2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Why we can't extend the DSET or DRVET
To: Jeff Hill <[email protected]>
Cc: "'Andrew Johnson'" <[email protected]>, "'Eric Norum'" <[email protected]>, "'Core-Talk'" <[email protected]>
Date: Fri, 21 Nov 2003 07:09:30 -0600
Jeff Hill wrote:
The device support interface is defined by the record type and not by the
device support module. So, in principal, if the record type decides to add a
new routine then this will work just fine with devices which follow the
rules and specify the proper number of entries for previous revisions of the
interface.
The devGpib for 3.13, Bemjamins version, gpibCore, and devGpib for asyn ALL define a struct gDset that has the first members the same as that used by stansard record types. If a standard record type they will have to be changed. I suspect that other device support may have done the same thing.
Marty
RE: Why we can't extend the DSET or DRVET Jeff Hill
Prev: Re: Why we can't extend the DSET or DRVET Andrew Johnson
Index: 2002  <2003>  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
