2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
Subject: Re: which appveyor config?
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Tue, 23 May 2023 14:39:48 +0200
Background:
To ease the tight policy of AppVeyor a bit - and keep multi-day backlogs from happening too often - we were creating multiple accounts on AppVeyor and split the CI jobs between them by branch / project:
epics-base
  Base (7.0, manual, using .appveyor.yml), pvAccess, pvData, ci-scripts (only tags, no PRs), pva2pva
epics-modules
  ci-scripts, gtest, pcas
epics-base-7
  Base (branch 7.0, using .appveyor/epics-base-7.yml)
epics-base-3
  Base (branch 3.15, using .appveyor/epics-base-3.yml)
So, the top level .appveyor.yml could probably be removed if the manual epics-base build points to the same configuration as the epics-base-7 build.
New builds for the automated 7.0 branch CI should go to .appveyor/epics-base-7.yml
Cheers,
~Ralph
which appveyor config? Zimoch Dirk via Core-talk
Prev: which appveyor config? Zimoch Dirk via Core-talk
Next: Build failed: EPICS Base base-7.0-614 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  <20232024  2025  2026
ANJ, 23 May 2023 · Home · News · About · Talk · Base · Modules · Extensions ·
