<2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.15 and dbd files
To: Geoff Savage <[email protected]>, EPICS Core-talk Archive <[email protected]>
Date: Mon, 02 Dec 2002 10:05:12 -0600
Hi Geoff,
Geoff Savage wrote:
From your talk at jlab on R3.15 I was not clear on the fate of dbd files. Will they still exist in R3.15? We use them in our ORACLE database. I understand how moving the information from the dbd file into the compiled objects will make things safer on the IOC but getting the same information into the ORACLE database will be impacted.
DBD files will still required in R3.15 - they are still the fundamental way in which an IOC's facilities are configured. I'm just converting them to another form for loading onto the IOC itself.
Note that we are adding new keywords to DBD files though - for R3.14 there is an additional function() statement which is needed for subroutine records on non-vxWorks IOCs, and in R3.15 there will be more changes to add link support. You will probably want to make sure that your Oracle process can cope with using a different DBD file for each IOC or group of IOCs.
- Andrew
"Life is what happens while you're busy making other plans." - John Lennon
Prev: CROSS_COMPILER_TARGET_ARCHS default change Janet Anderson
Next: Re: base max thread priority Andrew Johnson
Index: <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: POSIX recursive mutex Marty Kraimer
