2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: dataAccess
To: Jeff Hill <[email protected]>
Cc: 'Benjamin Franksen' <[email protected]>, 'Andrew Johnson' <[email protected]>, 'Bob Dalesio' <[email protected]>, 'Ralph Lange' <[email protected]>, 'Eric Norum' <[email protected]>, 'Ken Evans' <[email protected]>, 'Ned Arnold' <[email protected]>, 'Matej Sekoranja' <[email protected]>
Date: Fri, 25 Feb 2005 09:01:23 -0600
A few brief comments about dataAccess.
In the tutorial "dataViewer" is used in several places. I think you mean propertyViewer.
I can see how almost everything in the da*.h files could be described in Java (unsigned is one exception). Everyplace where dataAccess uses multiple inheritence, the classes are equivalent to Java interfaces. In fact it looks easy to create an equivalent set of Java classes and interfaces for what appears in da*.h. Of course, this is not the implementation but only the user interface.
I can also see how record/device support could be written in C instead of C++ and dataAccess could still be used by iocCore supplied libraries to transport data into and out of records. If we go with the V4 DBD idea of struct and array, utilities like dbToStructH,etc, could generate a header file AND code that uses dataAccess to get/put the struct fields.
We still have lots to think about in order to implement the Functional Requirements for V4. If we decide to use dataAccess it is only part of what is required.
Marty
RE: dataAccess Jeff Hill
RE: EPICS base V4: iocCore database Jeff Hill
Prev: Re: EPICS base V4 Ralph Lange
Next: Re: EPICS base V4: iocCore database Marty Kraimer
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: EPICS base V4: iocCore database Jeff Hill
Next: RE: dataAccess Jeff Hill
