** Patch added: "genVersionHeader.patch"
https://bugs.launchpad.net/epics-base/+bug/2015234/+attachment/5661142/+files/genVersionHeader.patch
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/2015234
Title:
newline problem with genVersionHeader.pl
Status in EPICS Base:
New
Bug description:
After merging the current EPICS 7.0 branch into my PSI branch, I got a
generated epicsVCS.h header file with invalid syntax on RHEL7 (but not
on RHEL8):
#ifndef EPICS_VCS_VERSION_DATE
#define EPICS_VCS_VERSION_DATE "Git: 2023-03-29 13:36:52 +0200
Note the newline within the string.
I tracked that down to a strange behavior of git show in git version
1.8.3.1 as installed by default on RHEL7:
Whenever the current commit is a merge, then the output of 'git show
-s --format=%ci' (as used by genVersionHeader.pl) shows an extra
newline!
Piping it to hexdump show the issue:
$git co 7.0
git show -s --format=%ci | hexdump -C
00000000 32 30 32 33 2d 30 33 2d 31 30 20 31 32 3a 30 32 |2023-03-10 12:02|
00000010 3a 32 39 20 2b 30 30 30 30 0a |:29 +0000.|
0000001a
Just as it should be.
Now check out a merge commit:
$git co e63184e
HEAD is now at e63184e... Merge PR #63, longout.OOPT
$ git show -s --format=%ci | hexdump -C
00000000 32 30 32 32 2d 31 32 2d 32 39 20 31 36 3a 33 31 |2022-12-29 16:31|
00000010 3a 34 32 20 2d 30 36 30 30 0a 0a |:42 -0600..|
0000001b
Note the extra 0a!
This extra newline gets pasted into epicsVCS.h.
BTW: Git version 2.31.1 as installed by default on RHEL8 does not show
this bug.
Of course one could blame the problem on the old git version, but I
think just to be on the safe side, it would be better to remove all
terminating newlines (and returns, maybe all whitespace) and not only
the last one, as perl seems to do.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/2015234/+subscriptions
- [Bug 2015234] [NEW] newline problem with genVersionHeader.pl Dirk Zimoch via Core-talk
[Bug 2015234] Re: newline problem with genVersionHeader.pl Dirk Zimoch via Core-talk
<2023>
2025
2026
<2023>
2025
2026
