** Merge proposal linked:
https://code.launchpad.net/~dougmurray/epics-base/+git/epics-base/+merge/422030
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1943245
Title:
epicsStrnEscapedFromRaw may print inclomplete escape sequences
Status in EPICS Base:
New
Bug description:
When epicsStrnEscapedFromRaw runs out of buffer space in the middle of an escape sequence, it prints incomplete and thus invalid sequences.
For example printing "\xff" (1 byte 0xff) into a buffer that is too short may result in `\`, `\x`, or `\xf`. In particular a stray `\` at the end may be misinterpreted for example when the escaped string itself is printed in quotes and then the outer ending quote gets "escaped".
Instead of printing incomplete sequences it should rather not print
the sequence at all.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1943245/+subscriptions
Re: [Merge] ~dougmurray/epics-base:fix-1943245 into epics-base:7.0 Andrew Johnson via Core-talk
Build failed: epics-base base-ememfs-827 AppVeyor via Core-talk
<2022>
2025
2026
[Bug 1943245] Re: epicsStrnEscapedFromRaw may print inclomplete escape sequences Andrew Johnson via Core-talk
[Bug 1939568] Re: Writing to mbboDirect.VAL does not work any more in EPICS >= 3.15 Andrew Johnson via Core-talk
<2022>
2025
2026
