2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Build failed in Jenkins: epics-base-3.15-win64 #563
From: APS Jenkins via Core-talk <core-talk at aps.anl.gov>
To: core-talk at aps.anl.gov
Date: Mon, 17 Apr 2023 22:10:02 -0500 (CDT)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-win64/563/display/redirect>
Changes:
Started by upstream project "epics-base-3.15" build number 567
originally caused by:
 Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on win64-2 (windows-x64) in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-win64/ws/>
The recommended git tool is: NONE
No credentials specified
 > C:/Program Files/Git/cmd/git.exe rev-parse --resolve-git-dir C:\jenkins\win64-2\workspace\epics-base-3.15-win64\.git # timeout=10
Fetching changes from the remote Git repository
 > C:/Program Files/Git/cmd/git.exe config remote.origin.url https://git.launchpad.net/epics-base # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > C:/Program Files/Git/cmd/git.exe --version # timeout=10
 > git --version # 'git version 2.20.1.windows.1'
Setting http proxy: webgateway221.anl.gov:9091
 > C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress -- https://git.launchpad.net/epics-base +refs/heads/3.15:refs/remotes/origin/3.15 # timeout=10
ERROR: Error fetching remote repo 'origin'
hudson.plugins.git.GitException: Failed to fetch from https://git.launchpad.net/epics-base
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1002)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1244)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1308)
	at hudson.scm.SCM.checkout(SCM.java:540)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1217)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:647)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:85)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:519)
	at hudson.model.Run.execute(Run.java:1897)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:44)
	at hudson.model.ResourceController.execute(ResourceController.java:101)
	at hudson.model.Executor.run(Executor.java:442)
Caused by: hudson.plugins.git.GitException: Command "C:/Program Files/Git/cmd/git.exe fetch --tags --force --progress -- https://git.launchpad.net/epics-base +refs/heads/3.15:refs/remotes/origin/3.15" returned status code 128:
stdout:
stderr: fatal: Couldn't find remote ref refs/heads/3.15
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2734)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:2111)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$500(CliGitAPIImpl.java:87)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:623)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:158)
	at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler$GitCommandMasterToSlaveCallable.call(RemoteGitImpl.java:151)
	at hudson.remoting.UserRequest.perform(UserRequest.java:211)
	at hudson.remoting.UserRequest.perform(UserRequest.java:54)
	at hudson.remoting.Request$2.run(Request.java:376)
	at hudson.remoting.InterceptingExecutorService.lambda$wrap$0(InterceptingExecutorService.java:78)
	at java.util.concurrent.FutureTask.run(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
	Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to win64-2
		at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1784)
		at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:356)
		at hudson.remoting.Channel.call(Channel.java:1000)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.execute(RemoteGitImpl.java:143)
		at sun.reflect.GeneratedMethodAccessor891.invoke(Unknown Source)
		at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
		at java.lang.reflect.Method.invoke(Method.java:498)
		at org.jenkinsci.plugins.gitclient.RemoteGitImpl$CommandInvocationHandler.invoke(RemoteGitImpl.java:129)
		at com.sun.proxy.$Proxy76.execute(Unknown Source)
		at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:1000)
Build failed in Jenkins: epics-base-3.15-win64 #564 APS Jenkins via Core-talk
Prev: Build failed in Jenkins: epics-base-3.15 #567 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-mac #405 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Prev: Jenkins build is back to normal : epics-base-3.15 #570 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-win64 #564 APS Jenkins via Core-talk
ANJ, 12 May 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
