<2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: base max thread priority
To: 'Marty Kraimer' <[email protected]>, 'Eric Norum' <[email protected]>
Cc: 'Till Straumann' <[email protected]>, "'Johnson, Andrew N.'" <[email protected]>
Date: Wed, 27 Nov 2002 08:52:06 -0700
> On vxWorks I am really afraid of allowing any user thread to be
> higher priority than the network threads. This caused
> failures in the past.
We have a new vxWorks IP kernel now so it is conceivable that this issue
has been resolved, but even after our regression tests pass I'm not sure
that we know for certain that the problem does not still exist. So the
challenge would be to find a way to test the new configuration on some
heavy loaded, but otherwise non-critical IOCs.
Jeff
> -----Original Message-----
> From: Marty Kraimer [mailto:[email protected]]
> Sent: Wednesday, November 27, 2002 8:40 AM
> To: Eric Norum
> Cc: Jeff Hill; 'Till Straumann'; 'Johnson, Andrew N.'
> Subject: Re: base max thread priority
> Eric Norum wrote:
> > Maybe something like:
> > static const unsigned epicsThreadPriorityIocsh = 91;
> > static const unsigned epicsThreadPriorityNetworkDaemons = 95;
> > static const unsigned epicsThreadPriorityBaseMax = 91;
> <<<Still
> > waiting for you folks to come up with a better name... >>>
> > Then EPICS applications could still have priorities higher
> than the
> > shell but lower than the network daemons, or even priorities
> higher than
> > the network daemons as necessary.
> Why not just have
> Then iocsh could just use this as it's priority.
> epicsThreadPriorityNetworkDaemons doesn't sound like an epics
> base issue. It is
> an OS epecific issue, e.g. it is an RTEMS issue. If we add it
> it will, at least
> for now, be used only for RTEMS. Does it even make sense for
> systems where
> iocCore is running in user space? Thus at leats for now it will
> only apply to RTEMS.
> higher priority
> than the network threads. This caused failures in the past.
> Marty
Re: base max thread priority Marty Kraimer
Prev: RE: base max thread priority Jeff Hill
Next: Re: base max thread priority Eric Norum
Index: <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: base max thread priority Marty Kraimer
Next: RE: base max thread priority Jeff Hill
