** Changed in: epics-base
Status: Triaged => Fix Committed
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1903924
Title:
The aao record type could use a DOL input link
Status in EPICS Base:
Fix Committed
Bug description:
There is currently no way to copy numeric arrays between record fields
just using the core database record types. The only way I can think to
do it with any standard record type at all would be to use the
aCalcout from the synapps/calc module, but that is a rather heavy-
weight solution.
This functionality could most easily be provided by adding a DOL input
link (and a related OMSL field) to the aao record type. It should be
possible to do this in a backwards compatible way and not break
existing databases; I would want any solution offered to come with a
unit test program which demonstrates that not setting the DOL and OMSL
fields leaves the record's behavior exactly the same as it was. I
suggest writing the test before adding the new fields.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1903924/+subscriptions
[Bug 2004463] Re: iocsh on vxWorks broken mdavidsaver via Core-talk
[Bug 2004463] Re: iocsh on vxWorks broken Dirk Zimoch via Core-talk
<2023>
2025
2026
Build failed: epics-base base-integration-927 AppVeyor via Core-talk
<2023>
2025
2026
