Hi Ralph,
Thank you for the link to the discussion – very interesting. There seem to be potential pitfalls to any approach so I think improving the error message is the best thing to do for
now – I’ve created a PR https://github.com/epics-base/epics-base/pull/492
Freddie
Sent: Saturday, May 18, 2024 4:36 PM
To: EPICS Core Talk <core-talk at aps.anl.gov>
Cc: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>
Subject: Re: EpicsHostArch on mingw64
----BEGIN PGP MESSAGE----
See https://bugs.launchpad.net/epics-base/+bug/1873406 and the lengthy discussion that is documented there.
Improving the error message sounds good, as it is indeed safe and probably doesn't hurt anyone's feelings.
Running gcc sounds clever, but it could also hit the "don't depend on user environment setting" criteria. Which compiler is used depends on the architecture setting. Calling the one in the PATH to find the architecture would be biased.
On the other hand: If the user has multiple compiler chains installed, no script will be able to read their mind finding out which one they would like to use.
- EpicsHostArch on mingw64 Freddie Akeroyd - STFC UKRI via Core-talk
- Re: EpicsHostArch on mingw64 Ralph Lange via Core-talk
Should we review our bugs & merges process? Johnson, Andrew N. via Core-talk
Build failed: EPICS Base 7 base-7.0-1145 AppVeyor via Core-talk
<2024>
2025
2026
Build failed: EPICS Base 7 base-7.0-1134 AppVeyor via Core-talk
<2024>
2025
2026
ANJ, 09 Jun 2024 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
