I previously sent this message to both tech-talk and core-talk. Neither Andrew Johnson nor I received it. I know that some people who are subscribed to tech-talk did receive it. It looks like perhaps people who are subscribed to both
lists do not receive the message at all?
I the future I will only send to one list or the other, since Andrew points out that core-talk is a subset of tech-talk.
Sent: Tuesday, March 12, 2024 3:54 PM
To: tech-talk at aps.anl.gov; core-talk at aps.anl.gov
Subject: startPVAServer prevents windows-x64 IOC from exiting
Folks,
I have found a serious problem with using the PVA server on Windows IOCs that are dynamically built. The IOC runs fine, but cannot be exited either with the “exit” command or with ^C. It can only be killed with the Windows Task Manager.
The problem occurs on the following:
- EPICS_HOST_ARCH: window-x64, windows-x64-debug. Does not occur on windows-x64-static.
- EPICS BASE: 7.0.7 and 7.0.8. Did not test other versions.
- Test application: makeBaseApp.pl from base 7.0.8. Modified st.cmd to add the line startPVAServer just before iocInit. Also happens in ADSimDetector with commonPlugins.cmd.
- Re: startPVAServer prevents windows-x64 IOC from exiting Michael Davidsaver via Core-talk
- startPVAServer prevents windows-x64 IOC from exiting Mark Rivers via Core-talk
<2024>
2025
2026
<2024>
2025
2026
ANJ, 13 Mar 2024 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
