<2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: base max thread priority
To: Eric Norum <[email protected]>
Cc: Till Straumann <[email protected]>, Jeff Hill <[email protected]>, "'Johnson, Andrew N.'" <[email protected]>
Date: Mon, 02 Dec 2002 09:11:44 -0600
Eric Norum wrote:
On Wednesday, November 27, 2002, at 03:17  PM, Till Straumann wrote:
Again: IMO, EPICS should have the _full_ range of OS priorities available.
Part of the job of porting EPICS to a particular OS would be assigning
the actual values of basic EPICS priorities (like epicsThreadPriorityIocsh, epicsThreadPriorityBaseMin, epicsThreadPriorityBaseMax...).
It's absurd: I use EPICS on a real-time OS but have no access to the
priorities needed to get real-time performance when I use the epicsThread API ;-)
I have mixed feelings. Again in the past when we created tasks with higher priority than netTask we got failures.
I do see that it is impossible on vxWorks to create a thread with a priority < 100. Thus it is not possible to create a thread with priority > tNetTask.
What to do????
If user really wants a thread with higher priority than tNetTask he/she could do what Eric suggests and change the priority of tNetTask.
Is 100 levels not enough? If priorities 91-99 were reserved for application threads only would it not be possible to do what you need?
I think that it's better to coerce other system tasks into the EPICS range if appropriate since it makes moving a given EPICS application from one processor to another so much easier.
Sounds good to me.
I think that the 'base max' (I'm still hoping that someone can come up with a good name for this) priority level (90, right???) should be added to epicsThread.h.
Could we just define
static const unsigned epicsThreadPriorityIocsh = 91;
And then state that nothing in base has a priority higher than epicsThreadPriorityIocsh?
If this is not OK I can't think of a better name than
I dont see any reason to define epicsThreadPriorityNetworkDaemons. The only operating system that will currently use it is RTEMS.
Marty
Re: base max thread priority Eric Norum
Prev: [no subject] Jeff Hill
Next: Re: base max thread priority Eric Norum
Index: <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: base max thread priority Eric Norum
