2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Windows misbehavior compiling Base (toolchain.c ?)
From: Ralph Lange via Core-talk <core-talk at aps.anl.gov>
To: EPICS Core Talk <core-talk at aps.anl.gov>
Date: Wed, 8 Jan 2025 09:43:20 +0100
On Wed, 8 Jan 2025 at 09:35, Torsten Bögershausen <tboegi at edom.se> wrote:
Hm, it seems as if cl is called with bad parameters ?
usage: cl [ option... ] filename... [ /link linkoption... ]
Question to the Makefile-fans:
How do we echo the invoved command before invoking it ?
/Torsten
No, that's additional cl output from running the command above that prints the version.
The last line of output is usually
toolchain.c
The compiler prints the file name whenever it compiles a file.
This is ci-scripts. Setting VV=1 is turning up verbosity. No Make magic needed.
Note that also recent EPICS builds (like the one at https://ci.appveyor.com/project/epics-base-7/epics-base/builds/51280022) obviously get stuck at that point for long enough that the 1hr timeout hits them at some point late in the compilation. They have VV=1 (as Base is their main project, not a dependency).
Cheers,
~Ralph
Windows misbehavior compiling Base (toolchain.c ?) Ralph Lange via Core-talk
Re: Windows misbehavior compiling Base (toolchain.c ?) Torsten Bögershausen via Core-talk
Prev: Re: Windows misbehavior compiling Base (toolchain.c ?) Torsten Bögershausen via Core-talk
Next: Re: Windows misbehavior compiling Base (toolchain.c ?) Zimoch Dirk via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
ANJ, 08 Jan 2025 · Home · News · About · Talk · Base · Modules · Extensions ·
