<2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: base max thread priority
To: 'Eric Norum' <[email protected]>
Cc: 'Marty Kraimer' <[email protected]>, 'Till Straumann' <[email protected]>, "'Johnson, Andrew N.'" <[email protected]>
Date: Wed, 27 Nov 2002 11:19:02 -0700
> Of course the issue of starvation of network/iocsh threads
> again arises.
To some extent there is no problem there. The EPICS assumption is that
the db scan threads can and will starve the ca server and db ca link
threads if the user configures them to use all available CPU.
Admittedly, user might need to use the network for other purposes
outside the scope of EPICS like debugging, but this gets back to the
issue of how the system admin would raise the priority of the shell, or
in this case the network, on demand.
Jeff
Re: base max thread priority Eric Norum
Prev: RE: INET address Jeff Hill
Next: Re: base max thread priority Till Straumann
Index: <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: base max thread priority Eric Norum
