2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: [Bug 1971737] Re: EPICS 3.13 clients cannot connect to EPICS 7 or 3.16
From: Dirk Zimoch via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Wed, 18 May 2022 10:01:40 -0000
Another small problem is that EPICS 3.13 IOCs may send their beacons to
the "wrong" port. This happens when EPICS_CA_ADDR_LIST contains
host:port entries. In this case, the IOCs send the beacons to the given
search port too. These are the reason for the "invalid (damaged?)
request code from UDP" messages. Some code is needed to ignore
CA_PROTO_RSRV_IS_UP messages on the wrong port.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1971737
Title:
Status in EPICS Base:
  New
Bug description:
  Since commit 95fd255d "rsrv: ignore CA client version older than v4.4"
  from Jul 30 2016, EPICS 3.13 clients cannot connect any more, even
  though their CA version is V4.8.
  The reason is that camessage drops the incoming CA_PROTO_SEARCH
  messages because the 3.13 client has not yet sent a CA_PROTO_VERSION
  message and thus the code reads client->minor_version_number as 0.
  This is a huge hindrance for upgrading 3.14 IOCs to EPICS 7 when there
  are still 3.13 IOC (which cannot be upgraded yet) in the network which
  need to connect.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1971737/+subscriptions
[Bug 1971737] [NEW] EPICS 3.13 clients cannot connect to EPICS 7 or 3.16 Dirk Zimoch via Core-talk
Prev: Build failed: EPICS Base 7 base-7.0-585 AppVeyor via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-586 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: [Bug 1971737] Re: EPICS 3.13 clients cannot connect to EPICS 7 or 3.16 Dirk Zimoch via Core-talk
Next: [Bug 1943245] Re: epicsStrnEscapedFromRaw may print inclomplete escape sequences Andrew Johnson via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
