2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: epics-7.0 » linux32 - Build # 425 - Still unstable!
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Tue, 23 Aug 2022 15:59:40 -0500 (CDT)
Build URL: https://jenkins.aps.anl.gov/job/epics-7.0/OS=linux32/425/
This job built successfully, but has failing tests.
Target summary:
[...truncated 5193 lines...]
Tests failed in:
    modules/pva2pva/testApp/O.linux-x86
configure/RULES_TOP:55: recipe for target 'test-results' failed
make: *** [test-results] Error 1
+ exit 255
Build step 'Execute shell' changed build result to UNSTABLE
TAP Reports Processing: START
Looking for TAP results report in workspace using pattern: **/O.*/*.tap
Saving reports...
Not all test cases were executed according to the test set plan. Marking build as UNSTABLE
There are failed test cases. Marking build as UNSTABLE
TAP Reports Processing: FINISH
Notifying upstream projects of job completion
Email was triggered for: Unstable (Test Failures)
Sending email for trigger: Unstable (Test Failures)
epics-7.0 » linux32 - Build # 426 - Still Unstable! APS Jenkins via Core-talk
epics-7.0 » linux32 - Build # 424 - Failure! APS Jenkins via Core-talk
Prev: epics-7.0 » linux32 - Build # 424 - Failure! APS Jenkins via Core-talk
Next: VxWorks network problem Zimoch Dirk (PSI) via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: epics-7.0 » linux32 - Build # 426 - Still Unstable! APS Jenkins via Core-talk
ANJ, 14 Sep 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
