7.0.5 does not show this behavior...
On Mon, 2022-06-27 at 10:09 +0200, Zimoch Dirk wrote:
> Hi everyone,
> Thanks Mark for testing it with AD. The linear ramp is probably similar to my "sequence" test device support.
> The client I used is caqtdm.
> As Mark already noticed, the problem does not appear with a client running on the same host. I guess this is the case
> because the host shortcuts the TCP traffic to itself and thus the bandwidth is much higher than what we can achieve
> between two different hosts.
> Running the IOC with RT priorities does not change anything.
> I had not counted the monitors, thus I did not notice that the IOC sends exactly n+1 frames. The behavior is
> consistent
> with putting a pointer to the array data (at an unchanging location) into a queue. If the data changes faster than it
> can be sent, then the next element in the queue will be a pointer not to the next frame but instead will miss some.
> After data production ends, all remaining pointers in the queue will point to the non-changing last frame, until some
> other client makes the array produce new data. At that point the original client will receive those updates while
> working through the backlog. Of course this behavior makes no sense at all. Either put the whole data into the queue
> or
> do not queue the pointer at all.
> Using PVA, I do not see this effect. Still the network cannot keep up with the rate the data is produced, thus frames
> are lost. But pressing the STOP button takes effect almost immediately. (Maybe after one or two more updates, but that
> can be latency in the client or network.) Is there a debug variable like CASDEBUG for PVA that would allow to see what
> PVA is sending?
> I can try to find out which commit changed the behavior in CA ...
> Dirk
> On Sat, 2022-06-25 at 09:03 +0000, Zimoch Dirk (PSI) via Core-talk wrote:
> > Hi Andrew,
> > The cameras run on Windows. I did my test on Linux but not as root, thus I had no RT scheduling. I will repeat the
> > test on Monday running as root.
> > The STOP message gets processed in time! A client that does not monitor the array sees the change immediately. The
> > counter stops. But CA keeps sending!
> > I had expected that the IOC would drop frames if CA cannot send fast enough. Not trying for minutes to work through
> > a
> > pile of unsent frames. And then not even sending updates but simply repeating the last frame.
> > Dirk
> > > Am 24.06.2022 um 18:10 schrieb Andrew Johnson via Core-talk <core-talk at aps.anl.gov>:
> > > Hi Dirk,
> > > What OS is the IOC running on — I'm guessing Linux but you didn't say. If so is it built for and using priority
> > > thread scheduling? If the OSSPRI field from epicsThreadShowAll is all zeros it isn't, and enabling that might
> > > help.
> > > The normal Linux scheduler tends to maximize throughput, not fairness, so it could be delaying the threads which
> > > process your STOP message while the threads handling image data can continue to make progress. However this is
> > > just
> > > a guess.
> > > - Andrew
> > > General musings: The setpriority(2) manpage on RHEL-7 says:
> > > > BUGS
> > > > According to POSIX, the nice value is a per-process setting. However, under
> > > > the current Linux/NPTL implementation of POSIX threads, the nice value is a
> > > > per-thread attribute: different threads in the same process can have different
> > > > nice values. Portable applications should avoid relying on the Linux behav‐
> > > > ior, which may be made standards conformant in the future.
> > > I wonder whether we should look at setting nice values for Linux threads when the process doesn't have the ability
> > > to use SCHED_FIFO?
> > > On 6/24/22 10:39 AM, Zimoch Dirk (PSI) via Core-talk wrote:
> > > > Hi folks,
> > > > Some of or users complained that a camera server became less responsive since it had been upgraded from EPICS
> > > > 3.14.12.6
> > > > to 7.0.6.1.
> > > > The camera sends image data as arrays of 20000000 SHORTs (5000x4000 pixels). When the user presses the "STOP"
> > > > button on
> > > > the client which displays the image, it takes a long time to stop. The more active clients, the longer it takes.
> > > > But even sending stop from a different client (e.g. command line caput) takes a long time before the GUI clients
> > > > update.
> > > > I have set up a simple simulation and run it with 'var CADEBUG 3'
> > > > Here is what I see: on EPICS 7.0.6.1
> > > > CAS: Sending a message of 40000032 bytes
> > > > CAS: TCP Request from 129.129.130.117:47142 => cmmd=4 (CA_PROTO_WRITE) cid=0x4 type=0 count=1 postsize=8
> > > > version=13
> > > > CAS: Request from 129.129.130.117:47142 => available=0x2 N=1 paddr=0x7efcb800db80
> > > > CAS: Request from 129.129.130.117:47142 => Wrote string "STOP"
> > > > [>80 times the same!]
> > > > CAS: Sending a message of 40000056 bytes <---- I think this one contains the update of the STOP button
> > > > [eventually stops many seconds later]
> > > > The IOC obviously gets the STOP message immediately when I press the button on the client. But the client (and
> > > > any
> > > > other
> > > > client showing the image) does not see the button change. The GUI appears "frozen". But a command line camonitor
> > > > monitoring the stop button (and a counter that counts the number of created images but not the image itself)
> > > > show
> > > > that
> > > > the records stop immediately.
> > > > Nevertheless the IOC keeps sending images. But the images do not change any more on the clients. So it seems
> > > > that
> > > > the
> > > > IOC keeps sending the same array data over and over again.
> > > > On 3.14.12, the output looks similar, but the "send after stop" consists of only a few messages:
> > > > CAS: Request from 129.129.130.117:47184 => cmmd=4 cid=0x1 type=0 count=1 postsize=8
> > > > CAS: Request from 129.129.130.117:47184 => available=0x2 N=1 paddr=0x7f0768010b28
> > > > CAS: Request from 129.129.130.117:47184 => Wrote string "STOP"
> > > > CAS: Sending a message of 40000056 bytes <---- update of the STOP button
> > > > What can be wrong here?
> > > > The IOC consists of a counting calc, a bo for the stop switch and a waveform record with a driver that simply
> > > > fills the
> > > > waveform with a sequence starting at the counter value. Nothing fancy.
> > > > Here is my db:
> > > > record (waveform, "DZ:BIGARRAY")
> > > > field(FTVL, "SHORT")
> > > > field(NELM, "20000000")
> > > > field(DTYP, "sequence")
> > > > field(SCAN, ".1 second")
> > > > field(SDIS, "DZ:STOP")
> > > > field(INP, "DZ:COUNT")
> > > > field(FLNK, "DZ:COUNT")
> > > > record (calc, "DZ:COUNT")
> > > > field(CALC, "VAL+1")
> > > > record(bo, "DZ:STOP")
> > > > field(ZNAM,"GO")
> > > > field(ONAM,"STOP")
> > > > I suspect this happens when record produces new waveforms faster than they can be sent.
> > > > The IOC has no problem processing the waveform at 10 Hz, but I see only about 3 CAS messages per second.
> > > > I had to slow down the waveform processing to ".5 second" to improves responsiveness. That is when the monitor
> > > > updates
> > > > can be sent as quickly as being produced. But opening a second client again spoils everything.
> > > > Dirk
- Re: Problem with huge waveforms in EPICS 7 Zimoch Dirk (PSI) via Core-talk
- Problem with huge waveforms in EPICS 7 Zimoch Dirk (PSI) via Core-talk
- Re: Problem with huge waveforms in EPICS 7 Andrew Johnson via Core-talk
<2022>
2025
2026
<2022>
2025
2026
