2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: [Bug 1918275] Re: dbdToHtml needs better error messages
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 07 May 2022 14:27:56 -0000
** Tags added: codeathon
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1918275
Title:
Status in EPICS Base:
  New
Bug description:
  The pod parser dbdToHtml.pl gives unhelpful error messages like:
  Unexpected end of input file, Pod block not closed
  Context: Pod markup in file 'filename.dbd.pod'
  This does not help at all to find the error. What is missing is at
  least the line number where the Pod block was opened. Better the
  name/type/keyword of the Pod block as well.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1918275/+subscriptions
Prev: [Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15 Andrew Johnson via Core-talk
Next: [Bug 1903924] Re: The aao record type could use a DOL input link Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
