<2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: base max thread priority
To: Marty Kraimer <[email protected]>
Cc: "Johnson, Andrew N." <[email protected]>, Jeff Hill <[email protected]>, Till Straumann <[email protected]>
Date: Tue, 26 Nov 2002 14:50:25 -0600
On Tuesday, November 26, 2002, at 02:25  PM, Marty Kraimer wrote:
At the EPICS meeting last week Till asked:
1) Could we declare a maximum priority for any component of base?
2) Why does iocsh run at epicsThreadPriorityMax?
Brief discussion.
1) sounds like a good request. How about
epicsThreadPriorityBaseMax = 91
2) I will assume that this was done to be like vxWorks, which runs the vxWorks shell at highest priority. If iocsh runs at epicsThreadPriorityBaseMax it seems like it should be OK. If a very high prority application thread uses all the CPU time iocsh can't get control but this is the applications problem.
(2) -- I think we did this to ensure that you could still get some response at the console even if some other task went insane and started gobbling CPU cycles. With a strict priority-based scheduler like RTEMS and vxWorks you'd have no possiblity of dealing with such tasks if the shell were at a lesser or equal priority.
Eric Norum <[email protected]>
Department of Electrical Engineering
University of Saskatchewan
Saskatoon, Canada.
Phone: (306) 966-5394   FAX:   (306) 966-5407
Re: base max thread priority Till Straumann
base max thread priority Marty Kraimer
Prev: base max thread priority Marty Kraimer
Next: Re: base max thread priority Till Straumann
Index: <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
