2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Support for _FORTIFY_SOURCE=3
From: NICOLE Remi via Core-talk <core-talk at aps.anl.gov>
To: "core-talk at aps.anl.gov" <core-talk at aps.anl.gov>
Date: Mon, 12 Feb 2024 10:00:26 +0000
During an upgrade of our build system, I encountered this error:
    *** buffer overflow detected ***: terminated
    [1]    2022546 IOT instruction (core dumped)  ./result/bin/softIoc
-S -d nixos/tests/archiver-appliance/test.db
After a bit of debugging, I found that _FORTIFY_SOURCE=3 was enabled by
default, which caused extra checks to be done in `strcpy`, which failed
in this particular instance:
1. running `softIoc -S -d test.db` (see attachments for the .db file)
2. EPICS reads the calcExample record
3. EPICS calls dbAllocRecord
4. EPICS initialize the CALC field
5. EPICS copies the initial value of CALC `"0"` to the alloc'ed record
6. crash because overflow detected
See the backtrace in the attachments.
This is weird because the CALC value is a char[80], so there shouldn't
be any overflow.
Can anyone reproduce? Can anyone see why this crashes?
In the meantime, I'll just fall back to _FORTIFY_SOURCE=2
Thanks a lot, and have a great day.
Rémi NICOLE <remi.nicole at cea.fr>
CEA/DRF/IRFU/DIS/LDISC
# Adapted from: https://github.com/epics-base/epics-base/blob/524f81b8bd147bb714c9ea7b7462b8912a134246/modules/database/src/template/top/exampleApp/Db/dbExample1.db
# To test regularly changing records
record(ai, "aiExample")
	field(DESC, "Analog input")
	field(INP, "calcExample.VAL  NPP NMS")
	field(EGUF, "10")
	field(EGU, "Counts")
	field(HOPR, "10")
	field(LOPR, "0")
	field(HIHI, "8")
	field(HIGH, "6")
	field(LOW, "4")
	field(LOLO, "2")
	field(HHSV, "MAJOR")
	field(HSV, "MINOR")
	field(LSV, "MINOR")
	field(LLSV, "MAJOR")
record(calc, "calcExample") {
	field(DESC, "Counter")
	field(SCAN, "1 second")
	field(FLNK, "aiExample")
	field(CALC, "(A<B)?(A+C):D")
	field(INPA, "calcExample.VAL NPP NMS")
	field(INPB, "9")
	field(INPC, "1")
	field(INPD, "0")
	field(HOPR, "10")
	field(HIHI, "8")
	field(HIGH, "6")
	field(LOW, "4")
	field(LOLO, "2")
	field(HSV, "MINOR")
	field(LSV, "MINOR")
# To test "static" records
record(ai, "static") {
	field(VAL, "1")
# To test the ADEL field
record(ai, "staticDeadband") {
	field(VAL, 0)
	field(ADEL, 5)
# To test "static", but regularly processed records
record(ai, "staticProcessed") {
	field(VAL, 0)
	field(ADEL, -1)
# To test waveforms
record(waveform, "waveform") {
	field(NELM, 10)
#0  0x00007ffff78a4d7c in __pthread_kill_implementation () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#1  0x00007ffff78559c6 in raise () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#2  0x00007ffff783e8fa in abort () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#3  0x00007ffff783f767 in __libc_message.cold () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#4  0x00007ffff79337f9 in __fortify_fail () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#5  0x00007ffff79331b4 in __chk_fail () from /nix/store/j6mwswpa6zqhdm1lm2lv9iix3arn774g-glibc-2.38-27/lib/libc.so.6
#6  0x00007ffff7f40b91 in strcpy (__src=0x45f770 "0", __dest=0x4d1be8 "")
    at /nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-glibc-2.38-27-dev/include/bits/string_fortified.h:79
#7  dbAllocRecord (pdbentry=pdbentry@entry=0x422638, precordName=precordName@entry=0x422578 "calcExample") at ../dbStatic/dbStaticRun.c:125
#8  0x00007ffff7f3635f in dbCreateRecord (pdbentry=pdbentry@entry=0x422638, precordName=precordName@entry=0x422578 "calcExample")
    at ../dbStatic/dbStaticLib.c:1441
#9  0x00007ffff7f3b237 in dbRecordHead (recordType=recordType@entry=0x4225d8 "calc", name=name@entry=0x422578 "calcExample", visible=visible@entry=0)
    at ../dbStatic/dbLexRoutines.c:1132
#10 0x00007ffff7f3dd14 in dbRecordHead (visible=0, name=0x422578 "calcExample", recordType=0x4225d8 "calc") at ../dbStatic/dbLexRoutines.c:1104
#11 yyparse () at ../dbStatic/dbYacc.y:234
#12 pvt_yy_parse () at ../dbStatic/dbYacc.y:395
#13 dbReadCOM (ppdbbase=ppdbbase@entry=0x7ffff7f77da0 <pdbbase>, filename=filename@entry=0x7fffffffbe5c "nixos/tests/archiver-appliance/test.db",
    fp=fp@entry=0x0, path=path@entry=0x0, substitutions=substitutions@entry=0x7fffffffb6c0 "") at ../dbStatic/dbLexRoutines.c:294
#14 0x00007ffff7f3f74d in dbReadDatabase (ppdbbase=ppdbbase@entry=0x7ffff7f77da0 <pdbbase>,
    filename=filename@entry=0x7fffffffbe5c "nixos/tests/archiver-appliance/test.db", path=path@entry=0x0, substitutions=substitutions@entry=0x7fffffffb6c0 "")
    at ../dbStatic/dbLexRoutines.c:350
#15 0x00007ffff7f0c52d in dbLoadRecords (file=0x7fffffffbe5c "nixos/tests/archiver-appliance/test.db", subs=0x7fffffffb6c0 "") at ../db/dbAccess.c:800
#16 0x0000000000407595 in main (argc=4, argv=0x7fffffffb888)
    at /nix/store/eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee-gcc-12.3.0/include/c++/12.3.0/bits/basic_string.h:233
Prev: Build failed: epics-base base-win32_static_set_thread_names-55 AppVeyor via Core-talk
Next: Build failed: EPICS Base 7 base-7.0-1096 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
ANJ, 14 Feb 2024 · Home · News · About · Talk · Base · Modules · Extensions ·
