICS 3.13 clients cannot connect any more, even
  though their CA version is V4.8.
  The reason is that camessage drops the incoming CA_PROTO_SEARCH
  messages because the 3.13 client has not yet sent a CA_PROTO_VERSION
  message and thus the code reads client->minor_version_number as 0.
  This is a huge hindrance for upgrading 3.14 IOCs to EPICS 7 when there
  are still 3.13 IOC (which cannot be upgraded yet) in the network which
  need to connect.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1971737/+subscriptions
[Bug 1971737] [NEW] EPICS 3.13 clients cannot connect to EPICS 7 or 3.16 Dirk Zimoch via Core-talk
Prev: [Bug 1971737] Re: EPICS 3.13 clients cannot connect to EPICS 7 or 3.16 Dirk Zimoch via Core-talk
Next: [Bug 1971737] Re: EPICS 3.13 clients cannot connect to EPICS 7 or 3.16 Dirk Zimoch via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
