2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: Manpages for PVA Command Line Tools
From: Michael Davidsaver via Core-talk <core-talk at aps.anl.gov>
To: "Daykin, Evan" <daykin at frib.msu.edu>
Cc: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Fri, 2 Dec 2022 11:47:54 -0800
On 12/2/22 06:28, Daykin, Evan wrote:
P.S. Is it 'txt2man' that you were thinking of? https://linux.die.net/man/1/txt2man
I think so.  I may have used txt2man as a starting point for the epicsdeb
man pages for the ca* executables.
-----Original Message-----
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Thursday, December 1, 2022 4:14 PM
To: Daykin, Evan <daykin at frib.msu.edu>
Cc: core-talk at aps.anl.gov
[EXTERNAL] This email originated from outside of FRIB
On 12/1/22 05:58, Daykin, Evan via Core-talk wrote:
Hi Core-Talk,
Are there any pre-existing manpages (in roff format) for pvlist, pvput, pvget, pvmonitor, pvinfo, softIocPVA and p2p? If not, I was going to make them.
Not that I know of.
Based on my experience with manpages for ca* [1], I would suggest not investing a huge amount of time into learning nroff markup.
There are a number of tools which take in some other text markup format, and output nroff.
(if you do, fyi. "man ./some.1" is a quick way to test changes)
I used to use asciidoc for this, but there may be better options now.  Maybe something with markdown? [2]
I also recall finding a tool which tried to massage the output of eg. "caget -h" into nroff.  However, I can find the name just now.
[1] https://github.com/epicsdeb/epics-base/tree/master/debian/man
[2] https://rtomayko.github.io/ronn/ronn.1.html
Manpages for PVA Command Line Tools Daykin, Evan via Core-talk
Re: Manpages for PVA Command Line Tools Michael Davidsaver via Core-talk
RE: Manpages for PVA Command Line Tools Daykin, Evan via Core-talk
Prev: Build completed: EPICS Base 7 base-7.0-711 AppVeyor via Core-talk
Next: Build failed: epics-base base-integration-907 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: RE: Manpages for PVA Command Line Tools Daykin, Evan via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-711 AppVeyor via Core-talk
ANJ, 02 Dec 2022 · Home · News · About · Talk · Base · Modules · Extensions ·
