<2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: base max thread priority
To: Jeff Hill <[email protected]>
Cc: 'Eric Norum' <[email protected]>, 'Marty Kraimer' <[email protected]>, "'Johnson, Andrew N.'" <[email protected]>
Date: Tue, 26 Nov 2002 16:09:42 -0800
Here's yet another idea how the runaway-task problem could be solved.
AFAIK, most OS provide a hook into the system timer ISR but not
into the console ISR [which makes what we discussed at JLAB less portable] - these hooks are vxWorks' watchdog timers, RTEMS' rtems_timers.
1) The shell task periodically resets (pets) a 'watchdog' counter.
2) A timer ISR increments 'watchdog'. Should 'watchdog' reach a critical
   'limit', this implies that the shell had no chance to pet.
   In this case, the ISR increments the task's priority and resets
   'watchdog'.
If a task with a priority > shell runs away, 2) will eventually raise
the shell's priority above the runaway task's and the user will regain control.
-- Till
Re: base max thread priority Eric Norum
RE: base max thread priority Jeff Hill
Prev: Re: base max thread priority Till Straumann
Next: Re: base max thread priority Eric Norum
Index: <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: base max thread priority Jeff Hill
