See <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/1063/display/redirect>
Changes:
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on linux32-1 (linux32) in workspace <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/>
The recommended git tool is: NONE
No credentials specified
> /usr/bin/git rev-parse --resolve-git-dir <https://jenkins.aps.anl.gov/job/epics-pvaPy-linux32/ws/.git> # timeout=10
Fetching changes from the remote Git repository
> /usr/bin/git config remote.origin.url https://github.com/epics-base/pvaPy.git # timeout=10
Cleaning workspace
> /usr/bin/git rev-parse --verify HEAD # timeout=10
Resetting working tree
> /usr/bin/git reset --hard # timeout=10
> /usr/bin/git clean -fdx # timeout=10
Fetching upstream changes from https://github.com/epics-base/pvaPy.git
> /usr/bin/git --version # timeout=10
> git --version # 'git version 1.7.1'
Setting http proxy: webgateway221.anl.gov:9091
> /usr/bin/git fetch --tags --progress https://github.com/epics-base/pvaPy.git +refs/heads/*:refs/remotes/origin/* # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://github.com/epics-base/pvaPy.git
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1002)
at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1244)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1308)
at hudson.scm.SCM.checkout(SCM.java:540)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1217)
at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:647)
at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:85)
at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:519)
at hudson.model.Run.execute(Run.java:1897)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:44)
at hudson.model.ResourceController.execute(ResourceController.java:101)
at hudson.model.Executor.run(Executor.java:442)
Caused by: hudson.plugins.git.GitException: Command "/usr/bin/git fetch --tags --progress https://github.com/epics-base/pvaPy.git +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: error: Proxy CONNECT aborted while accessing https://github.com/epics-base/pvaPy.git/info/refs
fatal: HTTP request failed
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2734)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2111)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:87)
at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:623)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:158)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:151)
at hudson.remoting.UserRequest.perform(UserRequest.java:211)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:376)
at hudson.remoting.InterceptingExecutorService.lambda$wrap$0(InterceptingExecutorService.java:78)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to linux32-1
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1784)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:356)
at hudson.remoting.Channel.call(Channel.java:1000)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:143)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:129)
at com.sun.proxy.$Proxy61.execute(Unknown Source)
at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1000)
- Build failed in Jenkins: epics-pvaPy-linux32 #1064 APS Jenkins via Core-talk
Build failed in Jenkins: epics-pvaClient-linux32 #716 APS Jenkins via Core-talk
Jenkins build is back to normal : epics-base-3.15-mac #399 APS Jenkins via Core-talk
<2022>
2025
2026
Build failed in Jenkins: epics-pvaClient-linux32 #718 APS Jenkins via Core-talk
<2022>
2025
2026
