2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Subject: Re: CI-Scripts and RTEMS Cached files on GHA
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Fri, 29 Mar 2024 10:37:32 +0100
Hi Andrew,
The node version changes are unrelated.
The GHA cache is set up to only cache our dependency modules, not the RTEMS chain (in /opt/rtems/...) that the failing build is missing.
The key difference is that a successful build installs the RTEMS environment:
While the failing build does not.
Any build that finds a vaild cache for Base fails, since the part of the ci-scripts that downloads and installs the RTEMS chain is not run.
If you look at the build history, the working builds are those that did not find a valid cache.
To state the obvious: When using caches, everything that is being generated or downloaded as part of the job must be in the cache.
Cheers,
~Ralph
On Thu, 28 Mar 2024 at 23:25, Johnson, Andrew N. via Core-talk <core-talk at aps.anl.gov> wrote:
Earlier today I had to clear the cached copies of the dependencies for the 3 RTEMS builds of pvAccessCPP. Looking at this run, despite apparently successfully restoring the cached copies:
Received 174353040 of 174353040 (100.0%), 169.5 MBs/sec
17Cache Size: ~166 MB (174353040 B)
18/usr/bin/tar -z -xf /home/runner/work/_temp/0a59dd1a-0e60-48ac-aa81-7b50d65052c4/cache.tgz -P -C /home/runner/work/pvAccessCPP/pvAccessCPP
19Cache restored successfully
20Cache restored from key: 7.0/ubuntu-20.04/gcc/default/5/RTEMS-pc686-qemu/
the main builds were failing with this error:
make[2]: Leaving directory '/home/runner/work/pvAccessCPP/pvAccessCPP/configure/O.linux-x86_64'
45 perl -CSD /home/runner/.cache/base-7.0/bin/linux-x86_64/convertRelease.pl checkRelease
46 make -C O.RTEMS-pc686-qemu -f ../Makefile TOP=../.. \
47 T_A=RTEMS-pc686-qemu install
48 /home/runner/.cache/base-7.0/configure/os/CONFIG.Common.RTEMS:37: /opt/rtems/5/i386-rtems5/pc686/Makefile.inc: No such file or directory
49 make[2]: *** No rule to make target '/opt/rtems/5/i386-rtems5/pc686/Makefile.inc'. Stop.
50 make[1]: *** [/home/runner/.cache/base-7.0/configure/RULES_ARCHS:58: install.RTEMS-pc686-qemu] Error 2
51 make: *** [/home/runner/.cache/base-7.0/configure/RULES_DIRS:85: configure.install] Error 2
52 Error: Process completed with exit code 2.
I am also seeing these "Annotations" about the run from GHA which I suspect may be related:
7.0 Ub-20 gcc-9 + RT-5.1 pc686
Node.js 16 actions are deprecated. Please update the following actions to use Node.js 20: actions/checkout@v2, actions/cache@v2, actions/upload-artifact@v2. For more information see: https://github.blog/changelog/2023-09-22-github-actions-transitioning-from-node-16-to-node-20/.
Show less
The following actions uses node12 which is deprecated and will be forced to run on node16: actions/checkout@v2, actions/cache@v2, actions/upload-artifact@v2. For more info: https://github.blog/changelog/2023-06-13-github-actions-all-actions-will-run-on-node16-instead-of-node12-by-default/
On deleting the cached data the dependencies are rebuilt and the main build succeeds (see run #70), but it fails again on subsequent builds (#71). I just cleared the caches again and re-ran the failed builds which I hope will succeed.
Can anyone explain what needs to be done to fix this properly?
- Andrew
Complexity comes for free, Simplicity you have to work for.
CI-Scripts and RTEMS Cached files on GHA Johnson, Andrew N. via Core-talk
Prev: Build completed: pvAccessCPP 1.0.88 AppVeyor via Core-talk
Next: Build failed: pvAccessCPP 1.0.89 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  <20242025  2026
Prev: CI-Scripts and RTEMS Cached files on GHA Johnson, Andrew N. via Core-talk
Next: Build failed: pvAccessCPP 1.0.86 AppVeyor via Core-talk
ANJ, 29 Mar 2024 · Home · News · About · Talk · Base · Modules · Extensions ·
