2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS base V4: iocCore database
To: Marty Kraimer <[email protected]>
Cc: Andrew Johnson <[email protected]>
Date: Mon, 21 Feb 2005 21:55:37 +0100
On Monday 21 February 2005 17:56, Marty Kraimer wrote:
> Benjamin Franksen wrote:
> > What I want to point out is that there is one very useful
> > thing missing from the data model, namely algebraic data types, a.k.a.
> > tagged unions. A syntax could look like this
> >union(name) {
> >	choice(choice_name,"choice_value",choice_data)
> >where 'choice_data' can be any valid data type, including struct or
> > another union. Thus, menu would be the special case where the
> > 'choice_data' is void (or null; another basic data type to be added).
> Andrew also suggested a union.
> JAVA does not have a union. Will this cause us any problems?
Well, neither does the C union fit exactly. You have to combine it with a tag
to discriminate cases; and the type system does not enforce any match between
tag and data content, so in the end we'll have to implement it as an ADT.
In Java, we would have to cast the data to an 'Object' and back, according to
the tag value. I think the implementation is in fact easier in Java than in
C.
Ben
Re: EPICS base V4: iocCore database Marty Kraimer
Prev: Re: EPICS base V4: iocCore database Benjamin Franksen
Next: Re: EPICS base V4: iocCore database Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS base V4: iocCore database Marty Kraimer
