2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Appveyor Build failure: EPICS Base 7 base-7.0-1997
From: "Johnson, Andrew N. via Core-talk" <core-talk at aps.anl.gov>
To: EPICS core-talk <core-talk at aps.anl.gov>
Date: Tue, 9 Dec 2025 15:05:31 +0000
The test failure here was unusual:
make[5]: Entering directory 'C:/projects/epics-base/modules/database/test/ioc/db/O.win32-x86-static'
perl -CSD dbCaLinkTest.t -tap > dbCaLinkTest.tap
epicsEventMustTriggerCRITICAL ERROR Thread CAC-event (009311E8) can't proceed, suspending.
Dumping a stack trace of thread 'CAC-event':
[ 0021C695]: C:\projects\epics-base\modules\libcom\src\osi\os\WIN32\osdBackTrace.cpp[line 23](epicsBackTrace+0x25)
[ 00210420]: C:\projects\epics-base\modules\libcom\src\osi\epicsStackTrace.c[line 80](epicsStackTrace+0x70)
[ 001E722C]: C:\projects\epics-base\modules\libcom\src\misc\cantProceed.c[line 67](cantProceed+0x4c)
[ 001E769A]: C:\projects\epics-base\modules\libcom\src\osi\epicsEvent.cpp[line 122](epicsEventMustTrigger+0x2a)u
[ 001510A8]: C:\projects\epics-base\modules\database\src\ioc\db\dbCa.c[line 213](testdbCaWaitForEventCB+0x58)
[ 0015291A]: C:\projects\epics-base\modules\database\src\ioc\db\dbCa.c[line 966](eventCallback+0x35a)
[ 001BC74F]: C:\projects\epics-base\modules\ca\src\client\oldSubscription.cpp[line 67](oldSubscription::current+0xaf)
[ 00182DFD]: C:\projects\epics-base\modules\database\src\ioc\db\dbContext.cpp[line 191](dbContext::callStateNotify+0x27d)
[ 0019D040]: C:\projects\epics-base\modules\database\src\ioc\db\dbChannelIO.h[line 111](dbChannelIO::callStateNotify+0x30)
[ 0019C7D5]: C:\projects\epics-base\modules\database\src\ioc\db\dbSubscriptionIO.cpp[line 121](dbSubscriptionEventCallback+0x35)
[ 0014E190]: C:\projects\epics-base\modules\database\src\ioc\db\dbEvent.c[line 989](event_read+0x1c0)
[ 0014E3FE]: C:\projects\epics-base\modules\database\src\ioc\db\dbEvent.c[line 1059](event_task+0x18e)
[ 001E58C3]: C:\projects\epics-base\modules\libcom\src\osi\os\WIN32\osdThread.c[line 508](epicsWin32ThreadEntry+0x73)
[ 00288998]: minkernel\crts\ucrt\src\appcrt\startup\thread.cpp[line 97](thread_start<unsigned int (__stdcall*)(void *),1>+0xb8)
[ 750D05C9](BaseThreadInitThunk+0x19)
[ 77157C5D](RtlGetAppContainerNamedObjectPath+0xed)
[ 77157C2D](RtlGetAppContainerNamedObjectPath+0xbd)
Thread CAC-event (009311E8) suspended
dbCaLinkTest.t: Timed out './dbCaLinkTest.exe' after 500 seconds
make[5]: Leaving directory 'C:/projects/epics-base/modules/database/test/ioc/db/O.win32-x86-static'
This happened after 2 passing tests, the remaining 99 tests weren’t run. Is this something we’ve seen before?
- Andrew
__
Intelligence isn’t measured by what you know, but by what you do when you don't know. Learning begins when you’re confused; when you reach the edge of your knowledge and plunge into new territory, taking your brain to a place it’s never been before.
Sent: Tuesday, December 9, 2025 1:28 AM
To: Johnson, Andrew N. <anj at anl.gov>
Subject: Build failed: EPICS Base 7 base-7.0-1997
This Message Is From an External Sender
This message came from outside your organization.
Build EPICS Base 7 base-7.0-1997 failed
Commit 4b6a6ddc7a by Minijackson on 12/8/2025 6:14 PM:
iocsh.h: import documentation from AppDevGuide, minor tweaks
Configure your notification preferences
Prev: Build failed: EPICS Base 7 base-7.0-1997 AppVeyor via Core-talk
Next: Build completed: EPICS Base 7 base-7.0-1998 AppVeyor via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
ANJ, 09 Dec 2025 · Home · News · About · Talk · Base · Modules · Extensions ·
