2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: [Bug 1841634] Re: CP link triggers lost when record is async
From: Andrew Johnson via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Sat, 07 May 2022 14:45:06 -0000
** Tags removed: codeathon
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1841634
Title:
Status in EPICS Base:
  Confirmed
Status in EPICS Base 7.0 series:
  Confirmed
Bug description:
  From Benjamin Franksen:
  Here is a small self-contained database to reproduce this:
  record(calcout,"input") {
      field(CALC,"A<4?A+1:A")
      field(INPA,"input")
      field(ODLY,"1")
      field(OUT,"input.A CA")
  record(calcout,"output") {
      field(ODLY,"1.5")
      field(INPA,"input CPP")
      field(CALC,"A")
      field(TPRO,1)
  record(calc,"check") {
      field(INPB,"output CPP")
      field(CALC,"A==B")
  Processing "input" (caput input.PROC 1) starts the test. The "check"
  record should eventually settle to 1 (but doesn't).
  With 7.0.3 I get this output:
  scanOnce: dbProcess of 'output' # initial CPP processing
  scanOnce: dbProcess of Active 'output' with RPRO=0
  Note how this says "with RPRO=0".
  And camonitor says:
  franksen@tiber: ~ > camonitor input output check
  input                          <undefined> 0 UDF INVALID
  output                         2019-08-27 16:02:16.106413 0
  check                          2019-08-27 16:02:16.106617 1
  input                          2019-08-27 16:02:26.498483 1
  check                          2019-08-27 16:02:26.498721 0
  input                          2019-08-27 16:02:27.493734 2
  output                         2019-08-27 16:02:27.993908 1
  input                          2019-08-27 16:02:28.489068 3
  input                          2019-08-27 16:02:29.484350 4
  output                         2019-08-27 16:02:29.984458 3
  I think the difference in behavior between processing due to a CPP
  input link versus processing due to a PP or CA output link is quite
  surprising.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1841634/+subscriptions
Prev: [Bug 1903924] Re: The aao record type could use a DOL input link Andrew Johnson via Core-talk
Next: Build failed: epics-base base-integration-820 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
